[Pywps-dev] REST interface
Jonas Eberle
jonas.eberle at gmx.de
Mon Jun 15 00:09:02 PDT 2015
I like this example very much. Such an approach was also used by istSOS - a Python framework for Sensor Observation Services. Any administration of this service is available based on such a REST API, see this link for a description:
https://geoservice.ist.supsi.ch/projects/istsos/index.php/IstSOS_WAlib_2.0
Cheers,
Jonas
----- Am 14. Jun 2015 um 22:21 schrieb Tom Kralidis <tomkralidis at gmail.com>:
> Thanks for the info - sounds great! Are you implementing WPS REST based on an
> OGC profile or best practice?
> Having said this, it might be valuable to investigate the degree of RESTful-ness
> one can achieve (i.e. using pure HTTP verbs instead, etc.). For example:
> http://example.org/wps # capabilities
> # config (needs auth)
> http://example.org/wps/server/config
> http://example.org/wps/server/instances
> http://example.org/wps/server/processes
> And so on.
> Sent from my iPhone
> > On Jun 14, 2015, at 15:55, Calin Ciociu <calin.ciociu at gmail.com> wrote:
> > Hello everyone,
> > As some may know I am working during the summer for Google Summer of Code 2015.
> > My job is to implement a REST interface for PyWPS-4.
> > So REST won't be much different than the actual way a client makes requests.
>> Something along the lines of
> > "http://localhost:5000/wps?SERVICE=wps&OPERATION=GetCapabilities"
>> What I was thinking was to add additional operation for different tasks like for
>> example get the server configuration or the list of running server instances
>> and processes. Also be able to set some configuration, control processes etc.
>> (Which might require also some kind of security otherwise anyone can just go
> > ahead and stop or deploy servers/processes)
> > What do you guys think?
>> Does this sound like a plan or should I have something different like
> > "http://localhost:5000/rest?operation=foo&..."?
> > Best regards,
> > Calin Ciociu
> > pywps-dev mailing list
> > pywps-dev at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20150615/b9e8d2f5/attachment.html>
More information about the pywps-dev
