[QGIS Commit] r9191 - in trunk/qgis/src/plugins: . ogr_converter
svn_qgis at osgeo.org
Wed Aug 27 09:29:01 EDT 2008
Author: mhugent
Date: 2008-08-27 09:29:01 -0400 (Wed, 27 Aug 2008)
New Revision: 9191
Added:
trunk/qgis/src/plugins/ogr_converter/
trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt
trunk/qgis/src/plugins/ogr_converter/README
trunk/qgis/src/plugins/ogr_converter/dialog.cpp
trunk/qgis/src/plugins/ogr_converter/dialog.h
trunk/qgis/src/plugins/ogr_converter/format.cpp
trunk/qgis/src/plugins/ogr_converter/format.h
trunk/qgis/src/plugins/ogr_converter/ogrconverter.png
trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc
trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
trunk/qgis/src/plugins/ogr_converter/plugin.cpp
trunk/qgis/src/plugins/ogr_converter/plugin.h
trunk/qgis/src/plugins/ogr_converter/translator.cpp
trunk/qgis/src/plugins/ogr_converter/translator.h
trunk/qgis/src/plugins/CMakeLists.txt
Ogr converter plugin written by mloskot
Modified: trunk/qgis/src/plugins/CMakeLists.txt
--- trunk/qgis/src/plugins/CMakeLists.txt 2008-08-27 13:21:17 UTC (rev 9190)
+++ trunk/qgis/src/plugins/CMakeLists.txt 2008-08-27 13:29:01 UTC (rev 9191)
@@ -21,4 +21,6 @@
SUBDIRS (quick_print)
-SUBDIRS (coordinate_capture dxf2shp_converter)
\ No newline at end of file
+SUBDIRS (coordinate_capture dxf2shp_converter)
+SUBDIRS (ogr_converter)
Added: trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt
--- trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,65 @@
+# $Id$
+# CMake configuration file for OGR Converter plugin
+# Author: Mateusz Loskot <mateusz at loskot.net>
+# Files
+SET (OGR_CONVERTER_SRCS
+ plugin.cpp
+ dialog.cpp
+ format.cpp
+ translator.cpp
+SET (OGR_CONVERTER_UIS ogrconverterguibase.ui)
+SET (OGR_CONVERTER_MOC_HDRS
+ plugin.h
+ dialog.h
+SET (OGR_CONVERTER_RCCS ogrconverter.qrc)
+SET (OGR_CONVERTER_PLUGIN ogrconverterplugin)
+# Build
+QT4_WRAP_UI (OGR_CONVERTER_UIS_H ${OGR_CONVERTER_UIS})
+QT4_WRAP_CPP (OGR_CONVERTER_MOC_SRCS ${OGR_CONVERTER_MOC_HDRS})
+QT4_ADD_RESOURCES(OGR_CONVERTER_RCC_SRCS ${OGR_CONVERTER_RCCS})
+ADD_LIBRARY (${OGR_CONVERTER_PLUGIN} MODULE
+ ${OGR_CONVERTER_SRCS}
+ ${OGR_CONVERTER_MOC_SRCS}
+ ${OGR_CONVERTER_RCC_SRCS}
+ ${OGR_CONVERTER_UIS_H}
+INCLUDE_DIRECTORIES (
+ ${CMAKE_CURRENT_BINARY_DIR}
+ ../../core
+ ../../core/raster
+ ../../core/renderer
+ ../../core/symbology
+ ../../gui
+ ${GDAL_INCLUDE_DIR}
+TARGET_LINK_LIBRARIES(${OGR_CONVERTER_PLUGIN}
+ ${GDAL_LIBRARY}
+ qgis_core
+ qgis_gui
+# Install
+INSTALL(TARGETS ${OGR_CONVERTER_PLUGIN}
+ RUNTIME DESTINATION ${QGIS_PLUGIN_DIR}
+ LIBRARY DESTINATION ${QGIS_PLUGIN_DIR}
Added: trunk/qgis/src/plugins/ogr_converter/README
--- trunk/qgis/src/plugins/ogr_converter/README (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/README 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,35 @@
+OGR Layer Converter Pluginm, Version 0.1 (Alpha)
+Author: Mateusz Loskot <mateusz at loskot.net>
+OGR Layer Converter aims to be a GUI-based implementation of well-known
+ogr2ogr utility from GDAL/OGR package. The plugin translates layers
+between OGR supported formats built-in GDAL/OGR library available for
+particular QGIS installation.
+Built-in formats are listed in drop-down boxes.
+Currently, it is possible to translate one selected source
+layer to another OGR format.
+Testing appreciated.
+ TODO
+translator.h: // TODO: Implement, currently always overwrite
+translator.h: // TODO: Append option not supported
+dialog.cpp:// TODO: Add support of QGIS projection selector
+dialog.cpp: // TODO: Transformation support
+dialog.cpp: // TODO: SRS transformation support
+dialog.cpp: // TODO: Use try-catch to display more meaningful error messages from Translator
+plugin.cpp: // TODO: Who is responsible for OGR cleanup?
+translator.cpp: // TODO: RAII for OGR handlers!!!
+translator.cpp: // TODO: Support translation of all layers from input data source
+translator.cpp: // TODO: -nlt option support
+translator.cpp: // TODO: Implement SRS transformation
+translator.cpp: // TODO: Append and createion options not implemented
+translator.cpp: // TODO: RAII for feature handlers!!!
+translator.cpp: // TODO: Transform feature geometry
+translator.cpp: // TODO: Skip failures support
+translator.cpp: // TODO: Add support for creation options
Added: trunk/qgis/src/plugins/ogr_converter/dialog.cpp
--- trunk/qgis/src/plugins/ogr_converter/dialog.cpp (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/dialog.cpp 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,453 @@
+// $Id$
+// Copyright (C) 2008 by Mateusz Loskot <mateusz at loskot.net>
+// This program is free software; you can redistribute it and/or modify
+// it under the terms of the GNU General Public License as published by
+// the Free Software Foundation; either version 2 of the License,
+// or (at your option) any later version.
+// qgis::plugin::ogrconv
+#include "dialog.h"
+#include "format.h"
+#include "translator.h"
+// QGIS includes
+#include <qgslogger.h>
+#include <qgscontexthelp.h>
+// TODO: Add support of QGIS projection selector
+//#include <qgsprojectionselector.h>
+// Qt4
+#include <QtAlgorithms>
+#include <QtDebug>
+#include <QFileDialog>
+#include <QMessageBox>
+#include <QSettings>
+#include <QString>
+#include <QStringList>
+#include <QVariant>
+namespace qgis { namespace plugin { namespace ogrconv {
+// GDAL/OGR loaded into private namespace
+#include <ogr_api.h>
+#include <ogrsf_frmts.h>
+Dialog::Dialog(QWidget* parent, Qt::WFlags fl)
+ : QDialog(parent, fl)
+ setupUi(this);
+ populateFormats();
+ resetSrcUi();
+ resetDstUi();
+Dialog::~Dialog()
+void Dialog::resetSrcUi()
+ // Clear all settings and states
+ inputSrcDataset->clear();
+ // TODO: Transformation support
+ //inputSrcSrs->clear();
+ comboSrcLayer->clear();
+ radioSrcFile->setDisabled(true);
+ radioSrcFile->setChecked(false);
+ radioSrcDirectory->setDisabled(true);
+ radioSrcDirectory->setChecked(false);
+ radioSrcProtocol->setDisabled(true);
+ radioSrcProtocol->setChecked(false);
+ // Configure types of input sources
+ unsigned char const& type = mSrcFormat.type();
+ if (isFormatType(type, Format::eFile))
+ radioSrcFile->setDisabled(false);
+ radioSrcFile->setChecked(true);
+ if (isFormatType(type, Format::eDirectory))
+ radioSrcDirectory->setDisabled(false);
+ if (!radioSrcFile->isEnabled())
+ radioSrcDirectory->setChecked(true);
+ if (isFormatType(type, Format::eProtocol))
+ radioSrcProtocol->setDisabled(false);
+ if (!radioSrcFile->isEnabled() && !radioSrcDirectory->isEnabled())
+ radioSrcProtocol->setChecked(true);
+ inputSrcDataset->setText(mSrcFormat.protocol());
+ setButtonState(buttonSelectSrc, isFormatType(type, Format::eProtocol));
+void Dialog::resetDstUi()
+ inputDstDataset->clear();
+ //inputDstSrs->clear();
+ unsigned char const& type = mDstFormat.type();
+ bool isProtocol = isFormatType(type, Format::eProtocol);
+ if (isProtocol)
+ inputDstDataset->setText(mDstFormat.protocol());
+ setButtonState(buttonSelectDst, isProtocol);
+void Dialog::setButtonState(QPushButton* btn, bool isProtocol)
+ Q_CHECK_PTR(btn);
+ if (isProtocol)
+ btn->setText(tr("Connect"));
+ else
+ btn->setText(tr("Browse"));
+void Dialog::populateFormats()
+ comboSrcFormats->clear();
+ comboDstFormats->clear();
+ QStringList drvSrcList;
+ QStringList drvDstList;
+ QString drvName;
+ if (0 >= OGRGetDriverCount())
+ OGRRegisterAll();
+ int const drvCount = OGRGetDriverCount();
+ for (int i = 0; i < drvCount; ++i)
+ OGRSFDriverH drv = OGRGetDriver(i);
+ Q_CHECK_PTR(drv);
+ if (0 != drv)
+ drvName = OGR_Dr_GetName(drv);
+ drvSrcList.append(drvName);
+ if (0 != OGR_Dr_TestCapability(drv, ODrCCreateDataSource))
+ drvDstList.append(drvName);
+ qSort(drvSrcList.begin(), drvSrcList.end());
+ qSort(drvDstList.begin(), drvDstList.end());
+ comboSrcFormats->addItems(drvSrcList);
+ comboDstFormats->addItems(drvDstList);
+void Dialog::populateLayers(QString const& url)
+ OGRDataSourceH ds = OGROpen(url.toAscii().constData(), 0, 0);
+ if (0 != ds)
+ QString lyrName;
+ QString lyrType;
+ int const size = OGR_DS_GetLayerCount(ds);
+ for (int i = 0; i < size; ++i)
+ OGRLayerH lyr = OGR_DS_GetLayer(ds, i);
+ if (0 != lyr)
+ OGRFeatureDefnH lyrDef = OGR_L_GetLayerDefn(lyr);
+ Q_ASSERT(0 != lyrDef);
+ lyrName = OGR_FD_GetName(lyrDef);
+ OGRwkbGeometryType const geomType = OGR_FD_GetGeomType(lyrDef);
+ lyrType = OGRGeometryTypeToName(geomType);
+ // FIXME: Appending type to layer name prevents from layer finding
+ //comboSrcLayer->addItem(lyrName + " (" + lyrType.toUpper() + ")");
+ comboSrcLayer->addItem(lyrName);
+ OGR_DS_Destroy(ds);
+ else
+ QMessageBox::warning(this,
+ tr("OGR Converter"),
+ tr("Could not establish connection to: '") + url + "'",
+ QMessageBox::Close);
+bool Dialog::testConnection(QString const& url)
+ bool success = false;
+ if (0 != ds)
+ success = true;
+ return success;
+QString Dialog::openFile()
+ QSettings sets;
+ QString path = QFileDialog::getOpenFileName(this,
+ tr("Open OGR file"),
+ sets.value("/Plugin-OGR/ogr-file", "./").toString(),
+ tr("OGR File Data Source (*.*)"));
+ return path;
+QString Dialog::openDirectory()
+ QString path = QFileDialog::getExistingDirectory(this,
+ tr("Open Directory"), "",
+ QFileDialog::ShowDirsOnly | QFileDialog::DontResolveSymlinks);
+ return path;
+void Dialog::on_buttonBox_accepted()
+ // Validate input settings
+ QString srcUrl(inputSrcDataset->text());
+ QString srcLayer(comboSrcLayer->currentText());
+ if (srcUrl.isEmpty())
+ QMessageBox::warning(this, "OGR Layer Converter",
+ tr("Input OGR dataset is missing!"));
+ return;
+ if (srcLayer.isEmpty())
+ tr("Input OGR layer name is missing!"));
+ return;
+ // Validate output settings
+ QString dstFormat(comboDstFormats->currentText());
+ QString dstUrl(inputDstDataset->text());
+ QString dstLayer(inputDstLayer->text());
+ if (dstLayer.isEmpty())
+ dstLayer = srcLayer;
+ if (dstFormat.isEmpty())
+ tr("Target OGR format not selected!"));
+ return;
+ if (dstUrl.isEmpty())
+ tr("Output OGR dataset is missing!"));
+ return;
+ tr("Output OGR layer name is missing!"));
+ return;
+ // TODO: SRS transformation support
+ //QString srcSrs("EPSG:");
+ //QString dstSrs("EPSG:");
+ //srcSrs += inputSrcSrs->text();
+ //dstSrs += inputDstSrs->text();
+ // Execute layer translation
+ // TODO: Use try-catch to display more meaningful error messages from Translator
+ Translator worker(srcUrl, dstUrl, dstFormat);
+ worker.setSourceLayer(srcLayer);
+ worker.setTargetLayer(dstLayer);
+ success = worker.translate();
+ if (success)
+ QMessageBox::information(this, "OGR Layer Converter",
+ tr("Successfully translated layer '") + srcLayer + "'");
+ else
+ tr("Failed to translate layer '") + srcLayer + "'");
+ // Close dialog box
+ accept();
+void Dialog::on_buttonBox_rejected()
+ reject();
+void Dialog::on_buttonBox_helpRequested()
+ QgsContextHelp::run(context_id);
+void Dialog::on_radioSrcFile_toggled(bool checked)
+ if (checked)
+ Q_ASSERT(isFormatType(type, Format::eFile));
+void Dialog::on_radioSrcDirectory_toggled(bool checked)
+ if (checked)
+ Q_ASSERT(isFormatType(type, Format::eDirectory));
+void Dialog::on_radioSrcProtocol_toggled(bool checked)
+ if (checked)
+ Q_ASSERT(isFormatType(type, Format::eProtocol));
+void Dialog::on_comboSrcFormats_currentIndexChanged(int index)
+ // Select source data format
+ QString frmtCode = comboSrcFormats->currentText();
+ mSrcFormat = mFrmts.find(frmtCode);
+ resetSrcUi();
+void Dialog::on_comboDstFormats_currentIndexChanged(int index)
+ // Select destination data format
+ QString frmtCode = comboDstFormats->currentText();
+ mDstFormat = mFrmts.find(frmtCode);
+ resetDstUi();
+void Dialog::on_buttonSelectSrc_clicked()
+ QSettings settings;
+ QString src;
+ if (radioSrcFile->isChecked())
+ src = openFile();
+ else if (radioSrcDirectory->isChecked())
+ src = openDirectory();
+ else if (radioSrcProtocol->isChecked())
+ src = inputSrcDataset->text();
+ else
+ Q_ASSERT(!"SHOULD NEVER GET HERE");
+ inputSrcDataset->setText(src);
+ if (!src.isEmpty())
+ populateLayers(src);
+void Dialog::on_buttonSelectDst_clicked()
+ QString dst;
+ QString msg;
+ dst = inputDstDataset->text();
+ if (testConnection(dst))
+ msg = tr("Successfully connected to: '") + dst + "'";
+ else
+ msg = tr("Could not establish connection to: '") + dst + "'";
+ QMessageBox::information(this, tr("OGR Converter"),
+ msg, QMessageBox::Close);
+ else if (isFormatType(type, Format::eDirectory))
+ dst = openDirectory();
+ else if (isFormatType(type, Format::eFile))
+ dst = QFileDialog::getSaveFileName(this,
+ tr("Choose a file name to save to"),
+ "output", tr("OGR File Data Source (*.*)"));
+ else
+ inputDstDataset->setText(dst);
+}}} // namespace qgis::plugin::ogrconv
Added: trunk/qgis/src/plugins/ogr_converter/dialog.h
--- trunk/qgis/src/plugins/ogr_converter/dialog.h (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/dialog.h 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,69 @@
+// $Id$
+#ifndef QGIS_PLUGIN_OGRCONV_DIALOG_H_INCLUDED
+#define QGIS_PLUGIN_OGRCONV_DIALOG_H_INCLUDED
+#include <ui_ogrconverterguibase.h>
+// Qt4
+#include <QDialog>
+ at author Mateusz Loskot
+class Dialog : public QDialog, private Ui::OgrConverterGuiBase
+ Q_OBJECT
+public:
+ Dialog(QWidget* parent = 0, Qt::WFlags fl = 0);
+ ~Dialog();
+private:
+ static const int context_id = 0;
+ FormatsRegistry mFrmts;
+ Format mSrcFormat;
+ Format mDstFormat;
+ void resetSrcUi();
+ void resetDstUi();
+ void setButtonState(QPushButton* btn, bool isProtocol);
+ void populateFormats();
+ void populateLayers(QString const& url);
+ bool testConnection(QString const& url);
+ QString openFile();
+ QString openDirectory();
+private slots:
+ void on_buttonBox_accepted();
+ void on_buttonBox_rejected();
+ void on_buttonBox_helpRequested();
+ void on_radioSrcFile_toggled(bool checked);
+ void on_radioSrcDirectory_toggled(bool checked);
+ void on_radioSrcProtocol_toggled(bool checked);
+ void on_buttonSelectSrc_clicked();
+ void on_buttonSelectDst_clicked();
+ void on_comboSrcFormats_currentIndexChanged(int index);
+ void on_comboDstFormats_currentIndexChanged(int index);
+#endif // QGIS_PLUGIN_OGRCONV_DIALOG_H_INCLUDED
Added: trunk/qgis/src/plugins/ogr_converter/format.cpp
--- trunk/qgis/src/plugins/ogr_converter/format.cpp (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/format.cpp 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,117 @@
+// $Id$
+// Qt4
+#include <QString>
+Format::Format()
+Format::Format(QString const& c, QString const& n)
+ : mCode(c), mName(n), mTypeFlags(0)
+Format::Format(QString const& c, QString const& n, unsigned char const& t)
+ : mCode(c), mName(n), mTypeFlags(t)
+Format::Format(QString const& c, QString const& n, QString const& p, unsigned char const& t)
+ : mCode(c), mName(n), mProtocol(p), mTypeFlags(t)
+QString const& Format::code() const
+ return mCode;
+QString const& Format::name() const
+ return mName;
+QString const& Format::protocol() const
+ return mProtocol;
+unsigned char const& Format::type() const
+ return mTypeFlags;
+FormatsRegistry::FormatsRegistry()
+ init();
+void FormatsRegistry::add(Format const& frmt)
+ QString code = frmt.code();
+ mFrmts[code] = frmt;
+Format const& FormatsRegistry::find(QString const& code)
+ mCache = mFrmts.value(code);
+ return mCache;
+void FormatsRegistry::init()
+ add(Format("AVCBin", "Arc/Info Binary Coverage", Format::eFile));
+ add(Format("AVCE00", "Arc/Info .E00 (ASCII) Coverage", Format::eFile));
+ add(Format("BNA", "Atlas BNA", Format::eFile));
+ add(Format("CSV", "Comma Separated Value", Format::eFile | Format::eDirectory));
+ add(Format("DODS", "DODS/OPeNDAP", Format::eFile));
+ add(Format("DGN", "Microstation DGN", Format::eFile));
+ add(Format("ESRI Shapefile", "ESRI Shapefile", Format::eFile | Format::eDirectory));
+ add(Format("FMEObjects Gateway", "FMEObjects Gateway", Format::eFile));
+ add(Format("Geoconcept Text Export", "Geoconcept", Format::eFile));
+ add(Format("GML", "Geography Markup Language", Format::eFile));
+ add(Format("GMT", "GMT ASCII Vectors", Format::eFile));
+ add(Format("GPX", "GPS Exchange Format", Format::eFile));
+ add(Format("GeoJSON", "GeoJSON", Format::eFile)); // FIXME: Format::eProtocol));
+ add(Format("GRASS", "GRASS", Format::eDirectory));
+ add(Format("Informix DataBlade", "IDB", "IDB:", Format::eProtocol));
+ add(Format("Interlis 1", "INTERLIS", Format::eFile));
+ add(Format("Interlis 2", "INTERLIS", Format::eFile));
+ add(Format("Ingres Database", "INGRES", "@driver=ingres,", Format::eProtocol));
+ add(Format("KML", "KML", Format::eFile));
+ add(Format("MapInfo", "MapInfo File", Format::eFile));
+ add(Format("Memory", "Memory", Format::eFile));
+ add(Format("MySQL", "MySQL", "MySQL:", Format::eProtocol));
+ add(Format("ODBC", "Open DataBase Connectivity", "ODBC:", Format::eProtocol));
+ add(Format("OGDI", "Open Geographic Datastore Interface Vectors", "gltp:", Format::eProtocol));
+ add(Format("OCI", "Oracle Spatial", "OCI:", Format::eProtocol));
+ add(Format("PGeo", "ESRI Personal GeoDatabase", "PGeo:", Format::eFile | Format::eProtocol));
+ add(Format("PostgreSQL", "PostgreSQL", "PG:", Format::eProtocol));
+ add(Format("S57", "IHO S-57", Format::eFile));
+ add(Format("SDE", "ESRI ArcSDE", "SDE:", Format::eProtocol));
+ add(Format("SDTS", "SDTS Topological Vector Profile", Format::eFile));
+ add(Format("SQLite", "SQLite Database File", Format::eFile));
+ add(Format("UK.NTF", "UK National Transfer Format", Format::eFile));
+ add(Format("TIGER", "U.S. Census TIGER/Line", Format::eFile));
+ add(Format("VRT", "Virtual Datasource", Format::eFile));
+ add(Format("XPLANE", "X-Plane/Flighgear Aeronautical Data", Format::eFile));
Added: trunk/qgis/src/plugins/ogr_converter/format.h
--- trunk/qgis/src/plugins/ogr_converter/format.h (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/format.h 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,76 @@
+// $Id$
+#ifndef QGIS_PLUGIN_OGRCONV_FORMATS_H_INCLUDED
+#define QGIS_PLUGIN_OGRCONV_FORMATS_H_INCLUDED
+// Qt4
+#include <QMap>
+#include <QString>
+class Format
+public:
+ enum Type
+ eUnknown = 0,
+ eFile = 1,
+ eDirectory = 2,
+ eProtocol = 4
+ Format();
+ Format(QString const& c, QString const& n);
+ Format(QString const& c, QString const& n, unsigned char const& t);
+ Format(QString const& c, QString const& n, QString const& p, unsigned char const& t);
+ QString const& code() const;
+ QString const& name() const;
+ QString const& protocol() const;
+ unsigned char const& type() const;
+private:
+ QString mCode;
+ QString mName;
+ QString mProtocol;
+ unsigned char mTypeFlags;
+inline bool isFormatType(unsigned char const& frmt, Format::Type const& type)
+ return ((frmt & type) == type);
+class FormatsRegistry
+public:
+ FormatsRegistry();
+ void add(Format const& frmt);
+ Format const& find(QString const& code);
+private:
+ void init();
+ QMap<QString, Format> mFrmts;
+ Format mCache;
+#endif // QGIS_PLUGIN_OGRCONV_FORMATS_H_INCLUDED
Added: trunk/qgis/src/plugins/ogr_converter/ogrconverter.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/ogr_converter/ogrconverter.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc
--- trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,5 @@
+<RCC>
+ <qresource prefix="/ogrconverter/" >
+ <file>ogrconverter.png</file>
+ </qresource>
+</RCC>
Added: trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
--- trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,378 @@
+<ui version="4.0" >
+ <class>OgrConverterGuiBase</class>
+ <widget class="QDialog" name="OgrConverterGuiBase" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>521</width>
+ <height>450</height>
+ </rect>
+ </property>
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="MinimumExpanding" hsizetype="MinimumExpanding" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="minimumSize" >
+ <size>
+ <width>520</width>
+ </size>
+ </property>
+ <property name="windowTitle" >
+ <string>OGR Layer Converter</string>
+ </property>
+ <property name="windowIcon" >
+ <iconset>
+ <normaloff/>
+ </iconset>
+ </property>
+ <layout class="QGridLayout" name="gridLayout" >
+ <item row="0" column="0" >
+ <widget class="QGroupBox" name="srcGroupBox" >
+ <property name="title" >
+ <string>Source</string>
+ </property>
+ <widget class="QWidget" name="" >
+ <rect>
+ <x>20</x>
+ <y>30</y>
+ <width>461</width>
+ <height>28</height>
+ </rect>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout" >
+ <item>
+ <widget class="QLabel" name="labelSrcFormat" >
+ <size>
+ <width>52</width>
+ <height>22</height>
+ </size>
+ </property>
+ <property name="text" >
+ <string>Format:</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="comboSrcFormats" >
+ <size>
+ <width>200</width>
+ <height>0</height>
+ </size>
+ </property>
+ <property name="maxCount" >
+ <number>200</number>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_3" >
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0" >
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <rect>
+ <x>20</x>
+ <y>70</y>
+ <height>21</height>
+ </rect>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_4" >
+ <item>
+ <widget class="QRadioButton" name="radioSrcFile" >
+ <string>File</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radioSrcDirectory" >
+ <string>Directory</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radioSrcProtocol" >
+ <string>Remote source</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <rect>
+ <x>21</x>
+ <y>140</y>
+ </rect>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_2" >
+ <item>
+ <widget class="QLabel" name="labelSrcLayer" >
+ <size>
+ <width>52</width>
+ </size>
+ </property>
+ <string>Layer:</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="comboSrcLayer" >
+ <size>
+ <width>300</width>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_2" >
+ </property>
+ <size>
+ <width>88</width>
+ <height>17</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <rect>
+ <x>21</x>
+ <y>100</y>
+ <width>457</width>
+ <height>34</height>
+ </rect>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_6" >
+ <item>
+ <widget class="QLabel" name="labelSrcDataset" >
+ <string>Dataset:</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLineEdit" name="inputSrcDataset" >
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="buttonSelectSrc" >
+ <size>
+ <width>90</width>
+ </size>
+ </property>
+ <string>Browse</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </widget>
+ </item>
+ <item row="2" column="0" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QGroupBox" name="dstGroupBox" >
+ <string>Target</string>
+ </property>
+ <rect>
+ <x>22</x>
+ <y>33</y>
+ <width>454</width>
+ </rect>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_3" >
+ <item>
+ <widget class="QLabel" name="labelDstFormat" >
+ <size>
+ <width>52</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="comboDstFormats" >
+ <size>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer" >
+ </property>
+ <size>
+ <width>88</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <rect>
+ <x>20</x>
+ <y>71</y>
+ </rect>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_7" >
+ <item>
+ <widget class="QLabel" name="labelDstDataset" >
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLineEdit" name="inputDstDataset" >
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="buttonSelectDst" >
+ <size>
+ <width>90</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <rect>
+ <x>20</x>
+ <y>110</y>
+ <width>451</width>
+ <height>24</height>
+ </rect>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_8" >
+ <item>
+ <widget class="QLabel" name="labelDstLayer" >
+ <size>
+ <width>52</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLineEdit" name="inputDstLayer" >
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_5" >
+ </property>
+ <size>
+ <width>40</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <layoutdefault spacing="6" margin="11" />
+ <tabstops>
+ <tabstop>inputSrcDataset</tabstop>
+ <tabstop>buttonSelectSrc</tabstop>
+ </tabstops>
+ <resources/>
+ <connections/>
+</ui>
Added: trunk/qgis/src/plugins/ogr_converter/plugin.cpp
--- trunk/qgis/src/plugins/ogr_converter/plugin.cpp (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/plugin.cpp 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,149 @@
+// $Id$
+// begin : Aug 24, 2008
+// copyright : (C) 2008 by Mateusz Loskot
+// email : mateusz at loskot.net
+#include "plugin.h"
+// QGIS
+#include <qgisinterface.h>
+#include <qgisgui.h>
+// Qt
+#include <QAction>
+#include <QToolBar>
+// std
+#include <cassert>
+// GDAL/OGR loaded into private namesapce
+static const char * const sIdent = "$Id$";
+static const QString sName = QObject::tr("OGR Layer Converter");
+static const QString sDescription = QObject::tr("Translates vector layers between formats supported by OGR library");
+static const QString sPluginVersion = QObject::tr("Version 0.1");
+static const QgisPlugin::PLUGINTYPE sPluginType = QgisPlugin::UI;
+// THE FOLLOWING METHODS ARE MANDATORY FOR ALL PLUGINS
+OgrPlugin::OgrPlugin(QgisInterface * theQgisInterface) :
+ QgisPlugin(sName, sDescription, sPluginVersion, sPluginType),
+ mQGisIface(theQgisInterface),
+ mQActionPointer(0)
+ assert(0 != mQGisIface);
+OgrPlugin::~OgrPlugin()
+void OgrPlugin::initGui()
+ // Create the action for tool
+ mQActionPointer = new QAction(QIcon(":/ogrconverter/ogrconverter.png"), tr("Run OGR Layer Converter"), this);
+ // Set the what's this text
+ mQActionPointer->setWhatsThis(tr("Replace this with a short description of the what the plugin does"));
+ // Connect the action to the run
+ connect(mQActionPointer, SIGNAL(triggered()), this, SLOT(run()));
+ // Add the icon to the toolbar
+ mQGisIface->addToolBarIcon(mQActionPointer);
+ mQGisIface->addPluginMenu(tr("OG&R Converter"), mQActionPointer);
+//method defined in interface
+void OgrPlugin::help()
+ //implement me!
+void OgrPlugin::run()
+ Dialog* ogrDialog = new Dialog(mQGisIface->getMainWindow(), QgisGui::ModalDialogFlags);
+ ogrDialog->setAttribute(Qt::WA_DeleteOnClose);
+ ogrDialog->show();
+void OgrPlugin::unload()
+ // TODO: Who is responsible for OGR cleanup?
+ //OGRCleanupAll();
+ // remove the GUI
+ mQGisIface->removePluginMenu("&OGR Layer Converter", mQActionPointer);
+ mQGisIface->removeToolBarIcon(mQActionPointer);
+ delete mQActionPointer;
+// THE FOLLOWING CODE IS AUTOGENERATED BY THE PLUGIN BUILDER SCRIPT
+// YOU WOULD NORMALLY NOT NEED TO MODIFY THIS, AND YOUR PLUGIN
+// MAY NOT WORK PROPERLY IF YOU MODIFY THIS INCORRECTLY
+// Required extern functions needed for every plugin
+// These functions can be called prior to creating an instance
+// of the plugin class.
+// Class factory to return a new instance of the plugin class
+QGISEXTERN QgisPlugin * classFactory(QgisInterface * theQgisInterfacePointer)
+ return new OgrPlugin(theQgisInterfacePointer);
+// Return the name of the plugin - note that we do not user class members as
+// the class may not yet be insantiated when this method is called.
+QGISEXTERN QString name()
+ return sName;
+// Return the description
+QGISEXTERN QString description()
+ return sDescription;
+// Return the type (either UI or MapLayer plugin)
+QGISEXTERN int type()
+ return sPluginType;
+// Return the version number for the plugin
+QGISEXTERN QString version()
+ return sPluginVersion;
+// Delete ourself
+QGISEXTERN void unload(QgisPlugin * thePluginPointer)
+ delete thePluginPointer;
Added: trunk/qgis/src/plugins/ogr_converter/plugin.h
--- trunk/qgis/src/plugins/ogr_converter/plugin.h (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/plugin.h 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,103 @@
+// $Id$
+#ifndef QGIS_PLUGIN_OGRCONV_PLUGIN_H_INCLUDED
+#define QGIS_PLUGIN_OGRCONV_PLUGIN_H_INCLUDED
+// QGIS
+#include "../qgisplugin.h"
+// Qt4
+#include <QObject>
+// Forward declarations
+class QAction;
+class QToolBar;
+class QgisInterface;
+* \class OgrPlugin
+* \brief Translates vector layers between formats supported by OGR library.
+class OgrPlugin : public QObject, public QgisPlugin
+ Q_OBJECT
+public:
+ // MANDATORY PLUGIN METHODS FOLLOW
+ * Constructor for a plugin. The QgisInterface pointer is passed by
+ * QGIS when it attempts to instantiate the plugin.
+ * @param theInterface Pointer to the QgisInterface object.
+ OgrPlugin(QgisInterface * theInterface);
+ //! Destructor
+ virtual ~OgrPlugin();
+public slots:
+ * Initialize the GUI interface for the plugin.
+ * This is only called once when the plugin is added to the plugin
+ * registry in the QGIS application.
+ virtual void initGui();
+ * Slot called when the menu item is triggered.
+ * If you created more menu items / toolbar buttons in initiGui,
+ * you should create a separate handler for each action - this
+ * single run() method will not be enough.
+ void run();
+ * Unload the plugin by cleaning up the GUI.
+ void unload();
+ //! show the help document
+ void help();
+private:
+ // MANDATORY PLUGIN PROPERTY DECLARATIONS
+ // FIXME: Is it used at all?
+ int mPluginType;
+ //! Pointer to the QGIS interface object
+ QgisInterface *mQGisIface;
+ //!pointer to the qaction for this plugin
+ QAction * mQActionPointer;
+ // ADD YOUR OWN PROPERTY DECLARATIONS AFTER THIS POINT.....
+}; // OgrPlugin
+#endif // QGIS_PLUGIN_OGRCONV_PLUGIN_H_INCLUDED
Added: trunk/qgis/src/plugins/ogr_converter/translator.cpp
--- trunk/qgis/src/plugins/ogr_converter/translator.cpp (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/translator.cpp 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,419 @@
+// $Id$
+// QGIS
+// Qt4
+#include <QString>
+Translator::Translator()
+ : mDstUpdate(false), mDstLayerOverwrite(true)
+Translator::Translator(QString const& src, QString const& dst, QString const& format)
+ : mSrcUrl(src), mDstUrl(dst), mDstFormat(format),
+ mDstUpdate(false), mDstLayerOverwrite(true)
+QString const& Translator::targetFormat() const
+ return mDstFormat;
+void Translator::setTargetFormat(QString const& format)
+ mDstFormat = format;
+QString const& Translator::targetLayer() const
+ return mDstLayer;
+void Translator::setTargetLayer(QString const& layer)
+ mDstLayer = layer;
+QString const& Translator::sourceLayer() const
+ return mSrcLayer;
+void Translator::setSourceLayer(QString const& layer)
+ mSrcLayer = layer;
+QString const& Translator::targetReferenceSystem() const
+ return mDstSrs;
+void Translator::setTargetReferenceSystem(QString const& srs)
+ mDstSrs = srs;
+QString const& Translator::sourceReferenceSystem() const
+ return mSrcSrs;
+void Translator::setSourceReferenceSystem(QString const& srs)
+ mSrcSrs = srs;
+bool Translator::isTargetUpdate() const
+ return mDstUpdate;
+void Translator::setUpdateTarget(bool update)
+ mDstUpdate = update;
+bool Translator::isTargetLayerOverwrite() const
+ return mDstLayerOverwrite;
+bool Translator::translate()
+ // TODO: RAII for OGR handlers!!!
+ // Open input data source
+ OGRDataSourceH srcDs = openDataSource(mSrcUrl, true);
+ if (0 == srcDs)
+ QgsDebugMsg("Open source failed: " + mSrcUrl);
+ return false;
+ // Open output data source
+ OGRDataSourceH dstDs = openDataTarget(mDstUrl, mDstUpdate);
+ if (0 == dstDs)
+ QgsDebugMsg("Open target failed: " + mDstUrl);
+ OGR_DS_Destroy(srcDs);
+ return false;
+ // TODO: Support translation of all layers from input data source
+ //for (int i = 0; i < OGR_DS_GetLayerCount(); ++i)
+ OGRLayerH srcLayer = OGR_DS_GetLayerByName(srcDs, mSrcLayer.toAscii().constData());
+ if (0 == srcLayer)
+ QgsDebugMsg("Can not find layer: " + mSrcLayer);
+ OGR_DS_Destroy(dstDs);
+ return false;
+ if (mDstLayer.isEmpty())
+ QgsDebugMsg("Using source layer name: " + mDstLayer);
+ mDstLayer = mSrcLayer;
+ QgsDebugMsg("START LAYER TRANSLATION ------");
+ success = translateLayer(srcDs, srcLayer, dstDs);
+ QgsDebugMsg("END LAYER TRANSLATION ------");
+ return success;
+bool Translator::translateLayer(OGRDataSourceH srcDs, OGRLayerH srcLayer, OGRDataSourceH dstDs)
+ // Implementation based on TranslateLayer function from ogr2ogr.cpp, from GDAL/OGR.
+ Q_ASSERT(0 != srcDs);
+ Q_ASSERT(0 != srcLayer);
+ Q_ASSERT(0 != dstDs);
+ // Get source layer schema
+ OGRFeatureDefnH srcLayerDefn = OGR_L_GetLayerDefn(srcLayer);
+ Q_ASSERT(0 != srcLayerDefn);
+ // Find if layer exists in target data source
+ int dstLayerIndex = 0;
+ OGRLayerH dstLayer = findLayer(dstDs, mDstLayer, dstLayerIndex);
+ // If the user requested overwrite, and we have the layer in question
+ // we need to delete it now so it will get recreated overwritten
+ if (0 != dstLayer && mDstLayerOverwrite
+ && 0 != OGR_DS_TestCapability(dstDs, ODsCDeleteLayer))
+ if (OGRERR_NONE != OGR_DS_DeleteLayer(dstDs, dstLayerIndex))
+ QgsDebugMsg("Delete layer failed when overwrite requested");
+ return false;
+ if (0 == dstLayer)
+ QgsDebugMsg("Destination layer not found, will attempt to create");
+ // If the layer does not exist, then create it
+ if (0 == OGR_DS_TestCapability(dstDs, ODsCCreateLayer))
+ QgsDebugMsg("Layer " + mDstLayer + " not found, and CreateLayer not supported by driver");
+ return false;
+ // FIXME: Do we need it here?
+ //CPLErrorReset();
+ // TODO: -nlt option support
+ OGRwkbGeometryType geomType = OGR_FD_GetGeomType(srcLayerDefn);
+ // TODO: Implement SRS transformation
+ OGRSpatialReferenceH dstLayerSrs = OGR_L_GetSpatialRef(srcLayer);
+ dstLayer = OGR_DS_CreateLayer(dstDs, mDstLayer.toAscii().constData(),
+ dstLayerSrs, geomType, 0);
+ // TODO: Append and createion options not implemented
+ // else if (!mDstLayerAppend)
+ Q_ASSERT(0 != dstLayer);
+ // Transfer attributes schema
+ if (!copyFields(dstLayer, srcLayerDefn))
+ QgsDebugMsg("Faild to copy fields from layer " + mSrcLayer);
+ return false;
+ // Transfer features
+ success = copyFeatures(srcLayer, dstLayer);
+ return success;
+bool Translator::copyFields(OGRFeatureDefnH layerDefn, OGRLayerH layer)
+ Q_ASSERT(0 != layerDefn);
+ Q_ASSERT(0 != layer);
+ int const count = OGR_FD_GetFieldCount(layerDefn);
+ for (int i = 0; i < count; ++i)
+ OGRFieldDefnH fieldDefn = OGR_FD_GetFieldDefn(layerDefn, i);
+ Q_ASSERT(0 != fieldDefn);
+ if (OGRERR_NONE != OGR_L_CreateField(layer, fieldDefn, true))
+ return false;
+ return true;
+bool Translator::copyFeatures(OGRLayerH srcLayer, OGRLayerH dstLayer)
+ long srcFid = 0;
+ long count = 0;
+ // TODO: RAII for feature handlers!!!
+ while (true)
+ OGRFeatureH srcFeat = OGR_L_GetNextFeature(srcLayer);
+ if (0 == srcFeat)
+ QgsDebugMsg("Next source feature is null, finishing");
+ success = true;
+ break;
+ srcFid = OGR_F_GetFID(srcFeat);
+ OGRFeatureH dstFeat = OGR_F_Create(srcLayerDefn);
+ if (OGRERR_NONE != OGR_F_SetFrom(dstFeat, srcFeat, true))
+ QString msg = QString("Unable to translate feature %1 from layer %2").arg(srcFid).arg(mSrcLayer);
+ QgsDebugMsg(msg);
+ OGR_F_Destroy(srcFeat);
+ OGR_F_Destroy(dstFeat);
+ success = false;
+ break;
+ Q_ASSERT(0 != dstFeat);
+ // TODO: Transform feature geometry
+ // TODO: Skip failures support
+ if (OGRERR_NONE != OGR_L_CreateFeature(dstLayer, dstFeat))
+ QgsDebugMsg("Feature creation failed");
+ success = false;
+ break;
+ count += 1;
+ success = true;
+ QgsDebugMsg(QString("Number of copied features: %1").arg(count));
+ return success;
+OGRSFDriverH Translator::findDriver(QString const& name)
+ if (OGRGetDriverCount() <= 0)
+ OGRRegisterAll();
+ OGRSFDriverH drv = 0;
+ QString drvName;
+ OGRSFDriverH drvTmp = OGRGetDriver(i);
+ Q_CHECK_PTR(drvTmp);
+ if (0 != drvTmp)
+ drvName = OGR_Dr_GetName(drvTmp);
+ if (name == drvName
+ && 0 != OGR_Dr_TestCapability(drvTmp, ODrCCreateDataSource))
+ QgsDebugMsg("Driver found: " + name);
+ drv = drvTmp;
+ break;
+ return drv;
+OGRLayerH Translator::findLayer(OGRDataSourceH ds, QString const& name, int& index)
+ if (0 == ds)
+ index = -1;
+ return 0;
+ OGRLayerH lyr = 0;
+ int const count = OGR_DS_GetLayerCount(ds);
+ OGRLayerH lyrTmp = OGR_DS_GetLayer(ds, i);
+ if (0 != lyrTmp)
+ OGRFeatureDefnH defn = OGR_L_GetLayerDefn(lyrTmp);
+ Q_ASSERT(0 != defn);
+ QString nameTmp(OGR_FD_GetName(defn));
+ if (name == nameTmp)
+ QgsDebugMsg("Layer found: " + nameTmp);
+ index = i;
+ lyr = lyrTmp;
+ break;
+ return lyr;
+OGRDataSourceH Translator::openDataSource(QString const& url, bool readOnly)
+ OGRDataSourceH ds = OGROpen(url.toAscii().constData(), !readOnly, 0);
+ if (0 == ds)
+ QgsDebugMsg("Failed to open: " + url);
+ return ds;
+OGRDataSourceH Translator::openDataTarget(QString const& url, bool update)
+ OGRDataSourceH ds = 0;
+ if (update)
+ // Try opening the output datasource as an existing, writable
+ ds = openDataSource(url, false);
+ else
+ // Find the output driver
+ OGRSFDriverH drv = findDriver(mDstFormat);
+ if (0 == drv)
+ QgsDebugMsg("Could not find driver: " + mDstFormat);
+ return 0;
+ // Create the output data source
+ // TODO: Add support for creation options
+ ds = OGR_Dr_CreateDataSource(drv, url.toAscii().constData(), 0);
+ if (0 == ds)
+ return ds;
Added: trunk/qgis/src/plugins/ogr_converter/translator.h
--- trunk/qgis/src/plugins/ogr_converter/translator.h (rev 0)
+++ trunk/qgis/src/plugins/ogr_converter/translator.h 2008-08-27 13:29:01 UTC (rev 9191)
@@ -0,0 +1,81 @@
+// $Id$
+#ifndef QGIS_PLUGIN_OGRCONV_TRANSLATOR_H_INCLUDED
+#define QGIS_PLUGIN_OGRCONV_TRANSLATOR_H_INCLUDED
+// Qt4
+#include <QString>
+class Translator
+public:
+ Translator();
+ Translator(QString const& src, QString const& dst, QString const& format);
+ QString const& targetFormat() const;
+ void setTargetFormat(QString const& format);
+ QString const& targetLayer() const;
+ void setTargetLayer(QString const& layer);
+ QString const& sourceLayer() const;
+ void setSourceLayer(QString const& layer);
+ QString const& targetReferenceSystem() const;
+ void setTargetReferenceSystem(QString const& srs);
+ QString const& sourceReferenceSystem() const;
+ void setSourceReferenceSystem(QString const& srs);
+ bool isTargetUpdate() const;
+ void setUpdateTarget(bool update);
+ bool isTargetLayerOverwrite() const;
+ // TODO: Implement, currently always overwrite
+ // void setTargetLayerOverwrite(bool overwrite);
+ bool translate();
+private:
+ QString mSrcUrl;
+ QString mDstUrl;
+ QString mDstFormat;
+ QString mSrcLayer;
+ QString mDstLayer;
+ QString mSrcSrs;
+ QString mDstSrs;
+ bool mDstUpdate;
+ bool mDstLayerOverwrite;
+ // TODO: Append option not supported
+ // bool mDstLayerAppend;
+ bool translateLayer(OGRDataSourceH srcDs, OGRLayerH srcLayer, OGRDataSourceH dstDs);
+ bool copyFields(OGRFeatureDefnH layerDefn, OGRLayerH layer);
+ bool copyFeatures(OGRLayerH srcLayer, OGRLayerH dstLayer);
+ OGRSFDriverH findDriver(QString const& name);
+ OGRLayerH findLayer(OGRDataSourceH ds, QString const& name, int& index);
+ OGRDataSourceH openDataSource(QString const& url, bool readOnly);
+ OGRDataSourceH openDataTarget(QString const& url, bool update);
+#endif // QGIS_PLUGIN_OGRCONV_TRANSLATOR_H_INCLUDED
