[QGIS Commit] r9043 - in trunk/qgis/src/plugins/dxf2shp_converter: . dxflib/src
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Aug 10 14:25:59 EDT 2008
Author: jef
Date: 2008-08-10 14:25:58 -0400 (Sun, 10 Aug 2008)
New Revision: 9043
   trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt
   trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp
fix dxf2shp plugin
Modified: trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt
--- trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt	2008-08-09 12:39:21 UTC (rev 9042)
+++ trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt	2008-08-10 18:25:58 UTC (rev 9043)
@@ -16,10 +16,6 @@
 SET (dxf2shpconverter_MOC_HDRS
      dxf2shpconverter.h
      dxf2shpconvertergui.h
-     builder.h
-     getInsertions.h
-     dxflib/src/dl_dxf.h
-     dxflib/src/dl_writer_ascii.h
 SET (dxf2shpconverter_RCCS  dxf2shpconverter.qrc)
Modified: trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp	2008-08-09 12:39:21 UTC (rev 9042)
+++ trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp	2008-08-10 18:25:58 UTC (rev 9043)
@@ -225,21 +225,23 @@
       SHPObject	*psShape;
       int dim = polyVertex.size();
-      double xv[dim];
-      double yv[dim];
-      double zv[dim];
+      double *xv = new double[dim];
+      double *yv = new double[dim];
+      double *zv = new double[dim];
       for (int i=0; i < dim; i++)
         xv[i] = polyVertex[i].x;
         yv[i] = polyVertex[i].y;
         zv[i] = polyVertex[i].z;
-      psShape = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL,
-          dim, xv, yv, zv, NULL  );
+      psShape = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL, dim, xv, yv, zv, NULL  );
+      delete [] xv;
+      delete [] yv;
+      delete [] zv;
       shpObjects.push_back(psShape);
@@ -363,9 +365,9 @@
   SHPObject	*psShape;
   int dim = arcPoints.size();
-  double xv[dim];
-  double yv[dim];
-  double zv[dim];
@@ -375,9 +377,12 @@
+  delete [] xv;
+  delete [] yv;
+  delete [] zv;
   fetchedprims++;
@@ -427,9 +432,9 @@
   SHPObject	*psShape;
   int dim = circlePoints.size();
-  double xv[dim];
-  double yv[dim];
-  double zv[dim];
@@ -439,9 +444,12 @@
+  delete [] xv;
+  delete [] yv;
+  delete [] zv;
   fetchedprims++;
@@ -502,9 +510,9 @@
     SHPObject	*psObject;
-    double xv[dim];
-    double yv[dim];
-    double zv[dim];
@@ -514,9 +522,12 @@
-    psObject = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL,
+    psObject = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL, dim, xv, yv, zv, NULL  );
+    delete [] xv;
+    delete [] yv;
+    delete [] zv;
     shpObjects.push_back(psObject);
     polyVertex.clear();
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp	2008-08-09 12:39:21 UTC (rev 9042)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp	2008-08-10 18:25:58 UTC (rev 9043)
@@ -25,12 +25,9 @@
-#if _MSC_VER > 1000
-#pragma once
-#endif // _MSC_VER > 1000
+#include <cstdio>
+#include <cstring>
-#include <stdio.h>
 #include "dl_writer_ascii.h"
 #include "dl_exception.h"
More information about the QGIS-commit mailing list
