[QGIS Commit] r9090 - trunk/qgis/src/core
svn_qgis at osgeo.org
Wed Aug 20 07:49:12 EDT 2008
Author: timlinux
Date: 2008-08-20 07:49:11 -0400 (Wed, 20 Aug 2008)
New Revision: 9090
trunk/qgis/src/core/qgsapplication.h
trunk/qgis/src/core/qgsattributeaction.h
trunk/qgis/src/core/qgsclipper.h
trunk/qgis/src/core/qgscontexthelp.h
trunk/qgis/src/core/qgscoordinatetransform.h
trunk/qgis/src/core/qgscsexception.h
trunk/qgis/src/core/qgsdataprovider.h
trunk/qgis/src/core/qgsdatasourceuri.h
Api documentation updates and setting grouping tag
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgsapplication.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -18,6 +18,10 @@
#include <QApplication>
+/** \ingroup core
+ * Extends QApplication to provide access to QGIS specific resources such
+ * as theme paths, database paths etc.
class CORE_EXPORT QgsApplication: public QApplication
public:
Modified: trunk/qgis/src/core/qgsattributeaction.h
--- trunk/qgis/src/core/qgsattributeaction.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgsattributeaction.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -36,8 +36,8 @@
class QDomDocument;
-/*! \class QgsAction
- * \brief Utility class that encapsulates an action and associated information
+/** \ingroup core
+ * Utility class that encapsulates an action based on vector attributes.
class CORE_EXPORT QgsAction
Modified: trunk/qgis/src/core/qgsclipper.h
--- trunk/qgis/src/core/qgsclipper.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgsclipper.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -27,14 +27,16 @@
#include <cmath>
#include <iostream>
-// The functions in this class are likely to be called from within a
-// render loop and hence need to as CPU efficient as possible.
+/** \ingroup core
+ * A class to trim lines and polygons to within a rectangular region.
+ * The functions in this class are likely to be called from within a
+ * render loop and hence need to as CPU efficient as possible.
+ * The main purpose of the functions in this class are to trim lines
+ * and polygons to lie within a rectangular region. This is necessary
+ * for drawing items to an X11 display which have a limit on the
+ * magnitude of the screen coordinates (+/- 32768, i.e. 16 bit integer).
-// The main purpose of the functions in this class are to trim lines
-// and polygons to lie within a rectangular region. This is necessary
-// for drawing items to an X11 display which have a limit on the
-// magnitude of the screen coordinates (+/- 32768, i.e. 16 bit integer).
class CORE_EXPORT QgsClipper
public:
Modified: trunk/qgis/src/core/qgscontexthelp.h
--- trunk/qgis/src/core/qgscontexthelp.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgscontexthelp.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -27,9 +27,8 @@
#ifdef Q_OS_MACX
#define QGSCONTEXTHELP_REUSE 1
#endif
- * \class QgsContextHelp
- * \brief Provides a context based help browser for a dialog.
+/** \ingroup core
+ * Provides a context based help browser for a dialog.
* The help text is stored in SQLite and accessed by a context identifier
* unique to each dialog. This is a singleton class which invokes the help
Modified: trunk/qgis/src/core/qgscoordinatetransform.h
--- trunk/qgis/src/core/qgscoordinatetransform.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgscoordinatetransform.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -36,10 +36,10 @@
typedef void* projPJ;
class QString;
-/*! \class QgsCoordinateTransform
-* \brief Class for doing transforms between two map coordinate systems.
+/** \ingroup core
+* Class for doing transforms between two map coordinate systems.
-* This class can convert map coordinates to a different spatial reference system.
+* This class can convert map coordinates to a different coordinate reference system.
* It is normally associated with a map layer and is used to transform between the
* layer's coordinate system and the coordinate system of the map canvas, although
* it can be used in a more general sense to transform coordinates.
Modified: trunk/qgis/src/core/qgscsexception.h
--- trunk/qgis/src/core/qgscsexception.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgscsexception.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -19,6 +19,9 @@
#define QGSCSEXCEPTION_H
#include "qgsexception.h"
+/** \ingroup core
+ * Custom exception class for Coordinate Reference System related exceptions.
class CORE_EXPORT QgsCsException : public QgsException
public:
Modified: trunk/qgis/src/core/qgsdataprovider.h
--- trunk/qgis/src/core/qgsdataprovider.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgsdataprovider.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -26,8 +26,8 @@
class QgsSpatialRefSys;
-/** \class QgsDataProvider
- * \brief Abstract base class for spatial data provider implementations
+/** \ingroup core
+ * Abstract base class for spatial data provider implementations.
* @author Gary E.Sherman
* This object needs to inherit from QObject to enable event
Modified: trunk/qgis/src/core/qgsdatasourceuri.h
--- trunk/qgis/src/core/qgsdatasourceuri.h 2008-08-20 11:36:43 UTC (rev 9089)
+++ trunk/qgis/src/core/qgsdatasourceuri.h 2008-08-20 11:49:11 UTC (rev 9090)
@@ -22,12 +22,10 @@
#include <QString>
-\struct QgsDataSourceURI
-\brief Structure for storing the component parts of a PostgreSQL/RDBMS datasource URI.
- This structure stores the database connection information, including host, database,
- user name, password, schema, password, and sql where clause
+/** \ingroup core
+ * Class for storing the component parts of a PostgreSQL/RDBMS datasource URI.
+ * This structure stores the database connection information, including host, database,
+ * user name, password, schema, password, and sql where clause
class CORE_EXPORT QgsDataSourceURI
