[QGIS Commit] r9114 - trunk/qgis/src/plugins/dxf2shp_converter
svn_qgis at osgeo.org
Thu Aug 21 18:50:22 EDT 2008
Author: jef
Date: 2008-08-21 18:50:22 -0400 (Thu, 21 Aug 2008)
New Revision: 9114
trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp
trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp
fix #1234 & #1235
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp 2008-08-21 22:38:50 UTC (rev 9113)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp 2008-08-21 22:50:22 UTC (rev 9114)
@@ -92,12 +92,11 @@
// not be enough
void dxf2shpConverter::run()
- dxf2shpConverterGui *myPluginGui = new dxf2shpConverterGui(mQGisIface
- ->getMainWindow(), QgisGui::ModalDialogFlags);
+ dxf2shpConverterGui *myPluginGui =
+ new dxf2shpConverterGui(mQGisIface->getMainWindow(), QgisGui::ModalDialogFlags);
myPluginGui->setAttribute(Qt::WA_DeleteOnClose);
- connect(myPluginGui, SIGNAL(createLayer(QString)), this, SLOT(addMyLayer
- (QString)));
+ connect(myPluginGui, SIGNAL(createLayer(QString)), this, SLOT(addMyLayer(QString)));
myPluginGui->show();
@@ -113,14 +112,7 @@
void dxf2shpConverter::addMyLayer(QString myfname)
- // need to get a pointer to the current layer
- mQString = myfname;
- QgsMapLayer *layer = mQGisIface->activeLayer();
- if (layer)
- QgsVectorLayer *lyr = (QgsVectorLayer*)layer;
- mQGisIface->addVectorLayer(mQString, "Converted_Layer", "ogr");
+ mQGisIface->addVectorLayer(myfname, "Converted_Layer", "ogr");
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp 2008-08-21 22:38:50 UTC (rev 9113)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp 2008-08-21 22:50:22 UTC (rev 9114)
@@ -126,15 +126,15 @@
void dxf2shpConverterGui::on_buttonBox_helpRequested()
QString s = "Fields description:\n"
- "* Input DXF file: path to the DXF file to be converted\n";
- "* Output Shp file: desired filename of the ShapeFile to be created\n";
- "* Shp output file type: specifies the type of the output shapefile\n";
- "* Export text labels checkbox: if checked, an additional shp points layer will be created, ";
- " and the associated dbf table will contain informations about the \"TEXT\" fields found";
- " in the dxf file, and the text strings themselves\n\n";
- "---\n";
- "Developed by Paolo L. Scala, Barbara Rita Barricelli, Marco Padula\n";
- "CNR, Milan Unit (Information Technology), Construction Technologies Institute.\n";
+ "* Input DXF file: path to the DXF file to be converted\n"
+ "* Output Shp file: desired filename of the ShapeFile to be created\n"
+ "* Shp output file type: specifies the type of the output shapefile\n"
+ "* Export text labels checkbox: if checked, an additional shp points layer will be created, "
+ " and the associated dbf table will contain informations about the \"TEXT\" fields found"
+ " in the dxf file, and the text strings themselves\n\n"
+ "---\n"
+ "Developed by Paolo L. Scala, Barbara Rita Barricelli, Marco Padula\n"
+ "CNR, Milan Unit (Information Technology), Construction Technologies Institute.\n"
"For support send a mail to scala at itc.cnr.it\n";
QMessageBox::information(this, "Help", s);
