[QGIS Commit] r8350 - in trunk/qgis/src: plugins/grass
providers/grass
svn_qgis at osgeo.org
Mon Apr 14 17:02:23 EDT 2008
Author: jef
Date: 2008-04-14 17:02:22 -0400 (Mon, 14 Apr 2008)
New Revision: 8350
trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
trunk/qgis/src/plugins/grass/qgsgrassregion.cpp
trunk/qgis/src/plugins/grass/qgsgrassshell.cpp
trunk/qgis/src/providers/grass/qgsgrass.cpp
trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
fix gcc warnings in grass provider and plugin
Modified: trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp 2008-04-14 11:13:53 UTC (rev 8349)
+++ trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp 2008-04-14 21:02:22 UTC (rev 8350)
@@ -1359,9 +1359,9 @@
// database path
QgsGrass::activeMode(); // because it calls private gsGrass::init()
#if defined(WIN32)
- G__setenv( "GISDBASE", (char *) getShortPath(mDatabaseLineEdit->text()).ascii() );
+ G__setenv( (char *)"GISDBASE", (char *) getShortPath(mDatabaseLineEdit->text()).ascii() );
#else
- G__setenv( "GISDBASE", (char *) mDatabaseLineEdit->text().ascii() );
+ G__setenv( (char *)"GISDBASE", (char *) mDatabaseLineEdit->text().ascii() );
#endif
QgsGrass::resetError();
Modified: trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp 2008-04-14 11:13:53 UTC (rev 8349)
+++ trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp 2008-04-14 21:02:22 UTC (rev 8350)
@@ -565,7 +565,7 @@
QgsGrass::setLocation ( gisdbase, location );
struct Cell_head window;
- char *err = G__get_window ( &window, "", "WIND", (char *) mapset.latin1() );
+ char *err = G__get_window ( &window, (char *)"", (char *)"WIND", (char *) mapset.latin1() );
if ( err ) {
QMessageBox::warning( 0, tr("Warning"), tr("Cannot read current region: ") + QString(err) );
Modified: trunk/qgis/src/plugins/grass/qgsgrassregion.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassregion.cpp 2008-04-14 11:13:53 UTC (rev 8349)
+++ trunk/qgis/src/plugins/grass/qgsgrassregion.cpp 2008-04-14 21:02:22 UTC (rev 8350)
@@ -195,7 +195,7 @@
- char *err = G__get_window ( &mWindow, "", "WIND", (char *) mapset.latin1() );
+ char *err = G__get_window ( &mWindow, (char *)"", (char *)"WIND", (char *) mapset.latin1() );
if ( err ) {
@@ -452,7 +452,7 @@
QgsGrass::setLocation ( QgsGrass::getDefaultGisdbase(), QgsGrass::getDefaultLocation() );
- G__setenv( "MAPSET", (char *) QgsGrass::getDefaultMapset().latin1() );
+ G__setenv( (char *)"MAPSET", (char *) QgsGrass::getDefaultMapset().latin1() );
if ( G_put_window(&mWindow) == -1 ) {
QMessageBox::warning( 0, tr("Warning"), tr("Cannot write region") );
Modified: trunk/qgis/src/plugins/grass/qgsgrassshell.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassshell.cpp 2008-04-14 11:13:53 UTC (rev 8349)
+++ trunk/qgis/src/plugins/grass/qgsgrassshell.cpp 2008-04-14 21:02:22 UTC (rev 8350)
@@ -216,7 +216,7 @@
shell = "/bin/bash";
- char *norc = "";
+ const char *norc = "";
QFileInfo si(shell);
if ( si.fileName() == "bash" || si.fileName() == "sh" )
@@ -229,12 +229,12 @@
// Warning: execle + --norc will not inherit not given variables
// -> overwrite here
- char *env = "GRASS_MESSAGE_FORMAT=gui";
+ const char *env = "GRASS_MESSAGE_FORMAT=gui";
char *envstr = new char[strlen(env)+1];
strcpy ( envstr, env );
putenv( envstr );
- putenv ( "GISRC_MODE_MEMORY" ); // unset
+ putenv ( (char *) "GISRC_MODE_MEMORY" ); // unset
env = "PS1=GRASS > ";
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp 2008-04-14 11:13:53 UTC (rev 8349)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp 2008-04-14 21:02:22 UTC (rev 8350)
@@ -324,12 +324,12 @@
// Set principal GRASS variables (in memory)
#if defined(WIN32)
- G__setenv( "GISDBASE", (char *) getShortPath(gisdbase).ascii() );
+ G__setenv( (char *)"GISDBASE", (char *) getShortPath(gisdbase).ascii() );
#else
- G__setenv( "GISDBASE", (char *) gisdbase.ascii() );
+ G__setenv( (char *)"GISDBASE", (char *) gisdbase.ascii() );
#endif
- G__setenv( "LOCATION_NAME", (char *) location.ascii() );
- G__setenv( "MAPSET", "PERMANENT"); // PERMANENT must always exist
+ G__setenv( (char *)"LOCATION_NAME", (char *) location.ascii() );
+ G__setenv( (char *)"MAPSET", (char *)"PERMANENT"); // PERMANENT must always exist
// Add all available mapsets to search path
char **ms = G_available_mapsets();
@@ -346,12 +346,12 @@
#if defined(WIN32)
#else
#endif
- G__setenv( "MAPSET", (char *) mapset.ascii() );
+ G__setenv( (char *)"MAPSET", (char *) mapset.ascii() );
@@ -554,14 +554,14 @@
putenv( gisrcEnvChar );
// Reinitialize GRASS
- G__setenv( "GISRC", const_cast<char *>(gisrcEnv.ascii()) );
+ G__setenv( (char *)"GISRC", const_cast<char *>(gisrcEnv.ascii()) );
#if defined(WIN32)
- G__setenv( "GISDBASE", const_cast<char *>(getShortPath(gisdbase).ascii()) );
+ G__setenv( (char *)"GISDBASE", const_cast<char *>(getShortPath(gisdbase).ascii()) );
#else
- G__setenv( "GISDBASE", const_cast<char *>(gisdbase.ascii()) );
+ G__setenv( (char *)"GISDBASE", const_cast<char *>(gisdbase.ascii()) );
#endif
- G__setenv( "LOCATION_NAME", const_cast<char *>(location.ascii()) );
- G__setenv( "MAPSET", const_cast<char *>(mapset.ascii()) );
+ G__setenv( (char *)"LOCATION_NAME", const_cast<char *>(location.ascii()) );
+ G__setenv( (char *)"MAPSET", const_cast<char *>(mapset.ascii()) );
defaultGisdbase = gisdbase;
defaultLocation = location;
defaultMapset = mapset;
@@ -595,13 +595,13 @@
mMapsetLock = "";
- putenv( "GISRC" );
+ putenv( (char *)"GISRC" );
- G__setenv( "GISRC", "" );
- G__setenv( "GISDBASE", "" );
- G__setenv( "LOCATION_NAME", "" );
- G__setenv( "MAPSET", "" );
+ G__setenv( (char *)"GISRC", (char *)"" );
+ G__setenv( (char *)"GISDBASE", (char *)"" );
+ G__setenv( (char *)"LOCATION_NAME", (char *)"" );
+ G__setenv( (char *)"MAPSET", (char *)"" );
defaultGisdbase = "";
defaultLocation = "";
defaultMapset = "";
@@ -893,7 +893,7 @@
QgsGrass::setLocation( gisbase, location );
- if ( G__get_window ( window, "", "WIND", mapset.toLocal8Bit().data() ) )
+ if ( G__get_window ( window, (char *)"", (char *)"WIND", mapset.toLocal8Bit().data() ) )
return false;
@@ -1027,7 +1027,7 @@
else if ( type == Region )
- if ( G__get_window (window, "windows",
+ if ( G__get_window (window, (char *)"windows",
map.toLocal8Bit().data(),
mapset.toLocal8Bit().data() ) != NULL )
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-04-14 11:13:53 UTC (rev 8349)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-04-14 21:02:22 UTC (rev 8350)
@@ -733,7 +733,7 @@
#endif
dbString dbstr;
db_init_string (&dbstr);
- db_set_string (&dbstr, "select * from ");
+ db_set_string (&dbstr, (char *)"select * from ");
db_append_string (&dbstr, layer.fieldInfo->table);
#ifdef QGISDEBUG
@@ -1076,7 +1076,7 @@
// TODO: Should be done better / in other place ?
// TODO: Is it necessary for close ?
- G__setenv( "MAPSET", (char *) map->mapset.ascii() );
+ G__setenv( (char *)"MAPSET", (char *) map->mapset.ascii() );
if ( closeMap ) Vect_close ( map->map );
@@ -1402,7 +1402,7 @@
// Set current mapset (mapset was previously checked by isGrassEditable() )
@@ -1472,7 +1472,7 @@
// TODO: Is it necessary for build/close ?
Vect_build_partial ( map->map, GV_BUILD_NONE, NULL);
Vect_build ( map->map, stderr );
