[PyWPS-dev] Running a subprocess via pyWPS?
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Tue Dec 11 09:51:29 PST 2018
Hi Derek,
I explored this at some length back in the day of PyWPS 3.2. The multithreading package never functioned from a PyWPS process (launched asa CGI). I never found out why and eventually moved to multiprocessing, which did the job. This was all quite some time ago, but I would still advise you to try the multiprocessing package.
Regards.
Email: luis.de.sousa at protonmail.ch
RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
URL: https://ldesousa.github.io
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Friday, December 7, 2018 1:40 PM, Derek Hohls <dhohls at csir.co.za> wrote:
> Hi
> I am using pyWPS 4. I am trying to use it to trigger the opening of a sub-process in a thread. However, I get no response back, nor does the subprocess appear to activate.
> I am looking for help in (a) how to get this going and (b) how to debug what the cause of the issue is.
> I have a attached a sample 'dummy' app (Note that for my actual application, the thread that is launched is expected to run continuously in the background; so the "ls" function I have used here is not a really good, representative example but the simplest one I could think of).
> Thanks in advance
> Derek
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181211/64e751b8/attachment-0001.html>
More information about the pywps-dev
