[QGIS Commit] r9198 - in trunk/qgis/src: app core/raster ui
svn_qgis at osgeo.org
Thu Aug 28 00:15:44 EDT 2008
Author: ersts
Date: 2008-08-28 00:15:44 -0400 (Thu, 28 Aug 2008)
New Revision: 9198
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
-Paletted image no longer open as faux RGB, but open as single band images with a color map
-Closes ticket #914
-Added a new QgsRasterlayer::readColorTable() that will read RGB/CMYK/HSV color maps from GDAL band
-Added load color map(palette) from band to color map tab
-QgsColorTable is now largely obsolete - more clean up need to totally remove
*Note raster layer type enum are no longer representative of the way layers are rendered and need to be updated
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-08-27 22:18:34 UTC (rev 9197)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-08-28 04:15:44 UTC (rev 9198)
@@ -29,8 +29,8 @@
#include "qgsmaplayerregistry.h"
#include "qgscontrastenhancement.h"
#include "qgsrastertransparency.h"
-#include "qgscolorrampshader.h"
#include <QTableWidgetItem>
#include <QHeaderView>
@@ -56,6 +56,7 @@
TRSTRING_NOT_SET( tr( "Not Set" ) ),
mRasterLayer( dynamic_cast<QgsRasterLayer*>( lyr ) )
ignoreSpinBoxEvent = false; //Short circuit signal loop between min max field and stdDev spin box
mGrayActualMinimumMaximum = false;
mRGBActualMinimumMaximum = false;
@@ -102,7 +103,7 @@
cboxColorMap->addItem( tr( "Grayscale" ) );
cboxColorMap->addItem( tr( "Pseudocolor" ) );
cboxColorMap->addItem( tr( "Freak Out" ) );
- cboxColorMap->addItem( tr( "Custom Colormap" ) );
+ cboxColorMap->addItem( tr( "Colormap" ) );
//add items to the color stretch combo box
cboxContrastEnhancementAlgorithm->addItem( tr( "No Stretch" ) );
@@ -145,139 +146,108 @@
headerLabels << "Label";
mColormapTreeWidget->setHeaderLabels( headerLabels );
- //disable Custom colormap tab completely until 'Custom Colormap' is selected (and only for type GRAY_OR_UNDEFINED)
+ //disable colormap tab completely until 'Colormap' is selected (and only for type GRAY_OR_UNDEFINED)
tabBar->setTabEnabled( tabBar->indexOf( tabPageColormap ), FALSE );
// Set up the combo boxes that contain band lists using the qstring list generated above
- if ( mRasterLayer->getRasterLayerType()
- == QgsRasterLayer::PALETTE ) //paletted layers have hard coded color entries
- cboRed->addItem( tr( "Red" ) );
- cboGreen->addItem( tr( "Red" ) );
- cboBlue->addItem( tr( "Red" ) );
+ QgsDebugMsg( "Populating band combo boxes" );
- cboRed->addItem( tr( "Green" ) );
- cboGreen->addItem( tr( "Green" ) );
- cboBlue->addItem( tr( "Green" ) );
+ // Get a list of band names
+ QStringList myBandNameList;
- cboRed->addItem( tr( "Blue" ) );
- cboGreen->addItem( tr( "Blue" ) );
- cboBlue->addItem( tr( "Blue" ) );
+ int myBandCountInt = mRasterLayer->getBandCount();
- cboRed->addItem( TRSTRING_NOT_SET );
- cboGreen->addItem( TRSTRING_NOT_SET );
- cboBlue->addItem( TRSTRING_NOT_SET );
+ QgsDebugMsg( QString( "Looping though %1 image layers to get their names " ).arg( myBandCountInt ) );
- cboGray->addItem( tr( "Red" ) );
- cboGray->addItem( tr( "Green" ) );
- cboGray->addItem( tr( "Blue" ) );
- cboGray->addItem( TRSTRING_NOT_SET );
- lstHistogramLabels->addItem( tr( "Palette" ) );
- else // all other layer types use band name entries only
+ for ( int myIteratorInt = 1;
+ myIteratorInt <= myBandCountInt;
+ ++myIteratorInt )
- QgsDebugMsg( "Populating combos for non paletted layer" );
+ //find out the name of this band
+ QString myRasterBandNameQString = mRasterLayer->getRasterBandName( myIteratorInt ) ;
+ //add the band to the histogram tab
- // Get a list of band names
- QStringList myBandNameList;
+ QPixmap myPixmap( 10, 10 );
- int myBandCountInt = mRasterLayer->getBandCount();
-#ifdef QGISDEBIG
- QgsDebugMsg( QString( "Looping though %1 image layers to get their names " ).arg( myBandCountInt ) );
-#endif
- for ( int myIteratorInt = 1;
- myIteratorInt <= myBandCountInt;
- ++myIteratorInt )
+ if ( myBandCountInt == 1 ) //draw single band images with black
- //find out the name of this band
- QString myRasterBandNameQString = mRasterLayer->getRasterBandName( myIteratorInt ) ;
- //add the band to the histogram tab
- QPixmap myPixmap( 10, 10 );
- if ( myBandCountInt == 1 ) //draw single band images with black
- myPixmap.fill( Qt::black );
- else if ( myIteratorInt == 1 )
- myPixmap.fill( Qt::red );
- else if ( myIteratorInt == 2 )
- myPixmap.fill( Qt::green );
- else if ( myIteratorInt == 3 )
- myPixmap.fill( Qt::blue );
- else if ( myIteratorInt == 4 )
- myPixmap.fill( Qt::magenta );
- else if ( myIteratorInt == 5 )
- myPixmap.fill( Qt::darkRed );
- else if ( myIteratorInt == 6 )
- myPixmap.fill( Qt::darkGreen );
- else if ( myIteratorInt == 7 )
- myPixmap.fill( Qt::darkBlue );
- else
- myPixmap.fill( Qt::gray );
- lstHistogramLabels->addItem( new QListWidgetItem( myPixmap, myRasterBandNameQString ) );
- mGradientHeight = pixHistogram->height() / 2;
- mGradientWidth = pixHistogram->width() / 2;
- //keep a list of band names for later use
- //! @note band names should not be translated!
- myBandNameList.append( myRasterBandNameQString );
+ myPixmap.fill( Qt::black );
- //select all histogram layers list items by default
- ++myIteratorInt )
+ else if ( myIteratorInt == 1 )
- QListWidgetItem *myItem = lstHistogramLabels->item( myIteratorInt - 1 );
- myItem->setSelected( true );
+ myPixmap.fill( Qt::red );
- for ( QStringList::Iterator myIterator = myBandNameList.begin();
- myIterator != myBandNameList.end();
- ++myIterator )
+ else if ( myIteratorInt == 2 )
- QString myQString = *myIterator;
-#ifdef QGISDEBUG
+ myPixmap.fill( Qt::green );
+ else if ( myIteratorInt == 3 )
+ myPixmap.fill( Qt::blue );
+ else if ( myIteratorInt == 4 )
+ myPixmap.fill( Qt::magenta );
+ else if ( myIteratorInt == 5 )
+ myPixmap.fill( Qt::darkRed );
+ else if ( myIteratorInt == 6 )
+ myPixmap.fill( Qt::darkGreen );
+ else if ( myIteratorInt == 7 )
+ myPixmap.fill( Qt::darkBlue );
+ else
+ myPixmap.fill( Qt::gray );
+ lstHistogramLabels->addItem( new QListWidgetItem( myPixmap, myRasterBandNameQString ) );
+ mGradientHeight = pixHistogram->height() / 2;
+ mGradientWidth = pixHistogram->width() / 2;
+ //keep a list of band names for later use
+ //! @note band names should not be translated!
+ myBandNameList.append( myRasterBandNameQString );
- QgsDebugMsg( QString( "Inserting : %1" ).arg( myQString ) );
-#endif
+ //select all histogram layers list items by default
+ ++myIteratorInt )
+ QListWidgetItem *myItem = lstHistogramLabels->item( myIteratorInt - 1 );
+ myItem->setSelected( true );
- cboGray->addItem( myQString );
- cboRed->addItem( myQString );
- cboGreen->addItem( myQString );
- cboBlue->addItem( myQString );
+ for ( QStringList::Iterator myIterator = myBandNameList.begin();
+ myIterator != myBandNameList.end();
+ ++myIterator )
+ QString myQString = *myIterator;
+ QgsDebugMsg( QString( "Inserting : %1" ).arg( myQString ) );
+ cboGray->addItem( myQString );
+ cboRed->addItem( myQString );
+ cboGreen->addItem( myQString );
+ cboBlue->addItem( myQString );
+ cboxColorMapBand->addItem( myQString );
+ cboRed->addItem( TRSTRING_NOT_SET );
+ cboGreen->addItem( TRSTRING_NOT_SET );
+ cboBlue->addItem( TRSTRING_NOT_SET );
+ cboGray->addItem( TRSTRING_NOT_SET );
cboxTransparencyBand->addItem( TRSTRING_NOT_SET );
QIcon myPyramidPixmap( QgisApp::getThemeIcon( "/mIconPyramid.png" ) );
@@ -292,6 +262,7 @@
pbtnMakeBandCombinationDefault->setIcon( QgisApp::getThemeIcon( "/mActionFileSave.png" ) );
pbtnMakeContrastEnhancementAlgorithmDefault->setIcon( QgisApp::getThemeIcon( "/mActionFileSave.png" ) );
+ pbtnLoadColorMapFromBand->setIcon( QgisApp::getThemeIcon( "/mActionNewAttribute.png" ) );
pbtnExportColorMapToFile->setIcon( QgisApp::getThemeIcon( "/mActionFileSave.png" ) );
pbtnLoadColorMapFromFile->setIcon( QgisApp::getThemeIcon( "/mActionFileOpen.png" ) );
@@ -357,6 +328,21 @@
* PUBLIC METHODS
+void QgsRasterLayerProperties::populateColorMapTable(const QList<QgsColorRampShader::ColorRampItem>& theColorRampList)
+ if ( theColorRampList.size() > 0 )
+ mColormapTreeWidget->clear();
+ QList<QgsColorRampShader::ColorRampItem>::const_iterator it;
+ for ( it = theColorRampList.begin(); it != theColorRampList.end(); ++it )
+ QTreeWidgetItem* newItem = new QTreeWidgetItem( mColormapTreeWidget );
+ newItem->setText( 0, QString::number( it->value, 'f' ) );
+ newItem->setBackground( 1, QBrush( it->color ) );
+ newItem->setText( 2, it->label );
void QgsRasterLayerProperties::populateTransparencyTable()
//Clear existsing color transparency list
@@ -505,7 +491,7 @@
labelContrastEnhancement->setEnabled( false );
break;
case QgsRasterLayer::PALETTED_SINGLE_BAND_PSEUDO_COLOR:
- rbtnThreeBand->setEnabled( true );
+ rbtnThreeBand->setEnabled( false );
rbtnSingleBand->setEnabled( true );
rbtnSingleBand->setChecked( true );
rbtnThreeBandMinMax->setEnabled( false );
@@ -602,7 +588,7 @@
else if ( mRasterLayer->getColorShadingAlgorithm() == QgsRasterLayer::COLOR_RAMP )
- cboxColorMap->setCurrentIndex( cboxColorMap->findText( tr( "Custom Colormap" ) ) );
+ cboxColorMap->setCurrentIndex( cboxColorMap->findText( tr( "Colormap" ) ) );
else if ( mRasterLayer->getColorShadingAlgorithm() == QgsRasterLayer::USER_DEFINED )
@@ -783,10 +769,7 @@
//restore colormap tab if the layer has custom classification
- if ( cboxColorMap->currentText() == tr( "Custom Colormap" ) )
- syncColormapTab();
+ syncColormapTab();
QgsDebugMsg( "populate general tab" );
@@ -873,21 +856,9 @@
return;
//restore the colormap tab if layer has custom symbology
- QList<QgsColorRampShader::ColorRampItem> myColorRampList = myRasterShaderFunction->getColorRampItemList();
- if ( myColorRampList.size() > 0 )
- QList<QgsColorRampShader::ColorRampItem>::const_iterator it;
- for ( it = myColorRampList.begin(); it != myColorRampList.end(); ++it )
- //restore state of colormap tab
- QTreeWidgetItem* newItem = new QTreeWidgetItem( mColormapTreeWidget );
- newItem->setText( 0, QString::number( it->value, 'f' ) );
- newItem->setBackground( 1, QBrush( it->color ) );
- newItem->setText( 2, it->label );
+ populateColorMapTable(myRasterShaderFunction->getColorRampItemList());
- sboxNumberOfEntries->setValue( myColorRampList.size() );
+ sboxNumberOfEntries->setValue( mColormapTreeWidget->topLevelItemCount() );
//restor state of 'color interpolation' combo box
if ( QgsColorRampShader::INTERPOLATED == myRasterShaderFunction->getColorRampType() )
@@ -1082,7 +1053,7 @@
mRasterLayer->setColorShadingAlgorithm( QgsRasterLayer::FREAK_OUT );
- else if ( cboxColorMap->currentText() == tr( "Custom Colormap" ) )
+ else if ( cboxColorMap->currentText() == tr( "Colormap" ) )
mRasterLayer->setColorShadingAlgorithm( QgsRasterLayer::COLOR_RAMP );
@@ -1379,7 +1350,7 @@
* ColorMap Tab
+ if ( cboxColorMap->currentText() == tr( "Colormap" ) )
QgsColorRampShader* myRasterShaderFunction = ( QgsColorRampShader* )mRasterLayer->getRasterShader()->getRasterShaderFunction();
if ( myRasterShaderFunction )
@@ -1700,7 +1671,7 @@
cboxContrastEnhancementAlgorithm->setEnabled( false );
- else if ( mRasterLayerIsGdal && theText == tr( "Custom Colormap" ) )
+ else if ( mRasterLayerIsGdal && theText == tr( "Colormap" ) )
tabBar->setTabEnabled( tabBar->indexOf( tabPageColormap ), TRUE );
rbtnSingleBandMinMax->setEnabled( false );
@@ -2712,6 +2683,22 @@
+void QgsRasterLayerProperties::on_pbtnLoadColorMapFromBand_clicked()
+ QList<QgsColorRampShader::ColorRampItem> myColorRampList;
+ if(mRasterLayer->readColorTable(cboxColorMapBand->currentIndex()+1, &myColorRampList))
+ populateColorMapTable(myColorRampList);
+ cboxColorInterpolation->setCurrentIndex( cboxColorInterpolation->findText( tr( "Exact" ) ) );
+ QgsDebugMsg("Color map loaded");
+ else
+ QMessageBox::warning(this, tr("Load Color Map"), tr("The color map for Band %n failed to load", "", cboxColorMapBand->currentIndex()+1));
+ QgsDebugMsg("Color map failed to load");
void QgsRasterLayerProperties::on_pbtnLoadColorMapFromFile_clicked()
int myLineCounter = 0;
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-08-27 22:18:34 UTC (rev 9197)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-08-28 04:15:44 UTC (rev 9198)
@@ -22,6 +22,8 @@
#include "ui_qgsrasterlayerpropertiesbase.h"
#include "qgisgui.h"
+#include "qgscolorrampshader.h"
class QgsMapLayer;
class QgsRasterLayer;
@@ -108,7 +110,9 @@
void handleColormapTreeWidgetDoubleClick( QTreeWidgetItem* item, int column );
/**This slots saves the current color map to a file */
void on_pbtnExportColorMapToFile_clicked();
- /**This slots saves the current color map to a file */
+ /**This slots loads the current color map from a band */
+ void on_pbtnLoadColorMapFromBand_clicked();
+ /**This slots loads the current color map from a file */
void on_pbtnLoadColorMapFromFile_clicked();
/**This slot loads the minimum and maximum values from the raster band and updates the gui*/
void on_pbtnLoadMinMax_clicked();
@@ -172,6 +176,9 @@
included or not
bool mRasterLayerIsWms;
+ /** \brief Clear current color map table and population with values from new list */
+ void populateColorMapTable(const QList<QgsColorRampShader::ColorRampItem>&);
/** \brief Clear the current transparency table and populate the table with the correct types for current drawing mode and data type*/
void populateTransparencyTable();
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-08-27 22:18:34 UTC (rev 9197)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-08-28 04:15:44 UTC (rev 9198)
@@ -537,8 +537,7 @@
setContrastEnhancementAlgorithm( myQSettings.value( "/Raster/defaultContrastEnhancementAlgorithm", "STRETCH_TO_MINMAX" ).toString() );
//decide what type of layer this is...
- //note that multiband images can have one or more 'undefindd' bands,
- //so we must do this check first!
+ //TODO Change this to look at the color interp and palette interp to decide which type of layer it is
if (( GDALGetRasterCount( mGdalDataset ) > 1 ) )
rasterLayerType = MULTIBAND;
@@ -554,13 +553,23 @@
if ( rasterLayerType == PALETTE )
- mRedBandName = "Red"; // sensible default
- mGreenBandName = "Green"; // sensible default
- mBlueBandName = "Blue";// sensible default
+ mRedBandName = TRSTRING_NOT_SET; // sensible default
+ mGreenBandName = TRSTRING_NOT_SET; // sensible default
+ mBlueBandName = TRSTRING_NOT_SET;// sensible default
mTransparencyBandName = TRSTRING_NOT_SET; // sensible default
- mGrayBandName = TRSTRING_NOT_SET; //sensible default
- drawingStyle = PALETTED_MULTI_BAND_COLOR; //sensible default
- setContrastEnhancementAlgorithm( QgsContrastEnhancement::NO_STRETCH );
+ mGrayBandName = getRasterBandName(1); //sensible default
+ QgsDebugMsg(mGrayBandName);
+ drawingStyle = PALETTED_SINGLE_BAND_PSEUDO_COLOR; //sensible default
+ //Load the color table from the band
+ readColorTable(1, &myColorRampList);
+ //Set up a new color ramp shader
+ setColorShadingAlgorithm(COLOR_RAMP);
+ QgsColorRampShader* myColorRampShader = ( QgsColorRampShader* ) mRasterShader->getRasterShaderFunction();
+ myColorRampShader->setColorRampType(QgsColorRampShader::EXACT);
+ myColorRampShader->setColorRampItemList(myColorRampList);
else if ( rasterLayerType == MULTIBAND )
@@ -583,14 +592,12 @@
else //GRAY_OR_UNDEFINED
- //Disabled automatically generating stats to improve initial load speed.
- //getRasterBandStats(1);
mRedBandName = TRSTRING_NOT_SET; //sensible default
mGreenBandName = TRSTRING_NOT_SET; //sensible default
mBlueBandName = TRSTRING_NOT_SET; //sensible default
mTransparencyBandName = TRSTRING_NOT_SET; //sensible default
drawingStyle = SINGLE_BAND_GRAY; //sensible default
- mGrayBandName = getRasterBandName( 1 ); // usually gdal will return gray or undefined
+ mGrayBandName = getRasterBandName( 1 );
//mark the layer as valid
@@ -1710,7 +1717,12 @@
return;
- QgsRasterBandStats myRasterBandStats = getRasterBandStats( theBandNo );
+ QgsRasterBandStats myRasterBandStats;
+ //If there is a color ramp, i.e., a paletted layer, then no need to generate stats
+ if(COLOR_RAMP != mColorShadingAlgorithm)
+ myRasterBandStats = getRasterBandStats( theBandNo );
GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
GDALDataType myDataType = GDALGetRasterDataType( myGdalBand );
void *myGdalScanData = readData( myGdalBand, theRasterViewPort );
@@ -2186,7 +2198,7 @@
// get the name of a band given its number
const QString QgsRasterLayer::getRasterBandName( int theBandNo )
+ QgsDebugMsg("entered.");
if ( theBandNo <= mRasterStatsList.size() && theBandNo > 0 )
//vector starts at base 0, band counts at base1 !
@@ -2239,7 +2251,6 @@
//TODO: This method needs some cleaning up PJE 2007-12-30
-//TODO: Values that are only used in debug should be totally wrapped in debug ifdefs
const QgsRasterBandStats QgsRasterLayer::getRasterBandStats( int theBandNo )
// check if we have received a valid band number
@@ -2277,41 +2288,7 @@
//declare a colorTable to hold a palette - will only be used if the layer color interp is palette ???
//get the palette colour table
QgsColorTable *myColorTable = &( myRasterBandStats.colorTable );
- if ( rasterLayerType == PALETTE )
- //override the band name - palette images are really only one band
- //so we are faking three band behaviour
- switch ( theBandNo )
- // a "Red" layer
- case 1:
- myRasterBandStats.bandName = mRedBandName;
- break;
- case 2:
- myRasterBandStats.bandName = mBlueBandName;
- break;
- case 3:
- myRasterBandStats.bandName = mGreenBandName;
- break;
- default:
- //invalid band id so return
- QgsRasterBandStats myNullReturnStats;
- return myNullReturnStats;
- break;
- else if ( rasterLayerType == GRAY_OR_UNDEFINED )
- //PJE 2008-01-14 This function should not be changing the band name,
- //The format below is not the same as the constructor
- //myRasterBandStats.bandName = myColorerpretation;
- else //rasterLayerType is MULTIBAND
- //do nothing
// XXX this sets the element count to a sensible value; but then you ADD to
// XXX it later while iterating through all the pixels?
//myRasterBandStats.elementCount = mRasterXDim * mRasterYDim;
@@ -2559,36 +2536,29 @@
QString QgsRasterLayer::validateBandName( QString const & theBandName )
- QgsDebugMsg( "validateBandName : Checking..." );
+ QgsDebugMsg( "Checking..." );
//check if the band is unset
if ( theBandName == TRSTRING_NOT_SET || theBandName == QSTRING_NOT_SET )
- QgsDebugMsg( "validateBandName : Band name is '" + QSTRING_NOT_SET + "'. Nothing to do." );
+ QgsDebugMsg( "Band name is '" + QSTRING_NOT_SET + "'. Nothing to do." );
// Use translated name internally
return TRSTRING_NOT_SET;
- //check if the image is paletted
- if ( rasterLayerType == PALETTE && ( theBandName == "Red" || theBandName == "Green" || theBandName == "Blue" ) )
- QgsDebugMsg( "validateBandName : Paletted image valid faux RGB band name" );
- return theBandName;
//check that a valid band name was passed
- QgsDebugMsg( "validateBandName : Looking through raster band stats for matching band name" );
+ QgsDebugMsg( "Looking through raster band stats for matching band name" );
for ( int myIterator = 0; myIterator < mRasterStatsList.size(); ++myIterator )
if ( mRasterStatsList[myIterator].bandName == theBandName )
- QgsDebugMsg( "validateBandName : Matching band name found" );
+ QgsDebugMsg( "Matching band name found" );
return theBandName;
- QgsDebugMsg( "validateBandName : No matching band name found in raster band stats" );
+ QgsDebugMsg( "No matching band name found in raster band stats" );
- QgsDebugMsg( "validateBandName : Testing older naming format" );
+ QgsDebugMsg( "Testing older naming format" );
//See of the band in an older format #:something.
//TODO Remove test in v2.0
if ( theBandName.contains( ':' ) )
@@ -2599,14 +2569,14 @@
int myBandNumber = myBandNameComponents.at( 0 ).toInt();
if ( myBandNumber > 0 )
- QgsDebugMsg( "validateBandName : Transformed older name format to current format" );
+ QgsDebugMsg( "Transformed older name format to current format" );
return "Band " + QString::number( myBandNumber );
//if no matches were found default to not set
- QgsDebugMsg( "validateBandName : All checks failed, returning '" + QSTRING_NOT_SET + "'" );
+ QgsDebugMsg( "All checks failed, returning '" + QSTRING_NOT_SET + "'" );
@@ -3792,9 +3762,90 @@
return false;
+bool QgsRasterLayer::readColorTable( int theBandNumber, QList<QgsColorRampShader::ColorRampItem>* theList)
+ QgsDebugMsg( "entered." );
+ //Invalid band number, segfault prevention
+ if (0 >= theBandNumber || 0 == theList)
+ QgsDebugMsg("Invalid paramter");
+ return false;
+ GDALRasterBandH myGdalBand = GDALGetRasterBand(mGdalDataset, theBandNumber);
+ GDALColorTableH myGdalColorTable = GDALGetRasterColorTable(myGdalBand);
+ if (myGdalColorTable)
+ QgsDebugMsg("Color table found");
+ int myEntryCount = GDALGetColorEntryCount(myGdalColorTable);
+ GDALColorInterp myColorInterpretation = GDALGetRasterColorInterpretation(myGdalBand);
+ QgsDebugMsg("Color Interpretation: " + QString::number((int)myColorInterpretation));
+ GDALPaletteInterp myPaletteInterpretation = GDALGetPaletteInterpretation(myGdalColorTable);
+ QgsDebugMsg("Palette Interpretation: " + QString::number((int)myPaletteInterpretation));
+ const GDALColorEntry* myColorEntry = 0;
+ for ( int myIterator = 0; myIterator < myEntryCount; myIterator++ )
+ myColorEntry = GDALGetColorEntry( myGdalColorTable, myIterator );
+ if ( !myColorEntry )
+ continue;
+ else
+ //Branch on the color interpretation type
+ if(myColorInterpretation == GCI_GrayIndex)
+ QgsColorRampShader::ColorRampItem myColorRampItem;
+ myColorRampItem.label = "";
+ myColorRampItem.value = (double)myIterator;
+ myColorRampItem.color = QColor::fromRgb(myColorEntry->c1, myColorEntry->c1, myColorEntry->c1, myColorEntry->c4);
+ theList->append(myColorRampItem);
+ else if(myColorInterpretation = GCI_PaletteIndex)
+ //Branch on palette interpretation
+ if(myPaletteInterpretation == GPI_RGB)
+ myColorRampItem.color = QColor::fromRgb(myColorEntry->c1, myColorEntry->c2, myColorEntry->c3, myColorEntry->c4);
+ else if(myPaletteInterpretation == GPI_CMYK)
+ myColorRampItem.color = QColor::fromCmyk(myColorEntry->c1, myColorEntry->c2, myColorEntry->c3, myColorEntry->c4);
+ else if(myPaletteInterpretation == GPI_HLS)
+ myColorRampItem.color = QColor::fromHsv(myColorEntry->c1, myColorEntry->c3, myColorEntry->c2, myColorEntry->c4);
+ else
+ else
+ QgsDebugMsg("Color interpretation type not supported yet");
+ return false;
+ else
+ QgsDebugMsg("No color table found for band " + QString::number(theBandNumber));
+ return false;
+ QgsDebugMsg("Color table loaded sucessfully");
+ return true;
void QgsRasterLayer::readColorTable( GDALRasterBandH gdalBand, QgsColorTable *theColorTable )
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-08-27 22:18:34 UTC (rev 9197)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-08-28 04:15:44 UTC (rev 9198)
@@ -136,6 +136,7 @@
#include "qgsrastershader.h"
#include "qgsrastershaderfunction.h"
#include "qgsrasterdataprovider.h"
@@ -629,7 +630,9 @@
+ /** \brief Read color table from GDAL raster band */
+ bool readColorTable( int theBandNumber, QList<QgsColorRampShader::ColorRampItem>* theList);
/** \brief This enumerator describes the different kinds of drawing we can do. */
enum DRAWING_STYLE
@@ -638,8 +641,8 @@
SINGLE_BAND_PSEUDO_COLOR,// a "Gray" or "Undefined" layer drawn using a pseudocolor algorithm
PALETTED_COLOR, //a "Palette" image drawn using color table
PALETTED_SINGLE_BAND_GRAY,// a "Palette" layer drawn in gray scale (using only one of the color components)
- PALETTED_SINGLE_BAND_PSEUDO_COLOR, // a "Palette" layer having only one of its color components rendered as psuedo color
- PALETTED_MULTI_BAND_COLOR, // a "Palette" image is decomposed to 3 channels (RGB) and drawn
+ PALETTED_SINGLE_BAND_PSEUDO_COLOR, // a "Palette" layer having only one of its color components rendered as psuedo color --PJE20080827 this is no longer accurate as it is used to shade the color ramp as well
+ PALETTED_MULTI_BAND_COLOR, // a "Palette" image is decomposed to 3 channels (RGB) and drawn --PJE20080827 this is no longer accurate
// as multiband
MULTI_BAND_SINGLE_BAND_GRAY, // a layer containing 2 or more bands, but using only one band to produce a grayscale image
MULTI_BAND_SINGLE_BAND_PSEUDO_COLOR, //a layer containing 2 or more bands, but using only one band to produce a pseudocolor image
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-08-27 22:18:34 UTC (rev 9197)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-08-28 04:15:44 UTC (rev 9198)
@@ -1228,6 +1228,9 @@
<verstretch>0</verstretch>
</sizepolicy>
</property>
+ <property name="maximum" >
+ <number>256</number>
+ </property>
</widget>
</item>
</layout>
@@ -1245,7 +1248,7 @@
</property>
</spacer>
</item>
- <item row="0" column="3" colspan="3" >
+ <item row="0" column="3" colspan="4" >
<layout class="QHBoxLayout" >
<property name="leftMargin" >
<number>11</number>
@@ -1284,7 +1287,7 @@
</property>
</spacer>
</item>
- <item row="1" column="3" colspan="3" >
+ <item row="1" column="3" colspan="4" >
<number>11</number>
@@ -1324,20 +1327,56 @@
</property>
</widget>
</item>
- <item row="2" column="2" colspan="2" >
+ <item row="2" column="2" >
<spacer>
<property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
<property name="sizeHint" >
<size>
- <width>281</width>
+ <width>211</width>
<height>27</height>
</size>
</property>
</spacer>
</item>
+ <item row="2" column="3" >
+ <layout class="QHBoxLayout" >
+ <property name="leftMargin" >
+ <number>11</number>
+ </property>
+ <item>
+ <widget class="QComboBox" name="cboxColorMapBand" />
+ </item>
+ <item>
+ <widget class="QToolButton" name="pbtnLoadColorMapFromBand" >
+ <property name="toolTip" >
+ <string>Load color map from band</string>
+ </property>
+ <property name="text" >
+ <string>...</string>
+ </property>
+ <property name="icon" >
+ <iconset>../../images/themes/default/mActionNewAttribute.png</iconset>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
<item row="2" column="4" >
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>20</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="2" column="5" >
<widget class="QToolButton" name="pbtnLoadColorMapFromFile" >
<string>Load color map from file</string>
@@ -1350,7 +1389,7 @@
</property>
</widget>
</item>
- <item row="2" column="5" >
+ <item row="2" column="6" >
<widget class="QToolButton" name="pbtnExportColorMapToFile" >
<string>Export color map to file</string>
@@ -1363,7 +1402,7 @@
</property>
</widget>
</item>
- <item row="3" column="0" colspan="6" >
+ <item row="3" column="0" colspan="7" >
<widget class="QTreeWidget" name="mColormapTreeWidget" >
<property name="columnCount" >
<number>3</number>
