[Pywps-dev] current work
Calin Ciociu
calin.ciociu at gmail.com
Wed Apr 8 02:32:29 PDT 2015
Hey Jachym,
I am currently finishing up on making the three requests WPS 1.0
compliant and run the tests to see if everything is still working.
Also planning on implementing RawDataOutput, asynchronous process
execution and status report.
Concerning the validator.
If I understood this correctly it is used to check if the inputs are
correct, like having the correct mimetype or are in the correct range of
values.
So they are used during the fetching of the data and before the process
is executed with the given data?
Calin
On 04/04/2015 12:21 PM, Jachym Cepicky wrote:
> Hi (especially) Calin (and others),
> what part of PyWPS-4 are you currently working on? I would like to
> start to dig into the code again a bit.
> From what I remember and see, there are several independent peases of
> code (validator, app, input/output, reference, ...) which are not
> connected together and the most important part would IMHO be, to plug
> them together, so we finally have one working core
> Jachym
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20150408/df7df4b7/attachment.html>
More information about the pywps-dev
