[QGIS Commit] r9066 -
branches/advanced_printing_branch/src/app/composer
svn_qgis at osgeo.org
Sat Aug 16 11:09:21 EDT 2008
Author: mhugent
Date: 2008-08-16 11:09:21 -0400 (Sat, 16 Aug 2008)
New Revision: 9066
branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp
Don't call cache() function in composer map from paint function because of stability problems with Qt>=4.4.0
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp 2008-08-16 12:57:53 UTC (rev 9065)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp 2008-08-16 15:09:21 UTC (rev 9066)
@@ -126,6 +126,11 @@
void QgsComposerMap::cache ( void )
+ if(mPreviewMode == Rectangle)
+ return;
int w = rect().width() * horizontalViewScaleFactor();
int h = rect().height() * horizontalViewScaleFactor();
@@ -151,9 +156,6 @@
draw( &p, mExtent, QSize(w, h), mCachePixmap.logicalDpiX());
p.end();
- mNumCachedLayers = mMapCanvas->layerCount();
- mCachedMapExtent = mExtent;
mCacheUpdated = true;
@@ -176,21 +178,13 @@
painter->setClipRect (thisPaintRect);
double currentScaleFactorX = horizontalViewScaleFactor();
- if( mComposition->plotStyle() == QgsComposition::Preview && mPreviewMode == Render /*&& screen resolution different than last time*/)
- if(currentScaleFactorX != mLastScaleFactorX)
- mCacheUpdated = false;
if ( mComposition->plotStyle() == QgsComposition::Preview && mPreviewMode != Rectangle)
- { // Draw from cache
- if ( !mCacheUpdated || mMapCanvas->layerCount() != mNumCachedLayers || mCachedMapExtent != mExtent)
- cache();
+ //draw cached pixmap. This function does not call cache() any more because
+ //Qt 4.4.0 and 4.4.1 have problems with recursive paintings
+ //QgsComposerMap::cache() and QgsComposerMap::update() need to be called by
+ //client functions
// Scale so that the cache fills the map rectangle
double scale = 1.0 * QGraphicsRectItem::rect().width() / mCachePixmap.width();
@@ -268,6 +262,8 @@
mExtent.setYmin(mExtent.yMin() + yMoveMapCoord);
mExtent.setYmax(mExtent.yMax() + yMoveMapCoord);
emit extentChanged();
+ cache();
+ update();
void QgsComposerMap::setSceneRect(const QRectF& rectangle)
@@ -283,6 +279,8 @@
mExtent = QgsRect(mExtent.xMin(), mExtent.yMin(), mExtent.xMax(), mExtent.yMin() + newHeight);
+ cache();
+ update();
void QgsComposerMap::setNewExtent(const QgsRect& extent)
@@ -319,6 +317,7 @@
mExtent = newExtent;
+ cache();
update();
@@ -389,7 +388,6 @@
mPreviewMode = Rectangle;
-#if 0 //leads to frequent crashes on Qt 4.4.0/4.4.1
//previewMode
QString previewMode = itemElem.attribute("previewMode");
if(previewMode == "Cache")
@@ -404,7 +402,6 @@
-#endif //0
//extent
QDomNodeList extentNodeList = itemElem.elementsByTagName("Extent");
@@ -431,6 +428,12 @@
QDomElement composerItemElem = composerItemList.at(0).toElement();
_readXML(composerItemElem, doc);
+ if(mPreviewMode != Rectangle)
+ cache();
+ update();
return true;
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp 2008-08-16 12:57:53 UTC (rev 9065)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp 2008-08-16 15:09:21 UTC (rev 9066)
@@ -111,6 +111,7 @@
mUpdatePreviewButton->setEnabled(false);
+ mComposerMap->cache();
mComposerMap->update();
@@ -291,6 +292,7 @@
mUpdatePreviewButton->setEnabled(false); //prevent crashes because of many button clicks
mComposerMap->setCacheUpdated(false);
mUpdatePreviewButton->setEnabled(true);
