[Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Jonas Eberle
jonas.eberle at gmx.de
Wed Apr 20 02:57:58 PDT 2016
You have an error in the request, storeExecuteResponse=true and status=true are individual attributes of the request, in your example these are data inputs! Please use & storeExecuteResponse=true & status=true at the end instead using the semicolon. Using the "old" PyWPS I also embraced the data inputs with brackets, this leads to less errors in my opinion: DataInputs= [ processor_name=ST_IPF_;processor_version=01.13 ]
Cheers,
Jonas
----- Am 20. Apr 2016 um 10:05 schrieb Robin Skahjem-Eriksen <skahjem-eriksen at stcorp.no>:
> Jonas, thank you for your clarification on the request attributes and the
> changes to the WPS spec.
> I have added `status=true`to the execution request in addition to the
> aforementioned attributes, and I still don't get a reponse with any URL to the
> ResponseDocument.
> My request looks like this:
> http://localhost/wps/?service=WPS&request=Execute&Identifier=ipf&version=1.0.0&DataInputs=processor_name=ST_IPF_TESTER;processor_version=01.13;input_selector=time-range;muninn_query=validity_stop
> > 1980-07-03 and validity_start <
> 1980-07-05;storeExecuteResponse=true;status=true
> And the process is defines as such:
> class IPF(Process):
> def __init__(self):
> inputs = [
> LiteralInput(
> 'processor_name',
> 'IPF processor name',
> data_type='string'
> LiteralInput(
> 'processor_version',
> 'IPF processor version',
> data_type='string'
> LiteralInput(
> 'input_selector',
> 'SOL input selection',
> data_type='string'
> LiteralInput(
> 'muninn_query',
> 'Muninn product catalog query string',
> data_type='string'
> outputs = [
> LiteralOutput(
> 'ipf_result',
> 'SUCCESS/FAILURE',
> data_type='string'
> super(IPF, self).__init__(
> self._handler,
> identifier='ipf',
> version='0.1',
> title='Generic IPF processor',
> abstract='Processors for handling IPF products',
> inputs=inputs,
> outputs=outputs,
> store_supported=True,
> status_supported=True
> (.. handler omitted ..)
> Am I missing something?
> Med vennlig hilsen / With kind regards,
> Software developer
> Science [&] Technology AS
> Reg. nr.: 996 229 009 MVA
> [E]: skahjem-eriksen at stcorp.no
> [Address]:
> Forskningsparken
> Gaustadalléen 21
> 0349 Oslo
> Norway
> [W]: http://www.stcorp.no
> [P]:+47 45 911 694
> [E]: info at stcorp.no
>> On Apr 19 2016, at 9:26 pm, Jonas Eberle <jonas.eberle at gmx.de> wrote:
>> Hi Robin,
>> I guess you're looking for the "statusLocation" attribute of the ExecuteResponse
>> tag. The value of this attribute is the URL to the response document,
>> especially needed when you use asynchronous execution (both, status=true and
>> storeExecuteResponse=true, needed in the execute request). There is no
>> executeResponseLocation element, please see the "Corrigendum for OpenGIS
>> Implementation Standard Web Processing Service (WPS) 1.0.0 (0.0.8)" [1].
>> Best regards,
>> Jonas
>> [1] = http://portal.opengeospatial.org/files/?artifact_id=32766
>> ----- Am 19. Apr 2016 um 11:09 schrieb Robin Skahjem-Eriksen
>>> I am trying to get pywps working so that a ResponseDocument is used to show the
>>> process status, by having the Execute response provide a URL to the
>>> ResponseDocument, as specified in the WPS 1.0 standard.
>>> I am not sure if pywps actually supports this and if so, the feature is not well
>>> documented. I see that pywps supports serving output files and serving these,
>>> and I was hoping that this could be used to provide the response document.
>>> I initialize a Process object with `store_supported` and `status_supported` set
>>> to `True` and provide `storeExecuteResponse=true` in the GET request. However,
>>> I haven't manged to receive a response containing the `executeResponseLocation`
>>> element, and I cannot find any code in the master branch code base that handles
>>> an `ExecuteResponseLocation`.
>>> Am I missing anything, or is this feature simply not supported by pywps?
>>> Software developer
>>> [Address]:
>>> Forskningsparken
>>> Gaustadalléen 21
>>> 0349 Oslo
>>> Norway
>>> [P]:+47 45 911 694
>>> pywps-dev mailing list
>>> pywps-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160420/7b8bdf70/attachment.html>
More information about the pywps-dev
