[Pywps-dev] Subclassing processes
David Huard
huard.david at ouranos.ca
Mon Apr 16 06:40:25 PDT 2018
Hi Luis,
Isn't there a risk for different Process instances to share the same Input
instances ? It seems to me that that could lead to weird behavior.
Cheers,
David
On Sat, Apr 14, 2018 at 2:18 PM Luís Moreira de Sousa <
luis.de.sousa at protonmail.ch> wrote:
> Hi David,
> I have done this in the past, pretty much as you say, by promoting the
> inputs and outputs objects to class properties. Other elements like title,
> abstract, etc, can be treated in the same way. This would all go into an
> "abstract" class from which actual process inherited. Perhaps there might
> be more elegant solutions, but to me this setting served well (I am a man
> of simple tastes).
> All that said, it could make sense defining inputs, outputs, etc as class
> properties in the Process class itself. Something to think about.
> Happy coding. Cheers.
> Bowlespark 8
> 6701 DN Wageningen
> The Netherlands
> Phone: +31 628 544 755
> Email: luis.de.sousa at protonmail.ch
> RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
> URL: https://ldesousa.github.io
> Sent with ProtonMail <https://protonmail.com> Secure Email.
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On April 11, 2018 11:51 PM, David Huard <huard.david at ouranos.ca> wrote:
> Hi all,
> I often find myself in situations where it would be useful to subclass a
> Process and avoid copy-pasting shared inputs and outputs. The way most
> processes are written does not lend itself well to this, inputs being
> instance objects rather than class objects. I was wondering if any of you
> had experience with an elegant way to subclass pywps processes that is
> readable and does not pollute the class namespace too much.
> Thanks,
> david
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20180416/44a9df8a/attachment.html>
More information about the pywps-dev
