[QGIS Commit] r9174 - in trunk/qgis/src: app/composer core/composer
gui
svn_qgis at osgeo.org
Tue Aug 26 07:06:17 EDT 2008
Author: mhugent
Date: 2008-08-26 07:06:17 -0400 (Tue, 26 Aug 2008)
New Revision: 9174
trunk/qgis/src/app/composer/qgscomposer.h
trunk/qgis/src/app/composer/qgscomposermapwidget.cpp
trunk/qgis/src/core/composer/qgscomposermap.cpp
trunk/qgis/src/gui/qgscomposerview.cpp
Better protection agains multiple map drawings with move content tool
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h 2008-08-26 09:16:13 UTC (rev 9173)
+++ trunk/qgis/src/app/composer/qgscomposer.h 2008-08-26 11:06:17 UTC (rev 9174)
@@ -212,13 +212,6 @@
/**Etablishes the signal slot connection for the class*/
void connectSlots();
- /** \brief move up the content of the file
- \param file file
- \param from starting position
- \param shift shift in bytes
- bool shiftFileContent( QFile *file, qint64 start, int shift );
//! Set buttons up
void setToolActionsOff( void );
Modified: trunk/qgis/src/app/composer/qgscomposermapwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposermapwidget.cpp 2008-08-26 09:16:13 UTC (rev 9173)
+++ trunk/qgis/src/app/composer/qgscomposermapwidget.cpp 2008-08-26 11:06:17 UTC (rev 9174)
@@ -98,6 +98,11 @@
return;
+ if(mComposerMap->isDrawing())
+ return;
QString comboText = mPreviewModeComboBox->currentText();
if ( comboText == tr( "Cache" ) )
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp 2008-08-26 09:16:13 UTC (rev 9173)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp 2008-08-26 11:06:17 UTC (rev 9174)
@@ -100,6 +100,13 @@
return;
+ if ( mDrawing )
+ return;
+ mDrawing = true;
QgsMapRenderer theMapRenderer;
theMapRenderer.setExtent( extent );
theMapRenderer.setOutputSize( size, dpi );
@@ -119,6 +126,8 @@
theMapRenderer.setScale( scale() );
theMapRenderer.render( painter );
theMapRenderer.setScale( bk_scale );
+ mDrawing = false;
void QgsComposerMap::cache( void )
@@ -158,18 +167,11 @@
void QgsComposerMap::paint( QPainter* painter, const QStyleOptionGraphicsItem* itemStyle, QWidget* pWidget )
- if ( mDrawing )
- return;
if ( !mComposition || !painter )
return;
- mDrawing = true;
QRectF thisPaintRect = QRectF( 0, 0, QGraphicsRectItem::rect().width(), QGraphicsRectItem::rect().height() );
painter->save();
painter->setClipRect( thisPaintRect );
@@ -218,7 +220,6 @@
painter->restore();
mLastScaleFactorX = currentScaleFactorX;
- mDrawing = false;
void QgsComposerMap::mapCanvasChanged( void )
@@ -251,20 +252,23 @@
void QgsComposerMap::moveContent( double dx, double dy )
- QRectF itemRect = rect();
- double xRatio = dx / itemRect.width();
- double yRatio = dy / itemRect.height();
- double xMoveMapCoord = mExtent.width() * xRatio;
- double yMoveMapCoord = -( mExtent.height() * yRatio );
- mExtent.setXMinimum( mExtent.xMin() + xMoveMapCoord );
- mExtent.setXMaximum( mExtent.xMax() + xMoveMapCoord );
- mExtent.setYmin( mExtent.yMin() + yMoveMapCoord );
- mExtent.setYmax( mExtent.yMax() + yMoveMapCoord );
- emit extentChanged();
- cache();
- update();
+ if(!mDrawing)
+ QRectF itemRect = rect();
+ double xRatio = dx / itemRect.width();
+ double yRatio = dy / itemRect.height();
+ double xMoveMapCoord = mExtent.width() * xRatio;
+ double yMoveMapCoord = -( mExtent.height() * yRatio );
+ mExtent.setXMinimum( mExtent.xMin() + xMoveMapCoord );
+ mExtent.setXMaximum( mExtent.xMax() + xMoveMapCoord );
+ mExtent.setYmin( mExtent.yMin() + yMoveMapCoord );
+ mExtent.setYmax( mExtent.yMax() + yMoveMapCoord );
+ emit extentChanged();
+ cache();
+ update();
void QgsComposerMap::setSceneRect( const QRectF& rectangle )
Modified: trunk/qgis/src/gui/qgscomposerview.cpp
--- trunk/qgis/src/gui/qgscomposerview.cpp 2008-08-26 09:16:13 UTC (rev 9173)
+++ trunk/qgis/src/gui/qgscomposerview.cpp 2008-08-26 11:06:17 UTC (rev 9174)
@@ -189,7 +189,6 @@
double moveX = scenePoint.x() - mMoveContentStartPos.x();
double moveY = scenePoint.y() - mMoveContentStartPos.y();
mMoveContentItem->moveContent( -moveX, -moveY );
- mMoveContentItem->update();
mMoveContentItem = 0;
break;
