[Pywps-dev] [WPS-dev] Fwd: XML Processing Model Working Group Revised Charter (Call for Review)
Anna Homolka
mail at anna-homolka.de
Tue May 20 04:11:34 PDT 2014
Sounds really interesting, the syntax looks quite understandable. But there is one problem, it’s only allowed to pass XML Documents through the process chain. One process can produce any kind of output, but this output is not allowed to be passed at the input and output ports.
I think the possible in- and outputs which also can be passed directly through the process should be complexValue, LiteralValue and BoundingBoxValue as allowed in PyWPS Processes.
Cheers
Anna
Von: Jonas Eberle [mailto:jonas.eberle at gmx.de]
Gesendet: Montag, 19. Mai 2014 18:35
An: pywps-dev at lists.osgeo.org
Cc: Anna Homolka
Betreff: Fwd: [WPS-dev] Fwd: XML Processing Model Working Group Revised Charter (Call for Review)
That's sounds interesting especially for the process chaining GSoC.
Please, Anna, take a look at it. We should check how this standard can be used for the WPS specification.
Cheers,
Jonas
_____
Von: "Raj Singh" <rsingh at opengeospatial.org>
An: wps-dev at lists.opengeospatial.org
Gesendet: Montag, 19. Mai 2014 17:09:46
Betreff: [WPS-dev] Fwd: XML Processing Model Working Group Revised Charter (Call for Review)
Many people have been interested in a standard way to chain WPS processes.
It seems to me that it would be useful to adopt the same approach as the general XML processing community.
There is a call for charter review at W3C for such a standard, which is defining XProc 2.0.
I hope this is of interest to WPS leaders.
Raj
The OGC: Making location count.
http://www.opengeospatial.org/ogc/organization/staff/rsingh
Begin forwarded message:
> Resent-From: w3c-ac-members at w3.org
> From: "Coralie Mercier" <coralie at w3.org>
> Subject: XML Processing Model Working Group Revised Charter (Call for Review)
> Date: May 19, 2014 at 4:53:42 AM EDT
> To: w3c-ac-forum at w3.org
> Dear Advisory Committee Representative,
> This is a Call for Review of a proposed charter for the XML Processing Model Working Group:
> http://www.w3.org/XML/2014/03/xproc-charter.html
> Please review the charter and indicate your support using this online form:
> https://www.w3.org/2002/09/wbs/33280/xproccharter2014/
> The deadline for responses is 23:59, Boston time on 2014-06-19.
> XProc is a simple dataflow language used to combine sequences of steps into tasks, primarily involving XML documents. In this regard it's a little like Make or ant or a Unix shell, but at a higher level and with clearer focus.
> The main change is to include a new version of XProc, the XML Processing Language, within the scope of the Working Group.
> There are no FTE changes.
> If you have any questions or need further information, please contact Liam Quin <liam at w3.org>, Team Contact and XML Activity Lead.
> This charter review follows section 6 of the W3C Process Document:
> http://www.w3.org/2005/10/Process-20051014/groups.html
> Thank you,
> For Tim Berners-Lee, W3C Director;
> Liam Quin, Team Contact and XML Activity Lead, and
> Coralie Mercier, W3C Communications
> Coralie Mercier - W3C Communications Team - http://www.w3.org
> mailto:coralie at w3.org +336 4322 0001 http://www.w3.org/People/CMercier/
WPS-dev mailing list
WPS-dev at lists.opengeospatial.org
https://lists.opengeospatial.org/mailman/listinfo/wps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20140520/d6baa3d8/attachment.html>
More information about the pywps-dev
