[QGIS Commit] r9196 - in trunk/qgis: python/core src/app src/core src/providers/ogr src/providers/postgres
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Aug 27 18:13:27 EDT 2008
Author: jef
Date: 2008-08-27 18:13:27 -0400 (Wed, 27 Aug 2008)
New Revision: 9196
   trunk/qgis/python/core/qgsvectordataprovider.sip
   trunk/qgis/src/app/qgsattributedialog.cpp
   trunk/qgis/src/app/qgscontinuouscolordialog.cpp
   trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
   trunk/qgis/src/app/qgsuniquevaluedialog.cpp
   trunk/qgis/src/core/qgsvectordataprovider.cpp
   trunk/qgis/src/core/qgsvectordataprovider.h
   trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
   trunk/qgis/src/providers/ogr/qgsogrprovider.h
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
   trunk/qgis/src/providers/postgres/qgspostgresprovider.h
vector provider update:
- rename maxValue to maximumValue
- rename getUniqueValues to uniqueValues and let it return a list
  of variants instead of strings.
- add protected convertValue to convert string values to attribute values
- update attribute dialog, continuous color dialog, graduated symbol dialog,
  unique value dialog, postgres provider and ogr provider accordingly
- fixes #1250
Modified: trunk/qgis/python/core/qgsvectordataprovider.sip
--- trunk/qgis/python/core/qgsvectordataprovider.sip	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/python/core/qgsvectordataprovider.sip	2008-08-27 22:13:27 UTC (rev 9196)
@@ -132,7 +132,7 @@
        * and maximal values. If provider has facilities to retrieve maximal
        * value directly, override this function.
-      virtual QVariant maxValue(int index);
+      virtual QVariant maximumValue(int index);
        * Return unique values of an attribute
@@ -141,7 +141,7 @@
        * Default implementation simply iterates the features
-      virtual void getUniqueValues(int index, QStringList &uniqueValues);
+      virtual void uniqueValues(int index, QList<QVariant> &uniqueValues);
        * Adds a list of features
Modified: trunk/qgis/src/app/qgsattributedialog.cpp
--- trunk/qgis/src/app/qgsattributedialog.cpp	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/app/qgsattributedialog.cpp	2008-08-27 22:13:27 UTC (rev 9196)
@@ -112,13 +112,15 @@
       case QgsVectorLayer::UniqueValues:
-        QStringList values;
-        mLayer->dataProvider()->getUniqueValues( it.key(), values );
+        QList<QVariant> values;
+        mLayer->dataProvider()->uniqueValues( it.key(), values );
         QComboBox *cb = new QComboBox();
         cb->setEditable( true );
-        cb->addItems( values );
+        for ( QList<QVariant>::iterator it = values.begin(); it != values.end(); it++ )
+          cb->addItem( it->toString() );
         int idx = cb->findText( myFieldValue.toString() );
         if ( idx >= 0 )
           cb->setCurrentIndex( idx );
@@ -219,10 +221,14 @@
         if ( editType == QgsVectorLayer::UniqueValuesEditable )
-          QCompleter *c = new QCompleter( values );
+          QStringList svalues;
+          for ( QList<QVariant>::const_iterator it = values.begin(); it != values.end(); it++ )
+            svalues << it->toString();
+          QCompleter *c = new QCompleter( svalues );
           c->setCompletionMode( QCompleter::PopupCompletion );
           le->setCompleter( c );
Modified: trunk/qgis/src/app/qgscontinuouscolordialog.cpp
--- trunk/qgis/src/app/qgscontinuouscolordialog.cpp	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/app/qgscontinuouscolordialog.cpp	2008-08-27 22:13:27 UTC (rev 9196)
@@ -23,6 +23,7 @@
 #include "qgssymbol.h"
 #include "qgsvectordataprovider.h"
 #include "qgsvectorlayer.h"
+#include "qgslogger.h"
 #include <QColorDialog>
@@ -168,11 +169,11 @@
   if ( provider )
     minimum = provider->minimumValue( classfield ).toDouble();
-    maximum = provider->maxValue( classfield ).toDouble();
+    maximum = provider->maximumValue( classfield ).toDouble();
   else
-    qWarning( "Warning, provider is null in QgsGraSyExtensionWidget::QgsGraSyExtensionWidget(...)" );
+    QgsDebugMsg( "Warning, provider is null" );
     return;
Modified: trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
--- trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2008-08-27 22:13:27 UTC (rev 9196)
@@ -254,7 +254,7 @@
     if ( modeComboBox->currentText() == tr( "Equal Interval" ) )
       minimum = provider->minimumValue( field ).toDouble();
-      maximum = provider->maxValue( field ).toDouble();
+      maximum = provider->maximumValue( field ).toDouble();
     else                    //don't waste performance if mMode is QgsGraduatedSymbolDialog::EMPTY
@@ -435,7 +435,7 @@
   int currentIndex = mClassListWidget->currentRow();
   mEntries.erase( classValue );
   delete( mClassListWidget->takeItem( currentIndex ) );
-  QgsDebugMsg( QString("numRows: %1").arg( mClassListWidget->count() ) );
+  QgsDebugMsg( QString( "numRows: %1" ).arg( mClassListWidget->count() ) );
   if ( mClassListWidget->count() < ( currentIndex + 1 ) )
Modified: trunk/qgis/src/app/qgsuniquevaluedialog.cpp
--- trunk/qgis/src/app/qgsuniquevaluedialog.cpp	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/app/qgsuniquevaluedialog.cpp	2008-08-27 22:13:27 UTC (rev 9196)
@@ -298,13 +298,13 @@
       return;
-    provider->getUniqueValues( nr, values );
+    provider->uniqueValues( nr, values );
     for ( int i = 0; i < values.size(); i++ )
-      if ( !mValues.contains( values[i] ) )
-        addClass( values[i] );
+      if ( !mValues.contains( values[i].toString() ) )
+        addClass( values[i].toString() );
Modified: trunk/qgis/src/core/qgsvectordataprovider.cpp
--- trunk/qgis/src/core/qgsvectordataprovider.cpp	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/core/qgsvectordataprovider.cpp	2008-08-27 22:13:27 UTC (rev 9196)
@@ -273,7 +273,7 @@
   return mCacheMinValues[index];
-QVariant QgsVectorDataProvider::maxValue( int index )
+QVariant QgsVectorDataProvider::maximumValue( int index )
   if ( !fields().contains( index ) )
@@ -292,19 +292,24 @@
   return mCacheMaxValues[index];
-void QgsVectorDataProvider::getUniqueValues( int index, QStringList &values )
+void QgsVectorDataProvider::uniqueValues( int index, QList<QVariant> &values )
   QgsFeature f;
   QgsAttributeList keys;
   keys.append( index );
   select( keys, QgsRect(), false );
-  QMap<QString, int> map;
+  QSet<QString> set;
+  values.clear();
   while ( getNextFeature( f ) )
-    map.insert( f.attributeMap()[index].toString(), 1 );
-  values = map.keys();
+    if ( set.contains( f.attributeMap()[index].toString() ) )
+      values.append( f.attributeMap()[index] );
+      set.insert( f.attributeMap()[index].toString() );
 void QgsVectorDataProvider::fillMinMaxCache()
@@ -356,3 +361,13 @@
   mCacheMinMaxDirty = FALSE;
+QVariant QgsVectorDataProvider::convertValue( QVariant::Type type, QString value )
+  QVariant v( value );
+  if ( !v.convert( type ) )
+    v = QVariant( QString::null );
+  return v;
Modified: trunk/qgis/src/core/qgsvectordataprovider.h
--- trunk/qgis/src/core/qgsvectordataprovider.h	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/core/qgsvectordataprovider.h	2008-08-27 22:13:27 UTC (rev 9196)
@@ -168,7 +168,7 @@
-    virtual QVariant maxValue( int index );
+    virtual QVariant maximumValue( int index );
@@ -177,7 +177,7 @@
-    virtual void getUniqueValues( int index, QStringList &uniqueValues );
+    virtual void uniqueValues( int index, QList<QVariant> &uniqueValues );
@@ -274,6 +274,7 @@
     void setFetchFeaturesWithoutGeom( bool fetch );
   protected:
+    QVariant convertValue( QVariant::Type type, QString value );
     void fillMinMaxCache();
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-08-27 22:13:27 UTC (rev 9196)
@@ -1256,7 +1256,7 @@
   return srs;
-void QgsOgrProvider::getUniqueValues( int index, QStringList &uniqueValues )
+void QgsOgrProvider::uniqueValues( int index, QList<QVariant> &uniqueValues )
   QgsField fld = mAttributeFields[index];
   QFileInfo fi( dataSourceUri() );
@@ -1274,7 +1274,7 @@
   OGRFeatureH f;
   while ( 0 != ( f = OGR_L_GetNextFeature( lyr ) ) )
-    uniqueValues.append( mEncoding->toUnicode( OGR_F_GetFieldAsString( f, 0 ) ) );
+    uniqueValues << convertValue( fld.type(), mEncoding->toUnicode( OGR_F_GetFieldAsString( f, 0 ) ) );
     OGR_F_Destroy( f );
@@ -1304,26 +1304,15 @@
     return QVariant();
-  QString str = mEncoding->toUnicode( OGR_F_GetFieldAsString( f, 0 ) );
+  QVariant value = convertValue( fld.type(), mEncoding->toUnicode( OGR_F_GetFieldAsString( f, 0 ) ) );
   OGR_F_Destroy( f );
-  QVariant value;
-  switch ( fld.type() )
-    case QVariant::String: value = QVariant( str ); break;
-    case QVariant::Int: value = QVariant( str.toInt() ); break;
-    case QVariant::Double: value = QVariant( str.toDouble() ); break;
-      //case QVariant::DateTime: value = QVariant(QDateTime::fromString(str)); break;
-    default: assert( NULL && "unsupported field type" );
   OGR_DS_ReleaseResultSet( ogrDataSource, l );
   return value;
-QVariant QgsOgrProvider::maxValue( int index )
+QVariant QgsOgrProvider::maximumValue( int index )
@@ -1343,20 +1332,9 @@
     return QVariant();
   OGR_F_Destroy( f );
-  QVariant value;
   return value;
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.h
--- trunk/qgis/src/providers/ogr/qgsogrprovider.h	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.h	2008-08-27 22:13:27 UTC (rev 9196)
@@ -175,12 +175,12 @@
     /** Returns the maximum value of an attribute
      *  @param index the index of the attribute */
-    QVariant maxValue( int index );
+    QVariant maximumValue( int index );
     /** Return the unique values of an attribute
      *  @param values reference to the list of unique values */
   protected:
     /** loads fields from input file to member attributeFields */
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-08-27 22:13:27 UTC (rev 9196)
@@ -494,30 +494,7 @@
       if ( !PQgetisnull( queryResult, row, col ) )
-        QString val = QString::fromUtf8( PQgetvalue( queryResult, row, col ) );
-          case QVariant::LongLong:
-            feature.addAttribute( *it, val.toLongLong() );
-            break;
-            feature.addAttribute( *it, val.toInt() );
-            break;
-            feature.addAttribute( *it, val.toDouble() );
-            break;
-            feature.addAttribute( *it, val );
-            break;
-          default:
-            QgsDebugMsg( QString( "feature %1, field %2, value '%3': unexpected variant type %4 considered as NULL" )
-                         .arg( oid )
-                         .arg( fld.name() )
-                         .arg( val )
-                         .arg( fld.type() ) );
-            feature.addAttribute( *it, QVariant( QString::null ) );
+        feature.addAttribute( *it, convertValue( fld.type(), QString::fromUtf8( PQgetvalue( queryResult, row, col ) ) ) );
       else
@@ -1540,8 +1517,7 @@
             .arg( sqlWhereClause );
     Result rmin = connectionRO->PQexec( sql );
-    QString minimumValue = QString::fromUtf8( PQgetvalue( rmin, 0, 0 ) );
-    return minimumValue.toDouble();
+    return convertValue( fld.type(), QString::fromUtf8( PQgetvalue( rmin, 0, 0 ) ) );
   catch ( PGFieldNotFound )
@@ -1550,7 +1526,7 @@
 // Returns the list of unique values of an attribute
-void QgsPostgresProvider::getUniqueValues( int index, QStringList &uniqueValues )
+void QgsPostgresProvider::uniqueValues( int index, QList<QVariant> &uniqueValues )
   uniqueValues.clear();
@@ -1586,8 +1562,7 @@
 // Returns the maximum value of an attribute
-QVariant QgsPostgresProvider::maxValue( int index )
+QVariant QgsPostgresProvider::maximumValue( int index )
   try
@@ -1608,8 +1583,7 @@
     Result rmax = connectionRO->PQexec( sql );
-    QString maxValue = QString::fromUtf8( PQgetvalue( rmax, 0, 0 ) );
-    return maxValue.toDouble();
+    return convertValue( fld.type(), QString::fromUtf8( PQgetvalue( rmax, 0, 0 ) ) );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h	2008-08-27 21:56:29 UTC (rev 9195)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h	2008-08-27 22:13:27 UTC (rev 9196)
@@ -184,12 +184,12 @@
     /**Returns true if layer is valid
More information about the QGIS-commit mailing list
