[Pywps-dev] code coverage and Coveralls.io integration
Tom Kralidis
tomkralidis at gmail.com
Sun Feb 21 18:11:27 PST 2016
Hi all: FYI I've added support for Coveralls.io integration which provides
code coverage testing. This works by adding the relevant directives to
our Travis-CI setup.
https://coveralls.io/github/geopython/pywps
Here's an example build: https://coveralls.io/builds/5153069
If desired we can adjust our Coveralls.io settings (Coverage Threshold
for failure,
Coverage Decrease Threshold for failure).
Should we have a minimum threshold for code coverage?
Note to run code coverage locally just run:
$ pip install coverage
$ coverage run --source=pywps -m unittest tests
$ coverage report -m
..Tom
More information about the pywps-dev
