[Pywps-dev] clarification of dependencies
Jachym Cepicky
jachym.cepicky at gmail.com
Tue Feb 16 11:37:42 PST 2016
agreed
> Questions:
> - is GDAL an absolute requirement? For example, our soon to be published
> instance of PyWPS does not use GDAL whatsoever
nope, it's there just for input data validation. but just for some cases
(STRICT validation) and it's used by tests
> - is OWSLib an absolute requirement? For example, our soon to be published
> instance of PyWPS does not use OWSLib whatsoever
yes - we rely on it
> - is werkzeug an absolute requirement? For example, Can I swap in
> Flask instead?
Quoting from http://werkzeug.pocoo.org/
Werkzeug is the base of frameworks such as Flask <http://flask.pocoo.org/> and
more
IMHO Flask should be able to install it's dependences automatically (?)
> - unipath is used in one single spot in the entire codebase
> https://github.com/geopython/pywps/blob/aed9f6b4b76f954a9a401309ecebb5a22a99d495/pywps/wpsserver.py#L37
> Any objections to working around this functionality thereby removing
> the unipath
> dependency requirement?
+1 (you did already, right?)
> My goal here is to have setup.py, tox.ini, and docs/conf.py derive from
> requirements.txt (for mocking for rtfd.org), but I'm not aware of the
> context/details behind the above.
Nice work, thanks
J
> Thanks
> ..Tom
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160216/e4f3882c/attachment-0001.html>
More information about the pywps-dev
