[QGIS Commit] r8962 - in docs/trunk/english_us/user_guide: .
help_and_support_screenies
svn_qgis at osgeo.org
Fri Aug 1 10:28:45 EDT 2008
Author: sholl
Date: 2008-08-01 10:28:45 -0400 (Fri, 01 Aug 2008)
New Revision: 8962
docs/trunk/english_us/user_guide/ChangeLog
docs/trunk/english_us/user_guide/help_and_support_screenies/Makefile
docs/trunk/english_us/user_guide/working_with_ogc.tex
docs/trunk/english_us/user_guide/working_with_projections.tex
docs/trunk/english_us/user_guide/working_with_raster.tex
docs/trunk/english_us/user_guide/working_with_vector.tex
* help_and_support_screenies/Makefile: added clean-target
* working_with_vector.tex: started to update the
layer-properties-dialog-description according to the
SVN-trunk-implemenation
* working_with_ogc.tex, working_with_projections.tex,
working_with_raster.tex: added FIXME-notes to easier find the
parts where to include new images
Modified: docs/trunk/english_us/user_guide/ChangeLog
--- docs/trunk/english_us/user_guide/ChangeLog 2008-08-01 14:25:30 UTC (rev 8961)
+++ docs/trunk/english_us/user_guide/ChangeLog 2008-08-01 14:28:45 UTC (rev 8962)
@@ -1,5 +1,17 @@
2008-08-01 Stephan Holl <stephan at keto>
+ * help_and_support_screenies/Makefile: added clean-target
+ * working_with_vector.tex: started to update the
+ layer-properties-dialog-description according to the
+ SVN-trunk-implemenation
+ * working_with_ogc.tex, working_with_projections.tex,
+ working_with_raster.tex: added FIXME-notes to easier find the
+ parts where to include new images
+2008-08-01 Stephan Holl <stephan at keto>
* operation_system_icons/*.eps: Deleted. We do not want generated
files in SVN, the Makefile generates them
Modified: docs/trunk/english_us/user_guide/help_and_support_screenies/Makefile
--- docs/trunk/english_us/user_guide/help_and_support_screenies/Makefile 2008-08-01 14:25:30 UTC (rev 8961)
+++ docs/trunk/english_us/user_guide/help_and_support_screenies/Makefile 2008-08-01 14:28:45 UTC (rev 8962)
@@ -38,5 +38,5 @@
#convert -geometry 300x -depth 1 $< $@
# convert $< $@
-#clean:
-# rm -f *.bak *~ *.pdf $(PNG) $(JPG)
+clean:
+ rm -f *.bak *~ *.pdf $(PNG) $(JPG)
Modified: docs/trunk/english_us/user_guide/working_with_ogc.tex
--- docs/trunk/english_us/user_guide/working_with_ogc.tex 2008-08-01 14:25:30 UTC (rev 8961)
+++ docs/trunk/english_us/user_guide/working_with_ogc.tex 2008-08-01 14:28:45 UTC (rev 8962)
@@ -138,6 +138,7 @@
Your screen should now look a bit like Figure \ref{fig:connection_wms}, which shows the
response provided by the NASA JPL OnEarth WMS server.
+% FIXME
% \begin{figure}[ht]
%\begin{figure}[ht]
% \begin{center}
@@ -404,6 +405,7 @@
\item Wait patiently for the features to appear
\end{enumerate}
+% FIXME
%\begin{figure}[ht]
% \begin{center}
% \caption{Adding a WFS layer}\label{fig:wfs_dmsolutions}
Modified: docs/trunk/english_us/user_guide/working_with_projections.tex
--- docs/trunk/english_us/user_guide/working_with_projections.tex 2008-08-01 14:25:30 UTC (rev 8961)
+++ docs/trunk/english_us/user_guide/working_with_projections.tex 2008-08-01 14:28:45 UTC (rev 8962)
@@ -67,6 +67,7 @@
The Projection tab of the \dialog{Project Properties} dialog contains four important components as numbered in Figure
\ref{fig:projections} and described below.
+% FIXME
%\begin{figure}[ht]
% \begin{center}
% \caption{Projection Dialog (GNU/Linux)}\label{fig:projections}\smallskip
@@ -117,6 +118,7 @@
database. In addition to your projections, this database contains your spatial
bookmarks and other custom data.
+% FIXME
%\begin{figure}[ht]
% \begin{center}
% \caption{Custom Projection Dialog (OS
Modified: docs/trunk/english_us/user_guide/working_with_raster.tex
--- docs/trunk/english_us/user_guide/working_with_raster.tex 2008-08-01 14:25:30 UTC (rev 8961)
+++ docs/trunk/english_us/user_guide/working_with_raster.tex 2008-08-01 14:28:45 UTC (rev 8962)
@@ -59,7 +59,7 @@
To view and set the \dropmenuopt{properties} for a raster layer, right click on the layer
name. This displays the raster layer context menu that includes a number of
items that allow you to:\index{raster layers!context menu}
+% FIXME
%\begin{figure}[ht]
% \begin{center}
% \caption{Raster context menu}\label{fig:raster_contextmenu}\smallskip
@@ -88,6 +88,7 @@
Properties} dialog. There are five
tabs on the dialog: \tab{Symbology}, \tab{General}, \tab{Metadata}, \tab{Pyramids} and \tab{Histogram}.
+% FIXME
%\begin{figure}[h]
% \begin{center}
% \caption{Raster Layers Properties
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2008-08-01 14:25:30 UTC (rev 8961)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2008-08-01 14:28:45 UTC (rev 8962)
@@ -71,6 +71,7 @@
You can also select the Encoding type for the shapefile if desired.
+% FIXME: new screenie here
%\begin{figure}[ht]
% \begin{center}
% \caption{Open an OGR Supported Vector Layer Dialog}\label{fig:openshapefile}\smallskip
@@ -81,6 +82,7 @@
Selecting a shapefile from the list and clicking \button{Open} loads it into QGIS. Figure
\ref{fig:loadedshapefile} shows QGIS after loading the \filename{alaska.shp} file.
%\begin{figure}[ht]
% \begin{center}
% \caption{QGIS with Shapefile of Alaska loaded}\label{fig:loadedshapefile}\smallskip
@@ -352,8 +354,20 @@
ogrinfo --formats | grep -i post
\end{verbatim}
-\subsubsection{Improving Performance}\label{label_improve}
+If you like to use PostgreSQLs \filename{COPY}-command instead of the default
+\filename{INSERT INTO} method you can export the following
+environment-variable (at least available on \nix and \osx):
+\begin{verbatim}
+ export PG_USE_COPY=YES
+\end{verbatim}
+\filename{ogr2ogr} does not create spatial indexes like \filename{shp2pgsl}
+does. You need to create them manually using the normal SQL-command
+\filename{CREATE INDEX} afterwards as an extra step (as described in the next
+section \ref{label_improve}).
+\subsubsection{Improving Performance} \label{label_improve}
Retrieving features from a PostgreSQL database can be time consuming,
especially over a network. You can improve the drawing performance of
PostgreSQL layers by ensuring that a \index{PostGIS!spatial index} spatial
@@ -415,7 +429,7 @@
vector features are displayed. Currently the following renderers
are available:
-\begin{description}
+\begin{description}
\item[Single symbol] - a single style is applied to every
object in the layer.\index{vector layers!renderers!single symbol}
\item[Graduated symbol] - objects within the layer are
@@ -432,8 +446,9 @@
To change the symbology for a layer, simply double click on its legend
entry and the vector \dialog{Layer Properties} dialog will be
-shown.\index{symbology!changing}.
+shown.\index{symbology!changing}
%\begin{figure}[H]
% \begin{center}
% \caption{Vector Layer Properties
@@ -442,19 +457,42 @@
%\end{center}
%\end{figure}
-Since \usertext{version v0.9} there is a function to use image files stored on
-your computer as fill pattern for vector layers.
+% FIXME: outdated
+% Since \usertext{version v0.9} there is a function to use image files stored on
+% your computer as fill pattern for vector layers.
+\minisec{Style Options} \label{sec:style_options} \index{vector layers!styles}
+Within this dialog you can style your vector layer. Depending on the selected
+rendering option you have the possibility to also classify your mapfeatures.
+At least the following styling options apply for nearly all renderes:
+ \item[Outline style] - pen-style for your outline of your feature. you can
+ also set this to 'no pen'.
+ \item[Outline color] - color of the ouline of your feature
+ \item[Outline width] - width of your features
+ \item[Fill color] - fill-color of your features.
+ \item[Fill style] - Style for filling. Beside the given brushes you can
+ select \selectstring{Fill style}{? texture} and click the \browsebutton
+ button for selecting your own fill-style. Currently the fileformats
+ \filename{*.jpeg, *.xpm, and *.png} are supported.
+\end{description}
+Once you have styled your layer you also could save your layer-style to a
+separate file (with \filename{*.qml}-ending).
+Therefor use the button \button{Save Style \ldots}. No need to say that
+\button{Load Style \ldots} loads your saved layer-style-file.
\minisec{Vector transparency} \label{sec:vect_transparency} \index{vector layers!transparency}
QGIS \CURRENT allows to set a transparency for every vector layer. This can be done with
-the slider right below the legend type (see fig. \ref{fig:vector_symbology}).
+the slider \slider{Transparency}{0}{20mm} inside the tab \tab{symbology} (see fig. \ref{fig:vector_symbology}).
This is very useful for overlaying several vector layers.
\subsubsection{General Tab}
The \tab{General} tab is essentially like that of the raster dialog. It allows you
to change the display name, set scale dependent rendering options, create a spatial
index of the vector file (only for OGR supported formats and PostGIS) and view or
-change the projection.
+change the projection of the specific vetor layer.
The \button{Query Builder} button allows you to create a subset of the features
in the layer - but this button currently only is available when you open the
@@ -471,7 +509,7 @@
\subsubsection{Labels Tab}
The \tab{Labels} tab allows you to enable labeling features and control a number of
-options related to placement, style and buffering.
+options related to fonts, placement, style, alignment and buffering.
We will illustrate this by labelling the lakes shapefile of the
\filename{qgis\_example\_dataset}:
@@ -484,7 +522,7 @@
\item Click on the \tab{Labels} tab.
\item Check the \checkbox{Display labels} checkbox to enable labeling.
\item Choose the field to label with.
- We'll use \selectstring{Field containing labels}{NAMES}.
+ We'll use \selectstring{Field containing label}{NAMES}.
\item Enter a default for lakes that have no name. The default label will be
used each time QGIS encounters a lake with no value in the \guilabel{NAMES} field.
\item Click \button{Apply}.
@@ -493,21 +531,24 @@
Now we have labels. How do they look? They are probably too big and poorly
placed in relation to the marker symbol for the lakes.
-Click on the \tab{Font Style} tab and use the \button{Font} and \button{Color}
-buttons to set the font and color.
+Select the \tab{Font} entry and use the \button{Font} and \button{Color}
+buttons to set the font and color. You can also change the angle and the
+placement of the text-label.
To change the position of the font relative to the feature:
\begin{enumerate}
-\item Click on the \tab{Font Alignment} tab.
+\item Click on the \tab{Font} entry.
\item Change the placement by selecting one of the radio buttons
in the \classname{Placement} group. To fix our labels, choose the
\radiobuttonon{Right} radio button.
+\item the \classname{Font size units} allows you to select between
+\radiobuttonon{Points} or \radiobuttonon{Map units}.
\item Click \button{Apply} to see your changes without closing the dialog.
\end{enumerate}
Things are looking better, but the labels are still too close to the marker. To
-fix this we can use the options on the \tab{Position} tab. Here we can add
+fix this we can use the options on the \tab{Position} entry. Here we can add
offsets for the X and Y directions. Adding an X offset of 5 will move our
labels off the marker and make them more readable. Of course if your marker
symbol or font is larger, more of an offset will be required.
@@ -520,22 +561,26 @@
\item Click the \tab{Buffer} tab.
\item Click the \checkbox{Buffer Labels?} checkbox to enable buffering.
\item Choose a size for the buffer using the spin box.
-\item Choose a color by clicking on \button{Colour} and choosing your
- favorite from the color selector.
+\item Choose a color by clicking on \button{Color} and choosing your
+ favorite from the color selector. You can also set some transparency for the
+ buffer if you prefer.
\item Click \button{Apply} to see if you like the changes.
\end{enumerate}
If you aren't happy with the results, tweak the settings and then test again
by clicking \button{Apply}.
-A buffer of 2 points seems to give a good result.
+A buffer of 1 points seems to give a good result.
Notice you can also specify the buffer size in map units if that works out
better for you.
-The remaining tabs on the \tab{Label} tab allow you control the appearance of the
-labels using attributes stored in the layer. The \tab{Data} tabs allow you to
+The remaining entries inside the \tab{Label} tab allow you control the appearance of the
+labels using attributes stored in the layer. The entries beginning with \tab{Data defined} allow you to
set all the parameters for the labels using fields in the layer.
+Not that the \tab{Label} tab provides a \classname{preview-box} where your
+selected label is shown.
\subsubsection{Actions Tab}\index{actions}\label{label_actions}
QGIS provides the ability to perform an action based on the attributes of a
@@ -570,7 +615,6 @@
\item \usertext{konqueror http://www.google.com/search?q=\%\%}
\end{itemize}
In the first example, the web browser konqueror is invoked and passed a URL to
open. The URL performs a Google search on the value of the \usertext{nam} field
from our vector layer. Note that the application or script called by the
@@ -631,7 +675,7 @@
where \usertext{qgis} is the search term. Armed with this information, we can
proceed:
-\begin{itemize}
+\begin{enumerate}
\item Make sure the \filename{lakes} layer is loaded.
\item Open the \dialog{Layer Properties} dialog by double-clicking on the layer in the
legend or right-click and choose \dropmenuopt{Properties} from the popup menu.
@@ -646,12 +690,12 @@
\item The text in the \guilabel{Action} field should now look like this:\\
\usertext{firefox \url{http://google.com/search?q=}}
\item Click on the drop-down box containing the field names for the
- \usertext{lakes} layer. It's located just to the right of the
+ \usertext{lakes} layer. It's located just to the left of the
\button{Insert Field} button.
\item From the drop-down box, select \selectstring{}{NAMES} and click \button{Insert Field}.
\item Your action text now looks like this:\\ \usertext{firefox
\url{http://google.com/search?q=\%NAMES}}
-\end{itemize}
+\end{enumerate}
This completes the action and it is ready to use. The final text of the action
should look like this:
@@ -664,6 +708,7 @@
of interest. Make sure the \filename{lakes} layer is active and identify a
lake. In the result box you'll now see that our action is visible:
+% FIXME: needs to be replaced
%\begin{figure}[H]
% \begin{center}
% \caption{Select feature and choose action}\label{fig:identify_action}\smallskip
@@ -688,6 +733,7 @@
actions to launch web-based reports for an attribute field or combination of
fields, specifying them in the same way we did in our Google search example.
+% FIXME: Note for SH: please continue editing this file here (SH:20080801)
\subsection{Editing}\index{editing}
QGIS supports basic capabilities for editing spatial data. Before reading any
