[QGIS Commit] r9146 - in trunk/qgis/src: app app/composer gui
svn_qgis at osgeo.org
Sun Aug 24 06:17:09 EDT 2008
Author: mhugent
Date: 2008-08-24 06:17:08 -0400 (Sun, 24 Aug 2008)
New Revision: 9146
Added:
trunk/qgis/src/gui/qgscomposerview.cpp
trunk/qgis/src/gui/qgscomposerview.h
Removed:
trunk/qgis/src/app/composer/qgscomposerview.cpp
trunk/qgis/src/app/composer/qgscomposerview.h
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/gui/CMakeLists.txt
Moved composer view to gui for potential reuse by plugins
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2008-08-24 09:06:14 UTC (rev 9145)
+++ trunk/qgis/src/app/CMakeLists.txt 2008-08-24 10:17:08 UTC (rev 9146)
@@ -63,7 +63,6 @@
composer/qgscomposerscalebarwidget.cpp
composer/qgscomposerlegenditemdialog.cpp
composer/qgscomposerlegendwidget.cpp
- composer/qgscomposerview.cpp
composer/qgscompositionwidget.cpp
legend/qgslegendgroup.cpp
@@ -127,7 +126,6 @@
composer/qgscomposermapwidget.h
composer/qgscomposerpicturewidget.h
composer/qgscomposerscalebarwidget.h
- composer/qgscomposerview.h
composer/qgscompositionwidget.h
legend/qgslegend.h
Deleted: trunk/qgis/src/app/composer/qgscomposerview.cpp
--- trunk/qgis/src/app/composer/qgscomposerview.cpp 2008-08-24 09:06:14 UTC (rev 9145)
+++ trunk/qgis/src/app/composer/qgscomposerview.cpp 2008-08-24 10:17:08 UTC (rev 9146)
@@ -1,419 +0,0 @@
- qgscomposerview.cpp
- begin : January 2005
- copyright : (C) 2005 by Radim Blazek
- email : blazek at itc.it
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
-#include <QMouseEvent>
-#include <QKeyEvent>
-#include "qgscomposerview.h"
-#include "qgscomposerlabel.h"
-#include "qgscomposerlegend.h"
-#include "qgscomposermap.h"
-#include "qgscomposeritemgroup.h"
-#include "qgscomposerpicture.h"
-#include "qgscomposerscalebar.h"
-QgsComposerView::QgsComposerView( QWidget* parent, const char* name, Qt::WFlags f ) :
- QGraphicsView( parent ), mShiftKeyPressed( false ), mRubberBandItem( 0 ), mMoveContentItem( 0 )
- setResizeAnchor( QGraphicsView::AnchorViewCenter );
- setMouseTracking( true );
- viewport()->setMouseTracking( true );
-void QgsComposerView::mousePressEvent( QMouseEvent* e )
- if ( !composition() )
- return;
- QPointF scenePoint = mapToScene( e->pos() );
- switch ( mCurrentTool )
- //select/deselect items and pass mouse event further
- case Select:
- if ( !mShiftKeyPressed ) //keep selection if shift key pressed
- composition()->clearSelection();
- //select topmost item at position of event
- QgsComposerItem* selectedItem = composition()->composerItemAt( scenePoint );
- if ( selectedItem )
- selectedItem->setSelected( true );
- QGraphicsView::mousePressEvent( e );
- emit selectedItemChanged( selectedItem );
- break;
- case MoveItemContent:
- //store item as member if it is selected and cursor is over item
- QgsComposerItem* item = dynamic_cast<QgsComposerItem*>( itemAt( e->pos() ) );
- if ( item )
- mMoveContentStartPos = scenePoint;
- mMoveContentItem = item;
- break;
- //create rubber band
- case AddMap:
- QTransform t;
- mRubberBandItem = new QGraphicsRectItem( 0, 0, 0, 0 );
- t.translate( scenePoint.x(), scenePoint.y() );
- mRubberBandItem->setTransform( t );
- mRubberBandItem->setZValue( 100 );
- scene()->addItem( mRubberBandItem );
- scene()->update();
- break;
- case AddLabel:
- QgsComposerLabel* newLabelItem = new QgsComposerLabel( composition() );
- newLabelItem->setText( "Quantum GIS" );
- newLabelItem->adjustSizeToText();
- scene()->addItem( newLabelItem );
- emit composerLabelAdded( newLabelItem );
- scene()->clearSelection();
- newLabelItem->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), newLabelItem->rect().width(), newLabelItem->rect().height() ) );
- newLabelItem->setZValue( 60 );
- newLabelItem->setSelected( true );
- emit selectedItemChanged( newLabelItem );
- emit actionFinished();
- break;
- case AddScalebar:
- QgsComposerScaleBar* newScaleBar = new QgsComposerScaleBar( composition() );
- //take first available map...
- QList<const QgsComposerMap*> mapItemList = composition()->composerMapItems();
- if ( mapItemList.size() > 0 )
- newScaleBar->setComposerMap( mapItemList.at( 0 ) );
- newScaleBar->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), 20, 20 ) );
- newScaleBar->applyDefaultSettings(); //4 segments, 1/5 of composer map width
- scene()->addItem( newScaleBar );
- emit composerScaleBarAdded( newScaleBar );
- newScaleBar->setZValue( 60 );
- newScaleBar->setSelected( true );
- emit selectedItemChanged( newScaleBar );
- break;
- case AddLegend:
- QgsComposerLegend* newLegend = new QgsComposerLegend( composition() );
- scene()->addItem( newLegend );
- emit composerLegendAdded( newLegend );
- newLegend->setZValue( 60 );
- newLegend->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), newLegend->rect().width(), newLegend->rect().height() ) );
- newLegend->setSelected( true );
- emit selectedItemChanged( newLegend );
- break;
- case AddPicture:
- QgsComposerPicture* newPicture = new QgsComposerPicture( composition() );
- scene()->addItem( newPicture );
- emit composerPictureAdded( newPicture );
- newPicture->setZValue( 60 );
- newPicture->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), 30, 30 ) );
- newPicture->setSelected( true );
- emit selectedItemChanged( newPicture );
- default:
- break;
-void QgsComposerView::mouseReleaseEvent( QMouseEvent* e )
- return;
- case Select:
- QGraphicsView::mouseReleaseEvent( e );
- break;
- if ( mMoveContentItem )
- //update map preview if composer map
- QgsComposerMap* composerMap = dynamic_cast<QgsComposerMap*>( mMoveContentItem );
- if ( composerMap )
- composerMap->setOffset( 0, 0 );
- double moveX = scenePoint.x() - mMoveContentStartPos.x();
- double moveY = scenePoint.y() - mMoveContentStartPos.y();
- mMoveContentItem->moveContent( -moveX, -moveY );
- mMoveContentItem->update();
- mMoveContentItem = 0;
- break;
- case AddMap:
- if ( !mRubberBandItem || mRubberBandItem->rect().width() < 0.1 || mRubberBandItem->rect().width() < 0.1 )
- scene()->removeItem( mRubberBandItem );
- delete mRubberBandItem;
- return;
- QgsComposerMap* composerMap = new QgsComposerMap( composition(), mRubberBandItem->transform().dx(), mRubberBandItem->transform().dy(), mRubberBandItem->rect().width(), mRubberBandItem->rect().height() );
- composerMap->setPreviewMode( QgsComposerMap::Rectangle );
- emit composerMapAdded( composerMap );
- composerMap->setZValue( 50 );
- scene()->addItem( composerMap );
- composerMap->setSelected( true );
- emit selectedItemChanged( composerMap );
- break;
- default:
- break;
-void QgsComposerView::mouseMoveEvent( QMouseEvent* e )
- return;
- if ( e->buttons() == Qt::NoButton )
- if ( mCurrentTool == Select )
- QGraphicsView::mouseMoveEvent( e );
- else
- double newWidth, newHeight; //for rubber band
- case Select:
- break;
- case AddMap:
- //adjust rubber band item
- newWidth = scenePoint.x() - mRubberBandItem->transform().dx();
- newHeight = scenePoint.y() - mRubberBandItem->transform().dy();
- mRubberBandItem->setRect( 0, 0, newWidth, newHeight );
- break;
- composerMap->setOffset( scenePoint.x() - mMoveContentStartPos.x(), scenePoint.y() - mMoveContentStartPos.y() );
- composerMap->update();
- break;
- default:
- break;
-void QgsComposerView::keyPressEvent( QKeyEvent * e )
- if ( e->key() == Qt::Key_Shift )
- mShiftKeyPressed = true;
- return;
- QList<QgsComposerItem*> composerItemList = composition()->selectedComposerItems();
- QList<QgsComposerItem*>::iterator itemIt = composerItemList.begin();
- //delete selected items
- if ( e->key() == Qt::Key_Delete )
- for ( ; itemIt != composerItemList.end(); ++itemIt )
- composition()->removeItem( *itemIt );
- delete( *itemIt );
- emit itemRemoved( *itemIt );
- else if ( e->key() == Qt::Key_Left )
- ( *itemIt )->move( -1.0, 0.0 );
- else if ( e->key() == Qt::Key_Right )
- ( *itemIt )->move( 1.0, 0.0 );
- else if ( e->key() == Qt::Key_Down )
- ( *itemIt )->move( 0.0, 1.0 );
- else if ( e->key() == Qt::Key_Up )
- ( *itemIt )->move( 0.0, -1.0 );
-void QgsComposerView::keyReleaseEvent( QKeyEvent * e )
- mShiftKeyPressed = false;
-void QgsComposerView::setComposition( QgsComposition* c )
- setScene( c );
-QgsComposition* QgsComposerView::composition()
- if ( scene() )
- QgsComposition* c = dynamic_cast<QgsComposition*>( scene() );
- if ( c )
- return c;
- return 0;
-void QgsComposerView::groupItems()
- return;
- QList<QgsComposerItem*> selectionList = composition()->selectedComposerItems();
- if ( selectionList.size() < 2 )
- return; //not enough items for a group
- QgsComposerItemGroup* itemGroup = new QgsComposerItemGroup( composition() );
- //connect signal/slot to let item group tell if child items get removed
- connect( itemGroup, SIGNAL( childItemDeleted( QgsComposerItem* ) ), this, SLOT( sendItemRemovedSignal( QgsComposerItem* ) ) );
- QList<QgsComposerItem*>::iterator itemIter = selectionList.begin();
- for ( ; itemIter != selectionList.end(); ++itemIter )
- itemGroup->addItem( *itemIter );
- composition()->addItem( itemGroup );
- itemGroup->setSelected( true );
- emit selectedItemChanged( itemGroup );
-void QgsComposerView::ungroupItems()
- return;
- QgsComposerItemGroup* itemGroup = dynamic_cast<QgsComposerItemGroup*>( *itemIter );
- if ( itemGroup )
- itemGroup->removeItems();
- composition()->removeItem( *itemIter );
- delete( *itemIter );
- emit itemRemoved( *itemIter );
-void QgsComposerView::sendItemRemovedSignal( QgsComposerItem* item )
- emit itemRemoved( item );
Deleted: trunk/qgis/src/app/composer/qgscomposerview.h
--- trunk/qgis/src/app/composer/qgscomposerview.h 2008-08-24 09:06:14 UTC (rev 9145)
+++ trunk/qgis/src/app/composer/qgscomposerview.h 2008-08-24 10:17:08 UTC (rev 9146)
@@ -1,117 +0,0 @@
- qgscomposerview.h
-/* $Id$ */
-#ifndef QGSCOMPOSERVIEW_H
-#define QGSCOMPOSERVIEW_H
-#include <QGraphicsView>
-class QKeyEvent;
-class QMouseEvent;
-class QgsComposition;
-class QgsComposerItem;
-class QgsComposerLabel;
-class QgsComposerLegend;
-class QgsComposerMap;
-class QgsComposerPicture;
-class QgsComposerScaleBar;
-/** \ingroup MapComposer
- * Widget to display the composer items. Manages the composer tools and the
- * mouse/key events.
- * Creates the composer items according to the current map tools and keeps track
- * of the rubber band item.
-class QgsComposerView: public QGraphicsView
- Q_OBJECT
- public:
- /**Current tool*/
- enum Tool
- Select = 0, // Select/Move item
- AddMap, // add new map
- AddLegend, // add vector legend
- AddLabel, // add label
- AddScalebar, // add scalebar
- AddPicture, // add raster/vector picture
- MoveItemContent //move content of item (e.g. content of map)
- QgsComposerView( QWidget* parent = 0, const char* name = 0, Qt::WFlags f = 0 );
- /**Add an item group containing the selected items*/
- void groupItems();
- /**Ungroups the selected items*/
- void ungroupItems();
- QgsComposerView::Tool currentTool() const {return mCurrentTool;}
- void setCurrentTool( QgsComposerView::Tool t ) {mCurrentTool = t;}
- /**Sets composition (derived from QGraphicsScene)*/
- void setComposition( QgsComposition* c );
- /**Returns the composition or 0 in case of error*/
- QgsComposition* composition();
- protected:
- void mousePressEvent( QMouseEvent* );
- void mouseReleaseEvent( QMouseEvent* );
- void mouseMoveEvent( QMouseEvent* );
- void keyPressEvent( QKeyEvent * e );
- void keyReleaseEvent( QKeyEvent * e );
- private:
- /**Status of shift key (used for multiple selection)*/
- bool mShiftKeyPressed;
- /**Current composer tool*/
- QgsComposerView::Tool mCurrentTool;
- /**Rubber band item*/
- QGraphicsRectItem* mRubberBandItem;
- /**Item to move content*/
- QgsComposerItem* mMoveContentItem;
- /**Start position of content move*/
- QPointF mMoveContentStartPos;
- public slots:
- /**For QgsComposerItemGroup to send its signals to QgsComposer (or other classes that keep track of input widgets)*/
- void sendItemRemovedSignal( QgsComposerItem* item );
- signals:
- /**Is emitted when selected item changed. If 0, no item is selected*/
- void selectedItemChanged( const QgsComposerItem* selected );
- /**Ist emittted when new composer label has been added to the view*/
- void composerLabelAdded( QgsComposerLabel* label );
- /**Is emitted when new composer map has been added to the view*/
- void composerMapAdded( QgsComposerMap* map );
- /**Is emitted when new composer scale bar has been added*/
- void composerScaleBarAdded( QgsComposerScaleBar* scalebar );
- /**Is emitted when a new composer legend has been added*/
- void composerLegendAdded( QgsComposerLegend* legend );
- /**Is emitted when a new composer picture has been added*/
- void composerPictureAdded( QgsComposerPicture* picture );
- /**Is emitted when a composer item has been removed from the scene*/
- void itemRemoved( QgsComposerItem* );
- /**Current action (e.g. adding composer map) has been finished. The purpose of this signal is that
- QgsComposer may set the selection tool again*/
- void actionFinished();
-#endif
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt 2008-08-24 09:06:14 UTC (rev 9145)
+++ trunk/qgis/src/gui/CMakeLists.txt 2008-08-24 10:17:08 UTC (rev 9146)
@@ -3,6 +3,7 @@
qgisgui.cpp
qgisinterface.cpp
qgscolorbutton.cpp
+qgscomposerview.cpp
qgscursors.cpp
qgsdetaileditemdelegate.cpp
qgsdetaileditemwidget.cpp
@@ -28,6 +29,7 @@
SET(QGIS_GUI_MOC_HDRS
+qgscomposerview.h
qgsdetaileditemdelegate.h
qgsdetaileditemwidget.h
qgisinterface.h
@@ -44,7 +46,7 @@
QT4_WRAP_CPP(QGIS_GUI_MOC_SRCS ${QGIS_GUI_MOC_HDRS})
INCLUDE_DIRECTORIES(${CMAKE_CURRENT_SOURCE_DIR} ../core
- ../core/raster ../core/renderer ../core/symbology
+ ../core/composer ../core/raster ../core/renderer ../core/symbology
${CMAKE_CURRENT_BINARY_DIR}
${CMAKE_CURRENT_BINARY_DIR}/../ui
${GEOS_INCLUDE_DIR}
Copied: trunk/qgis/src/gui/qgscomposerview.cpp (from rev 9141, trunk/qgis/src/app/composer/qgscomposerview.cpp)
--- trunk/qgis/src/gui/qgscomposerview.cpp (rev 0)
+++ trunk/qgis/src/gui/qgscomposerview.cpp 2008-08-24 10:17:08 UTC (rev 9146)
@@ -0,0 +1,419 @@
+ qgscomposerview.cpp
+ begin : January 2005
+ copyright : (C) 2005 by Radim Blazek
+ email : blazek at itc.it
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+#include <QMouseEvent>
+#include <QKeyEvent>
+#include "qgscomposerview.h"
+#include "qgscomposerlabel.h"
+#include "qgscomposerlegend.h"
+#include "qgscomposermap.h"
+#include "qgscomposeritemgroup.h"
+#include "qgscomposerpicture.h"
+#include "qgscomposerscalebar.h"
+QgsComposerView::QgsComposerView( QWidget* parent, const char* name, Qt::WFlags f ) :
+ QGraphicsView( parent ), mShiftKeyPressed( false ), mRubberBandItem( 0 ), mMoveContentItem( 0 )
+ setResizeAnchor( QGraphicsView::AnchorViewCenter );
+ setMouseTracking( true );
+ viewport()->setMouseTracking( true );
+void QgsComposerView::mousePressEvent( QMouseEvent* e )
+ if ( !composition() )
+ return;
+ QPointF scenePoint = mapToScene( e->pos() );
+ switch ( mCurrentTool )
+ //select/deselect items and pass mouse event further
+ case Select:
+ if ( !mShiftKeyPressed ) //keep selection if shift key pressed
+ composition()->clearSelection();
+ //select topmost item at position of event
+ QgsComposerItem* selectedItem = composition()->composerItemAt( scenePoint );
+ if ( selectedItem )
+ selectedItem->setSelected( true );
+ QGraphicsView::mousePressEvent( e );
+ emit selectedItemChanged( selectedItem );
+ break;
+ case MoveItemContent:
+ //store item as member if it is selected and cursor is over item
+ QgsComposerItem* item = dynamic_cast<QgsComposerItem*>( itemAt( e->pos() ) );
+ if ( item )
+ mMoveContentStartPos = scenePoint;
+ mMoveContentItem = item;
+ break;
+ //create rubber band
+ case AddMap:
+ QTransform t;
+ mRubberBandItem = new QGraphicsRectItem( 0, 0, 0, 0 );
+ t.translate( scenePoint.x(), scenePoint.y() );
+ mRubberBandItem->setTransform( t );
+ mRubberBandItem->setZValue( 100 );
+ scene()->addItem( mRubberBandItem );
+ scene()->update();
+ break;
+ case AddLabel:
+ QgsComposerLabel* newLabelItem = new QgsComposerLabel( composition() );
+ newLabelItem->setText( "Quantum GIS" );
+ newLabelItem->adjustSizeToText();
+ scene()->addItem( newLabelItem );
+ emit composerLabelAdded( newLabelItem );
+ scene()->clearSelection();
+ newLabelItem->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), newLabelItem->rect().width(), newLabelItem->rect().height() ) );
+ newLabelItem->setZValue( 60 );
+ newLabelItem->setSelected( true );
+ emit selectedItemChanged( newLabelItem );
+ emit actionFinished();
+ break;
+ case AddScalebar:
+ QgsComposerScaleBar* newScaleBar = new QgsComposerScaleBar( composition() );
+ //take first available map...
+ QList<const QgsComposerMap*> mapItemList = composition()->composerMapItems();
+ if ( mapItemList.size() > 0 )
+ newScaleBar->setComposerMap( mapItemList.at( 0 ) );
+ newScaleBar->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), 20, 20 ) );
+ newScaleBar->applyDefaultSettings(); //4 segments, 1/5 of composer map width
+ scene()->addItem( newScaleBar );
+ emit composerScaleBarAdded( newScaleBar );
+ newScaleBar->setZValue( 60 );
+ newScaleBar->setSelected( true );
+ emit selectedItemChanged( newScaleBar );
+ break;
+ case AddLegend:
+ QgsComposerLegend* newLegend = new QgsComposerLegend( composition() );
+ scene()->addItem( newLegend );
+ emit composerLegendAdded( newLegend );
+ newLegend->setZValue( 60 );
+ newLegend->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), newLegend->rect().width(), newLegend->rect().height() ) );
+ newLegend->setSelected( true );
+ emit selectedItemChanged( newLegend );
+ break;
+ case AddPicture:
+ QgsComposerPicture* newPicture = new QgsComposerPicture( composition() );
+ scene()->addItem( newPicture );
+ emit composerPictureAdded( newPicture );
+ newPicture->setZValue( 60 );
+ newPicture->setSceneRect( QRectF( scenePoint.x(), scenePoint.y(), 30, 30 ) );
+ newPicture->setSelected( true );
+ emit selectedItemChanged( newPicture );
+ default:
+ break;
+void QgsComposerView::mouseReleaseEvent( QMouseEvent* e )
+ return;
+ case Select:
+ QGraphicsView::mouseReleaseEvent( e );
+ break;
+ if ( mMoveContentItem )
+ //update map preview if composer map
+ QgsComposerMap* composerMap = dynamic_cast<QgsComposerMap*>( mMoveContentItem );
+ if ( composerMap )
+ composerMap->setOffset( 0, 0 );
+ double moveX = scenePoint.x() - mMoveContentStartPos.x();
+ double moveY = scenePoint.y() - mMoveContentStartPos.y();
+ mMoveContentItem->moveContent( -moveX, -moveY );
+ mMoveContentItem->update();
+ mMoveContentItem = 0;
+ break;
+ case AddMap:
+ if ( !mRubberBandItem || mRubberBandItem->rect().width() < 0.1 || mRubberBandItem->rect().width() < 0.1 )
+ scene()->removeItem( mRubberBandItem );
+ delete mRubberBandItem;
+ return;
+ QgsComposerMap* composerMap = new QgsComposerMap( composition(), mRubberBandItem->transform().dx(), mRubberBandItem->transform().dy(), mRubberBandItem->rect().width(), mRubberBandItem->rect().height() );
+ composerMap->setPreviewMode( QgsComposerMap::Rectangle );
+ emit composerMapAdded( composerMap );
+ composerMap->setZValue( 50 );
+ scene()->addItem( composerMap );
+ composerMap->setSelected( true );
+ emit selectedItemChanged( composerMap );
+ break;
+ default:
+ break;
+void QgsComposerView::mouseMoveEvent( QMouseEvent* e )
+ return;
+ if ( e->buttons() == Qt::NoButton )
+ if ( mCurrentTool == Select )
+ QGraphicsView::mouseMoveEvent( e );
+ else
+ double newWidth, newHeight; //for rubber band
+ case Select:
+ break;
+ case AddMap:
+ //adjust rubber band item
+ newWidth = scenePoint.x() - mRubberBandItem->transform().dx();
+ newHeight = scenePoint.y() - mRubberBandItem->transform().dy();
+ mRubberBandItem->setRect( 0, 0, newWidth, newHeight );
+ break;
+ composerMap->setOffset( scenePoint.x() - mMoveContentStartPos.x(), scenePoint.y() - mMoveContentStartPos.y() );
+ composerMap->update();
+ break;
+ default:
+ break;
+void QgsComposerView::keyPressEvent( QKeyEvent * e )
+ if ( e->key() == Qt::Key_Shift )
+ mShiftKeyPressed = true;
+ return;
+ QList<QgsComposerItem*> composerItemList = composition()->selectedComposerItems();
+ QList<QgsComposerItem*>::iterator itemIt = composerItemList.begin();
+ //delete selected items
+ if ( e->key() == Qt::Key_Delete )
+ for ( ; itemIt != composerItemList.end(); ++itemIt )
+ composition()->removeItem( *itemIt );
+ delete( *itemIt );
+ emit itemRemoved( *itemIt );
+ else if ( e->key() == Qt::Key_Left )
+ ( *itemIt )->move( -1.0, 0.0 );
+ else if ( e->key() == Qt::Key_Right )
+ ( *itemIt )->move( 1.0, 0.0 );
+ else if ( e->key() == Qt::Key_Down )
+ ( *itemIt )->move( 0.0, 1.0 );
+ else if ( e->key() == Qt::Key_Up )
+ ( *itemIt )->move( 0.0, -1.0 );
+void QgsComposerView::keyReleaseEvent( QKeyEvent * e )
+ mShiftKeyPressed = false;
+void QgsComposerView::setComposition( QgsComposition* c )
+ setScene( c );
+QgsComposition* QgsComposerView::composition()
+ if ( scene() )
+ QgsComposition* c = dynamic_cast<QgsComposition*>( scene() );
+ if ( c )
+ return c;
+ return 0;
+void QgsComposerView::groupItems()
+ return;
+ QList<QgsComposerItem*> selectionList = composition()->selectedComposerItems();
+ if ( selectionList.size() < 2 )
+ return; //not enough items for a group
+ QgsComposerItemGroup* itemGroup = new QgsComposerItemGroup( composition() );
+ //connect signal/slot to let item group tell if child items get removed
+ connect( itemGroup, SIGNAL( childItemDeleted( QgsComposerItem* ) ), this, SLOT( sendItemRemovedSignal( QgsComposerItem* ) ) );
+ QList<QgsComposerItem*>::iterator itemIter = selectionList.begin();
+ for ( ; itemIter != selectionList.end(); ++itemIter )
+ itemGroup->addItem( *itemIter );
+ composition()->addItem( itemGroup );
+ itemGroup->setSelected( true );
+ emit selectedItemChanged( itemGroup );
+void QgsComposerView::ungroupItems()
+ return;
+ QgsComposerItemGroup* itemGroup = dynamic_cast<QgsComposerItemGroup*>( *itemIter );
+ if ( itemGroup )
+ itemGroup->removeItems();
+ composition()->removeItem( *itemIter );
+ delete( *itemIter );
+ emit itemRemoved( *itemIter );
+void QgsComposerView::sendItemRemovedSignal( QgsComposerItem* item )
+ emit itemRemoved( item );
Copied: trunk/qgis/src/gui/qgscomposerview.h (from rev 9141, trunk/qgis/src/app/composer/qgscomposerview.h)
--- trunk/qgis/src/gui/qgscomposerview.h (rev 0)
+++ trunk/qgis/src/gui/qgscomposerview.h 2008-08-24 10:17:08 UTC (rev 9146)
@@ -0,0 +1,117 @@
+ qgscomposerview.h
+/* $Id$ */
+#ifndef QGSCOMPOSERVIEW_H
+#define QGSCOMPOSERVIEW_H
+#include <QGraphicsView>
+class QKeyEvent;
+class QMouseEvent;
+class QgsComposition;
+class QgsComposerItem;
+class QgsComposerLabel;
+class QgsComposerLegend;
+class QgsComposerMap;
+class QgsComposerPicture;
+class QgsComposerScaleBar;
+/** \ingroup MapComposer
+ * Widget to display the composer items. Manages the composer tools and the
+ * mouse/key events.
+ * Creates the composer items according to the current map tools and keeps track
+ * of the rubber band item.
+class QgsComposerView: public QGraphicsView
+ Q_OBJECT
+ public:
+ /**Current tool*/
+ enum Tool
+ Select = 0, // Select/Move item
+ AddMap, // add new map
+ AddLegend, // add vector legend
+ AddLabel, // add label
+ AddScalebar, // add scalebar
+ AddPicture, // add raster/vector picture
+ MoveItemContent //move content of item (e.g. content of map)
+ QgsComposerView( QWidget* parent = 0, const char* name = 0, Qt::WFlags f = 0 );
+ /**Add an item group containing the selected items*/
+ void groupItems();
+ /**Ungroups the selected items*/
+ void ungroupItems();
+ QgsComposerView::Tool currentTool() const {return mCurrentTool;}
+ void setCurrentTool( QgsComposerView::Tool t ) {mCurrentTool = t;}
+ /**Sets composition (derived from QGraphicsScene)*/
+ void setComposition( QgsComposition* c );
+ /**Returns the composition or 0 in case of error*/
+ QgsComposition* composition();
+ protected:
+ void mousePressEvent( QMouseEvent* );
+ void mouseReleaseEvent( QMouseEvent* );
+ void mouseMoveEvent( QMouseEvent* );
+ void keyPressEvent( QKeyEvent * e );
+ void keyReleaseEvent( QKeyEvent * e );
+ private:
+ /**Status of shift key (used for multiple selection)*/
+ bool mShiftKeyPressed;
+ /**Current composer tool*/
+ QgsComposerView::Tool mCurrentTool;
+ /**Rubber band item*/
+ QGraphicsRectItem* mRubberBandItem;
+ /**Item to move content*/
+ QgsComposerItem* mMoveContentItem;
+ /**Start position of content move*/
+ QPointF mMoveContentStartPos;
+ public slots:
+ /**For QgsComposerItemGroup to send its signals to QgsComposer (or other classes that keep track of input widgets)*/
+ void sendItemRemovedSignal( QgsComposerItem* item );
+ signals:
+ /**Is emitted when selected item changed. If 0, no item is selected*/
+ void selectedItemChanged( const QgsComposerItem* selected );
+ /**Ist emittted when new composer label has been added to the view*/
+ void composerLabelAdded( QgsComposerLabel* label );
+ /**Is emitted when new composer map has been added to the view*/
+ void composerMapAdded( QgsComposerMap* map );
+ /**Is emitted when new composer scale bar has been added*/
+ void composerScaleBarAdded( QgsComposerScaleBar* scalebar );
+ /**Is emitted when a new composer legend has been added*/
+ void composerLegendAdded( QgsComposerLegend* legend );
+ /**Is emitted when a new composer picture has been added*/
+ void composerPictureAdded( QgsComposerPicture* picture );
+ /**Is emitted when a composer item has been removed from the scene*/
+ void itemRemoved( QgsComposerItem* );
+ /**Current action (e.g. adding composer map) has been finished. The purpose of this signal is that
+ QgsComposer may set the selection tool again*/
+ void actionFinished();
+#endif
