[Pywps-dev] development workflow update
Jachym Cepicky
jachym.cepicky at gmail.com
Sun Feb 14 12:35:20 PST 2016
this is HUGE
thanks!
ne 14. 2. 2016 v 19:09 odesílatel Tom Kralidis <tomkralidis at gmail.com>
napsal:
> Done. Notes:
> - master is now updated. Development for PyWPS 4 is in geopython/pywps
> master
> - 3.2 branch support happens in pywps-3.2
> - just in case, I made a copy of master before the merge (branch
> called master-old-2014-02-14
> - devs should update their repos/forks accordingly before moving any
> further
> ..Tom
> On Sun, Feb 14, 2016 at 3:01 AM, Jachym Cepicky
> <jachym.cepicky at gmail.com> wrote:
> > HI Tom,
> > thanks for summarising the topic
> > I was always saying: we should put stable release to master.
> > But I think, .. pywps-4 is now in "good enough" shape, so it can be put
> to
> > master branch.
> > Anybody who uses "master" should be on the mailing list, so no big
> surprise
> > should occur, when the big bang happens.
> > so from my perspective: any time now :)
> > J
> > čt 11. 2. 2016 v 21:29 odesílatel Tom Kralidis <tomkralidis at gmail.com>
> > napsal:
> >> Thanks Luís. FYI I've tested this approach against my fork for an idea:
> >> https://github.com/tomkralidis/pywps
> >> Here is the commit history:
> >> https://github.com/tomkralidis/pywps/commits/master
> >> Note that last push is the action that updates master.
> >> As well, I would push a backup copy of master called master-old before
> >> merging just in case.
> >> Thoughts on moving forward? To recap, propose pywps-4 branch to become
> >> the new master branch and branch pywps-3.2 is our 3.x support.
> >> ..Tom
> >> On Thu, 11 Feb 2016, Luís de Sousa wrote:
> >> > Date: Thu, 11 Feb 2016 19:51:49 +0100
> >> > From: Luís de Sousa <luis.a.de.sousa at gmail.com>
> >> > To: Tom Kralidis <tomkralidis at gmail.com>
> >> > Cc: "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
> >> > Subject: Re: [Pywps-dev] development workflow update
> >> > Hi Tom,
> >> > I understand your points; the ours strategy looks appropriate.
> >> > Luís
> >> > On 11 February 2016 at 13:30, Tom Kralidis <tomkralidis at gmail.com>
> >> > wrote:
> >> >> Hi Luís: good question. IMHO keeping both under the same repostory
> >> >> makes sense from a project viability perspective:
> >> >> - we are in OSGeo incubation for 3. Doing a merge now keeps the
> >> >> project straight / clean over time
> >> >> - since the incubation started in 3, it is not clear if the
> >> >> application will be valid after rewriting the software, dump the
> old
> >> >> code base and starting from scratch. Having said this, 4 will have
> >> >> to
> >> >> to be mature, which takes time, with lots of deployments and
> >> >> community
> >> >> behind it
> >> >> - there is already a considerable community around 3 so let's
> leverage
> >> >> that existing community
> >> >> - the licensing change and rewrite between PyWPS 3 and 4 does not
> >> >> present
> >> >> any complications
> >> >> - packaging management becomes much easier along a single path
> >> >> ..Tom
> >> >>> Date: Thu, 11 Feb 2016 08:44:25 +0100
> >> >>> Hi there Tom,
> >> >>> What are the advantages of merging the two git projects? It seems
> far
> >> >>> simpler to keep versions 3 and 4 separated.
> >> >>> Luís
> >> >>> On 11 February 2016 at 02:37, Tom Kralidis <tomkralidis at gmail.com>
> >> >>> wrote:
> >> >>>> More thoughts:
> >> >>>> Given current master and pywps-4 branches have totally different
> >> >>>> commit histories, it is not possible to simply merge pywps-4 into
> >> >>>> master via GitHub pull request. One option we could consider is
> >> >>>> using
> >> >>>> the "ours" merge strategy:
> >> >>>> git checkout pywps-4
> >> >>>> git merge -s ours master
> >> >>>> git checkout master
> >> >>>> git merge pywps-4
> >> >>>> git push -f origin master
> >> >>>> This essentially pushes pywps-4 into master branch without wiping
> out
> >> >>>> master branch history.
> >> >>>> ..Tom
> >> >>>> On Tue, Feb 9, 2016 at 4:28 PM, Tom Kralidis <
> >> >>>> wrote:
> >> >>>>> Hi all: FYI the following have been completed
> >> >>>>> against https://github.com/geopython/pywps:
> >> >>>>> - master branch is up to date
> >> >>>>> - issues / milestones are up to date and represent 3.x and 4.x
> plans
> >> >>>>> - branch pywps-4 represents our PyWPS 4 effort
> >> >>>>> - branch pywps-3.2 represents our 3.x development. At this point
> in
> >> >>>>> time
> >> >>>>> any
> >> >>>>> fixes in master that apply to 3.x should be also applied to
> branch
> >> >>>>> pywps-3.2
> >> >>>>> - any further 3.x releases are to built/tagged/released off branch
> >> >>>>> pywps-3.2
> >> >>>>> At some point branch pywps-4 will be merged as master and
> pywps-3.2
> >> >>>>> will
> >> >>>>> be
> >> >>>>> our 3.x support branch. From that point forward, any changes in
> >> >>>>> master
> >> >>>>> should _not_ be applied to branch pywps-3.2 given the backward
> >> >>>>> compability break.
> >> >>>>> I'd like to hear thoughts on pywps-4 -> master efforts and when
> >> >>>>> folks
> >> >>>>> think is a good time to move that over. The idea here is that we
> >> >>>>> have
> >> >>>>> supported releases (3.2.3) to download or pip install, and master
> >> >>>>> represents development. Does anyone have any knowledge that
> master
> >> >>>>> is being used operationally anywhere (which is a bad idea given
> it's
> >> >>>>> not a release).
> >> >>>>> Cheers
> >> >>>>> ..Tom
> >> >>>> _______________________________________________
> >> >>>> pywps-dev mailing list
> >> >>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160214/fd662922/attachment.html>
More information about the pywps-dev
