[PyWPS-dev] Why is PyWPS using different XML tags/namespaces for BoundingBoxData as Input and Output?
Gunnar Ströer
gunnar.stroeer at yahoo.de
Fri Jan 18 04:40:17 PST 2019
Hi Community,
during my processes coding I've found out a discrepance in the supported Input and Output XML code in the case of using bounding box data. Am I right assuming that the built-in support for Input XML is based on the tag <wps:BoundingBoxData><ows:LowerCorner>(...) and for Output/Response XML is based on the tag <ows:BoundingBox><ows:LowerCorner>(...) only? Or can I modify this XML tag within PyWPS and without XML parse/replace?
As INPUT:
<wps:BoundingBoxData crs="EPSG:25832">
<ows:LowerCorner>413236.919203 5316621.52211</ows:LowerCorner>
<ows:UpperCorner>413719.644442 5317104.24735</ows:UpperCorner>
</wps:BoundingBoxData>
As OUTPUT:
<ows:BoundingBox crs="EPSG:25832" dimensions="2">
</ows:BoundingBox>
Cheers, Gunnar
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20190118/3b0256c8/attachment.html>
More information about the pywps-dev
