[Pywps-dev] git branches confusion (mess)
Tom Kralidis
tomkralidis at gmail.com
Tue Sep 5 05:45:14 PDT 2017
Hi Luís: comments interleaved.
On Tue, 5 Sep 2017, Luís Moreira de Sousa wrote:
> Date: Tue, 05 Sep 2017 08:14:02 -0400
> From: Luís Moreira de Sousa <luis.de.sousa at protonmail.ch>
> To: Tom Kralidis <tom.kralidis at gmail.com>
> Cc: Jachym Cepicky <jachym.cepicky at gmail.com>,
> jorge.dejesus <jorge.dejesus at geocat.net>,
> "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
> Subject: Re: [Pywps-dev] git branches confusion (mess)
> Hi all, my thoughts:
> What Tom proposes is essentially to use branches instead of tags for code releases. This is in my view a misuse of the system, and at odds with the recommendations from the GitHub people themselves [0]. Marking releases with branches creates three sets of issues:
Isn't master a branch itself? Any release is based on a branch and requires a tag.
> 1. The number of branches increases fast, making the GitHub interface harder to use and complicate branch management in the development environment.
I would say this becomes easier. Branches are created against minor releases. Bugfix releases are created against minor release branches.
> 2. Releases become attached to a perishable asset: it is very easy to delete a branch by mistake. In contrast there is no way to delete a tag in the GitHub interface - they were thought to be permanent.
How does one delete a branch in the GitHub interface? Tags are easily deleted via git command line.
> 3. A larger number of branches increases the likelihood of pull requests committed against the wrong branch.
Disgree; we have had commits being applied to the wrong branch with the current setup. Keeping master as the default branch with most people's Git mindsets being "master is default" prevents issues like applying changes to the wrong branch.
> For the particular issue at hand I believe the solution is to restrict the branch(es) against which pull requests can be issued. I do not know yet if or how is this possible, I opened a thread about it at StackOverflow [1]. Another thing that can be done right away is to protect the master branch [2], which forces additional checks before pull requests can be merged.
> Cheers.
> [0] https://help.github.com/articles/creating-releases/
> [1] https://stackoverflow.com/questions/46054696/restricting-branches-to-which-pull-requests-can-be-issued
> [2] https://help.github.com/articles/defining-the-mergeability-of-pull-requests/
> Im Grund 6
> CH-8600 Dübendorf
> Switzerland
> Phone: +41 (0)79 812 62 65
> Email: luis.de.sousa at protonmail.ch
> URL: https://sites.google.com/site/luismoreiradesousa
>> -------- Original Message --------
>> Local Time: September 2, 2017 7:11 PM
>> UTC Time: September 2, 2017 5:11 PM
>> From: tom.kralidis at gmail.com
>> To: Jachym Cepicky <jachym.cepicky at gmail.com>
>> Luís Moreira de Sousa <luis.de.sousa at protonmail.ch>, jorge.dejesus <jorge.dejesus at geocat.net>, pywps-dev at lists.osgeo.org <pywps-dev at lists.osgeo.org>
>> My proposal on Gitter was to keep master as the true dev branch and releasing stable branches on major releases. That seemed like overhead at the time and we agreed to go with a git-flow type model. Sometimes the 'master by default' thinking has PRs being issued to master by mistake.
>> What do folks think about:
>> - eliminating develop branch
>> - working off master as latest
>> - creating stable branches off major releases
>> Example for a major release:
>> - create x.y.z tag
>> - create x.y stable branch
>> - bug fixes are applied against master and x.y
>> - bug fix releases are made against x.y branch
>> - new features are applied against master
>> Thoughts?
>> ..Tom
>> Sent from my iPhone
>> On Sep 1, 2017, at 15:38, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
>>> Hi,
>>> I've just now put PyWPS `master` back to where it belongs 7cab386
>>> Before I did , I merged the code which was added to master to `develop` branch - no code should be lost.
>>> From now on, we have to carefully read, where the pull requests are supposed to be merged and not accept those pull requests, which are done against master.
>>> Related to this:
>>> I would suggest, we open our development policy one more time, seems, people are confused about the fact, that master is stable and not development branch. @TomKralidis had some alternative proposal on Gitter, maybe it could be shared in the mailing list, I would like to have PSC decided about this.
>>> J
>>> pá 1. 9. 2017 v 15:43 odesílatel Luís Moreira de Sousa <luis.de.sousa at protonmail.ch> napsal:
>>>> Hi Jachym, that sounds good. But which commits exactly were pushed to the master branch? Depending on that we could have a minor odd release as Jorge suggests.
>>>> Cheers.
>>>> Im Grund 6
>>>> CH-8600 Dübendorf
>>>> Switzerland
>>>> Phone: [+41 (0)79 812 62 65](tel:+41%2079%20812%2062%2065)
>>>>> Local Time: August 31, 2017 9:16 AM
>>>>> UTC Time: August 31, 2017 7:16 AM
>>>>> From: jorge.dejesus at geocat.net
>>>>> To: Jachym Cepicky <jachym.cepicky at gmail.com>, pywps-dev at lists.osgeo.org <pywps-dev at lists.osgeo.org>
>>>>> Hi to all
>>>>> I am more in favor of 1 :), but maybe do a pywps 4.0.1 release?
>>>>> J.
>>>>> On 28-08-17 07:34, Jachym Cepicky wrote:
>>>>>> Hi all,
>>>>>> seems, we have pushed to `master` instead of to `develop` ?
>>>>>> Suggestions?
>>>>>> I would do:
>>>>>> 1 - merge master to develop
>>>>>> 2 - reset master back to where it was (pywps-4.0.0)
>>>>>> J
>>>>>> _______________________________________________
>>>>>> pywps-dev mailing list
>>>>>> https://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev
