[Pywps-dev] AttributeError: 'Logger' object has no attribute 'INFO'
pablo zader pzader at gmail.com
Wed Feb 10 17:07:47 PST 2016
Hi Tom
Yes, pywps 3.2.3, sorry. and thanks for fix!
Pablo
2016-02-10 21:57 GMT-03:00 Tom Kralidis <tomkralidis at gmail.com>:
> Hi Pablo: I'm guessing you installed 3.2.3?
> This bug was introduced (by me, apologies) in 3.2.3 and has been
> since fixed.
> I've cut a 3.2.4 release[1].  We'll issue a PyPI release shortly.
> Thanks for reporting.
> ..Tom
> [1] https://github.com/geopython/pywps/releases/tag/pywps-3.2.4
> On Wed, 10 Feb 2016, pablo zader wrote:
> Date: Wed, 10 Feb 2016 21:37:27 -0300
>> From: pablo zader <pzader at gmail.com>
>> To: pywps-dev at lists.osgeo.org
>> Subject: [Pywps-dev] AttributeError: 'Logger' object has no attribute
>> 'INFO'
>> *Hi list*
>> *I Install pywps 3.2.2, but I have the following problem:*
>> pablo at pablo-Satellite-L845:~$ wps.py
>> "service=wps&request=getcapabilities"
>> Traceback (most recent call last):
>>  File "/usr/local/bin/wps.py", line 5, in <module>
>>    pkg_resources.run_script('pywps==3.2.3', 'wps.py')
>>  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 528, in
>> run_script
>>    self.require(requires)[0].run_script(script_name, ns)
>>  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1394, in
>> run_script
>>    execfile(script_filename, namespace, namespace)
>>  File
>> "/usr/local/lib/python2.7/dist-packages/pywps-3.2.3-py2.7.egg/EGG-INFO/scripts/wps.py",
>> line 86, in <module>
>>    wps = pywps.Pywps(method)
>>  File
>> "/usr/local/lib/python2.7/dist-packages/pywps-3.2.3-py2.7.egg/pywps/__init__.py",
>> line 183, in __init__
>>    self.setLogFile()
>>  File
>> line 256, in setLogFile
>>    logLevel =
>> eval("LOGGER."+config.getConfigValue("server","logLevel").upper())
>>  File "<string>", line 1, in <module>
>> *Try to look inside the object and the attributes INFO, ERROR, etc
>> exists:*
>> pablo at pablo-Satellite-L845:~$ python
>> Python 2.7.6 (default, Jun 22 2015, 17:58:13)
>> [GCC 4.8.2] on linux2
>> Type "help", "copyright", "credits" or "license" for more information.
>>> import logging
>>>>> LOGGER = logging.getLogger(__name__)
>>>>> dir(LOGGER)
>>>> ['__class__', '__delattr__', '__dict__', '__doc__', '__format__',
>> '__getattribute__', '__hash__', '__init__', '__module__', '__new__',
>> '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__',
>> '__str__', '__subclasshook__', '__weakref__', '_log', 'addFilter',
>> 'addHandler', 'callHandlers', 'critical', 'debug', 'disabled', 'error',
>> 'exception', 'fatal', 'filter', 'filters', 'findCaller', 'getChild',
>> 'getEffectiveLevel', 'handle', 'handlers', 'info', 'isEnabledFor',
>> 'level',
>> 'log', 'makeRecord', 'manager', 'name', 'parent', 'propagate',
>> 'removeFilter', 'removeHandler', 'root', 'setLevel', 'warn', 'warning']
>> Thanks ins advanced
>> Pablo
>> *Pablo J. Zader*
>> *Lic. en Cs. de la Computación*
>> *pablo.zader at gmail.com <pablo.zader at gmail.com>*
>> *"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
>> sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
>> *del libro Matemática estas ahi? A. Paenza "*
*Pablo J. Zader*
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160210/a52332d6/attachment-0001.html>
More information about the pywps-dev mailing list
