[pycsw-devel] MS4W version 4.0.5 available
Tom Kralidis
tomkralidis at gmail.com
Thu Dec 17 17:49:41 PST 2020
Hi Jeff: thanks for the info. Happy to see the pycsw mod_wsgi setup
working again
in MS4W! MS4W is a powerful GIS/SDI toolbox with numerous capabilities and very
easy to use, install and run (deployment wins), and packaging pycsw as
part of the
install helps with metadata and search. Thanks much for maintaining
pycsw on MS4W!!
On that note, happy holidays to everyone and best wishes for 2021.
..Tom
On Thu, Dec 17, 2020 at 7:45 PM Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> Forwarding the details of today's MS4W 4.0.5 release, which the pycsw
> community will find useful because it contains pycsw 2.6.0 enabled by
> default, of course, and served through Apache's mod_wsgi, with Python
> 3.9.1 and so many other goodies. (this means that each month there are
> over 5,000 new installations of pycsw on Windows, woot!) MS4W allows
> users to simply extract a zipfile and be serving and consuming
> CSW/WMS/WFS/WCS/SOS/WPS through pycsw & MapServer (yes pygeoapi soon
> also!).
> Details below...
> -------- Forwarded Message --------
> Hello everyone,
> MS4W 4.0.5 is now available, which contains many critical updates, such
> as the OpenSSL high-level security release, as well as an important
> upgrade to the PHP 7.4 series (as PHP 7.2 is no longer receiving
> security updates), into the Python 3.9 series also, plus rebuilds of the
> entire stack for the new pycsw version, Mapbender 3.2.x version, fast
> compression through Zstd for tiffs, latest PDAL, osm2pgsql, TinyOWS, and
> much more! Get it now at https://ms4w.com
> Please see MS4W's HISTORY.txt for all of the changes, but here are some
> of the highlights:
> - upgraded MapServer and MapScript (CSharp, Java, Python, PHP)
> to today's 7.7.0-dev
> - upgraded PHP to 7.4.13 security release (trac ticket 243)
> - upgraded MapCache to 1.11dev (git-master-20201214)
> - upgraded to TinyOWS git-master-20201216
> - modified TinyOWS config.xml to disable 'check_schema' to
> avoid HTTPS issues
> - added content encoding declaration to TinyOWS demo template
> - upgraded Apache HTTP Server to 2.4.46 (trac ticket 281)
> - upgraded Python to 3.9.1 (trac ticket 245)
> - upgraded pycsw to 2.6.0 (trac ticket 300)
> - re-set pycsw to use Apache mod_wsgi instead of CGI (trac
> ticket 262)
> - upgraded OpenSSL to 1.1.1i HIGH level security release (trac
> ticket 296)
> - upgraded SWIG support to git-master-20201215
> - rebuilt GDAL (including CSharp/Java/Python bindings,
> ECW/Oracle plugins)
> - set PYTHONHOME in setenv.bat for the installer (trac ticket 285)
> - minor updates to local.map
> - change quickmap.php to use local.map
> - added mention of Notepad++ syntax file into README_INSTALL
> (trac ticket 298)
> - upgraded libjpeg-turbo support to 2.0.6 (trac ticket 294)
> - rebuilt libTIFF support
> - added libTIFF utilities into /tools (trac ticket 297)
> - upgraded SQLite support to 3.34.0 (trac ticket 286)
> - upgraded cURL support to 7.74.0 (trac ticket 279)
> - rebuilt GeoTIFF support
> - changed site link in README-geotiff.txt (trac ticket 283)
> - upgraded Expat support to 2.2.10
> - rebuilt HDF4 support
> - rebuilt NetCDF support
> - upgraded PostgreSQL support to 13.1 with SSL enabled (trac
> ticket 291)
> - upgraded GEOS support to 3.9.0 (trac ticket 299)
> - upgraded ICONV support to 1.16 (trac ticket 295)
> - upgraded FreeXL support to 1.0.6
> - rebuilt libxml2 support
> - rebuilt SpatiaLite support
> - rebuilt SpatiaLite-tools
> - upgraded FITS support to 3.490
> - added CFITSIO utilities into /tools
> - upgraded Freetype support to 2.10.4
> - rebuilt Cairo support
> - rebuilt Poppler support
> - upgraded Zstandard compression support (for TIFF) to 1.4.7
> - upgraded to Oracle SDK 19.9.0.0.0
> - rebuilt HarfBuzz support
> - upgraded FriBidi support to 1.0.10 (trac ticket 215)
> - rebuilt libSVG support
> - rebuilt libSVG-Cairo support
> - updated cURL certificates bundle
> - rebuilt mod_fcgid
> - rebuilt Apache H264 Streaming Module
> - upgraded APCu to 5.1.19
> - rebuilt php_ogr extension
> - rebuilt mod_wsgi
> - upgraded PDAL utilities to git-master-20201217
> - properly enable the laz-perf library for the PDAL build
> - upgraded osm2pgsql commandline utility to git-master-20201216
> - updated the VC Redistributable in /tmp
> When installing, it is very important that (if you are using the .zip)
> your server must have the C++ Redistributable installed on it
> beforehand: execute the local file /ms4w/tmp/vcredist_x86.exe
> (alternatively if you use MS4W's setup.exe installer this is done
> automatically)
> As always please provide your requests for enhancements and issues
> through the MS4W tracker (so the feedback is not lost or forgotten):
> https://ms4w.com/trac/ You can also contact me directly for support.
> Wishing everyone a nice Christmas holiday,
> Thank you for using MS4W.
> "MS4W: open doors as well as windows"
> -jeff
> Jeff McKenna
> GatewayGeo: MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel
