[Pywps-dev] validators in pywps-4
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Nov 9 03:30:41 PST 2015
No,
there are some more
https://github.com/jachym/pywps-4/milestones/PyWPS%204.0.0%20stable%20version
J
po 9. 11. 2015 v 11:59 odesílatel Luís de Sousa <luis.a.de.sousa at gmail.com>
napsal:
> Great news Jachym!
> Can't issue #21 be closed now?
> Cheers,
> Luís
> On 6 November 2015 at 23:48, Jachym Cepicky <jachym.cepicky at gmail.com>
> wrote:
> > Hi all,
> > today, I managed to introduce first stable version of "validators" to
> > PyWPS-4
> > Each Input nad Output has format assinged
> > Each Format is of special type (either mimeType (like GML) or data type
> > (like Float))
> > Each format can have validator assinged - I implemented default
> validators
> > for GML, Shapefile and JSON.
> > Each Input can set, how strict should the validator be (mode = NONE,
> Simple,
> > Strict, VeryStrict)
> > Example:
> > ComplexInput('poly_in', 'Input1',
> > supported_formats=[Format('application/gml+xml')],
> > mode=MODE.STRICT)
> > Will expect one possible format - GML (validator is assigned
> automatically)
> > and will be validating using STRICT mode - in this case, OGR will be used
> > (no XML schema check)
> > This introduces new level of *security* and consistency to PyWPS-4
> > It was also one of the biggest tasks on my TODO list, on the way to
> PyWPS-4
> > stable version.
> > Next topics will follow:
> > Check our code: https://github.com/jachym/pywps-4
> > Travis unit tests: https://travis-ci.org/jachym/pywps-4
> > Travis integration tests: https://travis-ci.org/PyWPS/pywps-4-demo
> > Jachym
> > pywps-dev mailing list
> > pywps-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20151109/1048c5dd/attachment.html>
More information about the pywps-dev
