[QGIS Commit] r9164 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Mon Aug 25 06:58:25 EDT 2008
Author: leolami
Date: 2008-08-25 06:58:24 -0400 (Mon, 25 Aug 2008)
New Revision: 9164
Removed:
trunk/qgis/src/plugins/grass/modules/r.proj.res.1.png
trunk/qgis/src/plugins/grass/modules/r.proj.res.2.png
trunk/qgis/src/plugins/grass/modules/r.proj.res.qgm
trunk/qgis/src/plugins/grass/modules/v.in.shape.1.svg
trunk/qgis/src/plugins/grass/modules/v.in.shape.2.png
trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.1.svg
trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.2.png
trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.qgm
trunk/qgis/src/plugins/grass/modules/v.in.shape.qgm
Remove v.in.shape, v.in.shape.loc and r.proj.res
Deleted: trunk/qgis/src/plugins/grass/modules/r.proj.res.1.png
(Binary files differ)
Deleted: trunk/qgis/src/plugins/grass/modules/r.proj.res.2.png
Deleted: trunk/qgis/src/plugins/grass/modules/r.proj.res.qgm
--- trunk/qgis/src/plugins/grass/modules/r.proj.res.qgm 2008-08-25 09:18:42 UTC (rev 9163)
+++ trunk/qgis/src/plugins/grass/modules/r.proj.res.qgm 2008-08-25 10:58:24 UTC (rev 9164)
@@ -1,11 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Re-project a raster map from one location to the current location and change the map resolution" module="r.proj">
- <file key="input" />
- <option key="dbase" />
- <option key="location" />
- <option key="mapset" />
- <option key="method" />
- <option key="resolution" />
-</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules/v.in.shape.1.svg
--- trunk/qgis/src/plugins/grass/modules/v.in.shape.1.svg 2008-08-25 09:18:42 UTC (rev 9163)
+++ trunk/qgis/src/plugins/grass/modules/v.in.shape.1.svg 2008-08-25 10:58:24 UTC (rev 9164)
@@ -1,8 +0,0 @@
-<?xml version="1.0" standalone="no"?>
-<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 20001102//EN" "http://www.w3.org/TR/2000/CR-SVG-20001102/DTD/svg-20001102.dtd">
-<svg xmlns="http://www.w3.org/2000/svg" width="500" x="0" y="0" height="500" id="/hardmnt/janacek0/ssi/blazek/inst/qgis/cvs/plugins/grass/modules/r.to.vect.line.2" >
- <rect width="500" x="0" y="0" height="500" style="stroke:rgb(0,0,0);stroke-width:0;fill:rgb(255,255,255);" />
- <g style="stroke:rgb(0,0,0);stroke-width:0.9;fill:none;" >
- <line transform="translate(0.331263 0.331263)" style="stroke:rgb(0,0,0);stroke-width:15;fill:rgb(220,220,220);" y1="401" y2="96" x1="94" x2="399" />
- </g>
-</svg>
Deleted: trunk/qgis/src/plugins/grass/modules/v.in.shape.2.png
Deleted: trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.1.svg
--- trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.1.svg 2008-08-25 09:18:42 UTC (rev 9163)
+++ trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.1.svg 2008-08-25 10:58:24 UTC (rev 9164)
@@ -1,8 +0,0 @@
- </g>
-</svg>
Deleted: trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.2.png
Deleted: trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.qgm 2008-08-25 09:18:42 UTC (rev 9163)
+++ trunk/qgis/src/plugins/grass/modules/v.in.shape.loc.qgm 2008-08-25 10:58:24 UTC (rev 9164)
@@ -1,12 +0,0 @@
-<qgisgrassmodule label="Import ESRI Shapefile vector layers and create a fitted location" module="v.in.ogr">
- <flag key="o" answer="on" hidden="yes" />
- <flag key="z" answer="off" hidden="no" />
- <flag key="e" answer="off" hidden="no" />
- <file key="dsn" label="ESRI Shapefile" filters="shp(*.shp)" />
- <option key="output" />
- <option key="type" />
-</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules/v.in.shape.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.shape.qgm 2008-08-25 09:18:42 UTC (rev 9163)
+++ trunk/qgis/src/plugins/grass/modules/v.in.shape.qgm 2008-08-25 10:58:24 UTC (rev 9164)
@@ -1,11 +0,0 @@
-<qgisgrassmodule label="Import ESRI Shapefile vector layers" module="v.in.ogr">
- <flag key="r" answer="off" hidden="no" />
-</qgisgrassmodule>
