[QGIS Commit] r8976 - in trunk/qgis: python/core src/app src/core src/core/raster src/core/symbology
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 2 03:54:32 EDT 2008
Author: timlinux
Date: 2008-08-02 03:54:31 -0400 (Sat, 02 Aug 2008)
New Revision: 8976
   trunk/qgis/python/core/qgis.sip
   trunk/qgis/python/core/qgssymbol.sip
   trunk/qgis/src/app/qgssinglesymboldialog.cpp
   trunk/qgis/src/core/qgis.h
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
   trunk/qgis/src/core/symbology/qgssymbol.cpp
   trunk/qgis/src/core/symbology/qgssymbol.h
Allow point symbol sizes to be specifed in double format and allow symbols smaller than 3. Added some constants in qgis.h to default and minimum allowable point sizes.
Modified: trunk/qgis/python/core/qgis.sip
--- trunk/qgis/python/core/qgis.sip	2008-08-02 05:47:37 UTC (rev 8975)
+++ trunk/qgis/python/core/qgis.sip	2008-08-02 07:54:31 UTC (rev 8976)
@@ -108,3 +108,11 @@
    *  or user (~/.qgis.qgis.db) defined projection. */
   const int USER_PROJECTION_START_ID;
+  // Constants for point symbols
+  /** Magic number that determines the minimum allowable point size for point symbols */
+  const float MINIMUM_POINT_SIZE;
+  const float DEFAULT_POINT_SIZE;
Modified: trunk/qgis/python/core/qgssymbol.sip
--- trunk/qgis/python/core/qgssymbol.sip	2008-08-02 05:47:37 UTC (rev 8975)
+++ trunk/qgis/python/core/qgssymbol.sip	2008-08-02 07:54:31 UTC (rev 8976)
@@ -51,9 +51,9 @@
     /**Get point symbol*/
     virtual QString pointSymbolName() const;
     /**Set size*/
-    virtual void setPointSize(int s);
+    virtual void setPointSize(double s);
     /**Get size*/
-    virtual int pointSize() const;
+    virtual double pointSize() const;
     //! Destructor
     virtual ~QgsSymbol();
Modified: trunk/qgis/src/app/qgssinglesymboldialog.cpp
--- trunk/qgis/src/app/qgssinglesymboldialog.cpp	2008-08-02 05:47:37 UTC (rev 8975)
+++ trunk/qgis/src/app/qgssinglesymboldialog.cpp	2008-08-02 07:54:31 UTC (rev 8976)
@@ -184,7 +184,7 @@
   connect(mLabelEdit, SIGNAL(textChanged(const QString&)), this, SLOT(resendSettingsChanged()));
   connect (lstSymbols,SIGNAL(currentItemChanged ( QListWidgetItem * , QListWidgetItem * )),
       this, SLOT (symbolChanged (QListWidgetItem * , QListWidgetItem * )));
-  connect(mPointSizeSpinBox, SIGNAL(valueChanged(int)), this, SLOT(resendSettingsChanged()));
+  connect(mPointSizeSpinBox, SIGNAL(valueChanged(double)), this, SLOT(resendSettingsChanged()));
   connect(mRotationClassificationComboBox, SIGNAL(currentIndexChanged(const QString &)),
   connect(mScaleClassificationComboBox, SIGNAL(currentIndexChanged(const QString &)),
Modified: trunk/qgis/src/core/qgis.h
--- trunk/qgis/src/core/qgis.h	2008-08-02 05:47:37 UTC (rev 8975)
+++ trunk/qgis/src/core/qgis.h	2008-08-02 07:54:31 UTC (rev 8976)
@@ -133,6 +133,15 @@
   const int USER_PROJECTION_START_ID=100000;
+// Constants for point symbols
+  const float MINIMUM_POINT_SIZE=0.1;
+  const float DEFAULT_POINT_SIZE=2.0;
 // FIXME: also in qgisinterface.h
 #ifndef QGISEXTERN
 #ifdef WIN32
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-02 05:47:37 UTC (rev 8975)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-02 07:54:31 UTC (rev 8976)
@@ -3658,6 +3658,8 @@
   // Note: Make sure the raster is not opened in write mode
   // in order to force overviews to be written to a separate file.
+  // Otherwise reoopen it in read/write mode to stick overviews
+  // into the same file (if supported)
Modified: trunk/qgis/src/core/symbology/qgssymbol.cpp
--- trunk/qgis/src/core/symbology/qgssymbol.cpp	2008-08-02 05:47:37 UTC (rev 8975)
+++ trunk/qgis/src/core/symbology/qgssymbol.cpp	2008-08-02 07:54:31 UTC (rev 8976)
@@ -40,7 +40,7 @@
       mLabel(label),
       mType(t),
       mPointSymbolName( "hard:circle" ),
-      mPointSize( 3 ),
+      mPointSize( DEFAULT_POINT_SIZE ),
       mPointSymbolImage(1,1, QImage::Format_ARGB32_Premultiplied),
       mWidthScale(1.0),
       mCacheUpToDate( false ),
@@ -58,7 +58,7 @@
       mPen( c ),
       mBrush( c ),
-      mPointSize( 3 ),
       mWidthScale(1.0),
@@ -69,7 +69,7 @@
 QgsSymbol::QgsSymbol()
     : mPointSymbolName( "hard:circle" ),
-      mPointSize( 3 ),
       mWidthScale(1.0),
@@ -83,7 +83,7 @@
     : mPen( c ),
       mBrush( c ),
-      mPointSize( 3 ),
       mWidthScale(1.0),
@@ -227,17 +227,17 @@
     return mPointSymbolName;
-void QgsSymbol::setPointSize(int s)
+void QgsSymbol::setPointSize(double s)
-    if ( s < 3 )
-	mPointSize = 3;
-    else
-    	mPointSize = s;
+  if ( s < MINIMUM_POINT_SIZE )
+    mPointSize = MINIMUM_POINT_SIZE;
+  else
+    mPointSize = s;
-    mCacheUpToDate = mCacheUpToDate2 = false;
+  mCacheUpToDate = mCacheUpToDate2 = false;
-int QgsSymbol::pointSize() const
+double QgsSymbol::pointSize() const
     return mPointSize;
@@ -343,12 +343,12 @@
     pen.setColor ( selectionColor );
     QBrush brush = mBrush;
-    preRotateImage = QgsMarkerCatalogue::instance()->imageMarker ( mPointSymbolName, (int)(mPointSize * scale * widthScale * rasterScaleFactor),
+    preRotateImage = QgsMarkerCatalogue::instance()->imageMarker ( mPointSymbolName, (float)(mPointSize * scale * widthScale * rasterScaleFactor),
        pen, mBrush );
   else
        pen, mBrush );
@@ -517,7 +517,7 @@
     if ( !  psizenode.isNull() )
         QDomElement psizeelement = psizenode.toElement();
-        setPointSize( psizeelement.text().toInt() );
+        setPointSize( psizeelement.text().toFloat() );
     mRotationClassificationField = -1;
Modified: trunk/qgis/src/core/symbology/qgssymbol.h
--- trunk/qgis/src/core/symbology/qgssymbol.h	2008-08-02 05:47:37 UTC (rev 8975)
+++ trunk/qgis/src/core/symbology/qgssymbol.h	2008-08-02 07:54:31 UTC (rev 8976)
@@ -83,9 +83,9 @@
     /**Set size*/
     /**Get size*/
     //! Destructor
@@ -145,7 +145,7 @@
     /* Point symbol name */
     QString mPointSymbolName;
     /* Point size */
-    int mPointSize;
+    double mPointSize;
     /* TODO Because for printing we always need a symbol without oversampling but with line width scale,
      *      we keep also separate picture with line width scale */
More information about the QGIS-commit mailing list
