[Pywps-dev] GSoC 2016: Weekly report 2
Vikas Mishra vikasmishra95 at gmail.com
Tue Jun 7 04:36:53 PDT 2016
I think sharing a file can be done, How does this look?
https://www.dropbox.com/developers-v1/core/docs/python#DropboxClient.share
Also please note that the links created here are time-limited, does it make
any difference?
Thanks and regards,
Vikas Mishra
MSc(Hons) Economics + B.E. Electronics and Electrical Engineering
*Birla Institute of Technology & Science,* Pilani
KK Birla Goa Campus
8412898899|vikasmishra95 at gmail.com
On Tue, Jun 7, 2016 at 4:53 PM, Jonas Eberle <jonas.eberle at gmx.de> wrote:
> Hi Vikas,
> >> I planned on setting up the workflow on how to give these options to
> the user but I couldn’t decide and hence proceeded with implementing
> dropbox storage API
> I believe, the way we should approach is the same, we planed to use for
> FTP storage: configuration of dropbox account should be in handsof server
> administrator. Client should get access to dropbox directory OR file stored
> in dropbox directory directly. Returning folder is ok for now - DropBox
> does not currently fit in the OWS and GIS world seamlessly - that is the
> price we need to pay.
> Using the Python API you are able to share the file directly. Any reason
> against it? Sharing a folder could be a good option if there is one folder
> for each process that is running, but only useful if there are more than
> one output file. But the WPS client need to handle accessing a shared
> dropbox folder. Personally I would share the each file directly.
> Cheers,
> Jonas
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160607/8cf5f5c8/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160607/8cf5f5c8/attachment-0001.jpg>
More information about the pywps-dev mailing list
