[Pywps-dev] Docker extension
Carsten Ehbrecht ehbrecht at dkrz.de
Mon Mar 26 04:18:15 PDT 2018
Hi Adam,
I will merge my owslib.wps changes (including async/sync switch) in the next days into master.
> On 22. Mar 2018, at 16:51, Adam Laža <ad.laza32 at gmail.com> wrote:
> Also before the PR, I would appreciate to get rid of dependency on my fork of OWSLib where I use async/sync switch. We already discussed it at ML[1] with Carsten. Can you guys now when you're all together merge Carsten's solution into master of OWSLib?
Cheers,
Carsten
Carsten Ehbrecht
Abteilung Datenmanagement
Deutsches Klimarechenzentrum GmbH (DKRZ)
Bundesstraße 45 a • D-20146 Hamburg • Germany
Phone: +49 40 460094-148
FAX:   +49 40 460094-270
Email: ehbrecht at dkrz.de
URL:   www.dkrz.de
Geschäftsführer: Prof. Dr. Thomas Ludwig
Sitz der Gesellschaft: Hamburg
Amtsgericht Hamburg HRB 39784
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20180326/ed37a8b3/attachment.bin>
More information about the pywps-dev mailing list
