[Pywps-dev] [GSoC] Pause/Resume/Kill process response - Web-based administration
Jonas Eberle
jonas.eberle at gmx.de
Fri Jun 17 06:19:28 PDT 2016
Hi all,
I would recommend not to mix responses based on OGC WPS (equal to XML-based responses) with requests that are not in line with "typical" WPS requests.
I would assume the following:
1) If the request is something like /wps?service=WPS&request=Pause&jobid=<process_id> (this is a typical WPS request) the response should be XML-based along with or based on the XML defined by the WPS specification.
2) If the request is something like /processes/pause/<process_id> (not defined at all by OGC) the response, in my opinion, should be JSON-based (because this is easier for every programming language!)
The first is OGC-like, the second is completely different from any OGC specification.
Furthermore: Is it "good pratice" to include elements, such as "wps:ProcessPaused", that are not in line with the XML schema of the WPS specification?
Cheers,
Jonas
----- Am 17. Jun 2016 um 14:50 schrieb Jan Rudolf <rudolja1 at fit.cvut.cz>:
> Hi,
> I've implemented pause/resume/kill into PyWPS in a form, that you make
> HTTP request with /processes/pause/<process_id>, the process is paused
> and you will get just text response "<process_id> is paused". I think,
> that Jachym said, you want the response in an XML form like:
> <wps:ExecuteResponse ...>
> <wps:Process wps:processVersion="None">
> <ows:Identifier>sleep</ows:Identifier>
> <ows:Title>Sleep Process</ows:Title>
> <ows:Abstract>This process will sleep for a given delay or 10
> seconds if not a valid value</ows:Abstract>
> </wps:Process>
> <wps:Status creationTime="2016-06-16T22:13:25Z">
> <wps:ProcessAccepted>PyWPS Process sleep
> accepted</wps:ProcessAccepted>
> </wps:Status>
> </wps:ExecuteResponse>
> so for paused/killed/resumed processes is going to be similar response
> only with different status? <wps:ProcessPaused>PyWPS Process sleep
> paused</wps:ProcessPaused> for example.
> Thanks, Jan
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160617/5cbfda53/attachment.html>
More information about the pywps-dev
