[QGIS Commit] r9019 - in trunk/qgis/src: app core
svn_qgis at osgeo.org
Thu Aug 7 05:54:28 EDT 2008
Author: jef
Date: 2008-08-07 05:54:28 -0400 (Thu, 07 Aug 2008)
New Revision: 9019
trunk/qgis/src/app/qgsbookmarks.cpp
trunk/qgis/src/app/qgscustomprojectiondialog.cpp
trunk/qgis/src/core/qgsmaplayer.cpp
fix qml support for non-file data sources
Modified: trunk/qgis/src/app/qgsbookmarks.cpp
--- trunk/qgis/src/app/qgsbookmarks.cpp 2008-08-07 09:52:57 UTC (rev 9018)
+++ trunk/qgis/src/app/qgsbookmarks.cpp 2008-08-07 09:54:28 UTC (rev 9019)
@@ -251,7 +251,7 @@
int rc;
rc = sqlite3_open(QgsApplication::qgisUserDbFilePath().toUtf8().data(), &db);
- if(rc)
+ if(rc!=SQLITE_OK)
std::cout << "Can't open database: " << sqlite3_errmsg(db) << std::endl;
Modified: trunk/qgis/src/app/qgscustomprojectiondialog.cpp
--- trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2008-08-07 09:52:57 UTC (rev 9018)
+++ trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2008-08-07 09:54:28 UTC (rev 9019)
@@ -105,14 +105,13 @@
int myResult;
//check the db is available
myResult = sqlite3_open(QgsApplication::qgisUserDbFilePath().toUtf8().data(), &myDatabase);
- if(myResult)
+ if(myResult!=SQLITE_OK)
std::cout << "Can't open database: " << sqlite3_errmsg(myDatabase) << std::endl;
// XXX This will likely never happen since on open, sqlite creates the
// database if it does not exist.
- assert(myResult == 0);
+ assert(myResult == SQLITE_OK);
// Set up the query to retrieve the projection information needed to populate the PROJECTION list
QString mySql = "select * from tbl_projection order by name";
myResult = sqlite3_prepare(myDatabase, mySql.toUtf8(), mySql.length(), &myPreparedStatement, &myTail);
@@ -140,14 +139,13 @@
int myResult;
- if(myResult)
// Set up the query to retrieve the projection information needed to populate the ELLIPSOID list
QString mySql = "select * from tbl_ellipsoid order by name";
@@ -184,12 +182,12 @@
QString myName;
- if(myResult)
QString mySql = "delete from tbl_srs where srs_id='" + mCurrentRecordId + "'";
@@ -244,12 +242,12 @@
long myRecordCount=0;
- if(myResult)
QString mySql = "select count(*) from tbl_srs";
@@ -279,12 +277,12 @@
QString myName;
- if(myResult)
QString mySql = "select name from tbl_projection where acronym='" + theProjectionFamilyAcronym + "'";
@@ -310,12 +308,12 @@
QString myName;
- if(myResult)
QString mySql = "select name from tbl_ellipsoid where acronym='" + theEllipsoidAcronym + "'";
@@ -341,12 +339,12 @@
QString myName;
- if(myResult)
QString mySql = "select acronym from tbl_projection where name='" + theProjectionFamilyName + "'";
@@ -372,12 +370,12 @@
QString myName;
- if(myResult)
QString mySql = "select acronym from tbl_ellipsoid where name='" + theEllipsoidName + "'";
@@ -406,12 +404,12 @@
int myResult;
- if(myResult)
QString mySql = "select * from tbl_srs order by srs_id limit 1";
@@ -484,12 +482,12 @@
int myResult;
- if(myResult)
QString mySql = "select * from tbl_srs where srs_id < " + mCurrentRecordId + " order by srs_id desc limit 1";
@@ -563,15 +561,14 @@
int myResult;
- if(myResult)
QString mySql = "select * from tbl_srs where srs_id > " + mCurrentRecordId + " order by srs_id asc limit 1";
#ifdef QGISDEBUG
std::cout << "Query to move next:" << mySql.toLocal8Bit().data() << std::endl;
@@ -639,12 +636,12 @@
int myResult;
- if(myResult)
QString mySql = "select * from tbl_srs order by srs_id desc limit 1";
@@ -868,7 +865,7 @@
<< std::endl;
#ifdef QGISDEBUG
std::cout << "Update or insert sql \n" << mySql.toLocal8Bit().data() << std::endl;
@@ -993,9 +990,8 @@
QString mySql = "select parameters from tbl_projection name where name='"+theText+"'";
#ifdef QGISDEBUG
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2008-08-07 09:52:57 UTC (rev 9018)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2008-08-07 09:54:28 UTC (rev 9019)
@@ -434,7 +434,7 @@
QgsDebugMsg( QString("Trying to load style for \"%1\" from \"%2\"").arg(theURI).arg(db) );
myResult = sqlite3_open(db.toUtf8().data(), &myDatabase);
- if (!myResult)
+ if (myResult!=SQLITE_OK)
return false;
@@ -610,7 +610,7 @@
int myResult;
myResult = sqlite3_open( QDir( QgsApplication::qgisSettingsDirPath() ).absoluteFilePath( "qgis.qmldb").toUtf8().data(), &myDatabase);
- if (myResult)
return tr("User database could not be opened.");
