[Pywps-dev] configuration problem
pablo zader
pzader at gmail.com
Thu Feb 11 18:53:05 PST 2016
Hi Luis
Here the wrapper:
$> more /usr/lib/cgi-bin/pywps.cgi
#!/bin/sh
# Author: Jachym Cepicky
# Purpose: CGI script for wrapping PyWPS script
# Licence: GNU/GPL
# Usage: Put this script to your web server cgi-bin directory, e.g.
# /usr/lib/cgi-bin/ and make it executable (chmod 755 pywps.cgi)
# NOTE: tested on linux/apache
export PYWPS_CFG=/usr/local/wps/pywps.cfg
export PYWPS_PROCESSES=/usr/local/wps/processes/
#/usr/local/pywps-VERSION/wps.py
/home/pablo/pywps-pywps-3.2.2/wps.py
Thanks
Pablo
2016-02-11 15:54 GMT-03:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> Hi again Pablo,
> Could you post a listing of your CGI wrapper? That is the best way to
> undo this mystery.
> Cheers,
> Luís
> On 11 February 2016 at 19:35, pablo zader <pzader at gmail.com> wrote:
> > Hi Luis
> > The problem I see is that the script is trying to read processes from a
> > directory other
> > than one I configure. You can see:
> > PyWPS [2016-02-10 14:12:28,214] INFO: Importing the processes from
> default
> > (pywps/processes) location
> > But I configure this directory :
> > Apparently pywps is taking another configuration file.
> > I am using "Local PyWPS configuration file"
> http://geopython.github.io/pywps/doc/build/html/configuration/index.html).
> > Is this correct? or should I use Global Settings ?
> > Thanks in advanced
> > Pablo
> > 2016-02-11 4:37 GMT-03:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> >> Hi Pablo,
> >> My best guess is that there is an error in the returner.py module.
> >> Luís
> >> On 10 February 2016 at 18:34, pablo zader <pzader at gmail.com> wrote:
> >> > Hi Luis
> >> > Thanks. But my problem is not solved.
> >> > My configuration file is in the /usr/local/wps/pywps.cfg and the most
> >> > important content is:
> >> > [server]
> >> > maxoperations=30
> >> > maxinputparamlength=1024
> >> > maxfilesize=100mb
> >> > tempPath=/tmp/pywps
> >> > processesPath=/usr/local/wps/processes
> >> > outputUrl=http://localhost/wps/wpsoutputs
> >> > outputPath=/var/www/wps/wpsoutputs
> >> > debug=true # deprecated since 3.2, use logLevel instead
> >> > logFile=/tmp/pywps.log
> >> > logLevel=INFO
> >> > My process in /usr/local/wps/processes with content:
> >> > buffer.py dummyprocess.py __init__.pyc
> moreInstancesInOne.py
> >> > returner.pyc tests.pyc
> >> > buffer.pyc dummyprocess.pyc moreInOne.py
> >> > moreInstancesInOne.pyc
> >> > r_stats.py ultimatequestionprocess.py
> >> > convertraster.py __init__.py moreInOne.pyc returner.py
> >> > tests.py ultimatequestionprocess.pyc
> >> > My __init__.py:
> >> > __all__ =
> ["returner","dummyprocess","moreInOne","moreInstancesInOne","tests","ultimatequestionprocess","buffer","r_stats"]
> >> > But the getcapabilities request, returns:
> >> > default
> >> > Traceback (most recent call last):
> >> > File
> "/usr/local/lib/python2.7/dist-packages/pywps-3.2.2-py2.7.egg/pywps/Wps/__init__.py",
> >> > line 180, in _initFromDirectory
> >> > locals(), [processSources.__name__])
> >> > ImportError: No module named returner
> >> > PyWPS [2016-02-10 14:12:28,215] WARNING: Could not import processes
> from
> >> > 'processes': ImportError('No module named returner',)
> >> > PyWPS Warning: Usage of
> >> > PyWPS Warning: from pywps.Process.Process import WPSProcess
> >> > PyWPS Warning: is deprecated. Use
> >> > PyWPS Warning: from pywps.Process import WPSProcess
> >> > PyWPS Warning: instead!
> >> > PyWPS [2016-02-10 14:12:28,219] WARNING: Could not import process
> >> > [<class
> >> > tests.BBoxProcess3D at 0x2e657a0>]: TypeError("addBBoxInput() got an
> >> > unexpected keyword argument 'crs'",)
> >> > File
> >> > ImportError: No module named GMLBuffer
> >> > PyWPS [2016-02-10 14:12:28,220] WARNING: Could not import processes
> from
> >> > 'processes': ImportError('No module named GMLBuffer',)
> >> > File
> >> > ImportError: No module named reducer
> >> > PyWPS [2016-02-10 14:12:28,221] WARNING: Could not import processes
> from
> >> > 'processes': ImportError('No module named reducer',)
> >> > File
> >> > ImportError: No module named histogramprocess
> >> > PyWPS [2016-02-10 14:12:28,223] WARNING: Could not import processes
> from
> >> > 'processes': ImportError('No module named histogramprocess',)
> >> > PyWPS [2016-02-10 14:12:28,224] INFO: Following processes are
> imported:
> >> > ['dummyprocess', 'ultimatequestionprocess', 'complexVector',
> >> > 'complexRaster', 'noOutput', 'firstInstance', 'secondInstance',
> >> > 'assyncprocess', 'bboxprocess', 'complexprocess', 'literalprocess',
> >> > 'noinputsprocess']
> >> > Content-Type: application/xml
> >> > <wps:ProcessOfferings>
> >> > <wps:Process wps:processVersion="0.1">
> >> > <ows:Identifier>dummyprocess</ows:Identifier>
> >> > <ows:Title>Dummy Process</ows:Title>
> >> > <ows:Abstract>The Dummy process is used for testing the WPS structure.
> >> > The
> >> > process will accept 2 input numbers and will return the XML result
> with
> >> > an
> >> > add one and subtract one operation</ows:Abstract>
> >> > </wps:Process>
> >> > <wps:Process wps:processVersion="2.0">
> >> > <ows:Identifier>ultimatequestionprocess</ows:Identifier>
> >> > <ows:Title>Answer to Life, the Universe and Everything</ows:Title>
> >> > <ows:Abstract>Numerical solution that is the answer to Life, Universe
> >> > and
> >> > Everything. The process is an improvement to Deep Tought computer
> >> > (therefore
> >> > version 2.0) since it no longer takes 7.5 milion years, but only a few
> >> > seconds to give a response, with an update of status every 10
> >> > seconds.</ows:Abstract>
> >> > </wps:Process>
> >> > <wps:Process wps:processVersion="None">
> >> > <ows:Identifier>complexVector</ows:Identifier>
> >> > <ows:Title>First Process</ows:Title>
> >> > <ows:Abstract>Get vector imput and return it to output</ows:Abstract>
> >> > </wps:Process>
> >> > <ows:Identifier>complexRaster</ows:Identifier>
> >> > <ows:Title>Second Process</ows:Title>
> >> > </wps:Process>
> >> > <ows:Identifier>noOutput</ows:Identifier>
> >> > <ows:Title>No output given</ows:Title>
> >> > </wps:Process>
> >> > <ows:Identifier>firstInstance</ows:Identifier>
> >> > <ows:Title>First instance process</ows:Title>
> >> > </wps:Process>
> >> > <ows:Identifier>secondInstance</ows:Identifier>
> >> > <ows:Title>Second instance process</ows:Title>
> >> > </wps:Process>
> >> > <ows:Identifier>assyncprocess</ows:Identifier>
> >> > <ows:Title>Assynchronous process</ows:Title>
> >> > </wps:Process>
> >> > <ows:Identifier>bboxprocess</ows:Identifier>
> >> > <ows:Title>BBox process</ows:Title>
> >> > </wps:Process>
> >> > <ows:Identifier>complexprocess</ows:Identifier>
> >> > <ows:Title>Complex process</ows:Title>
> >> > </wps:Process>
> >> > <ows:Identifier>literalprocess</ows:Identifier>
> >> > <ows:Title>Literal process</ows:Title>
> >> > <ows:Metadata xlink:title="Foobar"
> >> > xlink:href="http://foo/bar" />
> >> > <ows:Metadata xlink:title="Barfoo"
> >> > xlink:href="http://bar/foo" />
> >> > <ows:Metadata xlink:title="Literal process"
> >> > xlink:href="
> http://localhost/cgi-bin/wps?service=WPS&request=DescribeProcess&version=1.0.0&identifier=literalprocess
> >> > xlink:href="http://foobar/" />
> >> > </wps:Process>
> >> > <ows:Identifier>noinputsprocess</ows:Identifier>
> >> > <ows:Title>No inputs</ows:Title>
> >> > </wps:Process>
> >> > </wps:ProcessOfferings>
> >> > </wps:Capabilities>
> >> > 1 - I do not understand this reading processes pywps/processes rather
> >> > than
> >> > /usr/local/WPS/processes
> >> > 2 - this reading another configuration file apparently different
> >> > Thanks in advanced
> >> > 2016-02-10 4:22 GMT-03:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> >> >> Hi Pablo, two notes:
> >> >> 1. That PyWPS instance seems to be still importing processes from the
> >> >> default location (pywps/pywps/processes); check your configuration
> >> >> file.
> >> >> 2. PyWPS is issuing an exception with the processes returner and
> >> >> histogramprocess; before querying PyWPS, making it is successfully
> >> >> importing all your processes.
> >> >> Regards,
> >> >> Luís
> >> >> On 10 February 2016 at 06:24, pablo zader <pzader at gmail.com> wrote:
> >> >> > Hi list
> >> >> > I have the next problem: making a GetCapabilities, returns a list
> of
> >> >> > processes that is different from what I have defined
> >> >> > I have:
> >> >> > $>ls /usr/local/wps/processes/
> >> >> > $>more /usr/local/wps/processes/__init__.py
> >> >> > __all__ =
> >> >> > But the query tells me that I have:
> >> >> > 'noinputsprocess']
> >> >> > Here the complete response:
> >> >> > $>wps.py "service=wps&request=getcapabilities"
> >> >> > PyWPS [2016-02-10 02:15:38,256] INFO: Importing the processes from
> >> >> > default
> >> >> > File
> >> >> > PyWPS [2016-02-10 02:15:38,257] WARNING: Could not import processes
> >> >> > from
> >> >> > PyWPS [2016-02-10 02:15:38,260] WARNING: Could not import process
> >> >> > [<class
> >> >> > tests.BBoxProcess3D at 0xfd17a0>]: TypeError("addBBoxInput() got an
> >> >> > File
> >> >> > PyWPS [2016-02-10 02:15:38,261] WARNING: Could not import processes
> >> >> > from
> >> >> > File
> >> >> > PyWPS [2016-02-10 02:15:38,263] WARNING: Could not import processes
> >> >> > from
> >> >> > File
> >> >> > PyWPS [2016-02-10 02:15:38,264] WARNING: Could not import processes
> >> >> > from
> >> >> > PyWPS [2016-02-10 02:15:38,265] INFO: Following processes are
> >> >> > imported:
> >> >> > 'noinputsprocess']
> >> >> > Thanks in advanced
> >> >> > Pablo
> >> >> > _______________________________________________
> >> >> > pywps-dev mailing list
> >> >> > pywps-dev at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/pywps-dev
> >> > Pablo J. Zader
> >> > Lic. en Cs. de la Computación
> >> > pablo.zader at gmail.com
> >> > "Los Grandes Hombres hablan sobre ideas...
> >> > Los Hombres Promedio hablan sobre cosas...
> >> > Los Hombres Pequeños hablan.. de otros Hombres.
> >> > del libro Matemática estas ahi? A. Paenza "
> > Pablo J. Zader
*Pablo J. Zader*
*Lic. en Cs. de la Computación*
*pablo.zader at gmail.com <pablo.zader at gmail.com>*
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahi? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160211/e57e40f0/attachment-0001.html>
More information about the pywps-dev
