[QGIS Commit] r8957 - in trunk/qgis/src: app core/raster ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Aug 1 06:52:51 EDT 2008
Author: timlinux
Date: 2008-08-01 06:52:50 -0400 (Fri, 01 Aug 2008)
New Revision: 8957
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.h
   trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
Added callback functions and hooked it up to the raster properties dialogs so that building pyramids and computing histogram now shows progress bar indication. Also change cursor to hourglass while computing histograms.
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-08-01 10:33:01 UTC (rev 8956)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-08-01 10:52:50 UTC (rev 8957)
@@ -1570,6 +1570,7 @@
 void QgsRasterLayerProperties::on_buttonBuildPyramids_clicked()
+  connect(mRasterLayer, SIGNAL(progressUpdate(int)), mPyramidProgress, SLOT(setValue(int)));
   // Go through the list marking any files that are selected in the listview
   // as true so that we can generate pyramids for them.
@@ -1592,6 +1593,7 @@
   QApplication::setOverrideCursor(Qt::WaitCursor);
   QString res = mRasterLayer->buildPyramids(myPyramidList,cboResamplingMethod->currentText());
   QApplication::restoreOverrideCursor();
+  disconnect(mRasterLayer, SIGNAL(progressUpdate(int)), mPyramidProgress, SLOT(setValue(int)));
   if (!res.isNull())
     if (res == "ERROR_WRITE_ACCESS")
@@ -1867,6 +1869,8 @@
 void QgsRasterLayerProperties::on_pbnHistRefresh_clicked()
+  connect(mRasterLayer, SIGNAL(progressUpdate(int)), mHistogramProgress, SLOT(setValue(int)));
+  QApplication::setOverrideCursor(Qt::WaitCursor);
 #ifdef QGISDEBUG
   std::cout << "QgsRasterLayerProperties::on_pbnHistRefresh_clicked" << std::endl;
 #endif
@@ -1960,6 +1964,7 @@
       myFirstItemFlag=false;
+  disconnect(mRasterLayer, SIGNAL(progressUpdate(int)), mHistogramProgress, SLOT(setValue(int)));
 #ifdef QGISDEBUG
   std::cout << "max " << myYAxisMax << std::endl;
   std::cout << "min " << myYAxisMin << std::endl;
@@ -2289,6 +2294,7 @@
   myPainter.end();
   pixHistogram->setPixmap(myPixmap);
+  QApplication::restoreOverrideCursor();
 void QgsRasterLayerProperties::on_pbnImportTransparentPixelValues_clicked()
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-01 10:33:01 UTC (rev 8956)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-01 10:52:50 UTC (rev 8957)
@@ -3728,18 +3728,18 @@
         if(theResamplingMethod==tr("Average Magphase"))
           myError = GDALBuildOverviews( mGdalDataset, "MODE", 1, myOverviewLevelsArray, 0, NULL,
-              GDALDummyProgress, NULL );
+              progressCallback, this); //this is the arg for the gdal progress callback
         else if(theResamplingMethod==tr("Average"))
           myError = GDALBuildOverviews( mGdalDataset, "AVERAGE", 1, myOverviewLevelsArray, 0, NULL,
         else // fall back to nearest neighbor
           myError = GDALBuildOverviews( mGdalDataset, "NEAREST", 1, myOverviewLevelsArray, 0, NULL,
         if (myError == CE_Failure || CPLGetLastErrorNo()==CPLE_NotSupported  )
@@ -4749,7 +4749,10 @@
     double myerval = (myRasterBandStats.maxVal-myRasterBandStats.minVal)/theBinCount;
-    GDALGetRasterHistogram( myGdalBand, myRasterBandStats.minVal-0.1*myerval, myRasterBandStats.maxVal+0.1*myerval, theBinCount, myHistogramArray ,theIgnoreOutOfRangeFlag ,theHistogramEstimatedFlag , GDALDummyProgress, NULL );
+    GDALGetRasterHistogram( myGdalBand, myRasterBandStats.minVal-0.1*myerval,
+        myRasterBandStats.maxVal+0.1*myerval, theBinCount, myHistogramArray
+        ,theIgnoreOutOfRangeFlag ,theHistogramEstimatedFlag , progressCallback,
+        this ); //this is the arg for our custome gdal progress callback
     for (int myBin = 0; myBin <theBinCount; myBin++)
@@ -5219,3 +5222,53 @@
     setContrastEnhancementAlgorithm(QgsContrastEnhancement::NO_STRETCH, theGenerateLookupTableFlag);
+void QgsRasterLayer::showProgress(int theValue)
+  emit progressUpdate(theValue);
+// global callback function
+int CPL_STDCALL progressCallback( double dfComplete,
+    const char * pszMessage,
+    void * pProgressArg)
+  static double dfLastComplete = -1.0;
+  QgsRasterLayer * mypLayer = (QgsRasterLayer *) pProgressArg;
+  if( dfLastComplete > dfComplete )
+    if( dfLastComplete >= 1.0 )
+      dfLastComplete = -1.0;
+    else
+      dfLastComplete = dfComplete;
+  if( floor(dfLastComplete*10) != floor(dfComplete*10) )
+    int    nPercent = (int) floor(dfComplete*100);
+    if( nPercent == 0 && pszMessage != NULL )
+      //fprintf( stdout, "%s:", pszMessage );
+    if( nPercent == 100 )
+      //fprintf( stdout, "%d - done.\n", (int) floor(dfComplete*100) );
+      mypLayer->showProgress(100);
+    else
+      int myProgress = (int) floor(dfComplete*100);
+      //fprintf( stdout, "%d.", myProgress);
+      mypLayer->showProgress(myProgress);
+      //fflush( stdout );
+  return TRUE;
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-08-01 10:33:01 UTC (rev 8956)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-08-01 10:52:50 UTC (rev 8957)
@@ -137,24 +137,17 @@
 #include "qgsrastertransparency.h"
 #include "qgsrastershader.h"
 #include "qgsrastershaderfunction.h"
- * New includes that will convert this class to a data provider interface
- * (B Morley)
 #include "qgsrasterdataprovider.h"
- * END
 #define CPL_SUPRESS_CPLUSPLUS
 #include <gdal.h>
+    const char *pszMessage,
+    void * pProgressArg );
 // Forward declarations
@@ -1113,11 +1106,20 @@
   //! Which provider is being used for this Raster Layer?
   QString providerKey();
+  /** A wrapper function to emit a progress update signal.
+   * For example used by gdal callback to show pyramid building progress.
+  void showProgress(int theValue);
 public slots:
   void showStatusMessage(const QString & theMessage);
+signals:
+  //for notifying listeners of long running processes
+  void progressUpdate(int theValue);
 private:
   //! Data provider key
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui	2008-08-01 10:33:01 UTC (rev 8956)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui	2008-08-01 10:52:50 UTC (rev 8957)
@@ -812,10 +812,10 @@
          </property>
          <layout class="QGridLayout" >
           <property name="horizontalSpacing" >
-           <number>-1</number>
+           <number>6</number>
           </property>
           <property name="verticalSpacing" >
           </property>
           <item row="0" column="0" >
            <widget class="QLabel" name="labelContrastEnhancement" >
@@ -1786,7 +1786,7 @@
        <string>Pyramids</string>
       </attribute>
-       <item rowspan="2" row="0" column="0" >
+       <item rowspan="2" row="0" column="0" colspan="3" >
         <widget class="QTextEdit" name="tePyramidDescription" >
          <property name="sizePolicy" >
           <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
@@ -1797,19 +1797,19 @@
          <property name="html" >
           <string>&lt;html>&lt;head>&lt;meta name="qrichtext" content="1" />&lt;style type="text/css">
 p, li { white-space: pre-wrap; }
-&lt;/style>&lt;/head>&lt;body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal;">
-&lt;p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;">&lt;/p>&lt;/body>&lt;/html></string>
+&lt;/style>&lt;/head>&lt;body style=" font-family:'Verdana'; font-size:10pt; font-weight:400; font-style:normal;">
+&lt;p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;">&lt;/p>&lt;/body>&lt;/html></string>
          </property>
         </widget>
        </item>
-       <item row="0" column="1" >
+       <item row="0" column="3" colspan="2" >
         <widget class="QLabel" name="textLabel5" >
          <property name="text" >
           <string>Pyramid resolutions</string>
          </property>
         </widget>
        </item>
-       <item row="1" column="1" >
+       <item row="1" column="3" colspan="2" >
         <widget class="QListWidget" name="lbxPyramidResolutions" >
           <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
@@ -1828,69 +1828,44 @@
          </property>
         </widget>
        </item>
-       <item row="2" column="0" colspan="2" >
-        <layout class="QHBoxLayout" >
-         <property name="leftMargin" >
-          <number>11</number>
+       <item row="2" column="0" >
+        <widget class="QLabel" name="textLabel4_2" >
+         <property name="text" >
+          <string>Resampling method</string>
          </property>
-         <property name="topMargin" >
+         <property name="buddy" >
+          <cstring>cboResamplingMethod</cstring>
          </property>
-         <property name="rightMargin" >
-         </property>
-         <property name="bottomMargin" >
-         </property>
+        </widget>
+       </item>
+       <item row="2" column="1" >
+        <widget class="QComboBox" name="cboResamplingMethod" >
          <item>
-          <spacer>
-           <property name="orientation" >
-            <enum>Qt::Horizontal</enum>
-           </property>
-           <property name="sizeType" >
-            <enum>QSizePolicy::Expanding</enum>
-           </property>
-           <property name="sizeHint" >
-            <size>
-             <width>156</width>
-             <height>20</height>
-            </size>
-           </property>
-          </spacer>
+           <string>Average</string>
+          </property>
          </item>
          <item>
-          <widget class="QLabel" name="textLabel4_2" >
-           <property name="text" >
-            <string>Resampling method</string>
-           </property>
-           <property name="buddy" >
-            <cstring>cboResamplingMethod</cstring>
-           </property>
-          </widget>
+           <string>Nearest Neighbour</string>
+          </property>
          </item>
-         <item>
-          <widget class="QComboBox" name="cboResamplingMethod" >
-           <item>
-             <string>Average</string>
-            </property>
-           </item>
-           <item>
-             <string>Nearest Neighbour</string>
-            </property>
-           </item>
-          </widget>
-         </item>
-         <item>
-          <widget class="QPushButton" name="buttonBuildPyramids" >
-            <string>Build pyramids</string>
-           </property>
-          </widget>
-         </item>
-        </layout>
+        </widget>
        </item>
+       <item row="2" column="2" colspan="2" >
+        <widget class="QProgressBar" name="mPyramidProgress" >
+         <property name="value" >
+          <number>0</number>
+         </property>
+        </widget>
+       </item>
+       <item row="2" column="4" >
+        <widget class="QPushButton" name="buttonBuildPyramids" >
+          <string>Build pyramids</string>
+         </property>
+        </widget>
+       </item>
       </layout>
      </widget>
      <widget class="QWidget" name="tabPageHistogram" >
@@ -1898,18 +1873,6 @@
        <string>Histogram</string>
       </attribute>
-       </property>
-       </property>
-       </property>
-       </property>
        <item row="0" column="0" colspan="2" >
         <widget class="QLabel" name="pixHistogram" >
@@ -1979,31 +1942,12 @@
          </layout>
         </widget>
        </item>
-       <item row="3" column="1" >
-        <widget class="QPushButton" name="pbnHistRefresh" >
-          <string>Refresh</string>
-         </property>
-        </widget>
-       </item>
        <item rowspan="2" row="1" column="1" >
         <widget class="QGroupBox" name="groupBox" >
          <property name="title" >
           <string>Options</string>
          </property>
-          </property>
-          </property>
-          </property>
-          </property>
            <widget class="QLabel" name="textLabel1_2" >
@@ -2011,6 +1955,22 @@
             </property>
            </widget>
           </item>
+          <item row="0" column="1" >
+           <widget class="QSpinBox" name="spinHistBinCount" >
+            <property name="minimum" >
+             <number>8</number>
+            </property>
+            <property name="maximum" >
+             <number>1024</number>
+            </property>
+            <property name="singleStep" >
+            </property>
+             <number>64</number>
+            </property>
+           </widget>
+          </item>
           <item row="1" column="0" colspan="2" >
            <widget class="QCheckBox" name="chkHistIgnoreOutOfRange" >
@@ -2028,26 +1988,10 @@
             </property>
            </widget>
           </item>
-           <widget class="QSpinBox" name="spinHistBinCount" >
-            <property name="minimum" >
-             <number>8</number>
-            </property>
-            <property name="maximum" >
-             <number>1024</number>
-            </property>
-            <property name="singleStep" >
-            </property>
-            <property name="value" >
-             <number>64</number>
-            </property>
-           </widget>
-          </item>
          </layout>
         </widget>
        </item>
-       <item rowspan="2" row="2" column="0" >
+       <item rowspan="4" row="2" column="0" >
         <widget class="QListWidget" name="lstHistogramLabels" >
          <property name="maximumSize" >
           <size>
@@ -2060,6 +2004,33 @@
          </property>
         </widget>
        </item>
+       <item row="3" column="1" >
+        <spacer>
+         <property name="orientation" >
+          <enum>Qt::Vertical</enum>
+         </property>
+         <property name="sizeHint" >
+          <size>
+           <width>20</width>
+           <height>40</height>
+          </size>
+         </property>
+        </spacer>
+       </item>
+       <item row="4" column="1" >
+        <widget class="QProgressBar" name="mHistogramProgress" >
+         </property>
+        </widget>
+       </item>
+       <item row="5" column="1" >
+        <widget class="QPushButton" name="pbnHistRefresh" >
+          <string>Refresh</string>
+         </property>
+        </widget>
+       </item>
       </layout>
      </widget>
     </widget>
More information about the QGIS-commit mailing list
