[QGIS Commit] r9214 - trunk/qgis/src/plugins/interpolation
svn_qgis at osgeo.org
Sat Aug 30 06:14:29 EDT 2008
Author: timlinux
Date: 2008-08-30 06:14:29 -0400 (Sat, 30 Aug 2008)
New Revision: 9214
Added:
trunk/qgis/src/plugins/interpolation/interpolation.png
trunk/qgis/src/plugins/interpolation/interpolator.qrc
trunk/qgis/src/plugins/interpolation/options.png
Removed:
trunk/qgis/src/plugins/interpolation/mIconInterpolation.xpm
trunk/qgis/src/plugins/interpolation/CMakeLists.txt
trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui
trunk/qgis/src/plugins/interpolation/qgsinterpolationplugin.cpp
Gui cleanups for interopolation plugin: use labels formatting compliant with qgis ui guide. Get rid of extra layouts. Improve layout. Use qrc file for resources. Make plugin icon consistent with requirements for docu team.
Modified: trunk/qgis/src/plugins/interpolation/CMakeLists.txt
--- trunk/qgis/src/plugins/interpolation/CMakeLists.txt 2008-08-30 09:28:54 UTC (rev 9213)
+++ trunk/qgis/src/plugins/interpolation/CMakeLists.txt 2008-08-30 10:14:29 UTC (rev 9214)
@@ -36,6 +36,7 @@
qgsinterpolationdialog.h
+SET (INTERPOLATION_RCCS interpolator.qrc)
# Build
@@ -43,12 +44,21 @@
QT4_WRAP_CPP (INTERPOLATION_MOC_SRCS ${INTERPOLATION_MOC_HDRS})
-ADD_LIBRARY (interpolationplugin MODULE ${INTERPOLATION_SRCS} ${INTERPOLATION_MOC_SRCS} ${INTERPOLATION_RCC_SRCS} ${INTERPOLATION_UIS_H})
+QT4_ADD_RESOURCES(INTERPOLATION_RCC_SRCS ${INTERPOLATION_RCCS})
+ADD_LIBRARY (interpolationplugin MODULE
+ ${INTERPOLATION_SRCS}
+ ${INTERPOLATION_MOC_SRCS}
+ ${INTERPOLATION_RCC_SRCS}
+ ${INTERPOLATION_UIS_H})
INCLUDE_DIRECTORIES(
${CMAKE_CURRENT_BINARY_DIR}
${GEOS_INCLUDE_DIR}
- ../../core ../../core/raster ../../core/renderer ../../core/symbology
+ ../../core
+ ../../core/raster
+ ../../core/renderer
+ ../../core/symbology
../../gui
@@ -65,4 +75,5 @@
INSTALL(TARGETS interpolationplugin
RUNTIME DESTINATION ${QGIS_PLUGIN_DIR}
- LIBRARY DESTINATION ${QGIS_PLUGIN_DIR})
+ LIBRARY DESTINATION ${QGIS_PLUGIN_DIR}
Added: trunk/qgis/src/plugins/interpolation/interpolation.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/interpolation/interpolation.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/src/plugins/interpolation/interpolator.qrc
--- trunk/qgis/src/plugins/interpolation/interpolator.qrc (rev 0)
+++ trunk/qgis/src/plugins/interpolation/interpolator.qrc 2008-08-30 10:14:29 UTC (rev 9214)
@@ -0,0 +1,6 @@
+<RCC>
+ <qresource prefix="/interpolator" >
+ <file>options.png</file>
+ <file>interpolation.png</file>
+ </qresource>
+</RCC>
Deleted: trunk/qgis/src/plugins/interpolation/mIconInterpolation.xpm
--- trunk/qgis/src/plugins/interpolation/mIconInterpolation.xpm 2008-08-30 09:28:54 UTC (rev 9213)
+++ trunk/qgis/src/plugins/interpolation/mIconInterpolation.xpm 2008-08-30 10:14:29 UTC (rev 9214)
@@ -1,33 +0,0 @@
-/* XPM */
-static const char *mIconInterpolation[]={
-"32 28 2 1",
-". c None",
-"# c #000000",
Added: trunk/qgis/src/plugins/interpolation/options.png
Property changes on: trunk/qgis/src/plugins/interpolation/options.png
Modified: trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui
--- trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui 2008-08-30 09:28:54 UTC (rev 9213)
+++ trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui 2008-08-30 10:14:29 UTC (rev 9214)
@@ -6,7 +6,7 @@
<x>0</x>
<y>0</y>
<width>485</width>
- <height>538</height>
+ <height>372</height>
</rect>
</property>
<property name="sizePolicy" >
@@ -16,7 +16,7 @@
</sizepolicy>
</property>
<property name="windowTitle" >
- <string>Dialog</string>
+ <string>Interpolation plugin</string>
</property>
<layout class="QGridLayout" >
<item row="0" column="0" >
@@ -32,20 +32,33 @@
</property>
- <layout class="QHBoxLayout" >
- <item>
- <widget class="QLabel" name="mInputVectorLayerLabel" >
- <property name="text" >
- <string>Input vector layer:</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="mInputLayerComboBox" />
- </item>
- </layout>
+ <widget class="QLabel" name="mInputVectorLayerLabel" >
+ <property name="text" >
+ <string>Input vector layer</string>
+ </property>
+ <property name="buddy" >
+ <cstring>mInputLayerComboBox</cstring>
+ </property>
+ </widget>
</item>
+ <item row="0" column="1" >
+ <widget class="QComboBox" name="mInputLayerComboBox" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="MinimumExpanding" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ </widget>
+ </item>
<item row="1" column="0" >
+ <widget class="QLabel" name="label" >
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" >
<widget class="QCheckBox" name="mUseZCoordCheckBox" >
<string>Use z-Coordinate for interpolation</string>
@@ -53,19 +66,25 @@
</widget>
</item>
<item row="2" column="0" >
- <item>
- <widget class="QLabel" name="mInterpolationAttributeLabel" >
- <string>Interpolation attribute: </string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="mInterpolationAttributeComboBox" />
- </item>
- </layout>
+ <widget class="QLabel" name="mInterpolationAttributeLabel" >
+ <string>Interpolation attribute </string>
+ </property>
+ <cstring>mInterpolationAttributeComboBox</cstring>
+ </property>
+ </widget>
</item>
+ <item row="2" column="1" >
+ <widget class="QComboBox" name="mInterpolationAttributeComboBox" >
+ </sizepolicy>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
@@ -81,97 +100,83 @@
<string>Output</string>
</property>
- <item row="0" column="0" colspan="2" >
- <item>
- <widget class="QLabel" name="mInterpolationLabel" >
- <string>Interpolation method:</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="mInterpolationMethodComboBox" />
- </item>
- </layout>
+ <item row="0" column="0" >
+ <widget class="QLabel" name="mInterpolationLabel" >
+ <string>Interpolation method</string>
+ </property>
+ <cstring>mInterpolationMethodComboBox</cstring>
+ </property>
+ </widget>
</item>
+ <widget class="QComboBox" name="mInterpolationMethodComboBox" />
+ </item>
+ <item row="0" column="2" >
+ <widget class="QToolButton" name="mConfigureInterpolationButton" >
+ <string>...</string>
+ </property>
+ <property name="icon" >
+ <iconset resource="interpolator.qrc" >:/interpolator/options.png</iconset>
+ </property>
+ </widget>
+ </item>
- <widget class="QPushButton" name="mConfigureInterpolationButton" >
+ <widget class="QLabel" name="mNumberOfColumnsLabel" >
- <string>Configure interpolation method...</string>
+ <string>Number of columns</string>
</property>
+ <cstring>mNumberOfColumnsSpinBox</cstring>
+ </property>
</widget>
</item>
- <item row="1" column="1" >
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
+ <item row="1" column="1" colspan="2" >
+ <widget class="QSpinBox" name="mNumberOfColumnsSpinBox" >
+ <property name="maximum" >
+ <number>10000000</number>
</property>
- <property name="sizeHint" stdset="0" >
- <size>
- <width>51</width>
- <height>20</height>
- </size>
+ </widget>
+ </item>
+ <item row="2" column="0" >
+ <widget class="QLabel" name="mNumberOfRowsLabel" >
+ <string>Number of rows</string>
</property>
- </spacer>
+ <cstring>mNumberOfRowsSpinBox</cstring>
+ </property>
+ </widget>
</item>
- <item row="2" column="0" colspan="2" >
- <item>
- <widget class="QLabel" name="mNumberOfColumnsLabel" >
- <string>Number of columns:</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QSpinBox" name="mNumberOfColumnsSpinBox" >
- <property name="maximum" >
- <number>10000000</number>
- </property>
- </widget>
- </item>
- </layout>
+ <item row="2" column="1" colspan="2" >
+ <widget class="QSpinBox" name="mNumberOfRowsSpinBox" >
+ </property>
+ </widget>
</item>
- <item row="3" column="0" colspan="2" >
- <item>
- <widget class="QLabel" name="mNumberOfRowsLabel" >
- <string>Number of rows:</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QSpinBox" name="mNumberOfRowsSpinBox" >
- </property>
- </widget>
- </item>
- </layout>
+ <item row="3" column="0" >
+ <widget class="QLabel" name="mOutputFileLabel" >
+ <string>Output file </string>
+ </property>
+ <cstring>mOutputFileLineEdit</cstring>
+ </property>
+ </widget>
</item>
- <item row="4" column="0" colspan="2" >
- <item>
- <widget class="QLabel" name="mOutputFileLabel" >
- <string>Output File: </string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLineEdit" name="mOutputFileLineEdit" />
- </item>
- <item>
- <widget class="QPushButton" name="mOutputFileButton" >
- <string>...</string>
- </property>
- </widget>
- </item>
- </layout>
+ <item row="3" column="1" >
+ <widget class="QLineEdit" name="mOutputFileLineEdit" />
</item>
+ <item row="3" column="2" >
+ <widget class="QToolButton" name="mOutputFileButton" >
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
@@ -181,13 +186,27 @@
</property>
<property name="standardButtons" >
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
</layout>
</widget>
- <resources/>
+ <tabstops>
+ <tabstop>mInputLayerComboBox</tabstop>
+ <tabstop>mUseZCoordCheckBox</tabstop>
+ <tabstop>mInterpolationAttributeComboBox</tabstop>
+ <tabstop>mInterpolationMethodComboBox</tabstop>
+ <tabstop>mConfigureInterpolationButton</tabstop>
+ <tabstop>mNumberOfColumnsSpinBox</tabstop>
+ <tabstop>mNumberOfRowsSpinBox</tabstop>
+ <tabstop>mOutputFileLineEdit</tabstop>
+ <tabstop>mOutputFileButton</tabstop>
+ <tabstop>buttonBox</tabstop>
+ </tabstops>
+ <resources>
+ <include location="interpolator.qrc" />
+ </resources>
<connections>
<connection>
<sender>buttonBox</sender>
@@ -196,8 +215,8 @@
<slot>accept()</slot>
<hints>
<hint type="sourcelabel" >
- <x>248</x>
- <y>254</y>
+ <x>257</x>
+ <y>362</y>
</hint>
<hint type="destinationlabel" >
<x>157</x>
@@ -212,8 +231,8 @@
<slot>reject()</slot>
<hints>
- <x>316</x>
- <y>260</y>
+ <x>325</x>
+ <y>362</y>
</hint>
<x>286</x>
Modified: trunk/qgis/src/plugins/interpolation/qgsinterpolationplugin.cpp
--- trunk/qgis/src/plugins/interpolation/qgsinterpolationplugin.cpp 2008-08-30 09:28:54 UTC (rev 9213)
+++ trunk/qgis/src/plugins/interpolation/qgsinterpolationplugin.cpp 2008-08-30 10:14:29 UTC (rev 9214)
@@ -19,8 +19,6 @@
#include "qgisinterface.h"
#include "qgsinterpolationdialog.h"
-#include "mIconInterpolation.xpm"
static const QString name_ = QObject::tr( "Interpolation plugin" );
static const QString description_ = QObject::tr( "A plugin for interpolation based on vertices of a vector layer" );
static const QString version_ = QObject::tr( "Version 0.001" );
@@ -39,7 +37,7 @@
if ( mIface )
- mInterpolationAction = new QAction( QIcon( mIconInterpolation ), tr( "&Interpolation" ), 0 );
+ mInterpolationAction = new QAction( QIcon( ":/interpolator/interpolation.png"), tr( "&Interpolation" ), 0 );
QObject::connect( mInterpolationAction, SIGNAL( triggered() ), this, SLOT( showInterpolationDialog() ) );
mIface->addToolBarIcon( mInterpolationAction );
mIface->addPluginMenu( tr( "&Interpolation" ), mInterpolationAction );
