[pycsw-devel] PyCSW Harvesting.
massimo di stefano
massimodisasha at gmail.com
Thu Nov 12 15:56:44 PST 2020
Hi Brian,
Try with QGIS Stable release <https://www.google.com/search?safe=active&sxsrf=ALeKk03vHxnIPBnW0Gz083Azz50gTWefmw:1605225359357&q=qgis+stable+release&sa=X&ved=2ahUKEwiIt9C6mv7sAhVooosKHfHjDWcQ6BMoADAdegQIKxAC>: 3.16.0 "Hannover"
> On Nov 13, 2020, at 12:45 AM, BRIAN STIFFENN LUNA BOLIVAR <bslunab at correo.udistrital.edu.co> wrote:
> Ok Tom thanks for your help. And Hi, Massimo, ok I'll try with your recommendation, you mean the 3.10.6 LTR QGIS version?
> El jue., 12 nov. 2020 a las 18:41, massimo di stefano (<massimodisasha at gmail.com <mailto:massimodisasha at gmail.com>>) escribió:
> Try upgrading to latest stable QGIS.
>> On Nov 13, 2020, at 12:34 AM, Tom Kralidis <tomkralidis at gmail.com <mailto:tomkralidis at gmail.com>> wrote:
>> On Thu, Nov 12, 2020 at 6:32 PM BRIAN STIFFENN LUNA BOLIVAR
>> <bslunab at correo.udistrital.edu.co <mailto:bslunab at correo.udistrital.edu.co>> wrote:
>>> I have to report a problem but I don't know if this happens because of pyCSW or qgis:
>>> When I use the MetaSearch plugin, appears my layers from WMS, but when I try to load a layer via WMS call, appears this error:
>>> AttributeError: 'NoneType' object has no attribute 'addRasterLayer'
>>> Traceback (most recent call last):
>>> File "C:/OSGEO4~1/apps/qgis-ltr/./python/plugins\MetaSearch\dialogs\maindialog.py", line 757, in add_to_ows
>>> ows_provider.addRasterLayer.connect(self.iface.addRasterLayer)
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20201113/d22715e0/attachment.html>
More information about the pycsw-devel
