[PyWPS-dev] json requests return utf-8 encoded strings :(
Martin Paredes
MParedes at dzynetech.com
Wed Aug 29 12:24:42 PDT 2018
Anytime I request data as json I receive back a html escaped (utf-8) string. It seems that because the data is already in
<![CDATA[
there should be no need to convert each " to " as it's just making the data so much larger.
What can I do to set the json to be returned as a regular ascii string? Is there a configuration setting, or do I need to modify the pywps code and rebuld (if so, could you point me to what I need to modify please)?
I've tried changing the pywps.cfg? like so:
[server]
encoding=iso-8859-1?
This happens with the default example testjson example (I didn't change anything, it was run straight from the code downloaded from github). Instead of getting back: ?
<wps:ComplexData mimeType="application/geojson" encoding="" schema=""><![CDATA[
["foo", {"bar":["baz", null, 1.0, 2]}]
]]></wps:ComplexData>
I'm getting:
"foo",
"bar": [
"baz",
null,
1.0,
2
Martin Paredes
DZYNE Technologies
Desk: 703.291.6662
Mobile: 202.251.7655
mparedes at dzynetech.com
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20180829/d9cef871/attachment.html>
More information about the pywps-dev
