[QGIS Commit] r9124 - trunk/qgis/src/app/composer
svn_qgis at osgeo.org
Sat Aug 23 03:45:13 EDT 2008
Author: mhugent
Date: 2008-08-23 03:45:12 -0400 (Sat, 23 Aug 2008)
New Revision: 9124
Removed:
trunk/qgis/src/app/composer/qgscomposeritemgroup.cpp
trunk/qgis/src/app/composer/qgscomposeritemgroup.h
trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp
trunk/qgis/src/app/composer/qgscomposervectorlegend.h
trunk/qgis/src/app/composer/qgsnumericscalebarstyle.cpp
trunk/qgis/src/app/composer/qgsnumericscalebarstyle.h
Removed more files that are no longer necessary
Deleted: trunk/qgis/src/app/composer/qgscomposeritemgroup.cpp
--- trunk/qgis/src/app/composer/qgscomposeritemgroup.cpp 2008-08-23 07:18:39 UTC (rev 9123)
+++ trunk/qgis/src/app/composer/qgscomposeritemgroup.cpp 2008-08-23 07:45:12 UTC (rev 9124)
@@ -1,176 +0,0 @@
- qgscomposeritemgroup.cpp
- begin : 2nd June 2008
- copyright : (C) 2008 by Marco Hugentobler
- email : marco dot hugentobler at karto dot baug dot ethz dot ch
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
-#include "qgscomposeritemgroup.h"
-#include "qgscomposition.h"
-#include "qgscomposer.h" //probably use other approach to delete items because including this in a composer class is ugly
-#include <QPen>
-#include <QPainter>
-QgsComposerItemGroup::QgsComposerItemGroup(QgsComposition* c): QgsComposerItem(c)
- setZValue(90);
- show();
-QgsComposerItemGroup::~QgsComposerItemGroup()
- QSet<QgsComposerItem*>::iterator itemIt = mItems.begin();
- for(; itemIt != mItems.end(); ++itemIt)
- emit childItemDeleted(*itemIt);
- delete (*itemIt);
-void QgsComposerItemGroup::addItem(QgsComposerItem* item)
- if(!item)
- return;
- if(mItems.contains(item))
- return;
- mItems.insert(item);
- item->setSelected(false);
- item->setFlag(QGraphicsItem::ItemIsSelectable, false); //item in groups cannot be selected
- //update extent (which is in scene coordinates)
- double minXItem = item->transform().dx();
- double minYItem = item->transform().dy();
- double maxXItem = minXItem + item->rect().width();
- double maxYItem = minYItem + item->rect().height();
- if(mSceneBoundingRectangle.isEmpty()) //we add the first item
- mSceneBoundingRectangle.setLeft(minXItem);
- mSceneBoundingRectangle.setTop(minYItem);
- mSceneBoundingRectangle.setRight(maxXItem);
- mSceneBoundingRectangle.setBottom(maxYItem);
- else
- if(minXItem < mSceneBoundingRectangle.left())
- if(minYItem < mSceneBoundingRectangle.top())
- if(maxXItem > mSceneBoundingRectangle.right())
- if(maxYItem > mSceneBoundingRectangle.bottom())
- QgsComposerItem::setSceneRect(mSceneBoundingRectangle); //call method of superclass to avoid repositioning of items
-void QgsComposerItemGroup::removeItems()
- QSet<QgsComposerItem*>::iterator item_it = mItems.begin();
- for(; item_it != mItems.end(); ++item_it)
- (*item_it)->setFlag(QGraphicsItem::ItemIsSelectable, true); //enable item selection again
- (*item_it)->setSelected(true);
- mItems.clear();
-void QgsComposerItemGroup::paint( QPainter * painter, const QStyleOptionGraphicsItem * option, QWidget * widget)
- drawFrame(painter);
- if(isSelected())
- drawSelectionBoxes(painter);
-void QgsComposerItemGroup::setSceneRect(const QRectF& rectangle)
- //calculate values between 0 and 1 for boundaries of all contained items, depending on their positions in the item group rectangle.
- //then position the item boundaries in the new item group rect such that these values are the same
- double xLeftCurrent = transform().dx();
- double xRightCurrent = xLeftCurrent + rect().width();
- double yTopCurrent = transform().dy();
- double yBottomCurrent = yTopCurrent + rect().height();
- double xItemLeft, xItemRight, yItemTop, yItemBottom;
- double xItemLeftNew, xItemRightNew, yItemTopNew, yItemBottomNew;
- double xParamLeft, xParamRight, yParamTop, yParamBottom;
- xItemLeft = (*item_it)->transform().dx();
- xItemRight = xItemLeft + (*item_it)->rect().width();
- yItemTop = (*item_it)->transform().dy();
- yItemBottom = yItemTop + (*item_it)->rect().height();
- xParamLeft = ( xItemLeft - xLeftCurrent) / (xRightCurrent - xLeftCurrent);
- xParamRight = ( xItemRight - xLeftCurrent) / (xRightCurrent - xLeftCurrent);
- yParamTop = (yItemTop - yTopCurrent) / (yBottomCurrent - yTopCurrent);
- yParamBottom = (yItemBottom - yTopCurrent) / (yBottomCurrent - yTopCurrent);
- xItemLeftNew = xParamLeft * rectangle.right() + (1 - xParamLeft) * rectangle.left();
- xItemRightNew = xParamRight * rectangle.right() + (1 - xParamRight) * rectangle.left();
- yItemTopNew = yParamTop * rectangle.bottom() + (1 - yParamTop) * rectangle.top();
- yItemBottomNew = yParamBottom * rectangle.bottom() + (1 - yParamBottom) * rectangle.top();
- (*item_it)->setSceneRect(QRectF(xItemLeftNew, yItemTopNew, xItemRightNew - xItemLeftNew, yItemBottomNew - yItemTopNew));
- QgsComposerItem::setSceneRect(rectangle);
-void QgsComposerItemGroup::drawFrame(QPainter* p)
- if(!mComposition)
- return;
- if(mFrame && mComposition->plotStyle() == QgsComposition::Preview)
- QPen newPen(pen());
- newPen.setStyle(Qt::DashLine);
- newPen.setColor(QColor(128, 128, 128, 128));
- p->setPen(newPen);
- p->setRenderHint(QPainter::Antialiasing, true);
- p->drawRect (QRectF( 0, 0, rect().width(), rect().height()));
-bool QgsComposerItemGroup::writeXML(QDomElement& elem, QDomDocument & doc)
- return true; //soon...
-bool QgsComposerItemGroup::readXML(const QDomElement& itemElem, const QDomDocument& doc)
- return false; //soon...
Deleted: trunk/qgis/src/app/composer/qgscomposeritemgroup.h
--- trunk/qgis/src/app/composer/qgscomposeritemgroup.h 2008-08-23 07:18:39 UTC (rev 9123)
+++ trunk/qgis/src/app/composer/qgscomposeritemgroup.h 2008-08-23 07:45:12 UTC (rev 9124)
@@ -1,68 +0,0 @@
- qgscomposeritemgroup.h
-#include "qgscomposeritem.h"
-#include <QObject>
-#include <QSet>
-class QgsComposition;
-/** \ingroup MapComposer
- * A container for grouping several QgsComposerItems
-class QgsComposerItemGroup: public QObject, public QgsComposerItem
- Q_OBJECT
- public:
- QgsComposerItemGroup(QgsComposition* c);
- ~QgsComposerItemGroup();
- /**Adds an item to the group. All the group members are deleted
- if the group is deleted*/
- void addItem(QgsComposerItem* item);
- /**Removes the items but does not delete them*/
- void removeItems();
- /**Draw outline and ev. selection handles*/
- void paint( QPainter * painter, const QStyleOptionGraphicsItem * option, QWidget * widget = 0);
- /**Sets this items bound in scene coordinates such that 1 item size units
- corresponds to 1 scene size unit*/
- void setSceneRect(const QRectF& rectangle);
- /** resizes an item in x- and y direction (scene coordinates)*/
- void resize(double dx, double dy);
- /** stores state in DOM node
- * @param elem is DOM element corresponding to 'Composer' tag
- * @param temp write template file
- bool writeXML(QDomElement& elem, QDomDocument & doc);
- /** sets state from DOM document
- * @param itemElem is DOM node corresponding to item tag
- bool readXML(const QDomElement& itemElem, const QDomDocument& doc);
- signals:
- void childItemDeleted(QgsComposerItem* item);
- protected:
- void drawFrame(QPainter* p);
- private:
- QSet<QgsComposerItem*> mItems;
- QRectF mSceneBoundingRectangle;
Deleted: trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp
--- trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp 2008-08-23 07:18:39 UTC (rev 9123)
+++ trunk/qgis/src/app/composer/qgscomposervectorlegend.cpp 2008-08-23 07:45:12 UTC (rev 9124)
@@ -1,960 +0,0 @@
- qgscomposervectorlegend.cpp
- begin : January 2005
- copyright : (C) 2005 by Radim Blazek
- email : blazek at itc.it
-#include "qgscomposervectorlegend.h"
-#include "qgscomposermap.h"
-#include "qgscontinuouscolorrenderer.h"
-#include "qgsmapcanvas.h"
-#include "qgsmaplayer.h"
-#include "qgsproject.h"
-#include "qgsrenderer.h"
-#include "qgssymbol.h"
-#include "qgsvectorlayer.h"
-#include <QContextMenuEvent>
-#include <QFontDialog>
-#include <QGraphicsScene>
-#include <QHeaderView>
-#include <QMenu>
-#include <QTreeWidgetItem>
-#include <iostream>
-#include <vector>
-#if 0
-QgsComposerVectorLegend::QgsComposerVectorLegend ( QgsComposition *composition, int id,
- int x, int y, int fontSize )
- : QWidget(composition), QgsComposerItem(x,y,10,10,0)
- setupUi(this);
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::QgsComposerVectorLegend()" << std::endl;
-#endif
- mComposition = composition;
- mId = id;
- mMapCanvas = mComposition->mapCanvas();
- init();
- // Font and pen
- if(fontSize < 10){
- fontSize = 10;
- mFont.setPointSize ( fontSize );
- // Set map to the first available if any
- std::vector<QgsComposerMap*> maps = mComposition->maps();
- if ( maps.size() > 0 ) {
- mMap = maps[0]->id();
- // Calc size and cache
- recalculate();
- // Add to scene
- mComposition->canvas()->addItem(this);
- QGraphicsRectItem::show();
- QGraphicsRectItem::update();
- writeSettings();
-QgsComposerVectorLegend::QgsComposerVectorLegend ( QgsComposition *composition, int id )
- : QgsComposerItem(0,0,10,10,0)
-#ifdef QGISDEBUG
-#endif
- setupUi(this);
- mId = id;
- init();
- readSettings();
- recalculate();
- // Add to scene
-void QgsComposerVectorLegend::init ( void )
- setSelected(false);
- mNumCachedLayers = 0;
- mTitle = tr("Legend");
- mMap = 0;
- mNextLayerGroup = 1;
- mFrame = true;
- // Cache
- mCacheUpdated = false;
- // Rectangle
- QGraphicsRectItem::setZValue(50);
-// setActive(true);
- // Layers list view
-//x mLayersListView->setResizeMode(QTreeView::AllColumns);
- mLayersListView->setColumnHidden(2, true);
- connect ( mLayersListView, SIGNAL(itemClicked(QTreeWidgetItem *, int)),
- this, SLOT(layerChanged(QTreeWidgetItem *)));
- // Plot style
- setPlotStyle ( QgsComposition::Preview );
- // Preview style
- mPreviewMode = Render;
- mPreviewModeComboBox->addItem ( tr("Cache"), Cache );
- mPreviewModeComboBox->addItem ( tr("Render"), Render );
- mPreviewModeComboBox->addItem ( tr("Rectangle"), Rectangle );
- mPreviewModeComboBox->setCurrentIndex ( mPreviewMode );
- connect ( mComposition, SIGNAL(mapChanged(int)), this, SLOT(mapChanged(int)) );
-QgsComposerVectorLegend::~QgsComposerVectorLegend()
- //std::cerr << "QgsComposerVectorLegend::~QgsComposerVectorLegend()" << std::endl;
-#define FONT_WORKAROUND_SCALE 10
-QRectF QgsComposerVectorLegend::render ( QPainter *p )
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::render p = " << p << std::endl;
-#endif
-#if 0
- // Painter can be 0, create dummy to avoid many if below
- QPainter *painter = NULL;
- QPixmap *pixmap = NULL;
- if ( p ) {
- painter = p;
- } else {
- pixmap = new QPixmap(1,1);
- painter = new QPainter( pixmap );
- //std::cout << "mComposition->scale() = " << mComposition->scale() << std::endl;
- // Font size in canvas units
- float titleSize = 25.4 * mComposition->scale() * mTitleFont.pointSizeF() / 72;
- float sectionSize = 25.4 * mComposition->scale() * mSectionFont.pointSizeF() / 72;
- float size = 25.4 * mComposition->scale() * mFont.pointSizeF() / 72;
- //std::cout << "font sizes = " << titleSize << " " << sectionSize << " " << size << std::endl;
- // Create fonts
- QFont titleFont ( mTitleFont );
- QFont sectionFont ( mSectionFont );
- QFont font ( mFont );
- titleFont.setPointSizeF ( titleSize );
- sectionFont.setPointSizeF ( sectionSize );
- font.setPointSizeF ( size );
- // Not sure about Style Strategy, QFont::PreferMatch?
- titleFont.setStyleStrategy ( (QFont::StyleStrategy) (QFont::PreferOutline | QFont::PreferAntialias) );
- sectionFont.setStyleStrategy ( (QFont::StyleStrategy) (QFont::PreferOutline | QFont::PreferAntialias) );
- font.setStyleStrategy ( (QFont::StyleStrategy) (QFont::PreferOutline | QFont::PreferAntialias) );
- QFontMetricsF titleMetrics ( titleFont );
- QFontMetricsF sectionMetrics ( sectionFont );
- QFontMetricsF metrics ( font );
- if ( plotStyle() == QgsComposition::Postscript) //do we need seperate PostScript rendering settings?
- // Fonts sizes for Postscript rendering
- double psTitleSize = titleMetrics.ascent() * 72.0 / mComposition->resolution(); //What??
- double psSectionSize = sectionMetrics.ascent() * 72.0 / mComposition->resolution();
- double psSize = metrics.ascent() * 72.0 / mComposition->resolution();
- titleFont.setPointSizeF ( psTitleSize * FONT_WORKAROUND_SCALE );
- sectionFont.setPointSizeF ( psSectionSize * FONT_WORKAROUND_SCALE );
- font.setPointSizeF ( psSize * FONT_WORKAROUND_SCALE );
- else
- titleFont.setPointSizeF ( titleSize * FONT_WORKAROUND_SCALE );
- sectionFont.setPointSizeF ( sectionSize * FONT_WORKAROUND_SCALE );
- font.setPointSizeF ( size * FONT_WORKAROUND_SCALE );
- double x, y;
- // Legend title -if we do this later, we can center it
- y = mMargin + titleMetrics.height();
- painter->setPen ( mPen );
- painter->setFont ( titleFont );
- painter->save(); //Save the painter state so we can undo the scaling later
- painter->scale(1./FONT_WORKAROUND_SCALE, 1./FONT_WORKAROUND_SCALE); //scale the painter to work around the font bug
- painter->drawText( QPointF(2 * mMargin * FONT_WORKAROUND_SCALE, y * FONT_WORKAROUND_SCALE), mTitle );
- painter->restore();
- //used to keep track of total width and height
- double width = 4 * mMargin + titleMetrics.width ( mTitle );
- double height = mMargin + mSymbolSpace + titleMetrics.height(); // mSymbolSpace?
- // Layers
- QgsComposerMap *map = mComposition->map ( mMap ); //Get the map from the composition by ID number
- if ( map ) {
- std::map<int,int> doneGroups;
- int nlayers = mMapCanvas->layerCount();
- for ( int i = nlayers - 1; i >= 0; i-- ) {
- QgsMapLayer *layer = mMapCanvas->getZpos(i);
-// if ( !layer->visible() ) continue; // skip non-visible layers
- if ( layer->type() != QgsMapLayer::VECTOR ) continue; //skip raster layers
- QString layerId = layer->getLayerID();
-// if( ! layerOn(layerId) ) continue; //does this need to go away?
- int group = layerGroup ( layerId );
- if ( group > 0 ) {
- if ( doneGroups.find(group) != doneGroups.end() ) {
- continue;
- } else {
- doneGroups.insert(std::make_pair(group,1));
- // Make list of all layers in the group and count section items
- std::vector<int> groupLayers; // vector of layers
- std::vector<double> itemHeights; // maximum item sizes
- std::vector<QString> itemLabels; // item labels
- int sectionItemsCount = 0;
- QString sectionTitle;
- for ( int j = nlayers - 1; j >= 0; j-- )
- QgsMapLayer *layer2 = mMapCanvas->getZpos(j);
-// if ( !layer2->visible() ) continue;
- if ( layer2->type() != QgsMapLayer::VECTOR ) continue;
- QString layerId2 = layer2->getLayerID();
- if( ! layerOn(layerId2) ) continue;
- int group2 = layerGroup ( layerId2 );
- QgsVectorLayer *vector = dynamic_cast <QgsVectorLayer*> (layer2);
- const QgsRenderer *renderer = vector->renderer();
- if ( (group > 0 && group2 == group) || ( group == 0 && j == i ) ) {
- groupLayers.push_back(j);
- QList<QgsSymbol*> symbols = renderer->symbols();
- if ( sectionTitle.length() == 0 ) {
- sectionTitle = layer2->name();
- if ( symbols.size() > sectionItemsCount ) {
- sectionItemsCount = symbols.size();
- itemHeights.resize(sectionItemsCount);
- itemLabels.resize(sectionItemsCount);
- // double widthScale = map->widthScale() * mComposition->scale();
- if ( plotStyle() == QgsComposition::Preview && mPreviewMode == Render ) {
- widthScale *= mComposition->viewScale();
- //double scale = map->symbolScale() * mComposition->scale();
- int icnt = 0;
- for ( QList<QgsSymbol*>::iterator it = symbols.begin(); it != symbols.end(); ++it ) {
- QgsSymbol* sym = (*it);
- // height
- if ( itemHeights[icnt] < mSymbolHeight ) { // init first
- itemHeights[icnt] = mSymbolHeight;
- QPixmap pic = QPixmap::fromImage(sym->getPointSymbolAsImage(widthScale, false));
- double h = scale * pic.height();
- if ( h > itemHeights[icnt] ) {
- itemHeights[icnt] = h;
- if ( itemLabels[icnt].length() == 0 ) {
- if ( sym->label().length() > 0 ) {
- itemLabels[icnt] = sym->label();
- } else {
- itemLabels[icnt] = sym->lowerValue();
- if (sym->upperValue().length() > 0)
- itemLabels[icnt] += " - " + sym->upperValue();
- icnt++;
- //std::cout << "group size = " << groupLayers.size() << std::endl;
- //std::cout << "sectionItemsCount = " << sectionItemsCount << std::endl;
- // Section title
- if ( sectionItemsCount > 1 )
- height += mSymbolSpace;
- x = 2*mMargin;
- y = height + sectionMetrics.height();
- painter->setFont ( sectionFont );
- painter->drawText(QPointF(x * FONT_WORKAROUND_SCALE, y * FONT_WORKAROUND_SCALE), sectionTitle );
- double w = 3*mMargin + sectionMetrics.width( sectionTitle );
- if ( w > width ) width = w;
- height += sectionMetrics.height();
- height += (1.5*mSymbolSpace);
- // Draw all layers in group
- double groupStartHeight = height;
- for ( int j = groupLayers.size()-1; j >= 0; j-- )
- //std::cout << "layer = " << groupLayers[j] << std::endl;
- double localHeight = groupStartHeight;
- layer = mMapCanvas->getZpos(groupLayers[j]);
- QgsVectorLayer *vector = dynamic_cast <QgsVectorLayer*> (layer);
- // Get a list of the symbols from the renderer - some renderers can have several symbols
- int icnt = 0;
- localHeight += mSymbolSpace;
- double symbolHeight = itemHeights[icnt];
- QPen pen = sym->pen();
- //double widthScale = map->widthScale();
- pen.setWidthF( ( widthScale * pen.widthF() ) );
- pen.setCapStyle(Qt::FlatCap); //make sure that the line doesn't extend past its endpoints
- painter->setPen ( pen );
- painter->setBrush ( sym->brush() );
- if ( vector->vectorType() == QGis::Point ) {
- double scale = map->symbolScale();
- // Get the picture of appropriate size directly from catalogue
- QPixmap pic = QPixmap::fromImage(sym->getPointSymbolAsImage(widthScale,false,sym->color()));
- painter->save();
- painter->scale(scale,scale);
- painter->drawPixmap ( static_cast<int>( (1.*mMargin+mSymbolWidth/2)/scale-pic.width()/2),
- static_cast<int>( (1.*localHeight+symbolHeight/2)/scale-1.*pic.height()/2),
- pic );
- } else if ( vector->vectorType() == QGis::Line ) {
- painter->drawLine (QPointF(mMargin, localHeight+mSymbolHeight/2),
- QPointF(mMargin+mSymbolWidth, localHeight+mSymbolHeight/2));
- } else if ( vector->vectorType() == QGis::Polygon ) {
- painter->drawRect (QRectF(mMargin, localHeight, mSymbolWidth, mSymbolHeight));
- // Label
- painter->setFont ( font );
- QString lab;
- if ( sectionItemsCount == 1 ) {
- lab = sectionTitle;
- } else {
- lab = itemLabels[icnt];
- // drawText (x, y w, h, ...) was cutting last letter (the box was too small)
- QRectF br = metrics.boundingRect ( lab );
- x = 2*mMargin + mSymbolWidth;
- y = localHeight + symbolHeight/2 + ( metrics.height()/2 - metrics.descent());
- painter->scale(1./FONT_WORKAROUND_SCALE, 1./FONT_WORKAROUND_SCALE);//scale the painter to work around the font bug
- painter->drawText(QPointF(x * FONT_WORKAROUND_SCALE, y * FONT_WORKAROUND_SCALE), lab );
- double w = 3*mMargin + mSymbolWidth + metrics.width(lab);
- localHeight += symbolHeight;
- icnt++;
- }//End of iterating through the symbols in the renderer
- // add height of section items to the total height
- height = groupStartHeight;
- for ( int j = 0; j < (int)itemHeights.size(); j++ ) {
- height += mSymbolSpace + itemHeights[j];
- if ( sectionItemsCount > 1 ) { // add more space to separate section from next item
- }//End of iterating through the layers
- }//END if(map)
- height += mMargin;
- if(mFrame)
- QPen pen(QColor(0,0,0), 0.5);
- painter->setPen( pen );
- painter->setBrush( QBrush( QColor(255,255,255), Qt::NoBrush));
- painter->setRenderHint(QPainter::Antialiasing, true);//turn on antialiasing
- painter->drawRect(QRectF(0, 0, width, height));
-// QGraphicsRectItem::setRect(0, 0, width, height); //BUG! - calling this causes a re-draw, which means we are continuously re-drawing.
- if ( !p ) {
- delete painter;
- delete pixmap;
- return QRectF ( 0, 0, width, height);
-#endif //0
-void QgsComposerVectorLegend::cache ( void )
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::cache()" << std::endl;
-#endif
- //typical boundingRect size is 15 units wide,
- mCachePixmap = QPixmap((int)QGraphicsRectItem::rect().width(), (int)QGraphicsRectItem::rect().height() );
- QPainter p(&mCachePixmap);
- mCachePixmap.fill(QColor(255,255,255));
- render ( &p );
- p.end();
- mNumCachedLayers = mMapCanvas->layerCount();
- mCacheUpdated = true;
-void QgsComposerVectorLegend::paint( QPainter* painter, const QStyleOptionGraphicsItem* itemStyle, QWidget* pWidget )
-#ifdef QGISDEBUG
- std::cout << "paint mPlotStyle = " << plotStyle() << " mPreviewMode = " << mPreviewMode << std::endl;
-#endif
- if ( plotStyle() == QgsComposition::Preview && mPreviewMode == Cache )
- if ( !mCacheUpdated || mMapCanvas->layerCount() != mNumCachedLayers ) //If the cache is out of date, update it.
- cache();
- painter->drawPixmap(0,0, mCachePixmap);
- else if(plotStyle() == QgsComposition::Preview && mPreviewMode == Rectangle)
- painter->setBrush( QBrush( QColor(255,255,255), Qt::NoBrush)); //use SolidPattern instead?
- painter->drawRect(QRectF(0, 0, QGraphicsRectItem::rect().width(), QGraphicsRectItem::rect().height()));
- else if ( (plotStyle() == QgsComposition::Preview && mPreviewMode == Render) ||
- plotStyle() == QgsComposition::Print ||
- plotStyle() == QgsComposition::Postscript )
- //We're in render preview mode or printing, so do a full render of the legend.
- painter->save();
- render(painter);
- // Draw the "selected highlight" boxes
- if ( isSelected() && plotStyle() == QgsComposition::Preview ) {
- painter->setPen( mComposition->selectionPen() );
- painter->setBrush( mComposition->selectionBrush() );
- double s = mComposition->selectionBoxSize();
- painter->drawRect(QRectF(0, 0, s, s)); //top left
- painter->drawRect(QRectF(QGraphicsRectItem::rect().width()-s, 0, s, s)); //top right
- painter->drawRect(QRectF(QGraphicsRectItem::rect().width()-s, QGraphicsRectItem::rect().height()-s, s, s)); //bottom right
- painter->drawRect(QRectF(0, QGraphicsRectItem::rect().height()-s, s, s)); //bottom left
-void QgsComposerVectorLegend::on_mFontButton_clicked ( void )
- bool result;
- mFont = QFontDialog::getFont(&result, mFont, this );
- if ( result ) {
- recalculate();
- QGraphicsRectItem::scene()->update();
- writeSettings();
-void QgsComposerVectorLegend::on_mTitleLineEdit_editingFinished ( void )
- mTitle = mTitleLineEdit->text();
- recalculate();
- writeSettings();
-void QgsComposerVectorLegend::on_mPreviewModeComboBox_activated ( int i )
- mPreviewMode = (PreviewMode) i;
-#ifdef QGISDEBUG
- std::cout << "mPreviewMode = " << mPreviewMode << std::endl;
-#endif
- writeSettings();
-void QgsComposerVectorLegend::on_mMapComboBox_activated ( int i )
- mMap = mMaps[i];
- recalculate();
- writeSettings();
-void QgsComposerVectorLegend::mapChanged ( int id )
- if ( id != mMap ) return;
- recalculate();
-void QgsComposerVectorLegend::on_mFrameCheckBox_stateChanged ( int )
- mFrame = mFrameCheckBox->isChecked();
- writeSettings();
-void QgsComposerVectorLegend::recalculate ( void )
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::recalculate" << std::endl;
-#endif
- // Recalculate sizes according to current font size
- // Title and section font
- mTitleFont = mFont;
- mTitleFont.setPointSizeF ( 1.4 * mFont.pointSizeF());
- mSectionFont = mFont;
- mSectionFont.setPointSizeF ( 1.2 * mFont.pointSizeF() );
- mMargin = 0.9 * size;
- mSymbolHeight = 1.3 * size;
- mSymbolWidth = 3.5 * size;
- mSymbolSpace = 0.4 * size;
-#ifdef QGISDEBUG
- std::cout << "font size = " << mFont.pointSizeF() << std::endl;
- std::cout << "title font size = " << mTitleFont.pointSizeF() << std::endl;
- std::cout << "mMargin = " << mMargin << " mSymbolHeight = " << mSymbolHeight
- << "mSymbolWidth = " << mSymbolWidth << " mSymbolSpace = " << mSymbolSpace << std::endl;
-#endif
- QRectF r = render(0);
- QGraphicsRectItem::setRect(0, 0, r.width(), r.height() );
-void QgsComposerVectorLegend::setOptions ( void )
- mTitleLineEdit->setText( mTitle );
- // Maps
- mMapComboBox->clear();
- mMaps.clear();
- bool found = false;
- mMapComboBox->addItem ( "" );
- mMaps.push_back ( 0 );
- for ( int i = 0; i < (int)maps.size(); i++ ) {
- mMapComboBox->addItem ( maps[i]->name() );
- mMaps.push_back ( maps[i]->id() );
- if ( maps[i]->id() == mMap ) {
- found = true;
- mMapComboBox->setCurrentIndex ( i+1 );
- if ( ! found ) {
- mMap = 0;
- mMapComboBox->setCurrentIndex ( 0 );
- mFrameCheckBox->setChecked ( mFrame );
- // Layers
- mLayersListView->clear();
- if ( mMap != 0 ) {
- if ( map ) {
- for ( int i = 0; i < nlayers; i++ ) {
- //if ( layer->type() != QgsMapLayer::VECTOR ) continue;
- QTreeWidgetItem *item = new QTreeWidgetItem(mLayersListView);
- item->setText(0, layer->name() );
- QString id = layer->getLayerID();
- item->setText(2, id );
- item->setCheckState(0, layerOn(id) ? Qt::Checked : Qt::Unchecked);
- int group = layerGroup(id);
- item->setText(1, QString::number(group) );
- mLayersListView->header()->resizeSections(QHeaderView::Stretch);
- mPreviewModeComboBox->setCurrentIndex( mPreviewMode );
-void QgsComposerVectorLegend::setSelected ( bool s )
- QGraphicsRectItem::setSelected(s);
- QGraphicsRectItem::update(); // show highlight
-bool QgsComposerVectorLegend::selected( void )
- return isSelected();
-void QgsComposerVectorLegend::contextMenuEvent( QContextMenuEvent *event)
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::contextMenuEvent" << std::endl;
-#endif
- QMenu layersPopupMenu( this);
- layersPopupMenu.addAction( tr("Combine selected layers"), this, SLOT(groupLayers()) );
- layersPopupMenu.exec( event->globalPos());
-bool QgsComposerVectorLegend::layerOn ( QString id )
- std::map<QString,bool>::iterator it = mLayersOn.find(id);
- if(it != mLayersOn.end() ) {
- return ( it->second );
- return true;
-void QgsComposerVectorLegend::setLayerOn ( QString id, bool on )
- it->second = on;
- } else {
- mLayersOn.insert(std::make_pair(id,on));
-int QgsComposerVectorLegend::layerGroup ( QString id )
- std::map<QString,int>::iterator it = mLayersGroups.find(id);
- if(it != mLayersGroups.end() ) {
- return 0;
-void QgsComposerVectorLegend::setLayerGroup ( QString id, int group )
- it->second = group;
- } else {
- mLayersGroups.insert(std::make_pair(id,group));
-void QgsComposerVectorLegend::layerChanged ( QTreeWidgetItem *lvi )
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::layerChanged" << std::endl;
-#endif
- if ( lvi == 0 ) return;
- QString id = lvi->text(2);
- setLayerOn(id, lvi->checkState(0) == Qt::Checked);
- writeSettings();
- recalculate();
-void QgsComposerVectorLegend::groupLayers ( void )
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::groupLayers" << std::endl;
-#endif
- QTreeWidgetItemIterator it( mLayersListView );
- int count = 0;
- QTreeWidgetItem *lastItem = NULL;
- QString id;
- while ( *it ) {
- if ( (*it)->isSelected() ) {
- #ifdef QGISDEBUG
- std::cout << "selected: " << (*it)->text(0).toLocal8Bit().data() << " " << (*it)->text(2).toLocal8Bit().data() << std::endl;
- #endif
- id = (*it)->text(2);
- setLayerGroup ( id, mNextLayerGroup );
- (*it)->setText(1,QString::number(mNextLayerGroup) );
- lastItem = *it;
- count++;
- ++it;
- if ( count == 1 ) { // one item only
- setLayerGroup ( id, 0 );
- lastItem->setText(1,"" );
-#ifdef QGISDEBUG
- std::cout << "Groups:" << std::endl;
- for ( std::map<QString,int>::iterator it3 = mLayersGroups.begin(); it3 != mLayersGroups.end(); ++it3 ) {
- std::cout << "layer: " << (it3->first).toLocal8Bit().data() << " group: " << it3->second << std::endl;
-#endif
- mNextLayerGroup++;
- writeSettings();
- recalculate();
-QWidget *QgsComposerVectorLegend::options ( void )
- setOptions ();
- return ( dynamic_cast <QWidget *> (this) );
-bool QgsComposerVectorLegend::writeSettings ( void )
-#ifdef QGISDEBUG
- std::cout << "QgsComposerVectorLegend::writeSettings" << std::endl;
-#endif
- QString path;
- path.sprintf("/composition_%d/vectorlegend_%d/", mComposition->id(), mId );
- QgsProject::instance()->writeEntry( "Compositions", path+"x", mComposition->toMM((int)QGraphicsRectItem::x()) );
- QgsProject::instance()->writeEntry( "Compositions", path+"y", mComposition->toMM((int)QGraphicsRectItem::y()) );
- QgsProject::instance()->writeEntry( "Compositions", path+"map", mMap );
- QgsProject::instance()->writeEntry( "Compositions", path+"title", mTitle );
- QgsProject::instance()->writeEntry( "Compositions", path+"font/size", mFont.pointSize() );
- QgsProject::instance()->writeEntry( "Compositions", path+"font/family", mFont.family() );
- QgsProject::instance()->writeEntry( "Compositions", path+"font/weight", mFont.weight() );
- QgsProject::instance()->writeEntry( "Compositions", path+"font/underline", mFont.underline() );
- QgsProject::instance()->writeEntry( "Compositions", path+"font/strikeout", mFont.strikeOut() );
- QgsProject::instance()->writeEntry( "Compositions", path+"frame", mFrame );
- // Layers: remove all, write new
- path.sprintf("/composition_%d/vectorlegend_%d/layers/", mComposition->id(), mId );
- QgsProject::instance()->removeEntry ( "Compositions", path );
- if ( map ) {
- path.sprintf("/composition_%d/vectorlegend_%d/layers/layer_%s/", mComposition->id(), mId, id.toLocal8Bit().data() );
- QgsProject::instance()->writeEntry( "Compositions", path+"on", layerOn(id) );
- QgsProject::instance()->writeEntry( "Compositions", path+"group", layerGroup(id) );
- QgsProject::instance()->writeEntry( "Compositions", path+"previewmode", mPreviewMode );
- return true;
-bool QgsComposerVectorLegend::readSettings ( void )
- bool ok;
- QString path;
- double x = mComposition->fromMM(QgsProject::instance()->readDoubleEntry( "Compositions", path+"x", 0, &ok));
- double y = mComposition->fromMM(QgsProject::instance()->readDoubleEntry( "Compositions", path+"y", 0, &ok));
- QGraphicsRectItem::setPos(x, y);
- mMap = QgsProject::instance()->readNumEntry("Compositions", path+"map", 0, &ok);
- mTitle = QgsProject::instance()->readEntry("Compositions", path+"title", "???", &ok);
- mFont.setFamily ( QgsProject::instance()->readEntry("Compositions", path+"font/family", "", &ok) );
- mFont.setPointSize ( QgsProject::instance()->readNumEntry("Compositions", path+"font/size", 10, &ok) );
- mFont.setWeight( QgsProject::instance()->readNumEntry("Compositions", path+"font/weight", (int)QFont::Normal, &ok) );
- mFont.setUnderline( QgsProject::instance()->readBoolEntry("Compositions", path+"font/underline", false, &ok) );
- mFont.setStrikeOut( QgsProject::instance()->readBoolEntry("Compositions", path+"font/strikeout", false, &ok) );
- mFrame = QgsProject::instance()->readBoolEntry("Compositions", path+"frame", true, &ok);
- // Preview mode
- mPreviewMode = (PreviewMode) QgsProject::instance()->readNumEntry("Compositions", path+"previewmode", Render, &ok);
- // Layers
- QStringList el = QgsProject::instance()->subkeyList ( "Compositions", path );
- for ( QStringList::iterator it = el.begin(); it != el.end(); ++it ) {
- int idx = (*it).indexOf('_');
- QString id = (*it).right( (*it).length() - (idx+1) );
- bool on = QgsProject::instance()->readBoolEntry("Compositions", path+"on", true, &ok);
- int group = QgsProject::instance()->readNumEntry("Compositions", path+"group", 0, &ok);
- setLayerOn ( id , on );
- setLayerGroup ( id, group );
- if ( group >= mNextLayerGroup ) mNextLayerGroup = group+1;
- recalculate();
- return true;
-bool QgsComposerVectorLegend::removeSettings( void )
- std::cerr << "QgsComposerVectorLegend::deleteSettings" << std::endl;
- QString path;
- path.sprintf("/composition_%d/vectorlegend_%d", mComposition->id(), mId );
- return QgsProject::instance()->removeEntry ( "Compositions", path );
-bool QgsComposerVectorLegend::writeXML( QDomNode & node, QDomDocument & document, bool temp )
- return true;
-bool QgsComposerVectorLegend::readXML( QDomNode & node )
- return true;
-#endif //0
Deleted: trunk/qgis/src/app/composer/qgscomposervectorlegend.h
--- trunk/qgis/src/app/composer/qgscomposervectorlegend.h 2008-08-23 07:18:39 UTC (rev 9123)
+++ trunk/qgis/src/app/composer/qgscomposervectorlegend.h 2008-08-23 07:45:12 UTC (rev 9124)
@@ -1,220 +0,0 @@
- qgscomposervectorlegend.h
-#ifndef QGSCOMPOSERVECTORLEGEND_H
-#define QGSCOMPOSERVECTORLEGEND_H
-#if 0
- * |<>| - mMargin
- * | Legend Title |
- * | Section |
- * -- | +-----+ | __
- * mSymbolHeight | | | | Item Label | __| - mFont->pointSize()
- * | | | - mSymbolSpace (vertical space between symbol, boxes)
- * | | | Item Label |
- * |<--->| - mSymbolWidth (lines and areas)
-#include "ui_qgscomposervectorlegendbase.h"
-#include <QGraphicsRectItem>
-#include <QPen>
-class QgsMapCanvas;
-class QDomNode;
-class QDomDocument;
-class QTreeWidgetItem;
- * \class QgsComposerVectorLegend
- * \brief Object representing map window.
-// NOTE: QgsComposerVectorLegendBase must be first, otherwise does not compile
-class QgsComposerVectorLegend : public QWidget,
- private Ui::QgsComposerVectorLegendBase,
- public QgsComposerItem
- Q_OBJECT
-public:
- /** \brief Constructor
- * \param id object id
- * \param fontSize font size in typographic points!
- QgsComposerVectorLegend( QgsComposition *composition, int id, int x, int y, int fontSize = 0 );
- /** \brief Constructor. Settings are read from project.
- QgsComposerVectorLegend( QgsComposition *composition, int id );
- ~QgsComposerVectorLegend();
- /** \brief Preview style */
- enum PreviewMode {
- Cache = 0, // Use raster cache
- Render, // Render the map
- Rectangle // Display only rectangle
- /** \brief Initialise GUI etc., share by constructors. */
- void init(void);
- // Reimplement QgsComposerItem:
- void setSelected( bool s );
- bool selected( void );
- QWidget *options ( void );
- bool writeSettings ( void );
- bool readSettings ( void );
- bool removeSettings ( void );
- bool writeXML( QDomNode & node, QDomDocument & document, bool temp = false );
- bool readXML( QDomNode & node );
- /** \brief Draw to paint device, internal use
- * \param painter painter or 0
- * \return bounding box
- QRectF render (QPainter *painter);
- /** \brief Reimplementation of QCanvasItem::paint - draw on canvas */
- void paint ( QPainter*, const QStyleOptionGraphicsItem*, QWidget*);
- /** \brief Calculate size according to current settings */
- void recalculate ( void );
- /** \brief Create cache image */
- void cache ( void );
- /** \brief Set values in GUI to current values */
- void setOptions ( void );
- /** \brief Is layer on/off ? */
- bool layerOn ( QString id );
- /** \brief set layer on/off */
- void setLayerOn ( QString id, bool on );
- /** \brief get layer group, 0 == no group */
- int layerGroup ( QString id );
- /** \brief set layer group, 0 == no group */
- void setLayerGroup ( QString id, int group );
-public slots:
- // Open font dialog
- void on_mFontButton_clicked ( void );
- // Title changed
- void on_mTitleLineEdit_editingFinished ( void );
- // Called by GUI if preview style was changed
- void on_mPreviewModeComboBox_activated ( int i );
- // Called by GUI when map selection changed
- void on_mMapComboBox_activated ( int i );
- // Called when map was changed
- void mapChanged ( int id );
- // Layer status changed
- void layerChanged ( QTreeWidgetItem *lvi );
- // Combine selected layers
- void groupLayers( void );
- // Frame settings changed
- void on_mFrameCheckBox_stateChanged ( int i );
-protected:
- // Show popup menu
- void contextMenuEvent ( QContextMenuEvent * event );
-private:
- // Pointer to composition
- QgsComposition *mComposition;
- // Pointer to map canvas
- QgsMapCanvas *mMapCanvas;
- // Composer map id or 0
- int mMap;
- // Vector of map id for maps in combobox
- std::vector<int> mMaps;
- // Title
- QString mTitle;
- // Font. Font size in typographic points!
- QFont mTitleFont;
- QFont mSectionFont;
- QFont mFont;
- // Pen
- QPen mPen;
- double mMargin;
- double mSymbolHeight;
- double mSymbolWidth;
- double mSymbolSpace;
- // Cache used in composer preview
- // NOTE: QCanvasView is slow with bigger images but the spped does not decrease with image size.
- // It is very slow, with zoom in in QCanvasView, it seems, that QCanvas is stored as a big image
- // with resolution necessary for current zoom and so always a big image mus be redrawn.
- QPixmap mCachePixmap;
- // Is cache up to date
- bool mCacheUpdated;
- PreviewMode mPreviewMode;
- /** \brief Number of layers when cache was created */
- int mNumCachedLayers;
- /** \brief Keeps info if the layer is on or off */
- std::map<QString,bool> mLayersOn;
- /** \brief layer groups */
- std::map<QString,int> mLayersGroups;
- /** \brief new layer group id */
- int mNextLayerGroup;
- /** \brief Draw frame */
- bool mFrame;
-#endif //0
-#endif
Deleted: trunk/qgis/src/app/composer/qgsnumericscalebarstyle.cpp
--- trunk/qgis/src/app/composer/qgsnumericscalebarstyle.cpp 2008-08-23 07:18:39 UTC (rev 9123)
+++ trunk/qgis/src/app/composer/qgsnumericscalebarstyle.cpp 2008-08-23 07:45:12 UTC (rev 9124)
@@ -1,87 +0,0 @@
- qgsnumericscalebarstyle.cpp
- begin : June 2008
- email : marco.hugentobler at karto.baug.ethz.ch
-#include "qgsnumericscalebarstyle.h"
-#include "qgscomposerscalebar.h"
-#include <QList>
-QgsNumericScaleBarStyle::QgsNumericScaleBarStyle(QgsComposerScaleBar* bar): QgsScaleBarStyle(bar)
-QgsNumericScaleBarStyle::QgsNumericScaleBarStyle(): QgsScaleBarStyle(0)
-QgsNumericScaleBarStyle::~QgsNumericScaleBarStyle()
-QString QgsNumericScaleBarStyle::name() const
- return "Numeric";
-void QgsNumericScaleBarStyle::draw(QPainter* p, double xOffset) const
- if(!p || !mScaleBar)
- return;
- p->save();
- p->setFont(mScaleBar->font());
- p->drawText(QPointF(mScaleBar->pen().widthF() + mScaleBar->boxContentSpace(), mScaleBar->boxContentSpace() \
- + mScaleBar->fontHeight()), scaleText());
- p->restore();
-QRectF QgsNumericScaleBarStyle::calculateBoxSize() const
- QRectF rect;
- if(!mScaleBar)
- return rect;
- QFontMetricsF fontMetrics(mScaleBar->font());
- return QRectF(mScaleBar->transform().dx(), mScaleBar->transform().dy(), 2 * mScaleBar->boxContentSpace() \
- + 2 * mScaleBar->pen().width() + fontMetrics.width(scaleText()), \
- mScaleBar->fontHeight() + 2 * mScaleBar->boxContentSpace());
-QString QgsNumericScaleBarStyle::scaleText() const
- QString scaleBarText;
- if(mScaleBar)
- //find out scale
- const QgsComposerMap* composerMap = mScaleBar->composerMap();
- if(composerMap)
- double scaleDenominator = composerMap->scale();
- scaleBarText = "1:" + QString::number(scaleDenominator);
- return scaleBarText;
Deleted: trunk/qgis/src/app/composer/qgsnumericscalebarstyle.h
--- trunk/qgis/src/app/composer/qgsnumericscalebarstyle.h 2008-08-23 07:18:39 UTC (rev 9123)
+++ trunk/qgis/src/app/composer/qgsnumericscalebarstyle.h 2008-08-23 07:45:12 UTC (rev 9124)
@@ -1,44 +0,0 @@
- qgsnumericscalebarstyle.h
- begin : June 2008
-#ifndef QGSNUMERICSCALEBARSTYLE_H
-#define QGSNUMERICSCALEBARSTYLE_H
-#include "qgsscalebarstyle.h"
- * A scale bar style that draws text in the form of '1:XXXXX'
-class QgsNumericScaleBarStyle: public QgsScaleBarStyle
- public:
- QgsNumericScaleBarStyle(QgsComposerScaleBar* bar);
- ~QgsNumericScaleBarStyle();
- QString name() const;
- void draw(QPainter* p, double xOffset = 0) const;
- //calculation of box size is different compared to segment based scale bars
- QRectF calculateBoxSize() const;
- private:
- QgsNumericScaleBarStyle(); //forbidden
- /**Returns the text for the scale bar or an empty string in case of error*/
- QString scaleText() const;
-#endif
