[Pywps-dev] Raster Output error
Lorenzo Bottaccioli
lorenzo.bottaccioli at gmail.com
Thu Jun 30 05:43:37 PDT 2016
HI Jachym,
This is the error I get:
*[Thu Jun 30 14:36:36.451990 2016] [:error] [pid 9432:tid 140582713661184]
<contextlib.GeneratorContextManager object at 0x7fdbd3517f90>*
*[Thu Jun 30 14:36:36.452096 2016] [:error] [pid 9432:tid 140582713661184]
/tmp/tmpvDyTG6*
*[Thu Jun 30 14:36:36.546497 2016] [:error] [pid 9432:tid 140582713661184]
[remote 130.192.5.114:46065 <http://130.192.5.114:46065>] mod_wsgi
(pid=9432): Exception occurred processing WSGI script
'/var/www/html/wps/pywps2.wsgi'.*
*[Thu Jun 30 14:36:36.546603 2016] [:error] [pid 9432:tid 140582713661184]
[remote 130.192.5.114:46065 <http://130.192.5.114:46065>] Traceback (most
recent call last):*
*[Thu Jun 30 14:36:36.546640 2016] [:error] [pid 9432:tid 140582713661184]
[remote 130.192.5.114:46065 <http://130.192.5.114:46065>] File
"/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/wrappers.py",
line 291, in application*
*[Thu Jun 30 14:36:36.546697 2016] [:error] [pid 9432:tid 140582713661184]
[remote 130.192.5.114:46065 <http://130.192.5.114:46065>] return
f(*args[:-2] + (request,))(*args[-2:])*
*[Thu Jun 30 14:36:36.546705 2016] [:error] [pid 9432:tid 140582713661184]
*[Thu Jun 30 14:36:36.546713 2016] [:error] [pid 9432:tid 140582713661184]
*[Thu Jun 30 14:36:36.546720 2016] [:error] [pid 9432:tid 140582713661184]
"/usr/local/lib/python2.7/dist-packages/pywps-4.0.0_alpha2-py2.7.egg/pywps/app/WPSResponse.py",
line 203, in __call__*
*[Thu Jun 30 14:36:36.546759 2016] [:error] [pid 9432:tid 140582713661184]
self.process.clean()*
*[Thu Jun 30 14:36:36.546763 2016] [:error] [pid 9432:tid 140582713661184]
"/usr/local/lib/python2.7/dist-packages/pywps-4.0.0_alpha2-py2.7.egg/pywps/app/Process.py",
line 291, in clean*
*[Thu Jun 30 14:36:36.546769 2016] [:error] [pid 9432:tid 140582713661184]
shutil.rmtree(self.workdir)*
*[Thu Jun 30 14:36:36.546772 2016] [:error] [pid 9432:tid 140582713661184]
"/usr/lib/python2.7/shutil.py", line 239, in rmtree*
*[Thu Jun 30 14:36:36.546779 2016] [:error] [pid 9432:tid 140582713661184]
onerror(os.listdir, path, sys.exc_info())*
*[Thu Jun 30 14:36:36.546782 2016] [:error] [pid 9432:tid 140582713661184]
"/usr/lib/python2.7/shutil.py", line 237, in rmtree*
*[Thu Jun 30 14:36:36.546786 2016] [:error] [pid 9432:tid 140582713661184]
[remote 130.192.5.114:46065 <http://130.192.5.114:46065>] names =
os.listdir(path)*
*[Thu Jun 30 14:36:36.546797 2016] [:error] [pid 9432:tid 140582713661184]
[remote 130.192.5.114:46065 <http://130.192.5.114:46065>] OSError: [Errno
2] No such file or directory: '/tmp/pyws_process_8iTSrj'*
Looks similar to the other! If i try to run the process many times some of
them gives this as error:
[Thu Jun 30 14:40:31.133572 2016] [:error] [pid 9431:tid 140582705268480]
[Thu Jun 30 14:40:31.133602 2016] [:error] [pid 9431:tid 140582705268480]
File
line 241, in _run_process
[Thu Jun 30 14:40:31.133631 2016] [:error] [pid 9431:tid 140582705268480]
wps_response = self.handler(wps_request, wps_response)
[Thu Jun 30 14:40:31.133641 2016] [:error] [pid 9431:tid 140582705268480]
File "/home/lorenzo/tools/pywps-4/demo/processes/raster.py", line 38, in
_handler
[Thu Jun 30 14:40:31.133657 2016] [:error] [pid 9431:tid 140582705268480]
response.outputs['raster_out'].output_format = Format('GEOTIFF')
[Thu Jun 30 14:40:31.133679 2016] [:error] [pid 9431:tid 140582705268480]
KeyError: 'raster_out'
[Thu Jun 30 14:40:31.133780 2016] [:error] [pid 9431:tid 140582705268480]
ERROR:PYWPS:Process error: raster.py._handler Line 38 'raster_out'
When it gives this error, in the /tmp/ directory I find a
pyws_process_****** folder with two files inside 1)output.tiff and
2)tmp*****. Output.tiff is a empty file tmp**** is the expected out put.
This is the script of the process:
*from pywps import Process, ComplexInput, ComplexOutput,
get_format,LiteralOutput, Format*
*from pywps.wpsserver import temp_dir*
*class Raster(Process):*
* def __init__(self):*
* inputs = [ComplexInput('raster','Raster
input',[Format('GEOTIFF')])]*
* outputs = [ComplexOutput('raster_out','Raster
input',[Format('GEOTIFF')]), LiteralOutput('response', 'Output response',
data_type='string')]*
* super(Raster, self).__init__(*
* self._handler,*
* identifier='rast_try',*
* title='Raster try',*
* inputs=inputs,*
* outputs=outputs,*
* store_supported=True,*
* status_supported=True*
* def _handler(self, request, response):*
* print temp_dir()*
* with temp_dir() as tmp:*
* print tmp*
* from osgeo import gdal*
* app=request.inputs['raster'][0].file*
* inds = gdal.Open(app)*
* outdriver = gdal.GetDriverByName('GTiff')*
* outds = outdriver.CreateCopy('output.tiff', inds)*
* outds.FlushCache()*
* response.outputs['raster_out'].output_format =
Format('GEOTIFF')*
* response.outputs['raster_out'].file = 'output.tiff'*
* response.outputs['response'].data = 'done'*
* return response*
Best,
Lorenzo
2016-06-29 10:25 GMT+02:00 Lorenzo Bottaccioli <
lorenzo.bottaccioli at gmail.com>:
> Hi Jachym,
> This is the GET request:
> http://localhost/pywps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
> Tnx
> Il 29 giu 2016 10:23 AM, "Jachym Cepicky" <jachym.cepicky at gmail.com> ha
> scritto:
>> Hi Lorenzo,
>> looks like your request is not formatted well - the XML input. How does
>> it look?
>> J
>> út 28. 6. 2016 v 15:29 odesílatel Lorenzo Bottaccioli <
>> lorenzo.bottaccioli at gmail.com> napsal:
>>> HI all,
>>> I have setup the pywps linked by Jachym (
>>> https://github.com/jachym/pywps/tree/pygrass) run on Apache2 with
>>> mod_wsgi.
>>> I have created a wsgi file with this script
>>> *import sys*
>>> *sys.path.insert(0, '/home/lorenzo/tools/pywps-4/')*
>>> *import pywps*
>>> *from pywps.app import Service, Process*
>>> *from processes.raster import Raster*
>>> *from processes.solar.PV_NOCT import PV_CALC*
>>> *from processes.get_year_rad import get_year_rad_pitch*
>>> *from processes.get_year_rad_zstat import get_year_rad_pitch_query*
>>> *from processes.get_year_rad_all import get_year_rad_all*
>>> *from processes.solar.real_sky import Real_sky*
>>> *application = Service(processes=[Raster(),*
>>> * PV_CALC(),*
>>> * get_year_rad_pitch(),*
>>> * get_year_rad_pitch_query(),*
>>> * Real_sky(),*
>>> * get_year_rad_all()], cfgfile='/var/www/pywps/pywps.cfg')*
>>> I still get an error when I try to use the Raster process which is:
>>> * outputs = [ComplexOutput('raster_out', 'Raster
>>> output',[Format('GEOTIFF')]),LiteralOutput('response', 'Output response',
>>> * self._handler,*
>>> * inputs=inputs,*
>>> * outputs=outputs,*
>>> Format('GEOTIFF')*
>>> * return response*
>>> The error I get in the apache error.log is:
>>> [Tue Jun 28 15:23:54.052594 2016] [:error] [pid 4437:tid
>>> 140256591759104] ERROR:PYWPS:Exception: code: 400, locator: None,
>>> description:
>>> [Tue Jun 28 15:23:54.052615 2016] [:error] [pid 4437:tid
>>> 140256591759104] Traceback (most recent call last):
>>> [Tue Jun 28 15:23:54.052617 2016] [:error] [pid 4437:tid
>>> 140256591759104] File
>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0.0_alpha2-py2.7.egg/pywps/app/WPSRequest.py",
>>> line 80, in _post_request
>>> [Tue Jun 28 15:23:54.052618 2016] [:error] [pid 4437:tid
>>> 140256591759104] doc =
>>> lxml.etree.fromstring(self.http_request.get_data())
>>> [Tue Jun 28 15:23:54.052620 2016] [:error] [pid 4437:tid
>>> 140256591759104] File "lxml.etree.pyx", line 3032, in
>>> lxml.etree.fromstring (src/lxml/lxml.etree.c:68106)
>>> [Tue Jun 28 15:23:54.052622 2016] [:error] [pid 4437:tid
>>> 140256591759104] File "parser.pxi", line 1785, in
>>> lxml.etree._parseMemoryDocument (src/lxml/lxml.etree.c:102455)
>>> [Tue Jun 28 15:23:54.052626 2016] [:error] [pid 4437:tid
>>> 140256591759104] File "parser.pxi", line 1673, in lxml.etree._parseDoc
>>> (src/lxml/lxml.etree.c:101284)
>>> [Tue Jun 28 15:23:54.052628 2016] [:error] [pid 4437:tid
>>> 140256591759104] File "parser.pxi", line 1074, in
>>> lxml.etree._BaseParser._parseDoc (src/lxml/lxml.etree.c:96466)
>>> [Tue Jun 28 15:23:54.052629 2016] [:error] [pid 4437:tid
>>> 140256591759104] File "parser.pxi", line 582, in
>>> lxml.etree._ParserContext._handleParseResultDoc
>>> (src/lxml/lxml.etree.c:91275)
>>> [Tue Jun 28 15:23:54.052630 2016] [:error] [pid 4437:tid
>>> 140256591759104] File "parser.pxi", line 683, in
>>> lxml.etree._handleParseResult (src/lxml/lxml.etree.c:92461)
>>> [Tue Jun 28 15:23:54.052632 2016] [:error] [pid 4437:tid
>>> 140256591759104] File "parser.pxi", line 633, in
>>> lxml.etree._raiseParseError (src/lxml/lxml.etree.c:91924)
>>> [Tue Jun 28 15:23:54.052633 2016] [:error] [pid 4437:tid
>>> 140256591759104] XMLSyntaxError: None
>>> Any suggestion to solve it?
>>> Best,
>>> Lorenzo
>>> 2016-06-28 10:28 GMT+02:00 Lorenzo Bottaccioli <
>>>> Hi Jachym,
>>>> I have changed my code in this. I create the file 'output.tiff' the
>>>> error indeed was not related to output.tiff.
>>>> output',[Format('GEOJSON')])]*
>>>> * self._handler,*
>>>> * inputs=inputs,*
>>>> * outputs=outputs,*
>>>> Format('GEOTIFF')*
>>>> * return response*
>>>> This is the Error:
>>>> 130.192.5.114 - - [28/Jun/2016 10:26:51] "GET
>>>> /wps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
>>>> HTTP/1.1" 500 -
>>>> File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line
>>>> 1836, in __call__
>>>> return self.wsgi_app(environ, start_response)
>>>> 1820, in wsgi_app
>>>> response = self.make_response(self.handle_exception(e))
>>>> 1403, in handle_exception
>>>> reraise(exc_type, exc_value, tb)
>>>> 1817, in wsgi_app
>>>> response = self.full_dispatch_request()
>>>> 1478, in full_dispatch_request
>>>> response = self.make_response(rv)
>>>> 1577, in make_response
>>>> rv = self.response_class.force_type(rv, request.environ)
>>>> File
>>>> line 847, in force_type
>>>> response = BaseResponse(*_run_wsgi_app(response, environ))
>>>> File
>>>> line 57, in _run_wsgi_app
>>>> return _run_wsgi_app(*args)
>>>> File
>>>> "/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/test.py",
>>>> line 871, in run_wsgi_app
>>>> app_rv = app(environ, start_response)
>>>> File
>>>> return f(*args[:-2] + (request,))(*args[-2:])
>>>> File
>>>> File
>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/WPSResponse.py",
>>>> line 180, in __call__
>>>> except HTTPException as httpexp:
>>>> NameError: global name 'HTTPException' is not defined
>>>> I'll test your banch ASAP and I let you know.
>>>> Tnx,
>>>> Lorenzo
>>>> 2016-06-27 22:39 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>>>> Lorenzo,
>>>>> two things,
>>>>> in your code:
>>>>> IOError: [Errno 2] No such file or directory:
>>>>> '/tmp/pywps/pypws_process_lQqN_6/done'
>>>>> ERROR:root:Service error: near "''": syntax error
>>>>> means - you can not save output.file as 'done' - it must be file name
>>>>> second: there was bug in pywps, which lead to error while constructing
>>>>> the final response from pywps, please test pygrass branch in my repository
>>>>> one more time:
>>>>> Format('GEOTIFF')
>>>>> should work ASSUMING, output.tiff is existing file!
>>>>> pá 24. 6. 2016 v 13:17 odesílatel Lorenzo Bottaccioli <
>>>>>> Hi all,
>>>>>> Can you please show a simple PyWPS process that revice a geotiff and
>>>>>> returns it back and the url for requesting it?.
>>>>>> I'm not finding a way to do that.
>>>>>> Thanks in advantage,
>>>>>> Best
>>>>>> Lorenzo
>>>>>> 2016-06-21 17:40 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>>>>>> hi,
>>>>>>> if you are running pywps in apache2, it's usually
>>>>>>> /var/log/apache2/error.log
>>>>>>> if flask - it should be written to the command line
>>>>>>> look for some pythonish error
>>>>>>> po 20. 6. 2016 v 17:29 odesílatel Lorenzo Bottaccioli <
>>>>>>>> Hi Jachym,
>>>>>>>> As I wrote in the previous mail I have changed
>>>>>>>> response.outputs['response'].file* = 'done' *in
>>>>>>>> response.outputs['response'].data = 'done' .
>>>>>>>> But I stil get an error:
>>>>>>>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
>>>>>>>> <title>500 Internal Server Error</title>
>>>>>>>> <h1>Internal Server Error</h1>
>>>>>>>> <p>The server encountered an internal error and was unable to
>>>>>>>> complete your request. Either the server is overloaded or there is an
>>>>>>>> error in the application.</p>
>>>>>>>> Which is the HTTPD error.log file? The pywps.log file is always
>>>>>>>> empty and the log level is set to DEBUG
>>>>>>>> Best,
>>>>>>>> Lorenzo
>>>>>>>> 2016-06-18 23:39 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com
>>>>>>>>> hi,
>>>>>>>>> as jonas was saying: response.outputs['response'].data = 'done'
>>>>>>>>> should work better
>>>>>>>>> Lorenzo: do you get anything in the HTTPD server error.log file?
>>>>>>>>> pá 10. 6. 2016 v 15:30 odesílatel Lorenzo Bottaccioli <
>>>>>>>>>> Hi,
>>>>>>>>>> I'have changed from file to data in response.outputs['response'].data
>>>>>>>>>> = 'done', but bow I still get an error in the response.
>>>>>>>>>> The GET request is written like this:
>>>>>>>>>> http://130.192.5.114:8080/wps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
>>>>>>>>>> In the terminal I dont get any error report.
>>>>>>>>>> Tnx,
>>>>>>>>>> Lorenzo
>>>>>>>>>> 2016-06-10 10:20 GMT+02:00 Jonas Eberle <jonas.eberle at gmx.de>:
>>>>>>>>>>> The error "no such file or directory" comes from the following
>>>>>>>>>>> line:
>>>>>>>>>>> response.outputs['response'].file = 'done'
>>>>>>>>>>> As response is a LiteralOutput I guess it is not correct to use
>>>>>>>>>>> the file attribute, better use the data attribute:
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Jonas
>>>>>>>>>>> ----- Am 10. Jun 2016 um 10:13 schrieb Jachym Cepicky <
>>>>>>>>>>> Hi Lorenzo,
>>>>>>>>>>> There are two bugs as I understand. The first one:
>>>>>>>>>>> do you have /tmp/pywps/ directory in you system (and is it
>>>>>>>>>>> writeable?)
>>>>>>>>>>> The second bug is about attempt to write log to database
>>>>>>>>>>> nice report btw, with the process I believe, we can fix it
>>>>>>>>>>> (both) once we find out what the problem could be
>>>>>>>>>>> Jachym
>>>>>>>>>>> st 8. 6. 2016 v 11:50 odesílatel Lorenzo Bottaccioli <
>>>>>>>>>>>> Hi List,
>>>>>>>>>>>> I'm trying to run a process that recives a GeoTIFF as input and
>>>>>>>>>>>> response a GeoTIFF as output. But I'm having an error. The process is this:
>>>>>>>>>>>> def __init__(self):
>>>>>>>>>>>> output',[Format('GEOJSON')]),LiteralOutput('response', 'Output response',
>>>>>>>>>>>> self._handler,
>>>>>>>>>>>> title='Raster try',
>>>>>>>>>>>> inputs=inputs,
>>>>>>>>>>>> outputs=outputs,
>>>>>>>>>>>> outds.FlushCache()
>>>>>>>>>>>> Format('GEOTIFF')
>>>>>>>>>>>> return response
>>>>>>>>>>>> The error that I recive is this one:
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Process.py",
>>>>>>>>>>>> line 156, in _run_process
>>>>>>>>>>>> wps_response.update_status('PyWPS Process finished', 100)
>>>>>>>>>>>> File
>>>>>>>>>>>> line 41, in update_status
>>>>>>>>>>>> self.doc = self._construct_doc()
>>>>>>>>>>>> File
>>>>>>>>>>>> line 171, in _construct_doc
>>>>>>>>>>>> output_elements = [self.outputs[o].execute_xml() for o in
>>>>>>>>>>>> self.outputs]
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/outputs.py",
>>>>>>>>>>>> line 276, in execute_xml
>>>>>>>>>>>> literal_data_doc = WPS.LiteralData(text_type(self.data))
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/basic.py",
>>>>>>>>>>>> line 231, in get_data
>>>>>>>>>>>> return IOHandler.get_data(self)
>>>>>>>>>>>> File
>>>>>>>>>>>> line 173, in get_data
>>>>>>>>>>>> file_handler = open(self.source, mode='r')
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Service.py",
>>>>>>>>>>>> line 358, in _parse_and_execute
>>>>>>>>>>>> wps_response = process.execute(wps_request, uuid)
>>>>>>>>>>>> File
>>>>>>>>>>>> line 145, in execute
>>>>>>>>>>>> wps_response = self._run_process(wps_request, wps_response)
>>>>>>>>>>>> File
>>>>>>>>>>>> line 178, in _run_process
>>>>>>>>>>>> wps_response.update_status('Process error: %s.%s Line %i
>>>>>>>>>>>> %s' % (fname, method_name, exc_tb.tb_lineno, e), -1)
>>>>>>>>>>>> File
>>>>>>>>>>>> line 47, in update_status
>>>>>>>>>>>> update_response(self.uuid, self)
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/dblog.py",
>>>>>>>>>>>> line 67, in update_response
>>>>>>>>>>>> cur.execute(update)
>>>>>>>>>>>> OperationalError: near "''": syntax error
>>>>>>>>>>>> How can I fix this?
>>>>>>>>>>>> Best,
>>>>>>>>>>>> Lorenzo
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> pywps-dev mailing list
>>>>>>>>>>>> pywps-dev at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160630/7ab40a05/attachment-0001.html>
More information about the pywps-dev
