[QGIS Commit] r9026 - in trunk/qgis: python/core src/core
src/core/raster
svn_qgis at osgeo.org
Thu Aug 7 18:18:47 EDT 2008
Author: timlinux
Date: 2008-08-07 18:18:47 -0400 (Thu, 07 Aug 2008)
New Revision: 9026
trunk/qgis/python/core/qgsmaplayer.sip
trunk/qgis/python/core/qgsrasterlayer.sip
trunk/qgis/python/core/qgsvectorlayer.sip
trunk/qgis/src/core/qgsmaplayer.cpp
trunk/qgis/src/core/qgsmaplayer.h
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/core/qgsvectorlayer.h
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
Use readXml, writeXml instead of readXML_,writeXML_
Modified: trunk/qgis/python/core/qgsmaplayer.sip
--- trunk/qgis/python/core/qgsmaplayer.sip 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/python/core/qgsmaplayer.sip 2008-08-07 22:18:47 UTC (rev 9026)
@@ -114,7 +114,7 @@
The DOM node corresponds to a DOM document project file XML element read
by QgsProject.
- This, in turn, calls readXML_(), which is over-rideable by sub-classes so
+ This, in turn, calls readXml(), which is over-rideable by sub-classes so
that they can read their own specific state from the given DOM node.
Invoked by QgsProject::read().
@@ -131,7 +131,7 @@
The DOM node corresponds to a DOM document project file XML element to be
written by QgsProject.
- This, in turn, calls writeXML_(), which is over-rideable by sub-classes so
+ This, in turn, calls writeXml(), which is over-rideable by sub-classes so
that they can write their own specific state to the given DOM node.
Invoked by QgsProject::write().
@@ -218,12 +218,12 @@
/** called by readXML(), used by children to read state specific to them from
project files.
- virtual bool readXML_( QDomNode & layer_node );
+ virtual bool readXml( QDomNode & layer_node );
/** called by writeXML(), used by children to write state specific to them to
project files.
- virtual bool writeXML_( QDomNode & layer_node, QDomDocument & document );
+ virtual bool writeXml( QDomNode & layer_node, QDomDocument & document );
/** debugging member - invoked when a connect() is made to this object */
void connectNotify( const char * signal );
Modified: trunk/qgis/python/core/qgsrasterlayer.sip
--- trunk/qgis/python/core/qgsrasterlayer.sip 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/python/core/qgsrasterlayer.sip 2008-08-07 22:18:47 UTC (rev 9026)
@@ -508,7 +508,7 @@
Called by QgsMapLayer::readXML().
- /* virtual */ bool readXML_( QDomNode & layer_node );
+ /* virtual */ bool readXml( QDomNode & layer_node );
@@ -519,7 +519,7 @@
Called by QgsMapLayer::writeXML().
- /* virtual */ bool writeXML_( QDomNode & layer_node, QDomDocument & doc );
+ /* virtual */ bool writeXml( QDomNode & layer_node, QDomDocument & doc );
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/python/core/qgsvectorlayer.sip 2008-08-07 22:18:47 UTC (rev 9026)
@@ -94,12 +94,12 @@
/** reads vector layer specific state from project file DOM node.
* @note Called by QgsMapLayer::readXML().
/** write vector layer specific state to project file DOM node.
* @note Called by QgsMapLayer::writeXML().
- virtual bool writeXML_( QDomNode & layer_node, QDomDocument & doc );
+ virtual bool writeXml( QDomNode & layer_node, QDomDocument & doc );
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2008-08-07 22:18:47 UTC (rev 9026)
@@ -157,7 +157,7 @@
mSRS->readXML(srsNode);
// now let the children grab what they need from the DOM node.
- if (!readXML_( layer_node ))
+ if (!readXml( layer_node ))
return false;
@@ -213,12 +213,12 @@
} // void QgsMapLayer::readXML
-bool QgsMapLayer::readXML_( QDomNode & layer_node )
+bool QgsMapLayer::readXml( QDomNode & layer_node )
// NOP by default; children will over-ride with behavior specific to them
return true;
-} // void QgsMapLayer::readXML_
+} // void QgsMapLayer::readXml
@@ -279,18 +279,18 @@
layer_node.appendChild( maplayer );
- return writeXML_( maplayer, document );
+ return writeXml( maplayer, document );
} // bool QgsMapLayer::writeXML
-bool QgsMapLayer::writeXML_( QDomNode & layer_node, QDomDocument & document )
+bool QgsMapLayer::writeXml( QDomNode & layer_node, QDomDocument & document )
return true;
-} // void QgsMapLayer::writeXML_
+} // void QgsMapLayer::writeXml
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/src/core/qgsmaplayer.h 2008-08-07 22:18:47 UTC (rev 9026)
@@ -128,7 +128,7 @@
by QgsProject.
@@ -145,7 +145,7 @@
@@ -289,12 +289,12 @@
project files.
project files.
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2008-08-07 22:18:47 UTC (rev 9026)
@@ -2027,9 +2027,9 @@
-bool QgsVectorLayer::readXML_( QDomNode & layer_node )
+bool QgsVectorLayer::readXml( QDomNode & layer_node )
- QgsDebugMsg(QString("Datasource in QgsVectorLayer::readXML_: ") + mDataSource.toLocal8Bit().data());
+ QgsDebugMsg(QString("Datasource in QgsVectorLayer::readXml: ") + mDataSource.toLocal8Bit().data());
// process the attribute actions
mActions->readXML(layer_node);
@@ -2163,7 +2163,7 @@
return mValid; // should be true if read successfully
-} // void QgsVectorLayer::readXML_
+} // void QgsVectorLayer::readXml
@@ -2253,7 +2253,7 @@
-/* virtual */ bool QgsVectorLayer::writeXML_( QDomNode & layer_node,
+/* virtual */ bool QgsVectorLayer::writeXml( QDomNode & layer_node,
// first get the layer element so that we can append the type attribute
@@ -2406,7 +2406,7 @@
return true;
-} // bool QgsVectorLayer::writeXML_
+} // bool QgsVectorLayer::writeXml
int QgsVectorLayer::findFreeId()
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2008-08-07 22:18:47 UTC (rev 9026)
@@ -160,12 +160,12 @@
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-08-07 22:18:47 UTC (rev 9026)
@@ -4031,7 +4031,7 @@
</rasterproperties>
</maplayer>
-bool QgsRasterLayer::readXML_( QDomNode & layer_node )
+bool QgsRasterLayer::readXml( QDomNode & layer_node )
//! @NOTE Make sure to read the file first so stats etc are initialised properly!
@@ -4281,11 +4281,11 @@
return true;
-} // QgsRasterLayer::readXML_( QDomNode & layer_node )
+} // QgsRasterLayer::readXml( QDomNode & layer_node )
-/* virtual */ bool QgsRasterLayer::writeXML_( QDomNode & layer_node,
+/* virtual */ bool QgsRasterLayer::writeXml( QDomNode & layer_node,
@@ -4647,7 +4647,7 @@
return true;
-} // bool QgsRasterLayer::writeXML_
+} // bool QgsRasterLayer::writeXml
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-08-07 22:14:56 UTC (rev 9025)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-08-07 22:18:47 UTC (rev 9026)
@@ -884,7 +884,7 @@
@@ -895,7 +895,7 @@
private:
