[QGIS Commit] r9140 - in trunk/qgis/src: app/composer core/sqlite3
plugins/grass
svn_qgis at osgeo.org
Sat Aug 23 18:33:20 EDT 2008
Author: jef
Date: 2008-08-23 18:33:20 -0400 (Sat, 23 Aug 2008)
New Revision: 9140
trunk/qgis/src/app/composer/qgscomposer.cpp
trunk/qgis/src/app/composer/qgscomposer.h
trunk/qgis/src/core/sqlite3/sqlite3.c
trunk/qgis/src/core/sqlite3/sqlite3.h
trunk/qgis/src/plugins/grass/qgsgrassedit.cpp
trunk/qgis/src/plugins/grass/qgsgrassmapcalc.h
fix common typo
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2008-08-23 22:31:48 UTC (rev 9139)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2008-08-23 22:33:20 UTC (rev 9140)
@@ -422,7 +422,7 @@
// << /PageSize [ %d %d ] >> setpagedevice
// %d %d is width and height in points
- // WARNING: If QCanvasView recieves repaint signal during the printing
+ // WARNING: If QCanvasView receives repaint signal during the printing
// (e.g. covered by QPrinter::setup dialog) it breaks somehow drawing of QCanvas items
// (for example not all features in the map are drawn.
// I don't know how to stop temporarily updating, (I don't want to reimplement
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h 2008-08-23 22:31:48 UTC (rev 9139)
+++ trunk/qgis/src/app/composer/qgscomposer.h 2008-08-23 22:33:20 UTC (rev 9140)
@@ -42,12 +42,12 @@
/** \ingroup MapComposer
* \brief A gui for composing a printable map.
* The constructor creates empty composer, without compositions and mFirstTime set to true.
- * - if signal projectRead() is recieved all old compositions are deleted and
+ * - if signal projectRead() is received all old compositions are deleted and
* - if the composition exists in project it is created from project settings (mFirstTime set to false)
* - if the composition does not exist in project
* - if the composer is visible new default composition is created (mFirstTime set to false)
* - if the composer is not visible the composer is left empty (mFirstTime set to true)
- * - if signal newProject() is recieved all old compositions are deleted and
+ * - if signal newProject() is received all old compositions are deleted and
* - if the composer is visible a new default composition is created (mFirstTime set to false)
Modified: trunk/qgis/src/core/sqlite3/sqlite3.c
--- trunk/qgis/src/core/sqlite3/sqlite3.c 2008-08-23 22:31:48 UTC (rev 9139)
+++ trunk/qgis/src/core/sqlite3/sqlite3.c 2008-08-23 22:33:20 UTC (rev 9140)
@@ -3986,7 +3986,7 @@
** be deallocated after sqlite3_result_value() returns without harm.
** {U16491} These routines are called from within the different thread
- ** than the one containing the application-defined function that recieved
+ ** than the one containing the application-defined function that received
** the [sqlite3_context] pointer, the results are undefined.
SQLITE_API void sqlite3_result_blob( sqlite3_context*, const void*, int, void( * )( void* ) );
Modified: trunk/qgis/src/core/sqlite3/sqlite3.h
--- trunk/qgis/src/core/sqlite3/sqlite3.h 2008-08-23 22:31:48 UTC (rev 9139)
+++ trunk/qgis/src/core/sqlite3/sqlite3.h 2008-08-23 22:33:20 UTC (rev 9140)
@@ -3620,7 +3620,7 @@
Modified: trunk/qgis/src/plugins/grass/qgsgrassedit.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassedit.cpp 2008-08-23 22:31:48 UTC (rev 9139)
+++ trunk/qgis/src/plugins/grass/qgsgrassedit.cpp 2008-08-23 22:33:20 UTC (rev 9140)
@@ -1310,7 +1310,7 @@
Vect_reset_line( mEditPoints );
mSelectedLine = 0;
- // TODO: mTool != NEW_LINE is a hack for lines until more buttons can be recieved
+ // TODO: mTool != NEW_LINE is a hack for lines until more buttons can be received
if ( mAttributes && mTool != QgsGrassEdit::NEW_LINE && mTool != QgsGrassEdit::NEW_BOUNDARY )
delete mAttributes;
Modified: trunk/qgis/src/plugins/grass/qgsgrassmapcalc.h
--- trunk/qgis/src/plugins/grass/qgsgrassmapcalc.h 2008-08-23 22:31:48 UTC (rev 9139)
+++ trunk/qgis/src/plugins/grass/qgsgrassmapcalc.h 2008-08-23 22:33:20 UTC (rev 9140)
@@ -93,13 +93,13 @@
bool inputRegion( struct Cell_head *window, bool all );
QStringList output( int type );
- /** \brief recieves contentsMousePressEvent from view */
+ /** \brief receives contentsMousePressEvent from view */
void contentsMousePressEvent( QMouseEvent* );
- /** \brief recieves contentsMouseReleaseEvent from view */
+ /** \brief receives contentsMouseReleaseEvent from view */
void contentsMouseReleaseEvent( QMouseEvent* );
- /** \brief recieves contentsMouseMoveEvent from view */
+ /** \brief receives contentsMouseMoveEvent from view */
void contentsMouseMoveEvent( QMouseEvent* );
void keyPressEvent( QKeyEvent * e );
