[Pywps-dev] configuration problem
pablo zader
pzader at gmail.com
Tue Feb 9 21:24:14 PST 2016
Hi list
I have the next problem: making a GetCapabilities, returns a list of
processes that is different from what I have defined
*I have:*
*$>ls /usr/local/wps/processes/*
buffer.py dummyprocess.py __init__.pyc moreInstancesInOne.py
returner.pyc tests.pyc
buffer.pyc dummyprocess.pyc moreInOne.py moreInstancesInOne.pyc
r_stats.py ultimatequestionprocess.py
convertraster.py __init__.py moreInOne.pyc returner.py
tests.py ultimatequestionprocess.pyc
*$>more /usr/local/wps/processes/__init__.py*
__all__ =
["returner","dummyprocess","moreInOne","moreInstancesInOne","tests","ultimatequestionprocess","buffer","r_stats"]
*But the query tells me that I have:*
['dummyprocess', 'ultimatequestionprocess', 'complexVector',
'complexRaster', 'noOutput', 'firstInstance', 'secondInstance',
'assyncprocess', 'bboxprocess', 'complexprocess', 'literalprocess',
'noinputsprocess']
*Here the complete response:*
$>wps.py "service=wps&request=getcapabilities"
PyWPS [2016-02-10 02:15:38,256] INFO: Importing the processes from default
(pywps/processes) location
File
"/usr/local/lib/python2.7/dist-packages/pywps-3.2.2-py2.7.egg/pywps/Wps/__init__.py",
line 180, in _initFromDirectory
locals(), [processSources.__name__])
ImportError: No module named returner
PyWPS [2016-02-10 02:15:38,257] WARNING: Could not import processes from
'processes': ImportError('No module named returner',)
PyWPS Warning: Usage of
PyWPS Warning: from pywps.Process.Process import WPSProcess
PyWPS Warning: is deprecated. Use
PyWPS Warning: from pywps.Process import WPSProcess
PyWPS Warning: instead!
PyWPS [2016-02-10 02:15:38,260] WARNING: Could not import process [<class
tests.BBoxProcess3D at 0xfd17a0>]: TypeError("addBBoxInput() got an
unexpected keyword argument 'crs'",)
File
ImportError: No module named GMLBuffer
PyWPS [2016-02-10 02:15:38,261] WARNING: Could not import processes from
'processes': ImportError('No module named GMLBuffer',)
File
ImportError: No module named reducer
PyWPS [2016-02-10 02:15:38,263] WARNING: Could not import processes from
'processes': ImportError('No module named reducer',)
File
ImportError: No module named histogramprocess
PyWPS [2016-02-10 02:15:38,264] WARNING: Could not import processes from
'processes': ImportError('No module named histogramprocess',)
PyWPS [2016-02-10 02:15:38,265] INFO: Following processes are imported:
'noinputsprocess']
Thanks in advanced
Pablo
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160210/6743f230/attachment.html>
More information about the pywps-dev
