[PyWPS-dev] Question about process inputs
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Tue Nov 6 10:30:43 PST 2018
Hi Suzana,
well spotted, this bug is present in the master branch. Please open a new issue, and if you are able to, then submit a matching pull request. As a reminder, detailed contribution instructions can be accessed here: https://pywps.readthedocs.io/en/latest/development.html
Thank you for contributing to PyWPS.
Phone: +31 628 544 755
Email: luis.de.sousa at protonmail.ch
RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
URL: https://ldesousa.github.io
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Tuesday, November 6, 2018 5:08 PM, Suzana Barreto <suzana.barreto at envsys.co.uk> wrote:
> Hi All,
> I have found the bug which is in basic.py class LiteralInput, when it initialises BasicIO, it sets the min_occurs, max_occurs to 1 instead of using the passed in parameter.
> Do I need to fix this in the code base, following the given procedures of course?
> Thanks,
> Suzana
> On Tue, 6 Nov 2018 at 15:09, Suzana Barreto <suzana.barreto at envsys.co.uk> wrote:
>> Hi All,
>> I am in the process of testing a process I created using PyWPS 4. I have found an odd issue with the LiteralInputs for my process. So for example, my process takes an input parameter (stats) where I have a max_occurs=9 which should allow for any number of strings detailing the statistics I would like calculated for a given input file. When I issue a request with a number of values ('sum', 'median', 'std') for that particular parameter, my response contains the result for only 1 of the statistics for that parameter. I traced the issue to service.py (create_literal_inputs), line 216 where a deque is created using the LiteralInput's max_occurs parameter to limit the size. Unfortunately, it appears that this attribute is always 1. When I do a describeProcess request, I notice that the max_occurs is also equal to 1 and this happens regardless of whatever value I change the max_occurs to on that or any other LiteralInputs for my process. So my question is, has anyone come across this issue? Am I doing something wrong? Below is the code showing how I have defined the inputs.
>> class
>> BasicZonalStats(Process):
>> def
>> __init__
>> self
>> inputs = [ComplexInput(
>> 'aoi_ndvi'
>> 'Raster ndvi'
>> supported_formats
>> =[Format(
>> 'image/tiff'
>> ), Format(
>> 'application/x-ogc-wcs'
>> min_occurs
>> 1
>> max_occurs
>> 1
>> mode
>> =MODE.NONE),
>> LiteralInput(
>> 'band'
>> 'the band to calculate stats for'
>> data_type
>> 'integer'
>> min_occurs
>> 1
>> max_occurs
>> 1
>> mode
>> =MODE.SIMPLE),
>> LiteralInput(
>> 'stats'
>> 'Statistics to calculate'
>> data_type
>> 'string'
>> min_occurs
>> 0
>> max_occurs
>> 9
>> allowed_values
>> 'sum'
>> 'std'
>> 'median'
>> 'majority'
>> 'minority'
>> 'unique'
>> 'range'
>> 'nodata'
>> 'nan'
>> mode
>> =MODE.SIMPLE),
>> LiteralInput(
>> 'nodata'
>> 'Nodata value'
>> data_type
>> 'integer'
>> mode
>> =MODE.SIMPLE),
>> ComplexInput(
>> 'zones'
>> 'Vector polygons to calculate stats on.'
>> supported_formats
>> =[Format(
>> 'application/json'
>> min_occurs
>> 1
>> max_occurs
>> 1
>> mode
>> =MODE.NONE)
>> outputs = [ComplexOutput(
>> 'zonal_stats'
>> 'Attribute Table'
>> supported_formats
>> =[Format(
>> 'application/json'
>> super
>> (BasicZonalStats,
>> self
>> __init__
>> self
>> ._handler,
>> identifier
>> 'zonal'
>> version
>> '0.1'
>> title
>> "Basic Zonal Statistics using Rasterstats"
>> abstract
>> "This is a naive and basic WPS, it assumes that both vector and raster inputs are in the same"
>> "projection and as such does not do any error checking. This will be fixed at a later stage so f"
>> "or now please ensure that the inputs are in the same projection."
>> profile
>> inputs
>> =inputs,
>> outputs
>> =outputs,
>> store_supported
>> True
>> status_supported
>> True
>> Any help with this would be much appreciated.
>> Thanks,
>> Suzana
>> Dr Suzana Barreto
>> Software Analyst
>> Environment Systems
>> Tel: [+44 (0) 1970 626688](tel:%2B44%20%280%29%201970%20626688)
>> [www.envsys.co.uk](http://www.envsys.co.uk/)
>> The information contained in this e-mail is intended only for the use of the person(s) to whom it is addressed and may contain confidential or privileged information. If you have received this e-mail in error please contact the sender and delete the material without copying, distributing or disclosing the content. All reasonable precautions have been taken to ensure that this e-mail is free from any virus, however, the recipient should verify this to be the case. Please 'think before you print'
> Dr Suzana Barreto
> Software Analyst
> Environment Systems
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181106/82bc419a/attachment-0001.html>
More information about the pywps-dev
