[Pywps-dev] pyWPS with access to a GeoTIFF via rasterstats/rasterio
Jachym Cepicky jachym.cepicky at gmail.com
Sat Aug 19 05:19:40 PDT 2017
Hi
how does your self.src look like? how did you get it? can you please pass
longer snippet of code?
Thanks
J
Ășt 16. 5. 2017 v 15:37 odesĂ­latel Derek Hohls <dhohls at csir.co.za> napsal:
> Hi
> I am wondering if anyone has experience in accessing and extracting data
> from a GeoTIFF via the rasterstats/rasterio libraries?
> The standalone code I have work fine when I run it from the console, but
> when called as part of a pyWPS process, it seems to hang at the point where
> rasterio tries to read the file - specifically, the call that rasterstats
> makes to rasterio is:
>         new_array = self.src.read(
>                 self.band, window=win, boundless=True, masked=masked)
> Unfortunately, the relevant rasterio code for file reads is in a compiled
> Cython file, so we cannot trace into it to find exactly where it is hanging.
> I have checked that an ordinary Python file routine can open & read that
> same file from within the pyWPS code, so it is not a file access or
> permission problem.
> Any help with this, or suggestions from similar experiences, is
> appreciated!
> Thanks
> Derek
> This message is subject to the CSIR's copyright terms and conditions,
> e-mail legal notice, and implemented Open Document Format (ODF) standard.
> The full disclaimer details can be found at
> http://www.csir.co.za/disclaimer.html.
> Please consider the environment before printing this email.
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20170819/7ef97f6d/attachment.html>
More information about the pywps-dev mailing list
