[Pywps-dev] Development workflow proposal
Luís de Sousa luis.a.de.sousa at gmail.com
Tue Feb 9 04:19:38 PST 2016
Hi Tom,
There is WPS 2.0 missing at least. I can not go through it right now,
but I will give a closer look in the next few days. I believe some odd
versions could already by set out.
Cheers,
Luís
On 9 February 2016 at 13:13, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Hi all: done for review/comment:
> https://github.com/geopython/pywps/milestones
> Thanks
> ..Tom
> On Tue, 9 Feb 2016, Jachym Cepicky wrote:
>> Date: Tue, 09 Feb 2016 07:39:06 +0000
>> From: Jachym Cepicky <jachym.cepicky at gmail.com>
>> To: Luís de Sousa <luis.a.de.sousa at gmail.com>,
>> Cc: "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
>> Subject: Re: [Pywps-dev] Development workflow proposal
>> Hi all,
>> I support this.
>> As Luís writes: moving milestones from pywps/pywps-4 according to new
>> scheme is next step now
>> J
>> út 9. 2. 2016 v 8:22 odesílatel Luís de Sousa <luis.a.de.sousa at gmail.com>
>> napsal:
>>> Hi Tom,
>>> That sounds good to me. We should now import the milestones from the
>>> old repository[0], taking into account this new versioning scheme. I
>>> will try to come up with a proposal throughout this week.
>>> Regards,
>>> Luís
>>> [0] https://github.com/PyWPS/pywps-4/milestones
>>> On 9 February 2016 at 04:34, Tom Kralidis <tomkralidis at gmail.com> wrote:
>>>> Hi all: as we move ahead with OSGeo incubation and PyWPS 4, I'd like to
>>>> propose / confirm the following workflow option for development.
>>>> 1./ https://github.com/geopython/pywps is the codebase
>>>> We have imported https://github.com/PyWPS/pywps-4 (source code) to
>>>> https://github.com/geopython/pywps/tree/pywps-4.  When branch pywps-4
>>>> is deemed ready we can merge/move as master branch.
>>>> 2./ branches are based on minor versions (i.e. pywps-x.y)
>>>> We can copy pywps-3.2.3 branch to pywps-3.2 which will signify our 3.x
>>>> support and then release 3.x releases against pywps-3.2.
>>>> When 4.0.0 is released, we can branch pywps-4.0
>>>> 3./ semantic versioning [1] and even/odd strategy [2] tags
>>>> This allows us to safely make dev releases which communicate
>>>> to users that a given release is unstable by design, i.e.:
>>>> 4.0.0 - stable
>>>> - 4.0.1 - bugfix based on 4.0 branch
>>>> 4.1.0 - unstable based off master
>>>> 4.2.0 - stable
>>>> I'm more than willing to move items forward to help the dev team
>>>> as per above if folks are in agreement.
>>>> Confirmation of the above would (IMHO) significantly increase the
>>>> clarity
>>>> of the PyWPS story for things like OSGeo incubation between PyWPS
>>>> versions, lower the barrier for new developers.  Given the significant
>>> efforts
>>>> behind PyWPS 4, it's probably a good time to bring this into
>>> geopython/pywps
>>>> to move the project forward.
>>>> Thoughts?
>>>> ..Tom
>>>> [1] http://semver.org
>>>> [2]
>>> http://producingoss.com/en/development-cycle.html#release-number-even-odd-strategy
>>>> _______________________________________________
>>>> pywps-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
