[PyWPS-dev] PR and broken CI?
Idan Miara
idan at miara.com
Thu Aug 27 02:24:04 PDT 2020
Hi all,
Sorry about the last email, it was my mistake.
I've fixed that and made a new PR, which is now ready for merging.
https://github.com/geopython/pywps/pull/545
I think this duplicated function should be avoided, but I didn't want to
make a larger change for this PR.
I will try to remove the duplicated function once this PR is approved.
Kind regards,
Idan
On Wed, 26 Aug 2020 at 14:42, Idan Miara <idan at miara.com> wrote:
> Hi all,
> I made the following PR:
> https://github.com/geopython/pywps/pull/544
> travis gives the following error:
> ImportError: cannot import name 'input_from_json' from
> 'pywps.inout.inputs'
> (/home/travis/build/geopython/pywps/pywps/inout/inputs.py)
> https://travis-ci.org/github/geopython/pywps/jobs/717314666
> This error has nothing to do with my PR and also the name input_from_json
> exists in pywps.inout.inputs so I'm not sure why it gives an error anyway.
> Can someone check it out please?
> Kind regards,
> Idan
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20200827/09cb87cf/attachment.html>
More information about the pywps-dev
