[PyWPS-dev] documentation build of PyWPS fails
    Jachym Cepicky
    jachym.cepicky at gmail.com
    Thu Jul  9 06:26:06 PDT 2020
thanks for the hint
J
po 6. 7. 2020 v 15:25 odesílatel David Huard <huard.david at ouranos.ca> napsal:
> Is pywps installed in the environment in which you are building the docs ?
> pywps bundles a sphinx extension to document processes.
> On Mon, Jul 6, 2020 at 2:59 AM Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
>> Hi all,
>> recently I can not build PyWPS documentation
>> cd doc
>> build html
>> Could not import extension pywps.ext_autodoc (exception: No module
>> named 'pywps')
>> I seems, that there is pywps autodoc extension missing in the files
>> and it seems that the author of this line in conf.py is Tom Kralidis
>> Any idea, what needs to be done in order to get this fixed?
>> Thanks
>> Jachym
>> Jachym Cepicky
>> e-mail: jachym.cepicky gmail com
>> URL: http://les-ejk.cz
>> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pywps-dev
> David Huard, PhD
> Spécialiste Scénarios et services climatiques, Ouranos
Jachym Cepicky
More information about the pywps-dev
