[QGIS Commit] r9167 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Mon Aug 25 10:15:50 EDT 2008
Author: leolami
Date: 2008-08-25 10:15:49 -0400 (Mon, 25 Aug 2008)
New Revision: 9167
trunk/qgis/src/plugins/grass/modules/v.db.select.qgm
trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm
Update v.db.select, v.db.select.where
Modified: trunk/qgis/src/plugins/grass/modules/v.db.select.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.select.qgm 2008-08-25 13:59:17 UTC (rev 9166)
+++ trunk/qgis/src/plugins/grass/modules/v.db.select.qgm 2008-08-25 14:15:49 UTC (rev 9167)
@@ -3,6 +3,6 @@
<qgisgrassmodule label="Prints vector map attribute" module="v.db.select">
<option key="map" layeroption="layer" />
- <option key="column" />
+ <field key="column" layer="map" type="integer,double,varchar"/>
<option key="fs" answer="|" hidden="yes" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm 2008-08-25 13:59:17 UTC (rev 9166)
+++ trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm 2008-08-25 14:15:49 UTC (rev 9167)
@@ -3,7 +3,7 @@
<qgisgrassmodule label="Prints vector map attributes with SQL" module="v.db.select">
<option key="where" />
</qgisgrassmodule>
