[QGIS Commit] r9096 - trunk/qgis/src/core
svn_qgis at osgeo.org
Wed Aug 20 13:39:46 EDT 2008
Author: timlinux
Date: 2008-08-20 13:39:42 -0400 (Wed, 20 Aug 2008)
New Revision: 9096
trunk/qgis/src/core/qgsdistancearea.h
trunk/qgis/src/core/qgsexception.h
trunk/qgis/src/core/qgsfeature.h
trunk/qgis/src/core/qgsfield.h
trunk/qgis/src/core/qgsgeometry.h
trunk/qgis/src/core/qgshttptransaction.h
trunk/qgis/src/core/qgslabel.h
trunk/qgis/src/core/qgslabelattributes.h
trunk/qgis/src/core/qgsline.h
trunk/qgis/src/core/qgslogger.h
trunk/qgis/src/core/qgsmaplayer.h
trunk/qgis/src/core/qgsmaplayerregistry.h
trunk/qgis/src/core/qgsmaprenderer.h
trunk/qgis/src/core/qgsmaptopixel.h
trunk/qgis/src/core/qgsmessageoutput.h
trunk/qgis/src/core/qgspoint.h
Api documentation updates and setting grouping tag
Modified: trunk/qgis/src/core/qgsdistancearea.h
--- trunk/qgis/src/core/qgsdistancearea.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsdistancearea.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -22,15 +22,15 @@
class QgsGeometry;
-General purpose distance and area calculator
-- calculations are done on ellipsoid
-- it's possible to pass points/features in any SRS, coordinates are transformed
-- two options how to use it
- + use measure() takes QgsGeometry as a parameter and calculates distance or area
- + use directly measureLine(), measurePolygon() which take list of QgsPoints
- (both cases transform the coordinates from source SRS to the ellipse coords)
-- returned values are in meters resp. square meters
+/** \ingroup core
+ * General purpose distance and area calculator.
+ * calculations are done on ellipsoid
+ * it's possible to pass points/features in any CRS, coordinates are transformed
+ * There are two options to use it
+ * + use measure() takes QgsGeometry as a parameter and calculates distance or area
+ * + use directly measureLine(), measurePolygon() which take list of QgsPoints
+ * (both cases transform the coordinates from source SRS to the ellipse coords)
+ * Returned values are in meters resp. square meters
class CORE_EXPORT QgsDistanceArea
Modified: trunk/qgis/src/core/qgsexception.h
--- trunk/qgis/src/core/qgsexception.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsexception.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -24,8 +24,8 @@
#include <QDomNode>
- Defines a qgis exception class
+/** \ingroup core
+ * Defines a qgis exception class.
class CORE_EXPORT QgsException : public std::exception
Modified: trunk/qgis/src/core/qgsfeature.h
--- trunk/qgis/src/core/qgsfeature.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsfeature.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -40,9 +40,9 @@
typedef QList<QgsFeature> QgsFeatureList;
- * @class QgsFeature - Feature attribute class.
- * Encapsulates a single feature including id and field/value.
+/** \ingroup core
+ * The feature class encapsulates a single feature including its id,
+ * geometry and a list of field/values attributes.
* @author Gary E.Sherman
Modified: trunk/qgis/src/core/qgsfield.h
--- trunk/qgis/src/core/qgsfield.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsfield.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -20,12 +20,10 @@
#include <QString>
#include <QVariant>
- \class QgsField
- \brief Class to encapsulate a field in an attribute table or data source.
- QgsField stores metadata about an attribute field, including name, type
- length, and if applicable, precision.
+/** \ingroup core
+ * Encapsulate a field in an attribute table or data source.
+ * QgsField stores metadata about an attribute field, including name, type
+ * length, and if applicable, precision.
class CORE_EXPORT QgsField
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsgeometry.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -48,7 +48,8 @@
class QgsRect;
+/** \ingroup core
+ * A geometry is the spatial representation of a feature.
* Represents a geometry with input and output in formats specified by
* (at least) the Open Geospatial Consortium (WKB / WKT), and containing
* various functions for geoprocessing of the geometry.
Modified: trunk/qgis/src/core/qgshttptransaction.h
--- trunk/qgis/src/core/qgshttptransaction.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgshttptransaction.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -27,16 +27,10 @@
class QTimer;
- \brief HTTP request/response manager that is redirect-aware.
- This class extends the Qt QHttp concept by being able to recognise
- and respond to redirection responses (e.g. HTTP code 302)
- TODO: Make it work
+/** \ingroup core
+ * HTTP request/response manager that is redirect-aware.
+ * This class extends the Qt QHttp concept by being able to recognise
+ * and respond to redirection responses (e.g. HTTP code 302)
class CORE_EXPORT QgsHttpTransaction : public QObject
Modified: trunk/qgis/src/core/qgslabel.h
--- trunk/qgis/src/core/qgslabel.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgslabel.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -42,7 +42,11 @@
typedef QMap<int, QgsField> QgsFieldMap;
-/** Render class to display labels */
+/** \ingroup core
+ * A class to render labels.
+ * Label rendering properties can be either specified directly or
+ * in most cases determined dynamically based on the value of an attribute.
class CORE_EXPORT QgsLabel
public:
Modified: trunk/qgis/src/core/qgslabelattributes.h
--- trunk/qgis/src/core/qgslabelattributes.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgslabelattributes.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -24,7 +24,8 @@
class QString;
class QColor;
-/** This class can be used to store attributes needed for label rendering.
+/** \ingroup core
+ * A class to store attributes needed for label rendering.
* Label attributes:
* border (color, width, style)
@@ -70,7 +71,7 @@
* - border color
* - border style
- * Each attribute is either se or unset.
+ * Each attribute is either set or unset.
class CORE_EXPORT QgsLabelAttributes
Modified: trunk/qgis/src/core/qgsline.h
--- trunk/qgis/src/core/qgsline.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsline.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -23,9 +23,8 @@
#include <iostream>
#include "qgspoint.h"
-/*! \class QgsLine
- * \brief A simple line object composed of a begin and end point.
+/** \ingroup core
+ * A simple line object composed of a begin and end point.
* Comparisons (==, !=) honor the direction of the line. This means that
* flipped lines with the same coordinates are not considered to be equal.
Modified: trunk/qgis/src/core/qgslogger.h
--- trunk/qgis/src/core/qgslogger.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgslogger.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -31,11 +31,17 @@
#define QgsDebugMsgLevel(str, level)
#endif
-/**QgsLogger is a class to print debug/warning/error messages to the console. The advantage of this class over std::cout, std::cerr & co. is that the output can be controlled with environment variables:
-QGIS_DEBUG is an int describing what debug messages are written to the console. If the debug level of a message is <= QGIS_DEBUG, the message is written to the console. It the variable QGIS_DEBUG is not defined, it defaults to 1 for debug mode and to 0 for release mode
-QGIS_DEBUG_FILE may contain a filename. Only the messages from this file are printed (provided they have the right debuglevel). If QGIS_DEBUG_FILE is not set, messages from all files are printed
+/** \ingroup core
+ * QgsLogger is a class to print debug/warning/error messages to the console.
+ * The advantage of this class over std::cout, std::cerr & co. is that the
+ * output can be controlled with environment variables:
+ * QGIS_DEBUG is an int describing what debug messages are written to the console.
+ * If the debug level of a message is <= QGIS_DEBUG, the message is written to the
+ * console. It the variable QGIS_DEBUG is not defined, it defaults to 1 for debug
+ * mode and to 0 for release mode
+ * QGIS_DEBUG_FILE may contain a filename. Only the messages from this file are
+ * printed (provided they have the right debuglevel). If QGIS_DEBUG_FILE is not
+ * set, messages from all files are printed
class CORE_EXPORT QgsLogger
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsmaplayer.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -34,9 +34,9 @@
class QKeyEvent;
class QPainter;
-/** \class QgsMapLayer
- * \brief Base class for all map layer types.
- * This class is the base class for all map layer types (vector, raster).
+/** \ingroup core
+ * Base class for all map layer types.
+ * This is the base class for all map layer types (vector, raster).
class CORE_EXPORT QgsMapLayer : public QObject
Modified: trunk/qgis/src/core/qgsmaplayerregistry.h
--- trunk/qgis/src/core/qgsmaplayerregistry.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsmaplayerregistry.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -28,10 +28,9 @@
class QgsMapLayer;
-* \class QgsMapLayerRegistry
-* \brief This class tracks map layers that are currently loaded an provides
-* a means to fetch a pointer to a map layer and delete it
+/** \ingroup core
+* This class tracks map layers that are currently loaded and provides
+* a means to fetch a pointer to a map layer and delete it.
class CORE_EXPORT QgsMapLayerRegistry : public QObject
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsmaprenderer.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -34,10 +34,8 @@
class QgsSpatialRefSys;
class QgsDistanceArea;
- * \class QgsMapRenderer
- * \brief Class for rendering map layer set
+/** \ingroup core
+ * A non GUI class for rendering a map layer set onto a QPainter.
class CORE_EXPORT QgsMapRenderer : public QObject
Modified: trunk/qgis/src/core/qgsmaptopixel.h
--- trunk/qgis/src/core/qgsmaptopixel.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsmaptopixel.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -26,11 +26,11 @@
class QgsPoint;
class QPoint;
-/*! \class QgsMapToPixel
-* \brief Class for doing transforms between map coordinates and device coordinates.
-* This class can convert device coordinates to map coordinates and vice versa.
+/** \ingroup core
+ * Perform transforms between map coordinates and device coordinates.
+ * This class can convert device coordinates to map coordinates and vice versa.
class CORE_EXPORT QgsMapToPixel{
public:
/* Constructor
Modified: trunk/qgis/src/core/qgsmessageoutput.h
--- trunk/qgis/src/core/qgsmessageoutput.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgsmessageoutput.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -25,17 +25,16 @@
typedef QgsMessageOutput* (*MESSAGE_OUTPUT_CREATOR)();
-\brief Interface for showing messages from QGIS in GUI independent way
+/** \ingroup core
+ * Interface for showing messages from QGIS in GUI independent way.
+ * This class provides abstraction of a dialog for showing output to the user.
+ * By default QgsMessageConsoleOutput will be used if not overridden with other
+ * message output creator function.
-This class provides abstraction of a dialog for showing output to the user.
-By default QgsMessageConsoleOutput will be used if not overridden
-with other message output creator function.
+ * QGIS application uses QgsMessageView class for displaying a dialog to the user.
-QGIS application uses QgsMessageView class for displaying a dialog to the user.
-Object deletes itself when it's not needed anymore. Children should use
-signal destroyed() to notify the deletion
+ * Object deletes itself when it's not needed anymore. Children should use
+ * signal destroyed() to notify the deletion
class CORE_EXPORT QgsMessageOutput
Modified: trunk/qgis/src/core/qgspoint.h
--- trunk/qgis/src/core/qgspoint.h 2008-08-20 15:16:49 UTC (rev 9095)
+++ trunk/qgis/src/core/qgspoint.h 2008-08-20 17:39:42 UTC (rev 9096)
@@ -23,6 +23,10 @@
#include <QString>
+/** \ingroup core
+ * A class to represent a point geometry.
+ * Currently no Z axis / 2.5D support is implemented.
class CORE_EXPORT QgsPoint
public:
