[QGIS Commit] r9183 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Wed Aug 27 04:00:57 EDT 2008
Author: jef
Date: 2008-08-27 04:00:57 -0400 (Wed, 27 Aug 2008)
New Revision: 9183
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
postgres provider update
- track open cursors and commit transaction whenever no open cursors are left
- close cursor after immediately after feature retrieval (releases locks earlier)
- wrap postgres calls in Conn class
- introduce Result class to handle PQclear mostly transparently (fixes minor leaks)
- remove executeDbCommand method (duplicate of PQexecNR)
- introduce support for estimate_extents (fixes #582)
- introduce support for enum types (fixes #1210)
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2008-08-27 07:44:03 UTC (rev 9182)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2008-08-27 08:00:57 UTC (rev 9183)
@@ -50,16 +50,15 @@
const QString POSTGRES_KEY = "postgres";
const QString POSTGRES_DESCRIPTION = "PostgreSQL/PostGIS data provider";
-QMap<QString, QgsPostgresProvider::Conn *> QgsPostgresProvider::connectionsRO;
-QMap<QString, QgsPostgresProvider::Conn *> QgsPostgresProvider::connectionsRW;
+QMap<QString, QgsPostgresProvider::Conn *> QgsPostgresProvider::Conn::connectionsRO;
+QMap<QString, QgsPostgresProvider::Conn *> QgsPostgresProvider::Conn::connectionsRW;
int QgsPostgresProvider::providerIds = 0;
QgsPostgresProvider::QgsPostgresProvider( QString const & uri )
: QgsVectorDataProvider( uri ),
mFetching( false ),
geomType( QGis::WKBUnknown ),
- mFeatureQueueSize( 200 ),
- gotPostgisVersion( false )
+ mFeatureQueueSize( 200 )
// assume this is a valid layer until we determine otherwise
valid = true;
@@ -89,32 +88,19 @@
QgsDebugMsg( "Table name is: " + mTableName );
connectionRW = NULL;
- connectionRO = connectDb( mUri.connInfo() );
+ connectionRO = Conn::connectDb( mUri.connInfo(), true );
if ( connectionRO == NULL )
valid = false;
return;
- /* Check to see if we have GEOS support and if not, warn the user about
- the problems they will see :) */
- QgsDebugMsg( "Checking for GEOS support" );
- if ( !hasGEOS( connectionRO ) )
- showMessageBox( tr( "No GEOS Support!" ),
- tr( "Your PostGIS installation has no GEOS support.\n"
- "Feature selection and identification will not "
- "work properly.\nPlease install PostGIS with "
- "GEOS support (http://geos.refractions.net)" ) );
QgsDebugMsg( "Checking for permissions on the relation" );
// Check that we can read from the table (i.e., we have
// select permission).
QString sql = QString( "select * from %1 limit 1" ).arg( mSchemaTableName );
- PGresult* testAccess = PQexec( connectionRO, sql.toUtf8() );
+ Result testAccess = connectionRO->PQexec( sql );
if ( PQresultStatus( testAccess ) != PGRES_TUPLES_OK )
showMessageBox( tr( "Unable to access relation" ),
@@ -122,12 +108,10 @@
tr( " relation.\nThe error message from the database was:\n" ) +
QString::fromUtf8( PQresultErrorMessage( testAccess ) ) + ".\n" +
"SQL: " + sql );
- PQclear( testAccess );
valid = false;
disconnectDb();
return;
sql = QString( "SELECT "
"has_table_privilege(%1,'DELETE'),"
@@ -136,7 +120,7 @@
"current_schema()" )
.arg( quotedValue( mSchemaTableName ) );
- testAccess = PQexec( connectionRO, sql.toUtf8() );
+ testAccess = connectionRO->PQexec( sql );
@@ -144,7 +128,6 @@
"SQL: " + sql );
valid = false;
disconnectDb();
return;
@@ -178,7 +161,6 @@
if ( mSchemaName == "" )
mSchemaName = mCurrentSchema;
sql = QString( "SELECT 1 FROM pg_class,pg_namespace WHERE "
"pg_class.relnamespace=pg_namespace.oid AND "
@@ -186,12 +168,11 @@
"relname=%1 AND nspname=%2" )
.arg( quotedValue( mTableName ) )
.arg( quotedValue( mSchemaName ) );
if ( PQresultStatus( testAccess ) == PGRES_TUPLES_OK && PQntuples( testAccess ) == 1 )
enabledCapabilities |= QgsVectorDataProvider::AddAttributes | QgsVectorDataProvider::DeleteAttributes;
if ( !getGeometryDetails() ) // gets srid and geometry type
@@ -217,7 +198,7 @@
// Set the postgresql message level so that we don't get the
// 'there is no transaction in progress' warning.
#ifndef QGISDEBUG
- PQexecNR( connectionRO, QString( "set client_min_messages to error" ).toUtf8() );
+ connectionRO->PQexecNR( "set client_min_messages to error" );
#endif
// Kick off the long running threads
@@ -289,15 +270,16 @@
//pLog.flush();
-PGconn *QgsPostgresProvider::connectDb( const QString & conninfo, bool readonly )
+QgsPostgresProvider::Conn *QgsPostgresProvider::Conn::connectDb( const QString & conninfo, bool readonly )
- QMap<QString, QgsPostgresProvider::Conn *> &connections = readonly ? connectionsRO : connectionsRW;
+ QMap<QString, QgsPostgresProvider::Conn *> &connections =
+ readonly ? QgsPostgresProvider::Conn::connectionsRO : QgsPostgresProvider::Conn::connectionsRW;
if ( connections.contains( conninfo ) )
QgsDebugMsg( QString( "Using cached connection for %1" ).arg( conninfo ) );
connections[conninfo]->ref++;
- return connections[conninfo]->conn;
+ return connections[conninfo];
QgsDebugMsg( QString( "New postgres connection for " ) + conninfo );
@@ -333,59 +315,70 @@
Conn *conn = new Conn( pd );
connections.insert( conninfo, conn );
- if ( readonly )
+ /* Check to see if we have GEOS support and if not, warn the user about
+ the problems they will see :) */
+ QgsDebugMsg( "Checking for GEOS support" );
+ if ( !conn->hasGEOS() )
- QgsDebugMsg( "Starting transaction for cursors" );
- PQexecNR( pd, QString( "BEGIN" ).toUtf8() );
+ showMessageBox( tr( "No GEOS Support!" ),
+ tr( "Your PostGIS installation has no GEOS support.\n"
+ "Feature selection and identification will not "
+ "work properly.\nPlease install PostGIS with "
+ "GEOS support (http://geos.refractions.net)" ) );
- return pd;
+ return conn;
void QgsPostgresProvider::disconnectDb()
if ( mFetching )
- PQexecNR( connectionRO, QString( "CLOSE qgisf%1" ).arg( providerId ).toUtf8() );
+ connectionRO->closeCursor( QString( "qgisf%1" ).arg( providerId ) );
mFetching = false;
- if ( !connectionRO )
+ if ( connectionRO )
- QMap<QString, Conn *>::iterator i;
- for ( i = connectionsRO.begin(); i != connectionsRO.end() && i.value()->conn != connectionRO; i++ )
+ Conn::disconnectRO( connectionRO );
- assert( i.value()->conn == connectionRO );
- assert( i.value()->ref > 0 );
+ if ( connectionRW )
+ Conn::disconnectRW( connectionRW );
- if ( --i.value()->ref == 0 )
- PQfinish( connectionRO );
- delete i.value();
- connectionsRO.remove( i.key() );
+void QgsPostgresProvider::Conn::disconnectRW( Conn *&connection )
+ disconnect( connectionsRW, connection );
- connectionRO = 0;
+void QgsPostgresProvider::Conn::disconnectRO( Conn *&connection )
+ disconnect( connectionsRO, connection );
- if ( connectionRW )
- for ( i = connectionsRW.begin(); i != connectionsRW.end() && i.value()->conn != connectionRW; i++ )
+void QgsPostgresProvider::Conn::disconnect( QMap<QString, Conn *>& connections, Conn *&conn )
+ QMap<QString, Conn *>::iterator i;
+ for ( i = connections.begin(); i != connections.end() && i.value() != conn; i++ )
- assert( i.value()->conn == connectionRW );
+ assert( i.value() == conn );
+ assert( i.value()->ref > 0 );
- PQfinish( connectionRW );
- delete i.value();
- connectionsRW.remove( i.key() );
- connectionRW = 0;
+ if ( --i.value()->ref == 0 )
+ i.value()->PQfinish();
+ delete i.value();
+ connections.remove( i.key() );
+ conn = NULL;
QString QgsPostgresProvider::storageType() const
@@ -393,21 +386,21 @@
return "PostgreSQL database with PostGIS extension";
-bool QgsPostgresProvider::declareCursor( const QString &cursorName,
- const QgsAttributeList &fetchAttributes,
- bool fetchGeometry,
- QString whereClause )
+bool QgsPostgresProvider::declareCursor(
+ const QString &cursorName,
+ const QgsAttributeList &fetchAttributes,
+ bool fetchGeometry,
+ QString whereClause )
try
- QString declare = QString( "declare %1 binary cursor for select %2" )
- .arg( cursorName ).arg( quotedIdentifier( primaryKey ) );
+ QString query = QString( "select %1" ).arg( quotedIdentifier( primaryKey ) );
if ( fetchGeometry )
- declare += QString( ",asbinary(%1,'%2')" )
- .arg( quotedIdentifier( geometryColumn ) )
- .arg( endianString() );
+ query += QString( ",asbinary(%1,'%2')" )
+ .arg( quotedIdentifier( geometryColumn ) )
+ .arg( endianString() );
for ( QgsAttributeList::const_iterator it = fetchAttributes.constBegin(); it != fetchAttributes.constEnd(); ++it )
@@ -421,30 +414,28 @@
const QString &type = fld.typeName();
if ( type == "money" )
- declare += QString( ",cash_out(%1)" ).arg( quotedIdentifier( fieldname ) );
+ query += QString( ",cash_out(%1)" ).arg( quotedIdentifier( fieldname ) );
else if ( type.startsWith( "_" ) )
- declare += QString( ",array_out(%1)" ).arg( quotedIdentifier( fieldname ) );
+ query += QString( ",array_out(%1)" ).arg( quotedIdentifier( fieldname ) );
else if ( type == "bool" )
- declare += QString( ",boolout(%1)" ).arg( quotedIdentifier( fieldname ) );
+ query += QString( ",boolout(%1)" ).arg( quotedIdentifier( fieldname ) );
else
- declare += "," + quotedIdentifier( fieldname ) + "::text";
+ query += "," + quotedIdentifier( fieldname ) + "::text";
- declare += " from " + mSchemaTableName;
+ query += " from " + mSchemaTableName;
if ( !whereClause.isEmpty() )
- declare += QString( " where %1" ).arg( whereClause );
+ query += QString( " where %1" ).arg( whereClause );
- QgsDebugMsg( "Binary cursor: " + declare );
- return PQexecNR( connectionRO, declare.toUtf8() );
+ return connectionRO->openCursor( cursorName, query );
catch ( PGFieldNotFound )
@@ -550,7 +541,7 @@
if ( mFetching )
- PQexecNR( connectionRO, QString( "CLOSE %1" ).arg( cursorName ).toUtf8() );
+ connectionRO->closeCursor( cursorName );
mFetching = false;
while ( !mFeatureQueue.empty() )
@@ -610,13 +601,13 @@
if ( mFeatureQueue.empty() )
QString fetch = QString( "fetch forward %1 from %2" ).arg( mFeatureQueueSize ).arg( cursorName );
- if ( PQsendQuery( connectionRO, fetch.toUtf8() ) == 0 ) //fetch features in asynchronously
+ if ( connectionRO->PQsendQuery( fetch ) == 0 ) // fetch features asynchronously
qWarning( "PQsendQuery failed (1)" );
- PGresult *queryResult;
- while (( queryResult = PQgetResult( connectionRO ) ) )
+ Result queryResult;
+ while (( queryResult = connectionRO->PQgetResult() ) )
int rows = PQntuples( queryResult );
if ( rows == 0 )
@@ -627,14 +618,14 @@
mFeatureQueue.push( QgsFeature() );
getFeature( queryResult, row, mFetchGeom, mFeatureQueue.back(), mAttributesToFetch );
} // for each row in queue
- PQclear( queryResult );
QgsDebugMsg( "End of features" );
+ mFetching = false;
return false;
@@ -662,7 +653,7 @@
if ( !declareCursor( cursorName, fetchAttributes, fetchGeometry, QString( "%2=%3" ).arg( quotedIdentifier( primaryKey ) ).arg( featureId ) ) )
return false;
- PGresult *queryResult = PQexec( connectionRO, QString( "fetch forward 1 from %1" ).arg( cursorName ).toUtf8() );
+ Result queryResult = connectionRO->PQexec( QString( "fetch forward 1 from %1" ).arg( cursorName ) );
if ( queryResult == 0 )
return false;
@@ -670,8 +661,7 @@
if ( rows == 0 )
QgsDebugMsg( "feature " + QString::number( featureId ) + " not found" );
return false;
else if ( rows != 1 )
@@ -681,10 +671,8 @@
bool gotit = getFeature( queryResult, 0, fetchGeometry, feature, fetchAttributes );
return gotit;
@@ -760,7 +748,7 @@
if ( mFetching )
//move cursor to first record
- PQexecNR( connectionRO, QString( "move 0 in qgisf%1" ).arg( providerId ).toUtf8() );
+ connectionRO->PQexecNR( QString( "move 0 in qgisf%1" ).arg( providerId ) );
mFeatureQueue.empty();
loadFields();
@@ -788,25 +776,21 @@
// Get the relation oid for use in later queries
QString sql = QString( "SELECT regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
- PGresult *tresult = PQexec( connectionRO, sql.toUtf8() );
+ Result tresult = connectionRO->PQexec( sql );
QString tableoid = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
- PQclear( tresult );
// Get the table description
sql = QString( "SELECT description FROM pg_description WHERE objoid=%1 AND objsubid=0" ).arg( tableoid );
- tresult = PQexec( connectionRO, sql.toUtf8() );
+ tresult = connectionRO->PQexec( sql );
if ( PQntuples( tresult ) > 0 )
mDataComment = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
// Populate the field vector for this layer. The field vector contains
// field name, type, length, and precision (if numeric)
sql = QString( "select * from %1 limit 0" ).arg( mSchemaTableName );
- PGresult *result = PQexec( connectionRO, sql.toUtf8() );
- //--std::cout << "Field: Name, Type, Size, Modifier:" << std::endl;
+ Result result = connectionRO->PQexec( sql );
// The queries inside this loop could possibly be combined into one
// single query - this would make the code run faster.
@@ -819,70 +803,82 @@
int fieldModifier = PQfmod( result, i );
QString fieldComment( "" );
- sql = QString( "SELECT typname,typlen FROM pg_type WHERE oid=%1" ).arg( typOid );
+ sql = QString( "SELECT typname,typtype,typelem,typlen FROM pg_type WHERE oid=%1" ).arg( typOid );
// just oid; needs more work to support array type
// "oid = (SELECT Distinct typelem FROM pg_type WHERE " //needs DISTINCT to guard against 2 or more rows on int2
// "typelem = " + typOid + " AND typlen = -1)";
- PGresult* oidResult = PQexec( connectionRO, sql.toUtf8() );
+ Result oidResult = connectionRO->PQexec( sql );
QString fieldTypeName = QString::fromUtf8( PQgetvalue( oidResult, 0, 0 ) );
- QString fieldSize = QString::fromUtf8( PQgetvalue( oidResult, 0, 1 ) );
- PQclear( oidResult );
+ QString fieldTType = QString::fromUtf8( PQgetvalue( oidResult, 0, 1 ) );
+ QString fieldElem = QString::fromUtf8( PQgetvalue( oidResult, 0, 2 ) );
+ QString fieldSize = QString::fromUtf8( PQgetvalue( oidResult, 0, 3 ) );
sql = QString( "SELECT attnum FROM pg_attribute WHERE attrelid=%1 AND attname=%2" )
.arg( tableoid ).arg( quotedValue( fieldName ) );
QString attnum = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
sql = QString( "SELECT description FROM pg_description WHERE objoid=%1 AND objsubid=%2" )
.arg( tableoid ).arg( attnum );
fieldComment = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
if ( fieldName != geometryColumn )
QVariant::Type fieldType;
- bool isArray = fieldTypeName.startsWith( "_" );
- if ( isArray )
- fieldTypeName = fieldTypeName.mid( 1 );
+ if ( fieldTType == "b" )
+ bool isArray = fieldTypeName.startsWith( "_" );
- if ( fieldTypeName == "int8" )
- fieldType = QVariant::LongLong;
- else if ( fieldTypeName.startsWith( "int" ) || fieldTypeName == "serial" )
- fieldType = QVariant::Int;
- else if ( fieldTypeName == "real" || fieldTypeName == "double precision" || fieldTypeName.startsWith( "float" ) || fieldTypeName == "numeric" )
- fieldType = QVariant::Double;
- else if ( fieldTypeName == "text" ||
- fieldTypeName == "char" ||
- fieldTypeName == "bpchar" ||
- fieldTypeName == "varchar" ||
- fieldTypeName == "bool" ||
- fieldTypeName == "money" ||
- fieldTypeName.startsWith( "time" ) ||
- fieldTypeName.startsWith( "date" ) )
+ if ( isArray )
+ fieldTypeName = fieldTypeName.mid( 1 );
+ if ( fieldTypeName == "int8" )
+ fieldType = QVariant::LongLong;
+ else if ( fieldTypeName.startsWith( "int" ) || fieldTypeName == "serial" )
+ fieldType = QVariant::Int;
+ else if ( fieldTypeName == "real" || fieldTypeName == "double precision" || fieldTypeName.startsWith( "float" ) || fieldTypeName == "numeric" )
+ fieldType = QVariant::Double;
+ else if ( fieldTypeName == "text" ||
+ fieldTypeName == "char" ||
+ fieldTypeName == "bpchar" ||
+ fieldTypeName == "varchar" ||
+ fieldTypeName == "bool" ||
+ fieldTypeName == "money" ||
+ fieldTypeName.startsWith( "time" ) ||
+ fieldTypeName.startsWith( "date" ) )
+ fieldType = QVariant::String;
+ else
+ QgsDebugMsg( "Field " + fieldName + " ignored, because of unsupported type " + fieldTypeName );
+ continue;
+ if ( isArray )
+ fieldTypeName = "_" + fieldTypeName;
+ else if ( fieldTType == "e" )
+ // enum
else
- QgsDebugMsg( "Field " + fieldName + " ignored, because of unsupported type " + fieldTypeName );
+ QgsDebugMsg( "Field " + fieldName + " ignored, because of unsupported type type " + fieldTType );
continue;
- if ( isArray )
- fieldTypeName = "_" + fieldTypeName;
- fieldType = QVariant::String;
attributeFields.insert( i, QgsField( fieldName, fieldType, fieldTypeName, fieldSize.toInt(), fieldModifier, fieldComment ) );
- PQclear( result );
QString QgsPostgresProvider::getPrimaryKey()
@@ -896,7 +892,7 @@
QgsDebugMsg( "Getting unique index using '" + sql + "'" );
- PGresult *pk = executeDbCommand( connectionRO, sql );
+ Result pk = connectionRO->PQexec( sql );
QgsDebugMsg( "Got " + QString::number( PQntuples( pk ) ) + " rows." );
@@ -914,9 +910,8 @@
sql = QString( "SELECT relkind FROM pg_class WHERE oid=regclass(%1)::oid" )
- PGresult* tableType = executeDbCommand( connectionRO, sql );
+ Result tableType = connectionRO->PQexec( sql );
QString type = QString::fromUtf8( PQgetvalue( tableType, 0, 0 ) );
- PQclear( tableType );
primaryKey = "";
@@ -929,7 +924,7 @@
sql = QString( "SELECT attname FROM pg_attribute WHERE attname='oid' AND attrelid=regclass(%1)" )
- PGresult* oidCheck = executeDbCommand( connectionRO, sql );
+ Result oidCheck = connectionRO->PQexec( sql );
if ( PQntuples( oidCheck ) != 0 )
@@ -947,7 +942,6 @@
"int4 with a unique constraint on it (which includes the\n"
"primary key) or has a PostgreSQL oid column.\n" ) );
- PQclear( oidCheck );
else if ( type == "v" ) // the relation is a view
@@ -977,7 +971,7 @@
// Get the column name and data type
sql = QString( "select attname,pg_type.typname from pg_attribute,pg_type where atttypid=pg_type.oid and attnum=%1 and attrelid=regclass(%2)" )
.arg( col ).arg( quotedValue( mSchemaTableName ) );
- PGresult* types = executeDbCommand( connectionRO, sql );
+ Result types = connectionRO->PQexec( sql );
if ( PQntuples( types ) > 0 )
@@ -996,8 +990,6 @@
//QgsDebugMsg( QString("name and type of %3. column of %1.%2 not found").arg(mSchemaName).arg(mTables).arg(col) );
- PQclear( types );
else
@@ -1005,7 +997,7 @@
.arg( col.replace( " ", "," ) )
QString colNames;
int numCols = PQntuples( types );
for ( int j = 0; j < numCols; ++j )
@@ -1039,7 +1031,7 @@
// If there is an oid on the table, use that instead,
// otherwise give up
sql = QString( "select attname from pg_attribute where attname='oid' and attrelid=regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
@@ -1052,7 +1044,6 @@
"as a qgis key into the table (either a column with a "
"unique index and type int4 or a PostgreSQL oid column.\n" );
// Either primaryKey has been set by the above code, or it
@@ -1065,7 +1056,6 @@
showMessageBox( tr( "Unable to find a key column" ), log );
- PQclear( pk );
if ( primaryKey.length() > 0 )
@@ -1109,7 +1099,7 @@
// Get the oid from pg_class for the given schema.relation for use
// in subsequent queries.
sql = QString( "select regclass(%1)::oid" ).arg( quotedValue( quotedIdentifier( schemaName ) + "." + quotedIdentifier( tableName ) ) );
- PGresult* result = PQexec( connectionRO, sql.toUtf8() );
QString rel_oid;
if ( PQntuples( result ) == 1 )
@@ -1122,10 +1112,8 @@
QgsDebugMsg( "Relation " + schemaName + "." + tableName +
" doesn't exist in the pg_class table."
"This shouldn't happen and is odd." );
continue;
// This sql returns one or more rows if the column 'tableCol' in
// table 'tableName' and schema 'schemaName' has one or more
@@ -1140,7 +1128,7 @@
"and conrelid=%2 and (contype='p' or contype='u') "
"and array_dims(conkey)='[1:1]'" ).arg( quotedValue( tableCol ) ).arg( rel_oid );
- result = PQexec( connectionRO, sql.toUtf8() );
+ result = connectionRO->PQexec( sql );
if ( PQntuples( result ) == 1 && colType == "int4" )
suitable[viewCol] = iter->second;
@@ -1163,7 +1151,6 @@
log << details;
if ( tableCol == "oid" )
oids.push_back( iter );
@@ -1199,16 +1186,15 @@
sql = QString( "select * from pg_index where indrelid=%1 and indkey[0]=(select attnum from pg_attribute where attrelid=%1 and attname=%2)" )
.arg( rel_oid )
.arg( quotedValue( i->second.column ) );
if ( PQntuples( result ) > 0 && uniqueData( mSchemaName, mTableName, i->first ) )
- { // Got one. Use it.
+ // Got one. Use it.
key = i->first;
QgsDebugMsg( "Picked column '" + key + "' because it has an index." );
break;
if ( key.isEmpty() )
@@ -1285,13 +1271,11 @@
.arg( quotedIdentifier( schemaName ) )
.arg( quotedIdentifier( tableName ) );
- PGresult* unique = PQexec( connectionRO, sql.toUtf8() );
+ Result unique = connectionRO->PQexec( sql );
if ( PQntuples( unique ) == 1 && QString::fromUtf8( PQgetvalue( unique, 0, 0 ) ).startsWith( "t" ) )
isUnique = true;
- PQclear( unique );
return isUnique;
@@ -1299,7 +1283,7 @@
QString newViewDefSql = QString( "SELECT definition FROM pg_views WHERE schemaname=%1 AND viewname=%2" )
.arg( quotedValue( ns ) ).arg( quotedValue( relname ) );
- PGresult* newViewDefResult = PQexec( connectionRO, newViewDefSql.toUtf8() );
+ Result newViewDefResult = connectionRO->PQexec( newViewDefSql );
int numEntries = PQntuples( newViewDefResult );
if ( numEntries > 0 ) //relation is a view
@@ -1375,25 +1359,21 @@
.arg( quotedValue( newAttNameTable ) );
- PGresult* viewColumnResult = PQexec( connectionRO, viewColumnSql.toUtf8() );
+ Result viewColumnResult = connectionRO->PQexec( viewColumnSql );
if ( PQntuples( viewColumnResult ) > 0 )
QString newTableSchema = QString::fromUtf8( PQgetvalue( viewColumnResult, 0, 0 ) );
QString newTableName = QString::fromUtf8( PQgetvalue( viewColumnResult, 0, 1 ) );
int retvalue = SRCFromViewColumn( newTableSchema, newTableName, newAttNameTable, newAttNameView, newViewDefinition, result );
- PQclear( viewColumnResult );
return retvalue;
else
return 1;
- PQclear( newViewDefResult );
//relation is table, we just have to add the type
QString typeSql = QString( "SELECT "
"pg_type.typname"
@@ -1413,13 +1393,12 @@
.arg( quotedValue( attname_table ) );
- PGresult* typeSqlResult = PQexec( connectionRO, typeSql.toUtf8() );
+ Result typeSqlResult = connectionRO->PQexec( typeSql );
if ( PQntuples( typeSqlResult ) < 1 )
return 1;
QString type = QString::fromUtf8( PQgetvalue( typeSqlResult, 0, 0 ) );
- PQclear( typeSqlResult );
result.schema = ns;
result.relation = relname;
@@ -1486,20 +1465,19 @@
"view_schema=%1 AND view_name=%2" )
.arg( quotedValue( mTableName ) );
//find out view definition
QString viewDefSql = QString( "SELECT definition FROM pg_views WHERE schemaname=%1 AND viewname=%2" )
- PGresult* viewDefResult = PQexec( connectionRO, viewDefSql.toUtf8() );
+ Result viewDefResult = connectionRO->PQexec( viewDefSql );
if ( PQntuples( viewDefResult ) < 1 )
- PQclear( viewDefResult );
return;
QString viewDefinition( QString::fromUtf8( PQgetvalue( viewDefResult, 0, 0 ) ) );
QString ns, relname, attname_table, attname_view;
SRC columnInformation;
@@ -1530,7 +1508,7 @@
if ( s.indexIn( viewDefinition ) != -1 )
attname_view = s.cap( 1 );
- qWarning( "original view column name was: " + attname_view.toUtf8() );
+ QgsDebugMsg( QString( "original view column name was: %1" ).arg( attname_view ) );
@@ -1538,8 +1516,6 @@
cols.insert( std::make_pair( attname_view, columnInformation ) );
QgsDebugMsg( "Inserting into cols (for key " + attname_view + " ): " + columnInformation.schema + "." + columnInformation.relation + "." + columnInformation.column + "." + columnInformation.type );
// Returns the minimum value of an attribute
@@ -1563,9 +1539,8 @@
.arg( sqlWhereClause );
- PGresult *rmin = PQexec( connectionRO, sql.toUtf8() );
+ Result rmin = connectionRO->PQexec( sql );
QString minimumValue = QString::fromUtf8( PQgetvalue( rmin, 0, 0 ) );
- PQclear( rmin );
return minimumValue.toDouble();
@@ -1598,13 +1573,12 @@
- PGresult *res = PQexec( connectionRO, sql.toUtf8() );
+ Result res = connectionRO->PQexec( sql );
if ( PQresultStatus( res ) == PGRES_TUPLES_OK )
for ( int i = 0; i < PQntuples( res ); i++ )
uniqueValues.append( QString::fromUtf8( PQgetvalue( res, i, 0 ) ) );
- PQclear( res );
@@ -1633,9 +1607,8 @@
- PGresult *rmax = PQexec( connectionRO, sql.toUtf8() );
+ Result rmax = connectionRO->PQexec( sql );
QString maxValue = QString::fromUtf8( PQgetvalue( rmax, 0, 0 ) );
- PQclear( rmax );
return maxValue.toDouble();
@@ -1653,9 +1626,8 @@
- PQclear( rmax );
return maxValue.toInt();
@@ -1686,15 +1658,13 @@
QVariant defaultValue( QString::null );
if ( PQntuples( result ) == 1 && !PQgetisnull( result, 0, 0 ) )
defaultValue = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
// QgsDebugMsg( QString("defaultValue for %1 is NULL: %2").arg(fieldId).arg( defaultValue.isNull() ) );
return defaultValue;
@@ -1706,24 +1676,22 @@
* Check to see if GEOS is available
-bool QgsPostgresProvider::hasGEOS( PGconn *connection )
+bool QgsPostgresProvider::Conn::hasGEOS()
// make sure info is up to date for the current connection
- postgisVersion( connection );
+ postgisVersion();
// get geos capability
return geosAvailable;
/* Functions for determining available features in postGIS */
-QString QgsPostgresProvider::postgisVersion( PGconn *connection )
+QString QgsPostgresProvider::Conn::postgisVersion()
- PGresult *result = PQexec( connection, QString( "select postgis_version()" ).toUtf8() );
+ Result result = PQexec( "select postgis_version()" );
postgisVersionInfo = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
QgsDebugMsg( "PostGIS version info: " + postgisVersionInfo );
QStringList postgisParts = postgisVersionInfo.split( " ", QString::SkipEmptyParts );
// Get major and minor version
@@ -1754,7 +1722,7 @@
projAvailable = ( proj[0].indexOf( "=1" ) > -1 );
- useWkbHex = postgisVersionMajor < 1;
+ mUseWkbHex = postgisVersionMajor < 1;
gotPostgisVersion = true;
@@ -1768,16 +1736,14 @@
if ( fieldValue == defaultValue && !defaultValue.isNull() )
- PGresult *result = PQexec( connectionRO, QString( "select %1" ).arg( defaultValue ).toUtf8() );
+ Result result = connectionRO->PQexec( QString( "select %1" ).arg( defaultValue ) );
if ( PQgetisnull( result, 0, 0 ) )
return QByteArray( 0 ); // QByteArray(0).isNull() is true
else
QString val = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
return val.toUtf8();
@@ -1797,7 +1763,7 @@
try
- PQexecNR( connectionRW, QString( "BEGIN" ).toUtf8() );
+ connectionRW->PQexecNR( "BEGIN" );
// Prepare the INSERT statement
QString insert = QString( "INSERT INTO %1(%2,%3" )
@@ -1805,7 +1771,7 @@
.arg( quotedIdentifier( primaryKey ) ),
values = QString( ") VALUES (GeomFromWKB($1%1,%2),$2" )
- .arg( useWkbHex ? "" : "::bytea" )
+ .arg( connectionRW->useWkbHex() ? "" : "::bytea" )
.arg( srid );
const QgsAttributeMap &attributevec = flist[0].attributeMap();
@@ -1875,14 +1841,12 @@
insert += values + ")";
QgsDebugMsg( QString( "prepare addfeatures: %1" ).arg( insert ) );
- PGresult *stmt = PQprepare( connectionRW, "addfeatures", insert.toUtf8(), fieldId.size() + 2, NULL );
+ PGresult *stmt = connectionRW->PQprepare( "addfeatures", insert, fieldId.size() + 2, NULL );
if ( stmt == 0 || PQresultStatus( stmt ) == PGRES_FATAL_ERROR )
throw PGException( stmt );
PQclear( stmt );
int primaryKeyHighWater = maxPrimaryKeyValue();
- const char **param = new const char *[ fieldId.size()+2 ];
for ( QgsFeatureList::iterator features = flist.begin(); features != flist.end(); features++ )
@@ -1891,41 +1855,28 @@
QString geomParam;
appendGeomString( features->geometry(), geomParam );
- QList<QByteArray> qparam;
- qparam.append( geomParam.toUtf8() );
- qparam.append( QString( "%1" ).arg( ++primaryKeyHighWater ).toUtf8() );
+ QStringList params;
+ params << geomParam;
+ params << QString( "%1" ).arg( ++primaryKeyHighWater );
features->setFeatureId( primaryKeyHighWater );
- param[0] = qparam[0];
- param[1] = qparam[1];
for ( int i = 0; i < fieldId.size(); i++ )
- qparam.append( paramValue( attributevec[ fieldId[i] ].toString(), defaultValue[i] ) );
- if ( qparam[i+2].isNull() )
- param[i+2] = 0;
- else
- param[i+2] = qparam[i+2];
+ params << paramValue( attributevec[ fieldId[i] ].toString(), defaultValue[i] );
- PGresult *result = PQexecPrepared( connectionRW, "addfeatures", fieldId.size() + 2, param, NULL, NULL, 0 );
+ PGresult *result = connectionRW->PQexecPrepared( "addfeatures", params );
if ( result == 0 || PQresultStatus( result ) == PGRES_FATAL_ERROR )
- delete param;
throw PGException( result );
PQclear( result );
- PQexecNR( connectionRW, QString( "DEALLOCATE addfeatures" ).toUtf8() );
- PQexecNR( connectionRW, QString( "COMMIT" ).toUtf8() );
- delete param;
+ connectionRW->PQexecNR( "DEALLOCATE addfeatures" );
+ connectionRW->PQexecNR( "COMMIT" );
catch ( PGException &e )
e.showErrorMessage( tr( "Error while adding features" ) );
- PQexecNR( connectionRW, QString( "ROLLBACK" ).toUtf8() );
+ connectionRW->PQexecNR( "ROLLBACK" );
returnvalue = false;
@@ -1942,7 +1893,7 @@
try
for ( QgsFeatureIds::const_iterator it = id.begin();it != id.end();++it )
@@ -1953,18 +1904,18 @@
QgsDebugMsg( "delete sql: " + sql );
//send DELETE statement and do error handling
- PGresult* result = PQexec( connectionRW, sql.toUtf8() );
+ PGresult *result = connectionRW->PQexec( sql );
PQclear( result );
e.showErrorMessage( tr( "Error while deleting features" ) );
reset();
@@ -1980,7 +1931,7 @@
try
for ( QgsNewAttributesMap::const_iterator iter = name.begin();iter != name.end();++iter )
@@ -1991,18 +1942,18 @@
QgsDebugMsg( sql );
//send sql statement and do error handling
PQclear( result );
e.showErrorMessage( tr( "Error while adding attributes" ) );
@@ -2019,7 +1970,7 @@
try
for ( QgsAttributeIds::const_iterator iter = ids.begin();iter != ids.end();++iter )
@@ -2033,7 +1984,7 @@
.arg( quotedIdentifier( column ) );
PQclear( result );
@@ -2042,12 +1993,12 @@
attributeFields.remove( *iter );
e.showErrorMessage( tr( "Error while deleting attributes" ) );
@@ -2064,7 +2015,7 @@
try
// cycle through the features
for ( QgsChangedAttributesMap::const_iterator iter = attr_map.begin();iter != attr_map.end();++iter )
@@ -2106,19 +2057,18 @@
.arg( fid );
PQclear( result );
e.showErrorMessage( tr( "Error while changing attributes" ) );
@@ -2132,7 +2082,7 @@
unsigned char *buf = geom->wkbBuffer();
for ( uint i = 0; i < geom->wkbSize(); ++i )
- if ( useWkbHex )
+ if ( connectionRW->useWkbHex() )
geomString += QString( "%1" ).arg(( int ) buf[i], 2, 16, QChar( '0' ) );
else
geomString += QString( "\\%1" ).arg(( int ) buf[i], 3, 8, QChar( '0' ) );
@@ -2151,19 +2101,18 @@
try
// Start the PostGIS transaction
QString update = QString( "UPDATE %1 SET %2=GeomFromWKB($1%3,%4) WHERE %5=$2" )
.arg( srid )
- PGresult *stmt = PQprepare( connectionRW, "updatefeatures", update.toUtf8(), 2, NULL );
+ PGresult *stmt = connectionRW->PQprepare( "updatefeatures", update, 2, NULL );
PQclear( stmt );
for ( QgsGeometryMap::iterator iter = geometry_map.begin();
@@ -2180,31 +2129,26 @@
QString geomParam;
appendGeomString( &*iter, geomParam );
- qparam.append( QString( "%1" ).arg( iter.key() ).toUtf8() );
+ params << QString( "%1" ).arg( iter.key() );
- const char *param[2];
- PGresult *result = PQexecPrepared( connectionRW, "updatefeatures", 2, param, NULL, NULL, 0 );
+ PGresult *result = connectionRW->PQexecPrepared( "updatefeatures", params );
PQclear( result );
} // if (*iter)
} // for each feature
- PQexecNR( connectionRW, QString( "DEALLOCATE updatefeatures" ).toUtf8() );
+ connectionRW->PQexecNR( "DEALLOCATE updatefeatures" );
e.showErrorMessage( tr( "Error while changing geometry values" ) );
@@ -2264,13 +2208,12 @@
#endif
QgsDebugMsg( "Approximate Number of features as text: " +
QString::fromUtf8( PQgetvalue( result, 0, 0 ) ) );
numberFeatures = QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toLong();
QgsDebugMsg( "Approximate Number of features: " + QString::number( numberFeatures ) );
@@ -2307,13 +2250,12 @@
QgsDebugMsg( "Getting approximate extent using: '" + sql + "'" );
// TODO: Guard against the result having no rows
for ( int i = 0; i < PQntuples( result ); i++ )
- std::string box3d = PQgetvalue( result, i, 0 );
+ QString box3d = PQgetvalue( result, i, 0 );
if ( 0 == i )
@@ -2324,28 +2266,40 @@
// extend the initial extent
QgsPostGisBox3d b = QgsPostGisBox3d( box3d );
layerExtent.combineExtentWith( &b );
- QgsDebugMsg( "After row " + QString::number( i ) +
- ", extent is: " + layerExtent.toString() );
+ QgsDebugMsg( QString( "After row %1, extent is %2" ).arg( i ).arg( layerExtent.toString() ) );
- // clear query result
#else // non-postgresql threads version
+ QString sql;
+ Result result;
+ QString ext;
// get the extents
+ if ( sqlWhereClause.isEmpty() )
+ result = connectionRO->PQexec( QString( "select estimated_extent(%1,%2,%3)" )
+ .arg( quotedValue( mSchemaName ) )
+ .arg( quotedValue( mTableName ) )
+ .arg( quotedValue( geometryColumn ) ) );
+ if ( PQntuples( result ) == 1 )
+ ext = PQgetvalue( result, 0, 0 );
- QString sql = QString( "select extent(%1) from %2" )
- .arg( mSchemaTableName );
- if ( sqlWhereClause.length() > 0 )
+ if ( ext.isEmpty() )
- sql += " where " + sqlWhereClause;
+ sql = QString( "select extent(%1) from %2" )
+ .arg( mSchemaTableName );
+ if ( !sqlWhereClause.isEmpty() )
+ sql += QString( "where %1" ).arg( sqlWhereClause );
#if WASTE_TIME
@@ -2359,47 +2313,20 @@
QgsDebugMsg( "Getting extents using schema.table: " + sql );
- if ( PQntuples( result ) > 0 )
+ QRegExp rx( "\\((.+) (.+),(.+) (.+)\\)" );
+ if ( ext.contains( rx ) )
- std::string box3d = PQgetvalue( result, 0, 0 );
+ QStringList ex = rx.capturedTexts();
- if ( box3d != "" )
- std::string s;
- box3d = box3d.substr( box3d.find_first_of( "(" ) + 1 );
- box3d = box3d.substr( box3d.find_first_not_of( " " ) );
- s = box3d.substr( 0, box3d.find_first_of( " " ) );
- double minx = strtod( s.c_str(), NULL );
- box3d = box3d.substr( box3d.find_first_of( " " ) + 1 );
- double miny = strtod( s.c_str(), NULL );
- box3d = box3d.substr( box3d.find_first_of( "," ) + 1 );
- double maxx = strtod( s.c_str(), NULL );
- double maxy = strtod( s.c_str(), NULL );
- layerExtent.setXMaximum( maxx );
- layerExtent.setXMinimum( minx );
- layerExtent.setYMaximum( maxy );
- layerExtent.setYMinimum( miny );
+ layerExtent.setXMinimum( ex[1].toDouble() );
+ layerExtent.setYMinimum( ex[2].toDouble() );
+ layerExtent.setXMaximum( ex[3].toDouble() );
+ layerExtent.setYMaximum( ex[4].toDouble() );
else
QgsDebugMsg( "extents query failed" );
#endif
#if 0
@@ -2425,9 +2352,9 @@
QgsDebugMsg( "received a custom event " + QString::number( e->type() ) );
- switch ( e->type() )
+ switch (( int ) e->type() )
- case( QEvent::Type ) QGis::ProviderExtentCalcEvent:
+ case QGis::ProviderExtentCalcEvent:
QgsDebugMsg( "extent has been calculated" );
@@ -2455,7 +2382,7 @@
break;
- case( QEvent::Type ) QGis::ProviderCountCalcEvent:
+ case QGis::ProviderCountCalcEvent:
QgsDebugMsg( "count has been calculated" );
@@ -2483,23 +2410,18 @@
// return data in the endian of the server
QString firstOid = QString( "select regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
- PGresult * oidResult = PQexec( connectionRO, firstOid.toUtf8() );
+ Result oidResult = connectionRO->PQexec( firstOid );
// get the int value from a "normal" select
QString oidValue = QString::fromUtf8( PQgetvalue( oidResult, 0, 0 ) );
QgsDebugMsg( "Creating binary cursor" );
// get the same value using a binary cursor
+ connectionRO->openCursor( "oidcursor", QString( "select regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) ) );
- QString oidDeclare = QString( "declare oidcursor binary cursor for select regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
- // set up the cursor
- PQexecNR( connectionRO, oidDeclare.toUtf8() );
- QString fetch = "fetch forward 1 from oidcursor";
QgsDebugMsg( "Fetching a record and attempting to get check endian-ness" );
- PGresult *fResult = PQexec( connectionRO, fetch.toUtf8() );
+ Result fResult = connectionRO->PQexec( "fetch forward 1 from oidcursor" );
swapEndian = true;
if ( PQntuples( fResult ) > 0 )
@@ -2513,10 +2435,8 @@
// compare the two oid values to determine if we need to do an endian swap
if ( oid == oidValue.toInt() )
swapEndian = false;
- PQclear( fResult );
- PQexecNR( connectionRO, QString( "close oidcursor" ).toUtf8() );
+ connectionRO->closeCursor( "oidcursor" );
return swapEndian;
@@ -2535,7 +2455,7 @@
QgsDebugMsg( "Getting geometry column: " + sql );
- PGresult *result = executeDbCommand( connectionRO, sql );
QgsDebugMsg( "geometry column query returned " + QString::number( PQntuples( result ) ) );
@@ -2543,14 +2463,12 @@
fType = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
srid = QString::fromUtf8( PQgetvalue( result, 0, 1 ) );
else
// Didn't find what we need in the geometry_columns table, so
// get stuff from the relevant column instead. This may (will?)
// fail if there is no data in the relevant table.
- PQclear( result ); // for the query just before the if() statement
sql = QString( "select srid(%1),geometrytype(%1) from %2" )
@@ -2563,14 +2481,13 @@
sql += " limit 1";
- result = executeDbCommand( connectionRO, sql );
srid = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
fType = QString::fromUtf8( PQgetvalue( result, 0, 1 ) );
if ( !srid.isEmpty() && !fType.isEmpty() )
@@ -2589,13 +2506,12 @@
if ( mUri.sql() != "" )
sql += " where " + mUri.sql();
if ( fType == "POINT" )
@@ -2654,24 +2570,6 @@
return valid;
-PGresult* QgsPostgresProvider::executeDbCommand( PGconn* connection,
- const QString& sql )
- PGresult *result = PQexec( connection, sql.toUtf8() );
- QgsDebugMsg( "Executed SQL: " + sql );
- if ( PQresultStatus( result ) == PGRES_TUPLES_OK )
- QgsDebugMsg( "Command was successful." );
- else
- QgsDebugMsg( "Command was unsuccessful. The error message was: "
- + QString::fromUtf8( PQresultErrorMessage( result ) ) );
- return result;
QString QgsPostgresProvider::quotedIdentifier( QString ident ) const
ident.replace( '"', "\"\"" );
@@ -2688,9 +2586,10 @@
return value.prepend( "'" ).append( "'" );
-PGresult *QgsPostgresProvider::PQexec( PGconn *conn, const char *query )
+PGresult *QgsPostgresProvider::Conn::PQexec( QString query )
- PGresult *res = ::PQexec( conn, query );
+ QgsDebugMsgLevel( QString( "Executing SQL: %1" ).arg( query ), 3 );
+ PGresult *res = ::PQexec( conn, query.toUtf8() );
#ifdef QGISDEBUG
if ( res )
@@ -2710,9 +2609,33 @@
return res;
-bool QgsPostgresProvider::PQexecNR( PGconn *conn, const char *query )
+bool QgsPostgresProvider::Conn::openCursor( QString cursorName, QString sql )
+ if ( openCursors++ == 0 )
+ QgsDebugMsg( "Starting read-only transaction" );
+ PQexecNR( "BEGIN READ ONLY" );
+ QgsDebugMsgLevel( QString( "Binary cursor %1 for %2" ).arg( cursorName ).arg( sql ), 3 );
+ return PQexecNR( QString( "declare %1 binary cursor for %2" ).arg( cursorName ).arg( sql ) );
+bool QgsPostgresProvider::Conn::closeCursor( QString cursorName )
+ bool res = PQexecNR( QString( "CLOSE %1" ).arg( cursorName ) );
+ if ( --openCursors == 0 )
+ QgsDebugMsg( "Commiting read-only transaction" );
+ PQexecNR( "COMMIT" );
+ return res;
+bool QgsPostgresProvider::Conn::PQexecNR( QString query )
+ Result res = ::PQexec( conn, query.toUtf8() );
if ( res )
int errorStatus = PQresultStatus( res );
@@ -2726,7 +2649,6 @@
QgsDebugMsgLevel( err, 3 );
#endif
- PQclear( res );
return errorStatus == PGRES_COMMAND_OK;
else
@@ -2736,6 +2658,48 @@
return false;
+PGresult *QgsPostgresProvider::Conn::PQgetResult()
+ return ::PQgetResult( conn );
+PGresult *QgsPostgresProvider::Conn::PQprepare( QString stmtName, QString query, int nParams, const Oid *paramTypes )
+ return ::PQprepare( conn, stmtName.toUtf8(), query.toUtf8(), nParams, paramTypes );
+PGresult *QgsPostgresProvider::Conn::PQexecPrepared( QString stmtName, const QStringList ¶ms )
+ const char **param = new const char *[ params.size()];
+ QList<QByteArray> qparam;
+ for ( int i = 0; i < params.size(); i++ )
+ qparam << params[i].toUtf8();
+ if ( params[i].isNull() )
+ param[i] = 0;
+ else
+ param[i] = qparam[i];
+ PGresult *res = ::PQexecPrepared( conn, stmtName.toUtf8(), params.size(), param, NULL, NULL, 0 );
+ delete [] param;
+ return res;
+void QgsPostgresProvider::Conn::PQfinish()
+ ::PQfinish( conn );
+int QgsPostgresProvider::Conn::PQsendQuery( QString query )
+ return ::PQsendQuery( conn, query.toUtf8() );
void QgsPostgresProvider::showMessageBox( const QString& title, const QString& text )
QgsMessageOutput* message = QgsMessageOutput::createMessageOutput();
@@ -2766,7 +2730,7 @@
PGconn * QgsPostgresProvider::pgConnection()
connectRW();
- return connectionRW;
+ return connectionRW->pgConnection();
QString QgsPostgresProvider::getTableName()
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2008-08-27 07:44:03 UTC (rev 9182)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2008-08-27 08:00:57 UTC (rev 9183)
@@ -197,18 +197,6 @@
QgsAttributeList allAttributesList();
- //! get postgis version string
- QString postgisVersion( PGconn * );
- //! get status of GEOS capability
- bool hasGEOS( PGconn * );
- //! get status of GIST capability
- bool hasGIST( PGconn * );
- //! get status of PROJ4 capability
- bool hasPROJ( PGconn * );
/**Returns the default value for field specified by @c fieldId */
QVariant getDefaultValue( int fieldId );
@@ -401,22 +389,7 @@
* Geometry type
QGis::WKBTYPE geomType;
- * Connection pointer
- PGconn *connectionRO;
- PGconn *connectionRW;
- bool connectRW()
- connectionRW = connectDb( mUri.connInfo(), false );
* Spatial reference id of the layer
@@ -457,8 +430,6 @@
bool deduceEndian();
bool getGeometryDetails();
- PGresult* executeDbCommand( PGconn* connection, const QString& sql );
// Produces a QMessageBox with the given title and text. Doesn't
// return until the user has dismissed the dialog box.
static void showMessageBox( const QString& title, const QString& text );
@@ -556,27 +527,6 @@
int SRCFromViewColumn( const QString& ns, const QString& relname, const QString& attname_table,
const QString& attname_view, const QString& viewDefinition, SRC& result ) const;
- //! PostGIS version string
- QString postgisVersionInfo;
- //! Are postgisVersionMajor, postgisVersionMinor, geosAvailable, gistAvailable, projAvailable valid?
- bool gotPostgisVersion;
- //! PostGIS major version
- int postgisVersionMajor;
- //! PostGIS minor version
- int postgisVersionMinor;
- //! GEOS capability
- bool geosAvailable;
- //! GIST capability
- bool gistAvailable;
- //! PROJ4 capability
- bool projAvailable;
int enabledCapabilities;
/**Returns the maximum value of the primary key attribute
@@ -597,29 +547,129 @@
void customEvent( QEvent *e );
- PGconn *connectDb( const QString &conninfo, bool readonly = true );
- void disconnectDb();
- bool useWkbHex;
void appendGeomString( QgsGeometry *geom, QString &geomParam ) const;
QByteArray paramValue( QString fieldvalue, const QString &defaultValue ) const;
- // run a query and check for errors
- static PGresult *PQexec( PGconn *conn, const char *query );
+ class Conn
+ public:
+ Conn( PGconn *connection ) :
+ ref( 1 ),
+ openCursors( 0 ),
+ conn( connection ),
+ gotPostgisVersion( false )
- // run a query and free result buffer
- static bool PQexecNR( PGconn *conn, const char *query );
+ //! get postgis version string
+ QString postgisVersion();
- struct Conn
+ //! get status of GEOS capability
+ bool hasGEOS();
+ //! get status of GIST capability
+ bool hasGIST();
+ //! get status of PROJ4 capability
+ bool hasPROJ();
+ //! encode wkb in hex
+ bool useWkbHex() { return mUseWkbHex; }
+ //! major PostgreSQL version
+ int majorVersion() { return postgisVersionMajor; }
+ // run a query and free result buffer
+ bool PQexecNR( QString query );
+ // cursor handling
+ bool openCursor( QString cursorName, QString declare );
+ bool closeCursor( QString cursorName );
+ PGconn *pgConnection() { return conn; }
+ // libpq wrapper
+ // run a query and check for errors
+ PGresult *PQexec( QString query );
+ void PQfinish();
+ int PQsendQuery( QString query );
+ PGresult *PQgetResult();
+ PGresult *PQprepare( QString stmtName, QString query, int nParams, const Oid *paramTypes );
+ PGresult *PQexecPrepared( QString stmtName, const QStringList ¶ms );
+ static Conn *connectDb( const QString &conninfo, bool readonly );
+ static void disconnectRW( Conn *&conn );
+ static void disconnectRO( Conn *&conn );
+ static void disconnect( QMap<QString, Conn *> &connections, Conn *&conn );
+ private:
+ int ref;
+ int openCursors;
+ PGconn *conn;
+ //! GEOS capability
+ bool geosAvailable;
+ //! PostGIS version string
+ QString postgisVersionInfo;
+ //! Are postgisVersionMajor, postgisVersionMinor, geosAvailable, gistAvailable, projAvailable valid?
+ bool gotPostgisVersion;
+ //! PostGIS major version
+ int postgisVersionMajor;
+ //! PostGIS minor version
+ int postgisVersionMinor;
+ //! GIST capability
+ bool gistAvailable;
+ //! PROJ4 capability
+ bool projAvailable;
+ bool mUseWkbHex;
+ static QMap<QString, Conn *> connectionsRW;
+ static QMap<QString, Conn *> connectionsRO;
+ class Result
- Conn( PGconn *connection ) : ref( 1 ), conn( connection ) {}
+ public:
+ Result( PGresult *theRes = 0 ) : res( theRes ) {}
+ ~Result() { if ( res ) PQclear( res ); }
- int ref;
- PGconn *conn;
+ operator PGresult *() { return res; }
+ Result &operator=( PGresult *theRes ) { if ( res ) PQclear( res ); res = theRes; return *this; }
+ private:
+ PGresult *res;
- static QMap<QString, Conn *> connectionsRW;
- static QMap<QString, Conn *> connectionsRO;
+ * Connection pointers
+ Conn *connectionRO;
+ Conn *connectionRW;
+ bool connectRW()
+ return connectionRW;
+ connectionRW = Conn::connectDb( mUri.connInfo(), false );
+ void disconnectDb();
static int providerIds;
