[Pywps-dev] [SoC] [SOC] Week report - Web-based administration and process control for PyWPS
Jan Rudolf rudolja1 at fit.cvut.cz
Tue Jun 7 14:54:28 PDT 2016
Hello,
this is, what I meant: I've got forked PyWPS installed in Virtualenv in
the develop mode, where resides my gsoc-pywps-app
(https://github.com/jan-rudolf/gsoc-pywps-app), which is served by
Apache. I've edited my forked PyWPS and added Flask application, that is
going to serve URL's
(https://github.com/jan-rudolf/pywps/tree/master/pywps/server) - it's
serving random (not relevant) URLs now from my example of using Flask
with Apache. So it's part of PyWPS, the user will easily plug the
application by import statement and connect with his web server
(Apache/Nginx) like
https://github.com/jan-rudolf/gsoc-pywps-app/blob/master/wsgi.py - lines
12 and 23. It has not pretty names and line 23 is going to look like
assigning constructor with a config file as a parameter (or similar) -
it's about the principle, it will look better.
We are going to have a discussion with Jachym about REST API, so that
will form the content of the Flask application. I would like also write
some kind of documentation, so anyone could try it run.
Jan
On 2016-06-07 12:02, Jan Rudolf wrote:
> Send it again (mistakes in English): Yes, I didn't mean using Flask as a
> production web server, I count
> on Apache/Nginx, but a Flask app for URL handling and web related stuff.
> On 2016-06-07 11:57, Jan Rudolf wrote: Yes, I didn't mean not using Flask as a production a webserver, I count
> On 2016-06-07 09:21, Jachym Cepicky wrote: Just noting: AFAIK we had already problem with Calin some time back,
> flask server was not able to handle more requests at once, Calin tried
> to run the administrative interface on different port, but I
> personally dislike such solution.
> IMHO the production environment is Apache2/Nginx - we shall focus on
> that
> J
> po 6. 6. 2016 v 23:06 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz>
> napsal:
> Hello,
> Settings: yes, I plan to do it.
> I have been reading a source code of PyWPS and demo applications in
> order to get a clear picture. I have a meeting with Jachym about
> REST
> API on Wednesday, so I would like to implement now an integration of
> Flask app into PyWPS with URL handling. I understand that Service.py
> acts as a WSGI application, it's the core thing. I have it as an
> entry
> point here
> https://github.com/jan-rudolf/gsoc-pywps-app/blob/master/wsgi.py.
> Because we want the web-based administration with own URLs,  so I
> would
> like to make as the entry point Flask's WSGI connection with defined
> URL's based on your wishes and one of the URL for Service.py purpose
> similarly as in one of the demo application. So this functionality,
> I
> would like to integrate for example into /pywps/webserver/, where
> would
> be class Server/Webserver with this features and all the related web
> (Flask) files. So user would, instead of pointing to
> Service.py/Service
> (https://github.com/jan-rudolf/gsoc-pywps-app/blob/master/wsgi.py),
> assign Server(config=config_file).run() (or similar) and it will run
> classic PyWPS with our extended URLs. Make it copy-paste-run for the
> user. What do you think? OR I will just implement it with my forked
> version and we can discuss it better.
> After this, process control will come in.
> Jan Rudolf
> On 2016-06-06 20:46, Jachym Cepicky wrote: Hi Jan,
> nice work
> would it be possible to document your settings and so on in PyWPS
> documentation? Take is as part of your work ;-)
> J
> ne 5. 6. 2016 v 21:18 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz> napsal:
> Hello,
> here is my week report
> http://gsoc-2016.jan-rudolf.cz/article/second-week-report.
> Best regards, Jan Rudolf
> SoC mailing list
> SoC at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/soc
pywps-dev mailing list
pywps-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160607/01f58f6a/attachment-0001.html>
More information about the pywps-dev mailing list
